Architecture and programming of 8051 MCU's - Chapter 6 : Examples > 8051
TODAY513 TOTAL34,475
Login  ▼
포럼 동영상강좌
◎유용한링크◎
→ Alldatasheet.com
BASIC4MCU | 8051 | Architecture and programming of 8051 MCU's - Chapter 6 : Examples
작성자 키트 작성일2017-09-12 11:15 조회171회 댓글0건
Introduction
The purpose of this chapter is to provide basic information about microcontrollers that one needs to know in order to be able to use them successfully in practice. This is why this chapter doesn't contain any super interesting program or device schematic with amazing solutions. Instead, the following examples are better proof that program writing is neither a privilege nor a talent issue, but the ability of simply putting puzzle pieces together using directives. Rest assured that design and development of devices mainly consists of the following method “test-correct-repeat”. Of course, the more you are in it, the more complicated it becomes since the puzzle pieces are put together by both children and first-class architects...
6.1 Basic connecting
Basic connecting - Power Supply
As seen in the figure above, in order to enable the microcontroller to operate properly it is necessary to provide:
  • Power supply:
  • Reset signal: and
  • Clock signal.
Clearly, it is about very simple circuits, but it does not have to be always like that. If the target device is used for controlling expensive machines or maintaining vital functions, everything gets increasingly complicated. However, this solution is sufficient for the time being...
Power supply
Even though this microcontroller can operate at different power supply voltages, why to test “Murphy’s low”?! A 5V DC is most commonly used. The circuit, shown in the figure, uses a cheap integrated three-terminal positive regulator LM7805, and provides high-quality voltage stability and quite enough current to enable the microcontroller and peripheral electronics to operate normally (enough current in this case means 1Amp).
Reset signal
In order that the mucrocontroller can operate properly, a logic 0 (0V) must be applied to the reset pin RS. The push button connecting the reset pin RS to power supply VCC is not necessary. However, it is almost always provided because it enables the microcontroller safe return to normal operating conditions if something goes wrong. 5V is brought to this pin, the microcontroller is reset and program starts execution from the beginning.
Clock signal
Even though the microcontroller has a built-in oscillator, it cannot operate without two external capacitors and quartz crystal which stabilize its operation and determines its frequency (operating speed of the microcontroller).
Clock signal
Of course, it is not always possible to apply this solution so that there are always alternative ones. One of them is to provide clock signal from a special source through invertor. See the figure on the left.
6.2 Additional components
Regardless of the fact that the microcontroller is a product of modern technology, it is of no use without being connected to additional components. Simply put, the appearance of voltage on its pins means nothing if not used for performing certain operations (turn something on/off, shift, display etc.).
Switches and Push buttons
There are no simpler devices than switches and push-buttons. This is the simplest way of detecting appearance of a voltage on the microcontroller input pin.
Switches and Pushbuttons
Nevertheless, it is not so simple in practice... It is about contact bounce- a common problem with m e c h a n i c a l switches. When the contacts strike together, their momentum and elasticity act together to cause bounce. The result is a rapidly pulsed electrical current instead of a clean transition from zero to full current. It mostly occurs due to vibrations, slight rough spots and dirt between contacts. This effect is usually unnoticeable when using these components in everyday life because the bounce happens too quickly. In other words, the whole this process does not last long (a few micro- or miliseconds), but it is long enough to be registered by the microcontroller. When using only a push-button as a pulse counter, errors occur in almost 100% of cases!
RC Debounce
The simplest solution to this problem is to connect a simple RC circuit to suppress quick voltage changes. Since the bounce period is not defined, the values of components are not precisely determined. In most cases, it is recomended to use the values shown in figure below.
If complete stability is needed then radical measures should be taken. The output of the circuit, shown in figure (RS flip-flop), will change its logic state only after detecting the first pulse triggered by contact bounce. This solution is expensive (SPDT switch), but effecient, the problem is definitely solved. Since the capacitor is not used, very short pulses can also be registered in this way.
Filp Flop Debounce
In addition to these hardware solutions, there is also a simple software solution. When a program tests the state of an input pin and detects a change, the check should be done one more time after a certain delay. If the change is confirmed, it means that a switch or push button has changed its position. The advantages of such solution are obvious: it is free of charge, effects of noises are eliminated and it can be applied to the poorer quality contacts as well. Disadvantage is the same as when using RC filter, i.e. pulses shorter than program delay cannot be registered.
Optocoupler
Optocouplers
An optocoupler is a device commonly used to galvanically separate microcontroller’s electronics from any potentially dangerous current or voltage in its surroundings. Optocouplers usually have one, two or four light sources (LED diodes) on their input while on their output, opposite to diodes, there is the same number of elements sensitive to light (phototransistors, photo-thyristors or photo-triacs). The point is that an optocoupler uses a short optical transmission path to transfer a signal between the elements of circuit, while keeping them electrically isolated. This isolation makes sense only if diodes and photo-sensitive elements are separately powered. In this way, the microcontroller and expensive additional electronics are completely protected from high voltage and noises which are the most common cause of destroying, damaging or unstable operation of electronic devices in practice. The most frequently used optocouplers are those with phototransistors on their outputs. When using the optocoupler with internal base-to-pin 6 connection (there are also optocouplers without it), the base can be left unconnected. An optional connection which lessens the effects of noises by eliminating very short pulses is presented by the broken line in the figure.
Relay
Relays
A relays is an electrical switch that opens and closes under control of another electrical circuit. It is therefore connected to ouput pins of the microcontroller and used to turn on/off high-power devices such as motors, transformers, heaters, bulbs, antenna systems etc. These are almost always placed away from the board sensitive components. There are various types of relays but all of them operate in the same way. When a current flows through the coil, the relay is operated by an electromagnet to open or close one or many sets of contacts. Similar to optocouplers, there is no galvanic connection (electrical contact) between input and output circuits. Relays usually demand both higher voltage and current to start operation, but there are also miniature ones which can be activated by a low current directly obtained from a microcontroller pin.
The figure shows the solution specific to the 8051 microcontroller. A darlington transistor is used here to activate relays because of its high current gain. This is not in accordance with “rules”, but is necessary in the event that logic one activation is applied since the output current is then very low (pin acts as an input).
Basic connecting of the microcontroller - Relays
In order to prevent the appearance of self-induction high voltage, caused by a sudden stop of current flow through the coil, an inverted polarized diode is connected in parallel to the coil. The purpose of this diode is to “cut off” the voltage peak.
Light-emitting diode (LED)
Light-emitting diodes are elements for light signalization in electronics. They are manufactured in different shapes, colors and sizes. For their low price, low power consumption and simple use, they have almost completely pushed aside other light sources, bulbs at first place. They perform similar to common diodes with the difference that they emit light when current flows through them.
It is important to limit their current, otherwise they will be permanently destroyed. For this reason, a conductor must be connected in parallel to an LED. In order to determine value of this conductor, it is necessary to know diode’s voltage drop in forward direction, which depends on what material a diode is made from and what colour it is. Typical values of the most frequently used diodes are shown in table below. As seen, there are three main types of LEDs. Standard ones get ful brightness at current of 20mA. Low Current diodes get ful brightness at ten times lower current while Super Bright diodes produce more intensive light than Standard ones.
COLORTYPETYPICAL CURRENT ID (MA)MAXIMAL CURRENT IF (MA)VOLTAGE DROP UD (V)
Infrared-30501.4
RedStandard20301.7
RedSuper Bright20301.85
RedLow Current2301.7
Orange-10302.0
GreenLow Current2202.1
Yellow-20302.1
Blue-20304.5
White-25354.4
Low current LED
Since the 8051 microcontroller can provide only low output current and since its pins are configured as outputs when voltage provided on them is 0V, direct connecting to LEDs is performed as shown in figure on the right (Low current LED, cathode is connected to the output pin).
LED displays
Basically, an LED display is nothing more than several LEDs moulded in the same plastic case. There are many types of displays composed of several dozens of built in diodes which can display different symbols.
LED displays
Most commonly used is a so called 7-segment display. It is composed of 8 LEDs, 7 segments are arranged as a rectangle for symbol displaying and there is an additional segment for decimal point displaying. In order to simplify connecting, anodes and catodes of all diodes are connected to the common pin so that there are common anode displays and common catode displays, respectively. Segments are marked with the latters from A to G, plus dp, as shown in the figure on the left. On connecting, each diode is treated separtely, which means that each must have its own current limiting resistor.
Displays connected to the microcontroller usually occupy a large number of valuable I/O pins, which can be a big problem especially if it is needed to display multy digit numbers. The problem is more than obvious if, for example, it is needed to display two 6-digit numbers (a simple calculation shows that 96 output pins are needed in this case). The solution to this problem is called MULTIPLEXING. This is how an optical illusion based on the same operating principle as a film camera is made. Only one digit is active at a time, but they change their state so quickly making impression that all digits of a number are simultaneously active.
Basic connecting of the microcontroller - LED displays
Here is an explanation on the figure above. First a byte representing units is applied on a microcontroller port and a transistor T1 is activated at the same time. After a while, the transistor T1 is turned off, a byte representing tens is applied on a port and a transistor T2 is activated. This process is being cyclically repeated at high speed for all digits and corresponding transistors.
The fact that the microcontroller is just a kind of miniature computer designed to understand only the language of zeros and ones is fully expressed when displaying any digit. Namely, the microcontroller doesn't know what units, tens or hundreds are, nor what ten digits we are used to look like. Therefore, each number to be displayed must be prepared in the following way:
First of all, a multy digit number must be split into units, tens etc. in a particular subroutine. Then each of these digits must be stored in special bytes. Digits get familiar format by performing “masking”. In other words, a binary format of each digit is replaced by a different combination of bits in a simple subroutine. For example, the digit 8 (0000 1000) is replaced by the binary number 0111 111 in order to activate all LEDs displaying digit 8. The only diode remaining inactive in this case is reserved for the decimal point. If a microcontroller port is connected to the display in such a way that bit 0 activates segment “a”, bit 1 activates segment “b”, bit 2 segment “c” etc., then the table below shows the “mask” for each digit.
Masking LED displays
DIGITS TO DISPLAYDISPLAY SEGMENTS
dpabcdefg
010000001
110011111
210010010
310000110
411001100
510100100
610100000
710001111
810000000
910000100
In addition to digits from 0 to 9, some letters of alphabet - A, C, E, J, F, U, H, L, b, c, d, o, r, t - can also be displayed by performing appropriate masking.
If the event that common chatode displays are used all units in the table should be replaced by zeros and vice versa. Additionally, NPN transistors should be used as drivers as well.
Liquid Crystal Displays (LCD)
An LCD display is specifically manufactured to be used with microcontrollers, which means that it cannot be activated by standard IC circuits. It is used for displaying different messages on a miniature liquid crysal display.
The model described here is for its low price and great capabilities most frequently used in practice. It is based on the HD44780 microcontroller (Hitachi) and can display messages in two lines with 16 characters each. It displays all the letters of alphabet, Greek letters, punctuation marks, mathematical symbols etc. In addition, it is possible to display symbols made up by the user. Other useful features include automatic message shift (left and right), cursor appearance, LED backlight etc.
LCD Pins
There are pins along one side of a small printed board. These are used for connecting to the microcontroller. There are in total of 14 pins marked with numbers (16 if it has backlight). Their function is described in the table bellow:
FUNCTIONPIN NUMBERNAMELOGIC STATEDESCRIPTION
Ground1Vss-0V
Power supply2Vdd-+5V
Contrast3Vee-0 - Vdd
Control of operating4RS0
1
D0 – D7 are interpreted as commands
D0 – D7 are interpreted as data
5R/W0
1
Write data (from controller to LCD)
Read data (from LCD to controller)
6E0
1
From 1 to 0
Access to LCD disabled
Normal operating
Data/commands are transferred to LCD
Data / commands7D00/1Bit 0 LSB
8D10/1Bit 1
9D20/1Bit 2
10D30/1Bit 3
11D40/1Bit 4
12D50/1Bit 5
13D60/1Bit 6
14D70/1Bit 7 MSB
LCD screen
LCD screen pixels
An LCD screen consists of two lines each containing 16 characters. Each character consists of 5x8 or 5x11 dot matrix. This book covers the most commonly used display, i.e. the 5x8 character display.
Display contrast depends on the power supply voltage and whether messages are displayed in one or two lines. For this reason, varying voltage 0-Vdd is applied on the pin marked as Vee. Trimmer potentiometer is usually used for that purpose. Some LCD displays have built-in backlight (blue or green LEDs). When used during operation, a current limiting resistor should be serially connected to one of the pins for backlight power supply (similar to LEDs).
LCD backlight
If there are no characters displayed or if all of them are dimmed when the display is on, the first thing that should be done is to check the potentiometer for contrast regulation. Is it properly adjusted? The same applies if the mode of operation has been changed (writing in one or two lines).
LCD Memory
The LCD display contains three memory blocks:
  • DDRAM Display Data RAM;
  • CGRAM Character Generator RAM; and
  • CGROM Character Generator ROM.
DDRAM Memory
DDRAM memory is used for storing characters to be displayed. The size of this memory is sufficient for storing 80 characters. Some memory locations are directly connected to the characters on display.
DDRAM Memory
It works quite simply: it is sufficient to configure the display so as to increment addresses automatically (shift right) and set the starting address for the message that should be displayed (for example 00 hex).
After that, all characters sent through lines D0-D7 will be displayed in the message format we are used to- from left to right. In this case, displaying starts from the first field of the first line since the address is 00 hex. If more than 16 characters are sent, then all of them will be memorized, but only the first sixteen characters will be visible. In order to display the rest of them, a shift command should be used. Virtually, everything looks as if the LCD display is a “window” which moves left-right over memory locations containing different characters. This is how the effect of message “moving” on the screen is made.
If the cursor is on, it appears at the location which is currently addressed. In other words, when a character appears at the cursor position, it will automatically move to the next addressed location.
Since this is a sort of RAM memory, data can be written to and read from it, but its contents is irretrievably lost when the power goes off.
CGROM Memory
CGROM memory contains the default chracter map with all characters that can be displayed on the screen. Each character is assigned to one memory location.
CGROM Memory
The addresses of CGROM memory locations match the characters of ASCII. If the program being currently executed encounters a command “send character P to port”, then the binary value 0101 0000 appears on the port. This value is the ASCII equivalent to the character P. It is then written to LCD, which results in displaying the symbol from 0101 0000 location of CGROM. In other words, the character “P” is displayed. This applies to all letters of alphabet (capitals and small), but not to numbers.
As seen on the previous “map”, addresses of all digits are pushed forward by 48 relative to their values (digit 0 address is 48, digit 1 address is 49, digit 2 address is 50 etc.). Accordingly, in order to display digits correctly, each of them needs to be added a decimal number 48 prior to be sent to LCD.
From their inception till today, computers can recognize only numbers, but not letters. It means that all data a computer swaps with a peripheral device has a binary format, even though the same is recognized by the man as letters (keyboard is an excellent example). Every character matches the unique combination of zeroes and ones. ASCII is character encoding based on the English alphabet. ASCII code specifies correspondance between standard character symbols and their numerical equivalents.
CGRAM memory
Apart from standard characters, the LCD display can also display symbols defined by the user itself. It can be any symbol in the size of 5x8 pixels. RAM memory called CGRAM in the size of 64 bytes enables it.
Memory registers are 8 bits wide, but only 5 lower bits are used. Logic one (1) in every register represents a dimmed dot, while 8 locations grouped together represent one character. It is best illustrated in figure below:
CGRAM memory
Symbols are usually defined at the beginnig of the program by simply writing zeros and ones to registers of CGRAM memory so that they form desired shapes. In order to display them it is sufficient to specify their address. Pay attention to the first coloumn in the CGROM map of characters. It doesn't contain RAM memory addresses, but symbols being discussed here. In this example, “display 0” means - display “č”, “display 1” means - display “ž” etc.
LCD Basic Commands
All data transferred to LCD through the outputs D0-D7 will be interpreted as a command or a data, which depends on the pin RS logic state:
RS = 1 - Bits D0-D7 are addresses of the characters to be displayed. LCD processor addresses one character from the character map and displays it. The DDRAM address specifies the location on which the character is to be displayed. This address is defined before the character is transferred or the address of previously transferred character is automatically incremented.
RS = 0 - Bits D0 - D7 are commands which determine the display mode. The commands recognized by the LCD are given in the table below:
COMMANDRSRWD7D6D5D4D3D2D1D0EXECUTION TIME
Clear display00000000011.64mS
Cursor home000000001x1.64mS
Entry mode set00000001I/DS40uS
Display on/off control0000001DUB40uS
Cursor/Display Shift000001D/CR/Lxx40uS
Function set00001DLNFxx40uS
Set CGRAM address0001CGRAM address40uS
Set DDRAM address001DDRAM address40uS
Read “BUSY” flag (BF)01BFDDRAM address-
Write to CGRAM or DDRAM10D7D6D5D4D3D2D1D040uS
Read from CGRAM or DDRAM11D7D6D5D4D3D2D1D040uS
I/D 1 = Increment (by 1)         R/L 1 = Shift right    0 = Decrement (by 1)             0 = Shift left    S 1 = Display shift on           DL 1 = 8-bit interface  0 = Display shift off             0 = 4-bit interface  D 1 = Display on                 N 1 = Display in two lines  0 = Display off                  0 = Display in one line  U 1 = Cursor on                  F 1 = Character format 5x10 dots  0 = Cursor off                   0 = Character format 5x7 dotsB 1 = Cursor blink on            D/C 1 = Display shift  0 = Cursor blink off               0 = Cursor shift
What is the Busy flag?
Compared to the microcontroller, the LCD is an extremely slow component. Because of this, it was necessary to provide a signal which will, upon command execution, indicate that the display is ready to receive a new data. That signal, called the busy flag, can be read from line D7. When the BF bit is cleared (BF=0), the display is ready to receive a new data.
LCD Connection
Depending on how many lines are used for connecting the LCD to the microcontroller, there are 8-bit and 4-bit LCD modes. The appropriate mode is selected at the beginning of the operation. This process is called “initialization”. 8-bit LCD mode uses outputs D0-D7 to transfer data in the way explained on the previous page. The main purpose of 4-bit LED mode is to save valuable I/O pins of the microcontroller. Only 4 higher bits (D4-D7) are used for communication, while other may be left unconnected. Each data is sent to the LCD in two steps: four higher bits are sent first (normally through the lines D4-D7), then four lower bits. Initialization enables the LCD to link and interpret received bits correctly. Data is rarely read from the LCD (it is mainly transferred from the microcontroller to LCD) so that it is often possible to save an extra I/O pin by simple connecting R/W pin to ground. Such saving has its price. Messages will be normally displayed, but it will not be possible to read the busy flag since it is not possible to read the display either.
LCD Connection
Fortunately, there is a simple solution. After sending a character or a command it is important to give the LCD enough time to do its job. Owing to the fact that execution of the slowest command lasts for approximately 1.64mS, it will be sufficient to wait approximately 2mS for LCD.
LCD Initialization
The LCD is automatically cleared when powered up. It lasts for approximately 15mS. After that, the display is ready for operation. The mode of operation is set by default. It means that:
  1. Display is cleared
  2. Mode
    • DL = 1 Communication through 8-bit interface
    • N = 0 Messages are displayed in one line
    • F = 0 Character font 5 x 8 dots
  3. Display/Cursor on/off
    • D = 0 Display off
    • U = 0 Cursor off
    • B = 0 Cursor blink off
  4. Character entry
    • ID = 1 Displayed addresses are automatically incremented by 1
    • S = 0 Display shift off
Automatic reset is in most cases performed without any problems. In most cases, but not always! If for any reason the power supply voltage does not reach ful value within 10mS, the display will start to perform completely unpredictably. If the voltage supply unit is not able to meet this condition or if it is needed to provide completely safe operation, the process of initialization is applied. Initialization, among other things, causes a new reset enabling display to operate normally.
Refer to the figure below for the procedure on 8-bit initialization:
It is not a mistake!
In this algorithm, the same value is transferred three times in a row.
In case of 4-bit initialization, the procedure is as follows:
6.3 Examples
The schematic below is used in the several following examples:
LED connection schematic
Apart from components necessary for the operation of the microcontroller such as oscillator with capacitors and the simplest reset circuit, there are also several LEDs and one push button. These are used to indicate the operation of the program.
All LEDs are polarized in such a way that they are activated by driving a microcontroller pin low (logic 0).
LED Blinking
The purpose of this example is not to demonstrate the operation of LEDs, but the operating speed of the microcontroller. Simply put, in order to enable LED blinking to be visible, it is necessary to provide sufficient amount of time to pass between on/off states of LEDs. In this example time delay is provided by executing a subroutine called Delay. It is a triple loop in which the program remains for approximately 0.5 seconds and decrements values stored in registers R0, R1 or R2. After returning from the subroutine, the pin state is inverted and the same procedure is repeated...
;************************************************************************;* PROGRAM NAME : Delay.ASM;* DESCRIPTION: Program turns on/off LED on the pin P1.0;* Software delay is used (Delay).;************************************************************************;BASIC DIRECTIVES$MOD53$TITLE(DELAY.ASM)$PAGEWIDTH(132)$DEBUG$OBJECT$NOPAGING;STACK        DSEG    AT    03FHSTACK_START:    DS    040H;RESET VECTORS       CSEG     AT    0       JMP      XRESET                  ;Reset vector              ORG      100H       XRESET: MOV     SP,#STACK_START         ;Define Stack pointer        MOV     P1,#0FFh                ;All pins are configured as inputsLOOP:        CPL     P1.0                    ;Pin P1.0 state is inverted        LCALL   Delay                   ;Time delay        SJMP    LOOPDelay:        MOV     R2,#20                  ;500 ms time delayF02:    MOV     R1,#50                  ;25 msF01:    MOV     R0,#230        DJNZ    R0,$        DJNZ    R1,F01        DJNZ    R2,F02END                                     ;End of program
Using Watch-dog Timer
This example describes how the watch-dog timer should not operate. The watch-dog timer is properly adjusted (nominal time for counting is 1024mS), but instruction used to reset it is intentionally left out so that this timer always "wins". As a result, the microcontroller is reset (state in registers remains unchanged), program starts execution from the beginning and the number in register R3 is incremented by 1 and then copied to port P1.
LEDs display this number in binary format...
;************************************************************************;* PROGRAM NAME : WatchDog.ASM;* DESCRIPTION : After watch-dog reset, program increments number in;* register R3 and shows it on port P1 in binary format.;************************************************************************;BASIC DIRECTIVES$MOD53$TITLE(WATCHDOG.ASM)$PAGEWIDTH(132)$DEBUG$OBJECT$NOPAGINGWMCON     DATA    96HWDTEN     EQU     00000001B        ; Watch-dog timer is enabledPERIOD    EQU     11000000B        ; Nominal Watch-dog period is set to be 1024ms ;RESET    VECTOR          CSEG    AT      0          JMP     XRESET           ; Reset vector          CSEG          ORG     100HXRESET:   ORL     WMCON,#PERIOD    ; Define Watch-dog period          ORL     WMCON,#WDTEN     ; Watch-dog timer is enabled          MOV     A,R3             ; R3 is moved to port 1          MOV     P1,A          INC     R3               ; Register R3 is incremented by 1LAB:      SJMP    LAB              ; Wait for watch-dog reset          END                      ; End of program
Timer T0 in mode 1
This program spends most of its time in an endless loop waiting for timer T0 to count up a full cycle. When it happens, an interrupt is generated, routine TIM0_ISR is executed and logic zero (0) on port P1 is shifted right by one bit. This is another way of demonstrating the operating speed of the microcontroller since each shift means that counter T0 has counted up 216 pulses!
;************************************************************************;* PROGRAM NAME : Tim0Mod1.ASM;* DESCRIPTION: Program rotates "0" on port 1. Timer T0 in mode 1 is;* used;************************************************************************;BASIC DIRECTIVES$MOD53$TITLE(TIM0MOD1.ASM)$PAGEWIDTH(132)$DEBUG$OBJECT$NOPAGING;DECLARATION OF VARIABLES;STACK        DSEG     AT     03FHSTACK_START:     DS     040H;RESET VECTORS       CSEG      AT 0       JMP       XRESET             ; Reset vector       ORG       00BH       JMP       TIM0_ISR           ; Timer T0 reset vector       ORG       100HXRESET: MOV      SP,#STACK_START    ; Define Stack pointer       MOV       TMOD,#01H          ; MOD1 is selected       MOV       A,#0FFH       MOV       P1,#0FFH       SETB      TR0                ; Timer T0 is enabled       MOV       IE,#082H           ; Interrupt enabled       CLR       CLOOP1: SJMP      LOOP1              ; Remain hereTIM0_ISR:        RRC     A          ; Rotate accumulator A through Carry flag                 MOV     P1,A       ; Contents of accumulator A is moved to PORT1                 RETI               ; Return from interrupt       END                          ; End of program
Timer T0 in Split mode
Similarly to the previous example, the program spends most of its time in a loop called LOOP1. Since 16-bit Timer T0 is split into two 8-bit timers, there are also two interrupt sources.
The first interrupt is generated after timer T0 reset. Routine TIM0_ISR in which logic zero (0) bit on port P1 rotates is executed. Outside looking, it seems that LEDs move.
Another interrupt is generated upon Timer T1 reset. Routine TIM1_ISR in which the bit state DIRECTION inverts is executed. Since this bit determines direction of bit rotation then the moving direction of LED is also changed.
If you press a push button T1 at some point, a logic zero (0) on the P3.2 output will disable Timer T1.
;************************************************************************;* PROGRAM NAME : Split.ASM;* DESCRIPTION: Timer TL0 rotates bit on port P1, while TL1 determines;* the rotation direction. Both timers operate in mode;* 3. Logic zero (0) on output P3.2 disables rotation on port P1.;************************************************************************;BASIC DIRECTIVES$MOD53$TITLE(SPLIT.ASM)$PAGEWIDTH(132)$DEBUG$OBJECT$NOPAGING;DECLARATION OF VARIABLES        BSEG    AT    0;DECLARATION OF BIT-VARIABLESSEMAPHORE:      DBIT    8DIRECTION       BIT     SEMAPHORE;STACK        DSEG    AT    03FHSTACK_START:    DS    040H;RESET VECTORS        CSEG    AT    0        JMP     XRESET                    ; Reset vector        ORG     00BH        JMP     TIM0_ISR                  ; Timer T0 reset vector        ORG     01BH        JMP     TIM1_ISR                  ; Timer T1 reset vector        ORG     100HXRESET: MOV     SP,#STACK_START           ; Define Stack pointer        MOV     TMOD,#00001011B           ; Define MOD3        MOV     A,#0FFH        MOV     P1,#0FFH        MOV     R0,#30D        SETB    TR0                       ; TL0 is turned on        SETB    TR1                       ; TL1 is turned on        MOV     IE,#08AH                  ; Interrupt enabled        CLR     C        CLR     DIRECTION                 ; Rotate to the rightLOOP1:  SJMP    LOOP1                     ; Remain hereTIM0_ISR:        DJNZ    R0,LAB3                   ; Slow down rotation by 256 times        JB      DIRECTION,LAB1        RRC     A                         ; Rotate contents of Accumulator to the right through                                          ; Carry flag        SJMP    LAB2LAB1:   RLC     A                         ; Rotate contents of Accumulator to the left through                                          ; Carry flagLAB2:   MOV     P1,A                      ; Contents of Accumulator is moved to port P1LAB3:   RETI                              ; Return from interruptTIM1_ISR:        DJNZ    R1,LAB4                   ; Slow down direction of rotation by 256 times        DJNZ    R2,LAB4                   ; When time expires, change rotation direction        CPL     SMER        MOV     R2,#30DLAB4:   RETI        END                               ; End of program
Simultaneous use of timers T0 and T1
This program can be considered as continuation of the previous one. They share the same idea, but in this case true timers T0 and T1 are used. In order to demonstrate the operation of both timers on the same port at the same time, timer T0 reset is used to shift logic zero (0) on the port, while Timer T1 reset is used to change rotation direction. This program spends most of its time in the loop LOOP1 waiting for an interrupt to be caused by reset. By checking the DIRECTION bit, information on rotation direction of both bits in accumulator as well as of moving port LED is obtained.
;************************************************************************;* PROGRAM NAME : Tim0Tim1.ASM;* DESCRIPTION: Timer TO rotates bit on port P1 while Timer1;* changes rotation direction. Both timers are configured to operate in mode 1.;************************************************************************;BASIC DIRECTIVES$MOD53$TITLE(TIM0TIM1.ASM)$PAGEWIDTH(132)$DEBUG$OBJECT$NOPAGING;DECLARATION OF VARIABLES       BSEG    AT    0;DECLARATION OF BIT-VARIABLESSEMAPHORE:      DBIT    8DIRECTION       BIT     SEMAPHORE;STACK       DSEG    AT    03FHSTACK_START:   DS    040H;RESET VECTORS       CSEG    AT    0       JMP     XRESET                     ; Reset vector       ORG     00BH                       ; Timer 0 Reset vector       JMP     TIM0_ISR       ORG     01BH                       ; Timer 1 Reset vector       JMP     TIM1_ISR       ORG     100HXRESET: MOV    SP,#STACK_START            ; Define Stack pointer        MOV    TMOD,#11H                  ; Select MOD1 for both timers        MOV    A,#0FFH        MOV    P1,#0FFH        MOV    R0,#30D                    ; R0 is initialized        SETB   TR0                        ; TIMER0 is turned on        SETB   TR1                        ; TIMER1 is turned on        MOV    IE,#08AH                   ; Timer0 and Timer1 Interrupt enabled        CLR    C        CLR    DIRECTION                  ; Rotate to the rightLOOP1:  SJMP   LOOP1                      ; Remain hereTIM0_ISR:        JB     DIRECTION,LAB1        RRC A                             ; Rotate contents of accumulator to the right through                                          ; Carry flag        SJMP   LAB2LAB1:   RLC    A                          ; Rotate contents of Accumulator to the left through                                          ; Carry flagLAB2:   MOV    P1,A                       ; Contents of Accumulator is moved to port P1        RETI                              ; Return from interruptTIM1_ISR:        DJNZ   R0,LAB3                    ; When time expires, change rotation direction        CPL    DIRECTION        MOV    R0,#30D                    ; Initialize R0LAB3:        RETI        END                               ; End of program
Using Timer T2
This example describes the use of Timer T2 configured to operate in Auto-Reload mode. In this very case, LEDs are connected to port P3 while the push button used for forced timer reset (T2EX) is connected to the P1.1 pin.
Program execution is similar to the previous examples. When timer ends counting, an interrupt is enabled and subroutine TIM2_ISR is executed, thus rotating a logic zero (0) in accumulator and moving the contents of accumulator to the P3 pin. At last, flags which caused an interrupt are cleared and program returns to the loop LOOP1 where it remains until a new interrupt request arrives...
If push button T2EX is pressed, timer is temporarily reset. This push button resets timer, while push button RESET resets the microcontroller.
Using Timer T2
;************************************************************************;* PROGRAM NAME : Timer2.ASM;* DESCRIPTION: Program rotates log. "0" on port P3. Timer2 determines;* the speed of rotation and operates in auto-reload mode;************************************************************************;BASIC DIRECTIVES$MOD53$TITLE(TIMER2.ASM)$PAGEWIDTH(132)$DEBUG$OBJECT$NOPAGING;DEFINITION OF VARIABLES        T2MOD    DATA     0C9H;STACK        DSEG     AT       03FHSTACK_START:     DS       040H;RESET VECTORS        CSEG     AT       0        JMP      XRESET                   ; Reset vector        ORG      02BH                     ; Timer T2 Reset vector        JMP      TIM2_ISR        ORG      100HXRESET: MOV      SP,#STACK_START          ; Define Stack pointer        MOV      A,#0FFH        MOV      P3,#0FFH        MOV      RCAP2L,#0FH              ; Prepare 16-bit auto-reload mode        MOV      RCAP2L,#01H        CLR      CAP2                     ; Enable 16-bit auto-reload mod         SETB     EXEN2                    ; Pin P1.1 reset is enabled        SETB     TR2                      ; Enable Timer T2         MOV      IE,#0A0H                 ; Interrupt is enabled        CLR      CLOOP1:  SJMP     LOOP1                    ; Remain hereTIM2_ISR:        RRC      A               ; Rotate contents of Accumulator to the right through                                          ; Carry flag                 MOV      P3,A            ; Move the contents of Accumulator A to PORT3                 CLR      TF2             ; Clear timer T2 flag TF2                  CLR      EXF2            ; Clear timer T2 flag EXF2                  RETI                     ; Return from interrupt                 END                      ; End of program
Using External Interrupt
Here is another example of interrupt execution. An external iterrupt is generated when a logic zero (0) is present on pin P3.2 or P3.3. Depending on which input is active, one of two routines will be executed:
A logic zero (0) on the P3.2 pin initiates execution of interrupt routine Isr_Int0, thus incrementing number in register R0 and copying it to port P0. Logic zero on the P3.3 pin initiates execution of subroutine Isr_Int1, number in register R1 is incremented by 1 and then copied to port P1.
In short, each press on push buttons INT0 and INT1 will be counted and immediately shown in binary format on appropriate port (LED which emitts light represents a logic zero (0)).
;************************************************************************;* PROGRAM NAME : Int.ASM;* DESCRIPTION : Program counts interrupts INT0 generated by appearance of high-to-low;* transition signal on pin P3.2 Result appears on port P0. Interrupts INT1 are also ;* counted up at the same time. They are generated byappearing high-to-low transition;* signal on pin P3. The result appears on port P1.;************************************************************************;BASIC DIRECTIVES$MOD53$TITLE(INT.ASM)$PAGEWIDTH(132)$DEBUG$OBJECT$NOPAGING;RESET VECTORS        CSEG     AT     0        JMP      XRESET               ; Reset vector        ORG      003H                 ; Interrupt routine address for INT0        JMP      Isr_Int0        ORG 013H                      ; Interrupt routine address for INT1        JMP      Isr_Int1        ORG      100HXRESET:        MOV      TCON,#00000101B      ; Interrupt INT0 is generated by appearing                                      ; high-to-low transition signal on pin P3.2                                      ; Interrupt INT0 is generated by appearing                                      ; high-to-low transition signal on pin P3.3        MOV      IE,#10000101B        ; Interrupt enabled        MOV      R0,#00H              ; Counter starting value        MOV      R1,#00H        MOV      P0,#00H              ; Reset port P0        MOV      P1,#00H              ; Reset port P1LOOP:   SJMP     LOOP                 ; Remain hereIsr_Int0:        INC R0                        ; Increment value of interrupt INT0 counter        MOV P0,R0        RETIIsr_Int1:        INC R1                        ; Increment value of interrupt INT1 counter        MOV P1,R1        RETI        END                           ; End of program
Using LED display
The following examples describe the use of LED displays. Common chatode displays are used here, which means that all built-in LEDs are polarized in such a way that their anodes are connected to the microcontroller pins. Since the common way of thinking is that logic one (1) turns something on and logic zero (0) turns something of, Low Current displays (low power consumption) and their diodes (segments) are connected serially to resistors of relatively high resistance.
In order to save I/O pins, four LED displays are connected to operate in multiplex mode. It means that all segments having the same name are connected to one output port each and only one display is active at a time.
Tranzistors and segmenats on displays are quickly activated, thus making impression that all digits are active simultaneously.
Using LED display
Writing digits on LED display
This program is a kind of “warming up” exerciese before real work starts. The purpose of this example is to display something on any display. Multiplex mode is not used this time. Instead, digit 3 is displayed on only one of them (first one on the right).
Since the microcontroller “does not know” how we write number 3, a small subroutine called Disp is used (the microcontroller writes this number as 0000 0011). This subroutine enables all decimal digits (0-9) to be displayed (masked). The principle of operation is simple. A number to be displayed is added to the current address and program jump is executed. Different numbers require different jump length. Precisely determined combination of zeroes and ones appears on each of these new locations (digit 1 mask, digit 2 mask...digit 9 mask). When this combination is transferred to the port, the display shows desired digit.
;************************************************************************;* PROGRAM NAME : 7Seg1.ASM;* DESCRIPTION: Program displays number "3" on 7-segment LED display;************************************************************************;BASIC DIRECTIVES$MOD53$TITLE(7SEG1.ASM)$PAGEWIDTH(132)$DEBUG$OBJECT$NOPAGING;STACK          DSEG     AT     03FHSTACK_START:       DS     040H;RESET VECTORS          CSEG     AT     0          JMP      XRESET               ; Reset vector          ORG      100HXRESET:   MOV      SP,#STACK_START      ; Define Stack pointer          MOV      P1,#0                ; Turn off all segments on displays          MOV      P3,#20h              ; Activate display D4LOOP:          MOV      A,#03                ; Send number “3” to display          LCALL    Disp                 ; Perform appropriate masking for the number          MOV      P1,A          SJMP     LOOPDisp:                                   ; Subroutine for displaying digits          INC      A          MOVC     A,@A+PC          RET          DB       3FH                  ; Digit 0 mask          DB       06H                  ; Digit 1 mask          DB       5BH                  ; Digit 2 mask          DB       4FH                  ; Digit 3 mask          DB       66H                  ; Digit 4 mask          DB       6DH                  ; Digit 5 mask          DB       7DH                  ; Digit 6 mask          DB       07H                  ; Digit 7 mask          DB       7FH                  ; Digit 8 mask          DB       6FH                  ; Digit 9 mask          END                           ; End of program
Writing and changing digits on LED display
This program is only an extended verson of the previous one. There is only one digit active- the first one on the right, and there is no use of multiplexing. Unlike the previous example, all decimal numbers are displayed (0-9). In order to enable digits to change at reasonable pace, a soubroutine L2 which causes a short time delay is executed prior to each change occurs. Basically, the whole process is very simple and takes place in the main loop called LOOP which looks as follows:
  1. R3 is copied to Accumulator and subroutine for masking digits Disp is executed;
  2. Accumulator is copied to the port and displayed;
  3. The contents of the R3 register is incremented;
  4. It is checked whether 10 cycles are counted or not. If it is, register R3 is reset in order to enable counting to start from 0; and
  5. Instruction labeled as L2 within subroutine is executed.
;************************************************************************;* PROGRAM NAME: 7Seg2.ASM;* DESCRIPTION: Program writes numbers 0-9 on 7-segment LED display;************************************************************************;BASIC DIRECTIVES$MOD53$TITLE(7SEG2.ASM)$PAGEWIDTH(132)$DEBUG$OBJECT$NOPAGING;STACK         DSEG     AT     03FHSTACK_START:      DS     040H;RESET VECTORS         CSEG     AT     0         JMP      XRESET                   ; Reset vector         ORG      100HXRESET:  MOV      SP,#STACK_START          ; Define Stack pointer         MOV      R3,#0                    ; Counter initial value         MOV      P1,#0                    ; Turn off all display segments         MOV      P3,#20h                  ; Activate display D4LOOP:         MOV      A,R3         LCALL    Disp                     ; Perform appropriate masking for number in                                           ; Accumulator         MOV      P1,A         INC      R3                       ; Increment number in register by 1         CJNE     R3,#10,L2                ; Check whether the number 10 is in R3         MOV      R3,#0                    ; If it is, reset counterL2:         MOV      R2,#20                   ; 500 mS time delayF02:     MOV      R1,#50                   ; 25 mSF01:     MOV      R0,#230         DJNZ     R0,$         DJNZ     R1,F01         DJNZ     R2,F02         SJMP     LOOPDisp:                                      ; Subroutine for writing digits         INC      A         MOVC     A,@A+PC         RET         DB       3FH                      ; Digit 0 mask         DB       06H                      ; Digit 1 mask         DB       5BH                      ; Digit 2 mask         DB       4FH                      ; Digit 3 mask         DB       66H                      ; Digit 4 mask         DB       6DH                      ; Digit 5 mask         DB       7DH                      ; Digit 6 mask         DB       07H                      ; Digit 7 mask         DB       7FH                      ; Digit 8 mask         DB       6FH                      ; Digit 9 mask         END                               ; End of program
Writing two-digit number on LED display
It is time for time multiplexing! This is the simplest example which displays the number 23 on two displays in such a way that one of them displays units, while the other displays tens. The most important thing in the program is time synchronization. Otherwise, everything is very simple. Transistor T4 enables display D4 and at the same time a bit combination corresponding to the digit 3 is set on the port. After that, transistor T4 is disabled and the whole process is repeated using transistor T3 and display D3 in order to display digit 2. This procedure must be continuosly repeated in order to make impression that both displays are active at the same time.
;************************************************************************;* PROGRAM NAME: 7Seg3.ASM;* DESCRIPTION: Program displays number "23" on 7-segment LED display;************************************************************************;BASIC DIRECTIVES$MOD53$TITLE(7SEG3.ASM)$PAGEWIDTH(132)$DEBUG$OBJECT$NOPAGING;STACK         DSEG      AT      03FHSTACK_START:       DS      040H;RESET VECTORS         CSEG      AT      0         JMP       XRESET                    ; Reset vector         ORG       100HXRESET:  MOV       SP,#STACK_START           ; Define Stack pointerLOOP:    MOV       P1,#0                     ; Turn off all display segments         MOV       P3,#20h                   ; Activate display D4         MOV       A,#03                     ; Write digit 3 on display D4         LCALL     Disp                      ; Find appropriate mask for that digit         MOV       P1,A                      ; Put the mask on the port         MOV       P1,#0                     ; Turn off all dislay segments         MOV       P3,#10h                   ; Activate display D3         MOV       A,#02                     ; Write digit 2 on display D3         LCALL     Disp                      ; Find mask for that digit         MOV       P1,A                      ; Put the mask on the port         SJMP      LOOP                      ; Return to the label LOOPDisp:                                        ; Subroutine for writing digits         INC       A         MOVC      A,@A+PC         RET         DB        3FH                       ; Digit 0 mask         DB        06H                       ; Digit 1 mask         DB        5BH                       ; Digit 2 mask         DB        4FH                       ; Digit 3 mask         DB        66H                       ; Digit 4 mask         DB        6DH                       ; Digit 5 mask         DB        7DH                       ; Digit 6 mask         DB        07H                       ; Digit 7 mask         DB        7FH                       ; Digit 8 mask         DB        6FH                       ; Digit 9 mask         END                                 ; End of program
Using four digit LED display
In this example all four displays, instead of two, are active so that it is possible to write numbers from 0 to 9999. Here, the number 1 234 is displayed. After initialization, the program remains in the loop LOOP where digital multiplexing is performed. The subroutine Disp is used to convert binary numbers into corresponding combinations of bits for the purpose of activating display lighting segments.
;************************************************************************;* PROGRAM NAME : 7Seg5.ASM;* DESCRIPTION : Program displays number"1234" on 7-segment LED display;************************************************************************;BASIC DIRECTIVES$MOD53$TITLE(7SEG5.ASM)$PAGEWIDTH(132)$DEBUG$OBJECT$NOPAGING;STACK         DSEG     AT     03FHSTACK_START:      DS     040H;RESET VECTORS         CSEG     AT     0         JMP      XRESET                  ; Reset vector         ORG      100HXRESET:  MOV      SP,#STACK_START         ; Define Stack pointerLOOP:    MOV      P1,#0                   ; Turn off all display segments          MOV      P3,#20h                 ; Activate display D4         MOV      A,#04                   ; Write digit 4 on display D4         LCALL    Disp                    ; Find mask for that digit         MOV      P1,A                    ; Put the mask on the port         MOV      P1,#0                   ; Turn off all display segments         MOV      P3,#10h                 ; Activate display D3         MOV      A,#03                   ; Write digit 3 on display D3         LCALL    Disp                    ; Find mask for that digit         MOV      P1,A                    ; Put the mask on the port         MOV      P1,#0                   ; Turn off all display segments         MOV      P3,#08h                 ; Activate display D2         MOV      A,#02                   ; Write digit 2 on display D2         LCALL    Disp                    ; Find mask for that digit         MOV      P1,A                    ; Put the mask on the port         MOV      P1,#0                   ; Turn off all display segments         MOV      P3,#04h                 ; Activate display D1         MOV      A,#01                   ; Write digit 1 on display D1         LCALL    Disp                    ; Find mask for that digit         MOV      P1,A                    ; Put the mask on the port         SJMP     LOOP                    ; Return to the lable LOOPDisp:                                     ; Subroutine for writing digits         INC      A         MOVC     A,@A+PC         RET         DB       3FH                     ; Digit 0 mask         DB       06H                     ; Digit 1 mask         DB       5BH                     ; Digit 2 mask         DB       4FH                     ; Digit 3 mask         DB       66H                     ; Digit 4 mask         DB       6DH                     ; Digit 5 mask         DB       7DH                     ; Digit 6 mask         DB       07H                     ; Digit 7 mask         DB       7FH                     ; Digit 8 mask         DB       6FH                     ; Digit 9 mask         END ; End of program
LED display as a two digit counter
Things are getting complicated... In addition to two digit multiplexing, the microcontroller also performs other operations. In this example, contents of registers R2 and R3 are incremented in order to display number counting (97, 98, 99, 00, 01, 02...).
This time, transistors which activate displays remain turned on for 25mS. The soubroutine Delay is in charge of that. Even though digits shift much slower now, it is still not slow enough to make impression of simultaneous operation. After both digits of a number blink for 20 times, the number on displays is incremented by 1 and the whole procedure is repeated.
;************************************************************************;* PROGRAM NAME : 7Seg4.ASM;* DESCRIPTION: Program displays numbers 0-99 on 7-segment LED displays;************************************************************************;BASIC DIRECTIVES$MOD53$TITLE(7SEG4.ASM)$PAGEWIDTH(132)$DEBUG$OBJECT$NOPAGING;STACK         DSEG      AT      03FHSTACK_START:       DS      040H;RESET VECTORS         CSEG      AT      0         JMP       XRESET                   ; Reset vector         ORG       100HXRESET:  MOV       SP,#STACK_START          ; Define Stack pointer         MOV       R2,#0                    ; Counter starting value         MOV       R3,#0         MOV       R4,#0LOOP:    INC       R4                       ;Wait for display to be "refreshed" for 100 times          CJNE      R4,#20d,LAB1             ;before incrementing the counter         MOV       R4,#0         MOV       P1,#0                    ; Turn off all display segments          INC       R2                       ; Increment Register containing units by 1         CJNE      R2,#10d,LAB1         MOV       R2,#0                    ; Reset units         INC       R3                       ; Increment Register with tens by 1         CJNE      R3,#10d,LAB1             ;         MOV       R3,#0                    ; Reset tensLAB1:         MOV       P3,#20h                  ; Activate display D4         MOV       A,R2                     ; Copy Register containing units to A         LCALL     Disp                     ; Call mask for that digit         MOV       P1,A                     ; Write units on display D4         LCALL     Delay                    ; 25ms delay         MOV       P1,#0                    ; Turn off all display segments         MOV       P3,#10h                  ; Activate display D3         MOV       A,R3                     ; Copy Register contaning tens to A         LCALL     Disp                     ; Call mask for that digit         MOV       P1,A                     ; Write tens on display D3         LCALL     Delay                    ; 25ms delay         SJMP      LOOPDelay:         MOV       R1,#50                   ; 5 ms delayF01:     MOV       R0,#250         DJNZ      R0,$         DJNZ      R1,F01         RETDisp:                                       ; Subroutine for displaying digits         INC       A         MOVC      A,@A+PC         RET         DB        3FH                      ; Digit 0 mask         DB        06H                      ; Digit 1 mask         DB        5BH                      ; Digit 2 mask         DB        4FH                      ; Digit 3 mask         DB        66H                      ; Digit 4 mask         DB        6DH                      ; Digit 5 mask         DB        7DH                      ; Digit 6 mask         DB        07H                      ; Digit 7 mask         DB        7FH                      ; Digit 8 mask         DB        6FH                      ; Digit 9 mask         END                                ; End of program
Handling EEPROM
This program writes data to on-chip EEPROM memory. In this case, the data is a hexadecimal number 23 which is to be written to the location with address 00.
To make sure that this number is correctly written, the same location of EEPROM is read 10mS later in order to compare these two numbers. If they match, F will be displayed. Otherwise, E will be displayed on the LED display (Error).
;************************************************************************;* PROGRAM NAME: EEProm1.ASM;* DESCRIPTION: Programming EEPROM at address 0000hex and displaying message;* on LED display.;************************************************************************;BASIC DIRECTIVES$MOD53$TITLE(EEPROM1.ASM)$PAGEWIDTH(132)$DEBUG$OBJECT$NOPAGINGWMCON     DATA     96HEEMEN     EQU      00001000B              ; Access to internal EEPROM is enabledEEMWE     EQU      00010000B              ; Write to EEPROM is enabledTEMP      DATA     030H                   ; Define Auxiliary registerTHE END   EQU      071H                   ; Display "F" ERROR     EQU      033H                   ; Display "E" ;STACK          DSEG     AT     03FHSTACK_START:       DS     040H;RESET VECTORS          CSEG     AT     0          JMP      XRESET                 ; Reset vector          ORG      100HXRESET:   MOV      IE,#00                 ; All interrupts are disabled          MOV      SP,#STACK_START          MOV      DPTR,#0000H            ; Choose location address in EEPROM          ORL      WMCON,#EEMEN           ; Access to EEPROM is enabled          ORL      WMCON,#EEMWE           ; Write to EEPROM is enabled          MOV      TEMP,#23H              ; Number written to EEPROM is moved to          MOV      A,TEMP                 ; register TEMP and Accumulator          MOVX     @DPTR,A                ; Write byte to EEPROM          CALL     DELAY                  ; 10ms delay          MOVX     A,@DPTR                ; Read the same location and compare to TEMP,          CJNE     A,TEMP,ERROR           ; If they don't match, jump to label ERROR          MOV      A,#KRAJ                ; Display F (correct)          MOV      P1,A          XRL      WMCON,#EEMWE           ; Write to EEPROM is disabled          XRL      WMCON,#EEMEN           ; Access to EEPROM is disabledLOOP1:    SJMP     LOOP1                  ; Remain hereERROR:    MOV      A,#ERROR               ; Display E (error)          MOV      P1,ALOOP2:    SJMP     LOOP2DELAY:    MOV      A,#0AH                 ; Delay          MOV      R3,ALOOP3:    NOPLOOP4:    DJNZ     B,LOOP4LOOP5:    DJNZ     B,LOOP5          DJNZ     R3,LOOP3          RET          END                             ; End of program
Data reception via UART
In order to enable successful UART serial communication, it is necessary to meet specific rules of the RS232 standard. It primarily refers to voltage levels required by this standard. Accordingly, -10V stands for logic one (1) in the message, while +10V stands for logic zero (0). The microcontroller converts accurately data into serial format, but its power supply voltage is only 5V. Since it is not easy to convert 0V into 10V and 5V into -10V, this operation is on both transmit and receive side left to a specialized IC circuit. Here, the MAX232 by MAXIM is used because it is widespread, cheap and reliable.
This example shows how to receive message sent by a PC. Timer T1 generates boud rate. Since the 11.0592 MHz quartz crystal is used here, it is easy to obtain standard baud rate which amouts to 9600 bauds. Each received data is immediately transferred to port P1 pins.
Receiving data via serial communication UART
;************************************************************************;* PROGRAM NAME : UartR.ASM;* DESCRIPTION: Each data received from PC via UART appears on the port;* P1.;*;************************************************************************;BASIC DIRECTIVES$MOD53$TITLE(UARTR.ASM)$PAGEWIDTH(132)$DEBUG$OBJECT$NOPAGING;STACK         DSEG     AT     03FHSTACK_START:      DS     040H;RESET VECTORS         CSEG     AT     0         JMP      XRESET                ; Reset vector         ORG      023H                  ; Starting address of UART interrupt routine         JMP      IR_SER         ORG      100HXRESET:  MOV      IE,#00                ; All interrupts are disabled         MOV      SP,#STACK_START       ; Initialization of Stack pointer         MOV      TMOD,#20H             ; Timer1 in mode2         MOV      TH1,#0FDH             ; 9600 baud rate at the frequency of                                        ; 11.0592MHz         MOV      SCON,#50H             ; Receiving enabled, 8-bit UART         MOV      IE,#10010000B         ; UART interrupt enabled         CLR      TI                    ; Clear transmit flag         CLR      RI                    ; Clear receive flag         SETB     TR1                   ; Start Timer1LOOP:    SJMP     LOOP                  ; Remain hereIR_SER:  JNB      RI,OUTPUT             ; If any data is received,                                        ; move it to the port         MOV      A,SBUF                ; P1         MOV      P1,A         CLR      RI                    ; Clear receive flagOUTPUT   RETI         END                            ; End of program
Data transmission via UART
This program describes how to use UART to transmit data. A sequence of numbers (0-255) is transmitted to a PC at 9600 baud rate. The MAX 232 is used as a voltage regulator.
;************************************************************************;* PROGRAM NAME : UartS.ASM;* DESCRIPTION: Sends values 0-255 to PC.;************************************************************************;BASIC DIRECTIVES$MOD53$TITLE(UARTS.ASM)$PAGEWIDTH(132)$DEBUG$OBJECT$NOPAGING;STACK         DSEG    AT    03FHSTACK_START:     DS    040H;RESET VECTORS         CSEG    AT    0         JMP     XRESET               ; Reset vector         ORG     100HXRESET:  MOV     IE,#00               ; All interrupts are disabled         MOV     SP,#STACK_START      ; Initialization of Stack pointer         MOV     TMOD,#20H            ; Timer1 in mode 2         MOV     TH1,#0FDH            ; 9600 baud rate at the frequency of                                      ; 11.0592MHz         MOV     SCON,#40H            ; 8-bit UART         CLR     TI                   ; Clear transmit bit         CLR     RI                   ; Clear receive flag         MOV     R3,#00H              ; Reset caunter         SETB    TR1                  ; Start Timer 1START:   MOV     SBUF,R3              ; Move number from counter to a PCLOOP1:   JNB     TI,LOOP1             ; Wait here until byte transmission is                                      ; complete         CLR     TI                   ; Clear transmit bit         INC     R3                   ; Increment the counter value by 1         CJNE    R3,#00H,START        ; If 255 bytes are not sent return to the                                      ; label STARTLOOP:    SJMP    LOOP                 ; Remain here         END                          ; End of program
Writing message on LCD display
This example uses the most frequently used type of LCD which displays text in two lines with 16 characters each. In order to save I/O ports, only 4 pins are used for communication here. In this way each byte is transmitted in two steps: first higher then lower nible.
LCD needs to be initialized at the beginning of the program. Besides, parts of the program which repeat in the program create special subroutines. All this may seem extremely complicated, but the whole program basically performs several simple operations and displays”Mikroelektronika Razvojni sistemi”.
Write message on LCD display
*************************************************************************;* PROGRAM NAME : Lcd.ASM;* DESCRIPRTION : Program for testing LCD display. 4-bit communication;* is used. Program does not check BUSY flag but uses program delay ;* between 2 commands. PORT1 is used for connection;* to the microcontroller.;************************************************************************;BASIC DIRECTIVES$MOD53$TITLE(LCD.ASM)$PAGEWIDTH(132)$DEBUG$OBJECT$NOPAGING;Stack          DSEG     AT     0E0hStack_Start:       DS     020hStart_address      EQU    0000h                                             ;Reset vectors          CSEG     AT     0          ORG      Start_address          JMP      Inic          ORG      Start_address+100h          MOV      IE,#00                    ; All interrupts are disabled          MOV      SP,#Stack_StartInic:     CALL     LCD_inic                  ; Initialize LCD;*************************************************;* MAIN PROGRAM;*************************************************START:    MOV      A,#80h                    ; Next character will appear on the first          CALL     LCD_status                ; location in the first line of LCD display.          MOV      A,#'M'                    ; Display character ‘M’.          CALL     LCD_putc                  ; Call subroutine for character transmission.          MOV      A,#'i'                    ; Display character ‘i’.          CALL     LCD_putc          MOV      A,#'k'                    ; Display character ‘k’.          CALL     LCD_putc          MOV      A,#'r'                    ; Display character ‘r’.          CALL     LCD_putc          MOV      A,#'o'                    ; Display character ‘o’.          CALL     LCD_putc          MOV      A,#'e'                    ; Display character ‘e’.          CALL     LCD_putc          MOV      A,#'l'                    ; Display character ‘l’.          CALL     LCD_putc          MOV      A,#'e'                    ; Display character ‘e’.          CALL     LCD_putc          MOV      A,#'k'                    ; Display character ‘k’.          CALL     LCD_putc          MOV      A,#'t'                    ; Display character ‘t’.          CALL     LCD_putc          MOV      A,#'r'                    ; Display character ‘r’.          CALL     LCD_putc          MOV      A,#'o'                    ; Display character ‘o’.          CALL     LCD_putc          MOV      A,#'n'                    ; Display character ‘n’.          CALL     LCD_putc          MOV      A,#'i'                    ; Display character ‘i’.          CALL     LCD_putc          MOV      A,#'k'                    ; Display character ‘k’.          CALL     LCD_putc          MOV      A,#'a'                    ; Display character ‘a’.          CALL     LCD_putc          MOV      A,#0c0h                   ; Next character will appear on the first          CALL     LCD_status                ; location in the second line of LCD display.          MOV      A,#'R'                    ; Display character ‘R’.          CALL     LCD_putc                  ; Call subroutine for character transmission.          MOV      A,#'a'                    ; Display character ‘a’.          CALL     LCD_putc          MOV      A,#'z'                    ; Display character ‘z’.          CALL     LCD_putc          MOV      A,#'v'                    ; Display character ‘v’.          CALL     LCD_putc          MOV      A,#'o'                    ; Display character ‘o’.          CALL     LCD_putc          MOV      A,#'j'                    ; Display character ‘j’.          CALL     LCD_putc          MOV      A,#'n'                    ; Display character ‘n’.          CALL     LCD_putc          MOV      A,#'i'                    ; Display character ‘i’.          CALL     LCD_putc          MOV      A,#' '                    ; Display character ‘ ’.          CALL     LCD_putc          MOV      A,#'s'                    ; Display character ‘s’.          CALL     LCD_putc          MOV      A,#'i'                    ; Display character ‘i’.          CALL     LCD_putc          MOV      A,#'s'                    ; Display character ‘s’.          CALL     LCD_putc          MOV      A,#'t'                    ; Display character ‘t’.          CALL     LCD_putc          MOV      A,#'e'                    ; Display character ‘e’.          CALL     LCD_putc          MOV      A,#'m'                    ; Display character ‘m’.          CALL     LCD_putc          MOV      A,#'i'                    ; Display character ‘i’.          CALL     LCD_putc          MOV      R0,#20d                   ; Wait time (20x10ms)          CALL     Delay_10ms                ;          MOV      DPTR,#LCD_DB              ; Clear display          MOV      A,#6d                     ;          CALL     LCD_inic_status           ;          MOV      R0,#10d                   ; Wait time(10x10ms)          CALL     Delay_10ms          JMP      START;*********************************************;* Subroutine for wait time (T= r0 x 10ms);*********************************************Delay_10ms:  MOV   R5,00h                    ; 1+(1+(1+2*r7+2)*r6+2)*r5 approximately             MOV   R6,#100d                  ; (if r7>10)             MOV   R7,#100d                  ; 2*r5*r6*r7             DJNZ  R7,$                      ; $ indicates current instruction.             DJNZ  R6,$-4             DJNZ  R5,$-6             RET;**************************************************************************************;* SUBROUTINE: LCD_inic;* DESCRIPTION: Subroutine for LCD initialization.;*;* (is used with 4-bit interface, under condition that pins DB4-7 on LCD;* are connected to pins PX.4-7 on microcontroller’s ports, i.e. four higher;* bits on the port are used).;*;* NOTE: It is necessary to define port pins for controlling LCD operation:;* LCD_enable, LCD_read_write, LCD_reg_select,similar to port for connection to LCD.;* It is also necessary to define addresses for the first character in each;* line.;**************************************************************************************LCD_enable     BIT    P1.3                   ; Bit for activating pin E on LCD.LCD_read_write BIT    P1.1                   ; Bit for activating pin RW on LCD.LCD_reg_select BIT    P1.2                   ; Bit for activating pin RS on LCD.LCD_port       SET    P1                     ; Port for connection to LCD.Busy           BIT    P1.7                   ; Port pin on which Busy flag appears.LCD_Start_I_red  EQU   00h                   ; Address of the first message character                                             ; in the first line of LCD display.LCD_Start_II_red EQU   40h                   ; Address of the first message character                                             ; in the second line of LCD display.LCD_DB:        DB     00111100b              ; 0 -8b, 2/1 lines, 5x10/5x7 format               DB     00101100b              ; 1 -4b, 2/1 lines, 5x10/5x7 format               DB     00011000b              ; 2 -Display/cursor shift, right/left               DB     00001100b              ; 3 -Display ON, cursor OFF, cursor blink off               DB     00000110b              ; 4 -Increment mode, display shift off               DB     00000010b              ; 5 -Display/cursor home               DB     00000001b              ; 6 -Clear display               DB     00001000b              ; 7 -Display OFF, cursor OFF, cursor blink offLCD_inic:                                    ;*****************************************               MOV    DPTR,#LCD_DB               MOV    A,#00d                 ; Triple initialization in 8-bit               CALL  LCD_inic_status_8       ; mode is performed at the beginning               MOV   A,#00d                  ; (in case of slow increment of               CALL  LCD_inic_status_8       ; power supply when the power supply is on               MOV   A,#00d               lcall LCD_inic_status_8               MOV   A,#1d                   ; Change from 8-bit into               CALL  LCD_inic_status_8       ; 4-bit mode               MOV   A,#1d               CALL  LCD_inic_status               MOV   A,#3d                   ; As from this point the program executes in                                             ;4-bit mode               CALL  LCD_inic_status               MOV   A,#6d               CALL  LCD_inic_status               MOV   A,#4d               CALL  LCD_inic_status               RETLCD_inic_status_8:                                             ;******************************************               PUSH  B               MOVC  A,@A+DPTR               CLR   LCD_reg_select          ; RS=0 - Write command               CLR   LCD_read_write          ; R/W=0 - Write data on LCD               MOV   B,LCD_port              ; Lower 4 bits from LCD port are memorized               ORL   B,#11110000b               ORL   A,#00001111b               ANL   A,B               MOV   LCD_port,A              ; Data is moved from A to LCD port               SETB  LCD_enable              ; high-to-low transition signal                                             ; is generated on the LCD's EN pin               CLR   LCD_enable                              MOV   B,#255d                 ; Time delay in case of improper reset               DJNZ  B,$                     ; during initialization               DJNZ B,$               DJNZ B,$               POP B               RETLCD_inic_status:;****************************************************************************               MOVC  A,@A+DPTR               CALL  LCD_status               RET;****************************************************************************;* SUBROUTINE: LCD_status;* DESCRIPTION: Subroutine for defining LCD status.;****************************************************************************LCD_status:    PUSH  B               MOV   B,#255d               DJNZ  B,$               DJNZ  B,$               DJNZ  B,$               CLR   LCD_reg_select          ; RS=O: Command is sent to LCD               CALL  LCD_port_out               SWAP  A                       ; Nibles are swapped in accumulator               DJNZ  B,$               DJNZ  B,$               DJNZ  B,$               CLR   LCD_reg_select          ; RS=0: Command is sent to LCD               CALL  LCD_port_out               POP   B               RET;****************************************************************************;* SUBROUTINE: LCD_putc;* DESCRIPTION: Sending character to be displayed on LCD.;****************************************************************************LCD_putc:      PUSH  B               MOV   B,#255d               DJNZ  B,$               SETB  LCD_reg_select          ; RS=1: Character is sent to LCD               CALL  LCD_port_out               SWAP  A                       ; Nibles are swapped in accumulator               DJNZ  B,$               SETB  LCD_reg_select          ; RS=1: Character is sent to LCD               CALL  LCD_port_out               POP   B               RET;****************************************************************************;* SUBROUTINE: LCD_port_out;* DESCRIPTION: Sending commands or characters on LCD display;****************************************************************************LCD_port_out:  PUSH  ACC               PUSH  B               MOV   B,LCD_port              ; Lower 4 bits of LCD port are memorized               ORL   B,#11110000b               ORL   A,#00001111b               ANL   A,B               MOV   LCD_port,A              ; Data is copied from A to LCD port               SETB  LCD_enable              ; high-to-low transition signal                                             ; is generated on the LCD's EN pin               CLR   LCD_enable                              POP   B               POP   ACC               RET               END                           ; End of program
Binary to decimal number conversion
When using LED and LCD displays, it is often necessary to convert numbers from binary to decimal. For example, if some register contains a number in binary format that should be displayed on a three digit LED display it is first necessary to convert it to decimal format. In other words, it is necessary to define what should be displayed on the most right display (units), middle display (tens) and most left display (hundreds).
The subroutine below performs conversion of one byte. Binary number is stored in the accumulator, while digits of that number in decimal format are stored in registers R3, R2 and accumulator (units, tens and hundreds, respectively).
;************************************************************************;* SUBROUTINE NAME : BinDec.ASM;* DESCRIPTION : Content of accumulator is converted into three decimal digits;************************************************************************BINDEC:            MOV     B,#10d         ; Store decimal number 10 in B                   DIV     AB             ; A:B. Remainder remains in B                   MOV     R3,B           ; Move units to register R3                   MOV     B,#10d         ; Store decimal number 10 in B                   DIV     AB             ; A:B. Remainder remains in B                   MOV     R2,B           ; Move tens to register R2                   MOV     B,#10d         ; Store decimal number 10 in B                   DIV     AB             ; A:B. Remainder remains in B                   MOV     A,B            ; Move hundreds to accumulator                   RET                    ; Return to the main program
조회수 171
8051 목록
