★=8051_IDE=★ > C51 Development Tools
서비스 종료 안내
안녕하세요, Basic4MCU입니다.
2025년 11월 30일을 끝으로 서비스 운영이 종료될 예정입니다.
오랜 시간 저희 Basic4MCU를 이용해주신 모든 분들께 감사드립니다.
서비스 종료 이후에는 더이상 접근이 불가하오니
필요하신 데이터는 11월 30일 이전에 반드시 백업해주시기 바랍니다.
이용에 불편을 드리게 되어 죄송합니다.
Basic4MCU 드림
TODAY30,152 TOTAL15,662,762
BASIC4MCU | ★=8051_IDE=★ | 8051_Keil | C51 Development Tools
작성자 master 작성일2018-02-19 16:32 조회3,345회 댓글0건
Home  /  C51 Development Tools
Product Overview
Keil Cx51 Product BrochureKeilKeil development tools for the 8051 Microcontroller Architecture support every level of software developer from the professional applications engineer to the student just learning about embedded software development.
The industry-standard Keil C Compilers, Macro Assemblers, Debuggers, Real-time Kernels, Single-board Computers, and Emulators support all 8051 derivatives and help you get your projects completed on schedule.
The Keil 8051 Development Tools are designed to solve the complex problems facing embedded software developers.
  • When starting a new project, simply select the microcontroller you use from the Device Database and the µVision IDE sets all compiler, assembler, linker, and memory options for you.
  • Numerous example programs are included to help you get started with the most popular embedded 8051 devices.
  • The Keil µVision Debugger accurately simulates on-chip peripherals (I²C, CAN, UART, SPI, Interrupts, I/O Ports, A/D Converter, D/A Converter, and PWM Modules) of your 8051 device. Simulation helps you understand hardware configurations and avoids time wasted on setup problems. Additionally, with simulation, you can write and test applications before target hardware is available.
  • When you are ready to begin testing your software application with target hardware, use the MON51, MON390, MONADI, or FlashMON51 Target Monitors, the ISD51 In-System Debugger, or the ULINK USB-JTAG Adapter to download and test program code on your target system.
Overview
Keil downloads include software products and updates, example programs and various utilities you may use to learn about or extend the capabilities of your Keil development tools.
C51
Development tools for Classic and Extended 8051 Microcontrollers
Version 9.57
Complete the following form to download the Keil software development tools.
C51
Classic 및 Extended 8051 마이크로 컨트롤러 용 개발 도구
버전 9.57
다음 양식을 작성하여 Keil 소프트웨어 개발 도구를 다운로드하십시오.
프로그램은 여기서 다운로드 받으면 됩니다.
예전에는 작성하는 것 없이 평가버전을 다운로드 할 수 있었는데
뭘 작성하라고 귀찮게 하는 것이...더 못되어 진 것 같습니다.
이 회사 제품은 8051 유저들에게 호응이 좋았는데 정품은 얼마 전에 본 금액으로도 2백만원대로 고가였습니다.
수십년 된 8비트 컴파일러를 너무 비싸게 금액을 책정해서 판매 정책이 마음에 들지 않았는데요
그깟 평가버전 주면서 연락처까지 작성하게 하는 행위를 하는군요
C51 Evaluation Tools
  • The 8051 compiler, assembler, linker, and debugger are limited to 2 Kbytes of object code. Source code may be of any size.
  • Programs that generate more than 2 Kbytes of object code will not compile, assemble, or link.
  • The debugger supports programs that are 2 Kbytes or smaller.
  • The startup code generated includes LJMPs. Code generated cannot be used in single-chip devices that support 2 Kbytes or less of program space.
  • Programs start at offset 0x0800. Programs generated with the evaluation software may not be programmed into single-chip devices with less than 2 Kbytes of on-chip ROM.
  • No hardware support for multiple DPTR registers is provided.
  • No support for floating-point arithmetic and no support for user libraries is provided.
  • No support for in-line assembly using #pragma ASM.
  • The following components which are present in the PK51 Full Version are not included in the Evaluation Version: Linker for Code Banking and RTX51 Tiny Real-time Operating System.
C51 평가 도구
  • 8051 컴파일러, 어셈블러, 링커 및 디버거는 2KB의 개체 코드로 제한됩니다. 소스 코드의 크기는 제한되지 않습니다.
  • 2KB를 초과하는 목적 코드를 생성하는 프로그램은 컴파일, 어셈블 또는 링크되지 않습니다.
  • 디버거는 2KB 이하의 프로그램을 지원합니다.
  • 생성 된 시작 코드에는 LJMP가 포함됩니다. 생성 된 코드는 2KB 이하의 프로그램 공간을 지원하는 단일 칩 장치에서는 사용할 수 없습니다.
  • 오프셋 0x0800에서 프로그램이 시작됩니다. 평가 소프트웨어로 생성 된 프로그램은 2KB 미만의 온칩 ROM이있는 단일 칩 장치에 프로그래밍 할 수 없습니다.
  • 여러 개의 DPTR 레지스터에 대한 하드웨어 지원이 제공되지 않습니다.
  • 부동 소수점 산술을 지원하지 않으며 사용자 라이브러리를 지원하지 않습니다.
  • #pragma ASM을 사용하여 인라인 어셈블리를 지원하지 않습니다.
  • PK51 정식 버전에 포함 된 다음 구성 요소는 평가판 버전 : 코드 뱅킹 링커 및 RTX51 초소형 실시간 운영 체제에 포함되어 있지 않습니다.
Hex 코드 2KB로 제한 한다는 내용입니다.
그 외에도 지원하지 않는다는 내용이 더 있으니 읽어보세요
조회수 3,345
★=8051_IDE=★HOME > ★=8051_IDE=★ > 전체 목록
