microsyl.com > 여러가지 회로들
TODAY542 TOTAL33,804
Login  ▼
포럼동영상강좌
◎유용한링크◎
→ Alldatasheet.com
BASIC4MCU | 여러가지 회로들 | microsyl.com
작성자 키트 작성일2017-08-24 11:11 조회197회 댓글0건
MicroSyl | Microcontroler fan source
MAY
1
Who I am
Author admin    Category General Posting     Tags Sylvain Bissonnette
About me:
I am your host, Sylvain Bissonnette. I am French Canadian (Québécois) and live in Boucherville, QC.
My passion for electronics systems started when I was 8 years. My dad also worked in electronics and he's been my mentor.
What I like the most in electronic is working with MCU and developing embedded and Windows software for my systems.
Currently, I am working for Hydro-Québec (the Electric Company). I am part of a dynamic team working in research and development.
My main duties consist in designing and developing device drivers for various projects.
I love my work and have been doing it for more than 20 years.
My other activities are: Scuba diving, underwater photography, travel, wood working and of course, drinking beer!
Cheers,
Sylvain Bissonnette
APR
1
Please Read Me,
Author admin    Category Lastes News     Tags AVR
Hi Friends
     English is not my native language,  I'm french speaking, so that's why there is a lot of gramatical error in my blog & code.  I will be please to correct those error if you point it to me.
    I also want to clarify, that all I give is on my blog, do not ask me for PCB or any other files or "Please help me" without doing anything before writing to me. I think I am generous please do not exaggerate.
Sylvain Bissonnette
FEB
21
Kitchen Table
Author admin    Category LED     Tags
History
I was looking for a new LED project, by surfin the web I found shift bright led and I idee came to my mind
Shift Brite can be found at macetech
read more
FEB
23
AVR ISP Galvanic Isolation
Author admin    Category All projectsWork Bench Tools     Tags
History
I had done a project where the AVR is powered via the main 110Vac line,  So I had to find a solution to be able to test my code in real life, I had look to many thing and found very cool opto-isolator, "you must check the datasheet IL717"
read more
FEB
18
Super Laser Driver
Author admin    Category All projectsLaser     Tags
History
Yes you will say another Laser Driver, but take time to check all the features of this one,  I had look and I had build a lot of those and each one had some poor result.
read more
NOV
15
Vintage Audio Spectrum Display
Author admin    Category All projectsAudio     Tags
History
After doing some project with vintage tube I got the idea of doing a audio spectrum display with "magic eyes tube". and drive those with a AVR MCU with Fast Fourier Transform
read more
MAY
6
MegaLoad U | Beta tester needed
Author admin    Category All projects     Tags AVR Bootloader
I just finish a new version of MegaLoad,  It's name is MegaLoad U  for Universal.  You will be able to use old and future devices without upgrading MegaLoad U.  It not compatible with the old bootloader files.  You need the bootloader that came with MegaLoad U.  It's a first release so please be cool with me!  So I'm waiting for your beta testing…
No longer support for Megaload
DownLoad
MegaLoad U
BootLoader
APR
30
PCB shop
Author admin    Category Work Bench Tools     Tags boardcircuitPCBPrinted
History
Here is my PCB shop,  If you do just a little bit of electronics you need this. Home made PCB is a kind of an art.  You can archive without any problem track as small as 10 mils without any trace cut or short.  I've used MG Chemical products with great success. One thing to know is that there is a lots of possibility of problem due to many factor.
read more
APR
16
My Lab
History
Here is my lab,  it could give you some idea to build yours, with lots of year and money you can do it !
read more
MAR
31
Bench Power Supply 0-25v @ 0-5amp
Author admin    Category Work Bench Tools     Tags AmpAVRPowerSupplyVolt
History
This project is like the one that all of you must have done in electronics.  I took the idea from Circuit Cellar. The original power supply provides an output of 2.5-15V at 500mA. This circuit will provide 0-25V at 0 to 5A. You will see there is a lot of modification to achieve this.
This is my second version of this power supply, the first one was made with mosfet who need a higher voltage on the gate I had to use a higher input voltage and because of this there was a lot of heat generated for nothing.  This version work with transistor and it's much more better.
read more
MAR
30
RGB Laser Projector
Author admin    Category All projectsLaser     Tags AVRdriverLaserprojectorrgb
History
This project is my second one with laser, I had learn many thing from my first green laser projector. Now I had decide to make a professional laser projector with 3 laser of 3 different color, Red, Green and Blue. And with galvos who have better spec.  I had buy a 30kpps galvo, a 300mw red, 80mw green and 250mw blue.
read more
MAR
30
MegaLoad
Author admin    Category All projectsSoftware     Tags AVRAVR BootloaderBootloaderMegaLoad
History
MegaLoad is a Windows based boot loader for all Atmel ATMega microcontrollers that support the Bootloader function.  MegaLoad is a solution for everybody who wants fast loading (~8k in 3 seconds) and easy software upgrade via MCU RS232 port.
MegaLoad is written in Visual C# and the source code is available for 100$usd that can be pay via paypal at bibi@microsyl.com
read more
MAR
30
Weather Station
History
    This project is one of many others I had made to control my house with rules, web interface, logger and many more. This one is a weather station that reports almost anything about the external environment. I bought mechanical part of the wind sensor at http://www.aag.com.mx/indexaag.html I had to remove all the electronics that came with it and replace them with my own.
read more
MAR
29
AVR Code Debuger
Author admin    Category All projectsWork Bench Tools     Tags AVRDebuggerTerminal
History
    The fact is, 10 years ago this project could have been completed. It will be a useful tool to help you debug code. The challenge was to make a debugger that does not require any MCU resources to be used from the MCU, allowing the debugger to run integrated with the code being debugged.
read more
MAR
29
Water Detector
Author admin    Category All projectsGadjet     Tags Water Detector
History
    This is a very simple one.  That's the only project who don't have any MCU, why??? Because it is connected to a external MCU!,  It is a water detector who serve to close the main water valve of my home if water is detected at certain places.
read more
MAR
29
Very High Gain Microphone
Author admin    Category All projectsGadjet     Tags AGCHigh Gain Microphone
History
This project is my father’s idea, he found in an old army surplus store with a radar dish and mount.  His idea was to make a very high gain microphone to be able to listen to almost anything, like birds or whatever else you want.
read more
MAR
29
Mood Light
Author admin    Category All projectsLED     Tags AVRColorLED 3WMood LightMoodlightRGB LED
History
    This project began when I was surfing the web looking for any cool electronic projects. I found the mood lamp made by Toon Beerten "http://tobe.nimio.info/led_mood_lamp.php". I was really impressed by the 3 watt RGB LED. I bought some of those on ebay and made some tests with an AVR with PWM to control each color intensity. At this point I found those LEDs very interesting and powerful, so then I needed a project.
read more
MAR
29
Mood Lamp
Author admin    Category All projectsGadjetLED     Tags AVRColorLED 3WMood LightMoodlightRGB LED
History
    After I made my Kitchen Mood Light,  I had another idea for 3W RGB LED's.  My idea was to make a simple lamp with 3W RGB LED's, controlled by a MCU, and have an IR remote control to change the color, effects and patterns.
read more
MAR
29
Inductor & Capacitor Meter (LCMeter)
History
    Here is my new inductance & capacitance meter. I had took the analog oscillator part from a well know schematic found on the internet and adapt it for a AVR.  It's impressive to have a very accurate result with a so small circuit.  The way it's work is simple you chance a oscillator frequency with the part you want to find is value.
read more
MAR
28
Scope Clock
Author admin    Category All projectsClock     Tags AVRClockOscilloScopeScopVintage
History
One day my father asked me if I wanted his old Heatkit 10-10 oscilloscope. Quickly I said "No. What can I do with this old AC-only 500khz single trace scope?" A couple of weeks later I was surfing the net and I saw some guy who had made a clock with the CRT like my father's scope. I grabbed the phone to ask him if he still had the scope … and the answer was yes.
read more
MAR
28
Nixie Clock
Author admin    Category All projectsClock     Tags AVRClockNixieNixie ClockVintage
History
After doing the Scope clock project I was feeling in an "antique mood". So I bought some big nixie tubes on eBay from Russia and also I bought the nixie tube driver. It's a 74141 and it can handle 200 volts!
read more
MAR
27
Train Modeling Digital Devices Control (DCC)
Author admin    Category All projectsElectric Train     Tags AVRControlDCCDevicesDigitalTrain Modeling
History
        This is the second part of the DCC project, controlling all accessories via the DCC data on the track.  You can connect: switches, lights and many more…  This board has hardware address setting via jumpers, so you can have many of those
read more
MAR
25
Train Modeling Digital Control (DCC)
History
    This is a common project with my father, building a train modeling. One more time it could be simple, but I had decided to challenge myself once again.  The train modeling had changed with years, now you can have more than one engines on the same track and each one could have a different speed, direction "watch out".  It's done by sending data on the track by reversing the voltage on the track with an exact timing protocol.
read more
MAR
25
Digital Temperature, Humidity, Barometric Pressur Sensor
History
    This project is one of many others I had made to control my house with rules, web interface, logger and many more. This project could take several measurements: Temperature/Humidity/Barometric pressure measurements.  All measurements are taken digitally and have their own dedicated A/D converter in each sensor.  It's a REAL digital environment sensor WITHOUT any calibration.
read more
MAR
24
Network Light Dimmer
Author admin    Category All projectsGadjet     Tags AVRDimmerLigntRemote Light
History
This project is one of many I have undertaken to control my house using a set of rules, a web interface, a logger and many more components. This project is a light dimmer which has multiple control interfaces such an RS485 network, an infrared remote control, a proximity touch slider or touch sensor.
read more
MAR
24
Function Generator
Author admin    Category All projectsWork Bench Tools     Tags AVRDDSFunction Generator
History
This project didn’t look complicated but it was. The MCU part is really simple: just some code for the Display, Keypad and DDS Communication.
A DDS is a chip that is driven by a hi-frequency oscillator. I used a 50 Mhz clock. Inside this IC there is a big divider that goes down to less than 1Hz. The resulting clock is passed to another counter which is connected to a Sine ROM table.  If you need a triangle wave, the counter is directly connected to the output.  For a square wave, the signal which drives the counter is redirected to the primary output.
read more
MAR
24
Digital Room to Room Intercom
Author admin    Category All projectsAudio     Tags AVRIntercom
History
This project was inspired by my girlfriend, who asked me to build an intercom for our house. There are many ways to build an intercom; an example is batteries in series with 2 telephones, a key switch and an amplifier. I felt this was far too simple. I decided to build an intercom with an MCU which digitalizes a voice and then sends it serially and then regenerates the analog signal.
read more
MAR
24
LED Sign with MMC Memory card
Author admin    Category All projectsGadjet     Tags AVRDisplayLEDMemory CardMMCSign
History
At the beginning this project was to buy a led sign to interface with my home automation network. This automation network display information like temperature, wind speed, humidity, etc.  I had bought on EBay a LED Sign but when I received it I got a surprise! There was no serial port to program messages… After a couple of days, I look inside to see how it was built.
read more
MAR
24
Nokia LCD Library
Author admin    Category All projectsLibrary     Tags AVRLCDLibraryNokia
History
I found this LCD make for cellular phone Nokia 3310 by browsing the web at www.jelu.se. There is many interesting things about this LCD: low price, easy to interface via SPI port, can support graphic and text and consume low current.  The only thing that I did is writing code who gives you friendly functions to support this LCD.  The last version of the library only send the bytes who had changed since the last update. It's considerably reduce the refresh time who can be very important in a batteries powered system.
read more
MAR
23
Graphic LCD Library for SED1330
Author admin    Category All projectsLibrary     Tags AVRGraphicLCDLibrarySED1330
History
This LCD is very different from the other standards text 2 x 20. This graphic and text LCD is 320 x 200 pixels. This LCD have differents memories map for the text and graphic region.  If you buy this LCD in a "real" electronic store you will pay like 400$ each but you can find it brand new in a surplus store for 50$!!!.  I used this LCD in a major project to display charts and a lots of information collected around my house: temperature, humidity, wind speed, etc. This LCD is perfect for project that needs  to display a lot of information.
read more
MAR
23
Text LCD Library
Author admin    Category All projectsLibrary     Tags AVRLCD Library
History
What can we say about a standard text LCD? Nothing else then for 90% of your project you usually begin with this LCD. With those friendly functions you will be able to begin your projects without loosing time writing code for the LCD.
read more
MAR
23
OneWire Library
Author admin    Category All projectsLibrary     Tags AVRDallasLibraryMaximOneWire
History
The OneWire protocol which in fact needs two wires (data and ground) is fantastic for many reasons: you can have a very long cable (250 feets), you can have multiples of devices on this cable and with a simple code you can poll those devices to get temperature, voltage, switch position, wind speed, etc.
read more
MAR
23
Door Bell
Author admin    Category All projectsAudio     Tags AudioAVRBellDoorPWM
History
The door bell seems like a simple project but it's not! There is one major difficulty it's to generate a sine wave via Pulse Width Modulation.
read more
MAR
23
Frequancy Meter
Author admin    Category All projectsWork Bench Tools     Tags AVRFrequancyMeter
History
Here is my new Frequency meter who was done with a LCD's cellular phone!!!  This is a simple project. The Frequency is passing  through an op-amp to convert it in a square wave. The ouput of the op-amp is feeding the 3*8 bits counter (24 bits) who can accumulate at a maximum of 16777216 count.
read more
MAR
20
MP3 Player
Author admin    Category All projectsAudio     Tags AVRFAT32IDELibraryMP3USB
History
I decided to do this project for several reasons: first I like music, second I have a huge collection of MP3, and third I wanted to be able to play them anytime in my living room.  I began the project with one major restriction, the printed circuit board of MP3 player MUST be single side in order to do it myself.  After 2 months of drawing, I realized this project was in fact ‘feasible’! One major characteristic of this player was the bi-directional remote control. I had to give several information, folders and songs on a small graphic LCD.
read more
MAR
18
Propeller Clock
Author admin    Category All projectsGadjet     Tags AVRPropeller Clock
History
I got this idea by browsing the web. I found by hazard  Mr. Bob Blick's page who make the first propeller clock.  I began to check how can I build one myself.  Base on AVR AT90S2313 I saw rapidly that my MCU must be clocked very fast to make all the calculations needed to light the leds at the right place.  The speed is at 16Mhz,  4 times faster than Atmel's specifications. It's working without any problems.
read more
MAR
18
Bar Code Reader
Author admin    Category All projectsGadjet     Tags Bar Code ReaderCueCatDecoding
History
This is a low cost bar code reader made from a product which has a very long history. You can see it at this link.  The bar code reader named CueCat is built to be connected in a PS2 keyboard port (standard PC/AT Keyboard). The problem is the information encrypted.
read more
조회수 197
여러가지 회로들 목록
여러가지 회로들 목록
39 터치 LED circuit 이미지 키트 08-24 259
38 Amateur Radio Projects 이미지 키트 08-24 330
열람중 microsyl.com 이미지 키트 08-24 198
36 Circuit lab, diagrams,Free circuits 키트 08-24 184
35 My Electronics Projects - Tripod 키트 08-24 157
34 Electronics Circuits, Electronics Projects list 이미지 키트 08-24 164
33 Students Projects List, GD Topics and More 키트 08-24 36
32 Electronics Project Design References and Tips 키트 08-24 39
31 ELECTRONICS PROJECT IDEAS 이미지 키트 08-24 49
30 Top 25 Electrical Mini Projects 키트 08-24 54
29 Simple electronics projects and circuits 이미지 키트 08-24 41
28 Circuit-Projects 키트 08-24 53
27 Homemade Circuit Projects 이미지 키트 08-24 53
26 Dick Cappels' Project Pages 키트 08-24 48
25 Micro IR remote control boat 이미지 키트 08-24 82
