질문게시판 > rfid 질문 드립니다.
TODAY420 TOTAL1,079,049
BASIC4MCU | 질문게시판 | rfid 질문 드립니다.
작성자 호기심왕 작성일2019-10-04 15:53 조회642회 댓글3건
안녕하세요 rfid   rc522 사용중입니다
사진처럼 rc522 2개를 빵판에 바로 꼽은 뒤 나머지 선을 사용하여 연결하였습니다.
rfid의 기본 멀티 예제를 사용하여 실험을 해보았는데
두개를 한번에 꼽고 사용을하면 둘다 인식을 못하는데
rc522 모듈을 하나씩만 연결할때는 정상 작동이 됩니다.
어떠점이 잘못됬는지 모르겠어서 질문드립니다.
읽어주셔서 감사합니다!
 * Example sketch/program showing how to read data from more than one PICC to serial.
 * This is a MFRC522 library example; for further details and other examples see: https://github.com/miguelbalboa/rfid
 * Example sketch/program showing how to read data from more than one PICC (that is: a RFID Tag or Card) using a
 * MFRC522 based RFID Reader on the Arduino SPI interface.
 * Warning: This may not work! Multiple devices at one SPI are difficult and cause many trouble!! Engineering skill
 *          and knowledge are required!
 * @license Released into the public domain.
 * Typical pin layout used:
 *             MFRC522      Arduino       Arduino   Arduino    Arduino          Arduino
 *             Reader/PCD   Uno/101       Mega      Nano v3    Leonardo/Micro   Pro Micro
 * Signal      Pin          Pin           Pin       Pin        Pin              Pin
 * RST/Reset   RST          9             5         D9         RESET/ICSP-5     RST
 * SPI SS 1    SDA(SS)      ** custom, take a unused pin, only HIGH/LOW required **
 * SPI SS 2    SDA(SS)      ** custom, take a unused pin, only HIGH/LOW required **
 * SPI MOSI    MOSI         11 / ICSP-4   51        D11        ICSP-4           16
 * SPI MISO    MISO         12 / ICSP-1   50        D12        ICSP-1           14
 * SPI SCK     SCK          13 / ICSP-3   52        D13        ICSP-3           15
#include
#include
constexpr uint8_t RST_PIN = 7;     // Configurable, see typical pin layout above
constexpr uint8_t SS_1_PIN = 10;   // Configurable, take a unused pin, only HIGH/LOW required, must be diffrent to SS 2
constexpr uint8_t SS_2_PIN = 9;    // Configurable, take a unused pin, only HIGH/LOW required, must be diffrent to SS 1
constexpr uint8_t NR_OF_READERS = 2;
byte ssPins[] = {SS_1_PIN, SS_2_PIN};
MFRC522 mfrc522[NR_OF_READERS];   // Create MFRC522 instance.
 * Initialize.
  Serial.begin(9600); // Initialize serial communications with the PC
  while (!Serial);    // Do nothing if no serial port is opened (added for Arduinos based on ATMEGA32U4)
  SPI.begin();        // Init SPI bus
  for (uint8_t reader = 0; reader < NR_OF_READERS; reader++) {
    mfrc522[reader].PCD_Init(ssPins[reader], RST_PIN); // Init each MFRC522 card
    Serial.print(F("Reader "));
    Serial.print(reader);
    Serial.print(F(": "));
    mfrc522[reader].PCD_DumpVersionToSerial();
 * Main loop.
    // Look for new cards
    if (mfrc522[reader].PICC_IsNewCardPresent() && mfrc522[reader].PICC_ReadCardSerial()) {
      // Show some details of the PICC (that is: the tag/card)
      Serial.print(F(": Card UID:"));
      dump_byte_array(mfrc522[reader].uid.uidByte, mfrc522[reader].uid.size);
      Serial.println();
      Serial.print(F("PICC type: "));
      MFRC522::PICC_Type piccType = mfrc522[reader].PICC_GetType(mfrc522[reader].uid.sak);
      Serial.println(mfrc522[reader].PICC_GetTypeName(piccType));
      // Halt PICC
      mfrc522[reader].PICC_HaltA();
      // Stop encryption on PCD
      mfrc522[reader].PCD_StopCrypto1();
    } //if (mfrc522[reader].PICC_IsNewC
  } //for(uint8_t reader
 * Helper routine to dump a byte array as hex values to Serial.
void dump_byte_array(byte *buffer, byte bufferSize) {
  for (byte i = 0; i < bufferSize; i++) {
    Serial.print(buffer[i] < 0x10 ? " 0" : " ");
    Serial.print(buffer[i], HEX);
댓글 3
조회수 642
두 개의 모듈을 연결해서 동작시킬 수 있는 예제를 찾아보세요
현재 올린 예제가 멀티 가능한 예제라면 체크할 수 있도록 사이트 링크를 적어보세요
호기심왕님의 댓글
호기심왕 댓글의 댓글 작성일
라이브러리에 mfr 검색해서 설치후 예제 파일 사용했습니다!
https://www.google.com/search?pws=0&gl=us&ei=FA6YXa6WDY-_wAOajZfwCg&q=%EC%95%84%EB%91%90%EC%9D%B4%EB%85%B8+multi+rc522+%EB%9D%BC%EC%9D%B4%EB%B8%8C%EB%9F%AC%EB%A6%AC&oq=%EC%95%84%EB%91%90%EC%9D%B4%EB%85%B8+multi+RC522+%EB%9D%BC%EC%9D%B4%EB%B8%8C&gs_l=psy-ab.3.0.33i160.4807.12019..13357...11.0..1.144.1949.0j16......0....1..gws-wiz.FifPlFWwQG8
멀티로 구성이 가능한 라이브러리가 아니라면 초보자들은 사용하지 못합니다.
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 1681
공지 사이트 이용 안내댓글[11] master 17-10-29 11168
공지 [무료 공개] 소스코드 하이라이트 v2.0 beta [2013.02.07]댓글[1] 이미지첨부파일 master 18-01-23 4203
질문 Atmega128P BLDC 모터관련 질문좀할게요(3)댓글[1] 새글 차니 20-05-30 16
답변 답변글 답변 : Atmega128P BLDC 모터관련 질문좀할게요(3) 새글 master 20-05-30 15
질문 (질문)atmega128을 이용한 LED제어댓글[2] 새글 발양말 20-05-29 36
질문 아두이노와 자동차 연결댓글[1] 새글 수닝 20-05-29 20
질문 micros() 함수 질문입니다.댓글[1] 아누이도 20-05-29 20
질문 avr 미세먼지센서에 관련하여 질문 있습니다!!댓글[1] jhjh 20-05-28 19
질문 아두이노 질문입니다!댓글[1] 아누이도 20-05-28 21
질문 아두캠 사진촬영댓글[1] 던질까 20-05-28 28
질문 atmega 128 을 이용한 UART 통신 질문 있습니다! 이미지첨부파일 옥수수깡 20-05-28 22
답변 답변글 답변 : atmega 128 을 이용한 UART 통신 질문 있습니다! master 20-05-28 27
질문 아두이노 실행 반복/중단 문제입니다댓글[1] KSJ126 20-05-28 18
질문 아두이노 수정 부탁드려요댓글[1] 알둘이놀 20-05-28 21
질문 안녕하세요.. 아두이노 완전초짜질문있습니다.댓글[2] 이미지 g대학 20-05-28 26
질문 아두이노 관련 질문입니다.댓글[1] 이미지 아누이도 20-05-28 22
질문 초음파 2개 제어해서 거리에 따른 LED 불 켜기댓글[1] 전과자14학번 20-05-28 29
질문 esp32 microptyhon으로 가변저항기와 서보모터 하잇 20-05-28 17
답변 답변글 답변 : esp32 microptyhon으로 가변저항기와 서보모터댓글[1] master 20-05-28 17
질문 코드비전 코드좀 봐주세요댓글[1] 하미레스 20-05-28 39
답변 답변글 답변 : 코드비전 코드좀 봐주세요댓글[2] master 20-05-28 32
질문 atmega128과 앱인벤터, 블루투스를 이용한 데이터 수신댓글[1] jiseok 20-05-27 36
질문 동작감시센서 전구에 대한 질문 입니다댓글[2] 골름 20-05-27 25
질문 아두이노 dc모터와 서보모터 동시 제어 관련댓글[2] 첨부파일 김민우요 20-05-27 51
질문 워터펌프 블루투스 제어에서 ⸮ 가 시리얼모니터에 무한으로 출력됩니다..댓글[5] 이미지첨부파일 요승 20-05-27 66
질문 초음파 2개 제어해서 LED 점등 질문댓글[3] 전과자14학번 20-05-27 56
질문 8051 어셈블리어 질문 좀 드리겠습니다.댓글[1] 이미지첨부파일 XGXG 20-05-27 36
질문 회로도 질문입니다댓글[3] 이미지첨부파일 포도좋아 20-05-27 41
질문 AVR 재 질문댓글[1] 전과자14학번 20-05-27 21
