질문게시판 > 네오픽셀 조도센서 블루투스
TODAY590 TOTAL1,181,013
BASIC4MCU | 질문게시판 | 네오픽셀 조도센서 블루투스
작성자 픽의종점 작성일2019-10-09 16:01 조회557회 댓글0건
	몇가지 오픈소스 조합해서 만든파일인데 갑자기 컴파일이안됩니다
#ifdef __AVR__
 #include <avr/power.h>
#endif
SoftwareSerial bluetooth(2, 3);
#define LED_PIN    6
#define LED_COUNT 24
Adafruit_NeoPixel strip(LED_COUNT, LED_PIN, NEO_GRB + NEO_KHZ800);
#if defined(__AVR_ATtiny85__) && (F_CPU == 16000000)
  clock_prescale_set(clock_div_1);
#endif
  strip.begin();
  strip.show();
  strip.setBrightness(10);
  bluetooth.begin(9600);
  int a,b,c,d;
  b=analogRead(A0);
  d=map(b,0,1024,0,255);
  Serial.println(d);
  strip.setBrightness(d);
  a=bluetooth.read();
  if(a!=-1){
    c=a;
  if(c==0){
    rainbow(1);
  }else if(c==1){
    colorWipe(strip.Color(0,0,0), 1);
void colorWipe(uint32_t color, int wait) {
  for(int i=0; i<strip.numPixels(); i++) {
    strip.setPixelColor(i, color);
    strip.show();
    delay(wait);
void rainbow(int wait) {
  for(long firstPixelHue = 0; firstPixelHue < 65536; firstPixelHue += 256) {
    for(int i=0; i<strip.numPixels(); i++) { /
      int pixelHue = firstPixelHue + (i * 65536L / strip.numPixels());
      strip.setPixelColor(i, strip.gamma32(strip.ColorHSV(pixelHue)));
    strip.show();
    delay(wait);
#ifdef __AVR__
#endif
#define PIN 6
#define NUM_LEDS 22
Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUM_LEDS, PIN, NEO_GRB + NEO_KHZ800);
// the original levels for the leds (mix of yellow and red) that we define in setup()
unsigned int r[NUM_LEDS];
unsigned int g[NUM_LEDS];
unsigned int b[NUM_LEDS];
// the new levels we randomized
unsigned int rx[NUM_LEDS];
unsigned int gx[NUM_LEDS];
unsigned int bx[NUM_LEDS];
// the levels to approach the new levels by tweaning (these we use to set the neopixels)
double rz[NUM_LEDS];
double gz[NUM_LEDS];
double bz[NUM_LEDS];
// the diff to the new levels to twean to them in 10 steps
double dr[NUM_LEDS];
double dg[NUM_LEDS];
double db[NUM_LEDS];
int ASD,SDF,DFG,FGH;
int count = 0;
#endif
  strip.begin();
  strip.show(); // Initialize all pixels to 'off'
  // set the original candle led levels; 3 groups of colors
  for (int i=0; i<NUM_LEDS; i++) {
    if (i%3==0) {
      r[i] = 70;
      g[i] = 0;
      b[i] = 0;
    if (i%3==1) {
      r[i] = 60;
      g[i] = 30;
      b[i] = 0;
    if (i%3==2) {
      r[i] = 100;
      g[i] = 70;
      b[i] = 0;
  ASD=analogRead(A0);
  if((ASD>=300)&&(ASD<=600)){
  SDF=map(ASD,300,600,0,200);
  DFG=bluetooth.read();
  if(DFG>=0){
    FGH=DFG;
  Serial.println(SDF);
  if(FGH == 0){
    strip.setBrightness(0);
  }else if(FGH == 1){
    strip.setBrightness(SDF);
  }else if(FGH == 2){
  }else if(FGH == 3){
    strip.setBrightness(100);
  }else if(FGH == 4){
    strip.setBrightness(250);
    rz[i] += dr[i];
    gz[i] += dg[i];
    bz[i] += db[i];
    // to guard from overflow or accidental unwanted flickering
    if (rz[i]<0) rz[i] = 0;
    if (rz[i]>255) rz[i] = 255;
    if (gz[i]<0) gz[i] = 0;
    if (gz[i]>255) gz[i] = 255;
    if (bz[i]<0) bz[i] = 0;
    if (bz[i]>255) bz[i] = 255;
  count++;
  if (count>9) {  // we set new levels now after 10 iterations
    count = 0;
    // set new levels based on a factor, and this in those 3 'groups' of leds
    for (int j=0; j<3; j++) {
      float z = 10.0/random(4, 11);  // min is inclusive, max is exclusive (giving range from 0.4 to 1.0)
      for (int i=0; i<4; i++) {
        int idx = j*4+i;
        rx[idx] = (int) (r[idx] * z);
        gx[idx] = (int) (g[idx] * z);
        bx[idx] = (int) (b[idx] * z);
    // calculate the diff values (1/10th step)
      dr[i] = (rx[i] - rz[i])/10;
      dg[i] = (gx[i] - gz[i])/10;
      db[i] = (bx[i] - bz[i])/10;
  // update the leds
    strip.setPixelColor(i, strip.Color((int)rz[i], (int)gz[i], (int)bz[i], 255) );
  strip.show();
  delay(10);    // run our loop at approx 100Hz; so new LED levels reach every ~100 ms (~10Hz)
#ifdef __AVR__
 #include <avr/power.h> // Required for 16 MHz Adafruit Trinket
#endif
int count = 0;
#define LED_PIN    6
#define LED_COUNT 120
  strip.begin();          // INITIALIZE NeoPixel strip object (REQUIRED)
  strip.show();            // Turn OFF all pixels ASAP
  strip.setBrightness(255); // Set BRIGHTNESS to about 1/5 (max = 255)
    for(int i=0; i<strip.numPixels(); i++) { // For each pixel in strip...
    strip.setPixelColor(i, strip.Color(255,  255,  0));        //  Set pixel's color (in RAM)
    strip.show();                          //  Update strip to match
    delay(40);
    ASD=analogRead(A0);
  if(DFG>=0){
    FGH=DFG;
    if(FGH == 0){
  }else if(FGH == 1){
  }else if(FGH == 2){
  }else if(FGH == 3){
  }else if(FGH == 4){
    strip.setPixelColor(i, strip.Color(0,  255,  255));        //  Set pixel's color (in RAM)
    delay(40);
    ASD=analogRead(A0);
  if(DFG>=0){
    FGH=DFG;
    if(FGH == 0){
  }else if(FGH == 1){
  }else if(FGH == 2){
  }else if(FGH == 3){
  }else if(FGH == 4){
    strip.setPixelColor(i, strip.Color(255,  0,  255));        //  Set pixel's color (in RAM)
    delay(40);
    ASD=analogRead(A0);
  if(DFG>=0){
    FGH=DFG;
if(FGH == 0){
  }else if(FGH == 1){
  }else if(FGH == 2){
  }else if(FGH == 3){
  }else if(FGH == 4){
조회수 557
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 1968
공지 사이트 이용 안내댓글[12] master 17-10-29 12095
공지 [무료 공개] 소스코드 하이라이트 v2.0 beta [2013.02.07]댓글[1] 이미지첨부파일 master 18-01-23 4574
질문 아두이노 안드로이드 통신질문드립니다.댓글[2] 새글 dongeun9 20-08-06 12
질문 4-digit 7-Segment display 질문입니다!댓글[1] 새글 mirght 20-08-05 22
질문 아두이노 스텝모터 푸쉬버튼 질문드립니다.댓글[1] 새글 랩돌이 20-08-05 24
질문 메가로 진행중인데 질문드려요,,댓글[1] dongeun9 20-07-31 55
질문 아두이노 우노 -> 메가댓글[2] dongeun9 20-07-30 71
질문 아두이노 우노+DC모터 제어 질문드립니다.댓글[1] 빈군 20-07-30 56
질문 아두이노어플 통신 질문드립니다댓글[1] dongeun9 20-07-29 50
질문 모터를 작동시키기만 하면, 외부인터럽트에서 이상이 발생합니다.댓글[1] 꾸람이 20-07-29 67
질문 질문 드립니다.댓글[1] 알려주세요제발ㅠㅠ 20-07-29 48
질문 질문드립니다 수파도프 20-07-28 42
답변 답변글 답변 : 질문드립니다 master 20-07-28 47
질문 아두이노 우노 -> 메가 질문드립니다댓글[2] dongeun9 20-07-28 55
질문 ATmega와 안드로이드 블루투스 연결 질문입니다. 구래몬 20-07-28 42
답변 답변글 답변 : ATmega와 안드로이드 블루투스 연결 질문입니다.댓글[1] master 20-07-28 51
질문 아두이노 RC카 양쪽 모터속도제어 질문입니다.댓글[3] 첨부파일 MaTD 20-07-27 86
질문 통신프로토콜 ? 세상통합 20-07-27 43
질문 타이머 인터럽트를 이용한 스텝모터 제어 질문입니다.댓글[6] 꾸람이 20-07-26 74
질문 매우 초보적인 아두이노 코딩질문입니다.댓글[1] 이미지첨부파일 화이팅dP 20-07-23 72
질문 아두이노 우노 푸쉬 버튼 서보모터 작동 관련 초보 질문입니다.댓글[1] 이미지 구름신 20-07-23 52
질문 적외선 거리센서 탐지범위 설정하는 방법 알려주시면 감사하겠습니다. 큐큐큐큨 20-07-22 49
답변 답변글 답변 : 적외선 거리센서 탐지범위 설정하는 방법 알려주시면 감사하겠습니다. master 20-07-22 62
질문 코딩 질문.. 전자학습자 20-07-22 64
답변 답변글 답변 : 코딩 질문..댓글[4] master 20-07-22 84
질문 소스 코드 질문좀 드리겠습니다..! 코딩공부하자 20-07-21 69
답변 답변글 답변 : 소스 코드 질문좀 드리겠습니다..! master 20-07-21 57
답변 답변글 답변 : 답변 : 소스 코드 질문좀 드리겠습니다..!댓글[4] 코딩공부하자 20-07-22 80
질문 아두이노 스텝모터 도와주세요~ 랩돌이 20-07-20 75
