질문게시판 > 답변 : 시계, 스위치 제어
TODAY801 TOTAL2,165,300
BASIC4MCU | 질문게시판 | 답변 : 시계, 스위치 제어
작성자 master 작성일2019-11-01 12:43 조회17,714회 댓글7건
// DateTime : 2019-11-01 오후 12:42:02
#include <iom128v.h>
#include <avrdef.h>
#include <stdio.h>
volatile   signed char sec=57,min=59,hr=11;
volatile unsigned char mode=0,half_sec_flag=0,set_flag=0,str[30];
void delay_ms(unsigned int m){
  int i,j;
  for(i=0i<mi++){
    for(j=0j<2180j++){ ; }
void write_cmd(char c) { PORTC=cPORTG=2delay_us(1); PORTG=0delay_ms3); }
void write_data(char d){ PORTC=dPORTG=3delay_us(1); PORTG=1delay_us(50); }
void write_str(char *s){ while(*s)write_data(*s++); }
void clcd_init(void){
  delay_ms(15);
  write_cmd(0x38); write_cmd(0x38); write_cmd(0x38);
  write_cmd(0x08); write_cmd(0x01); write_cmd(0x06); write_cmd(0x0C);
#pragma interrupt_handler int4_isr:iv_INT4
void int4_isr(void){ set_flag^=1; }
#pragma interrupt_handler int5_isr:iv_INT5
void int5_isr(void){
  if(set_flag){
    sec=0;
    if(mode){ if(++min>59)min=0; }
    else    { if(++hr >23)hr =0; }
#pragma interrupt_handler int6_isr:iv_INT6
void int6_isr(void){
  if(set_flag){
    sec=0;
    if(mode){ if(--min<0)min=59; }
    else    { if(--hr <0)hr =23; }
#pragma interrupt_handler int7_isr:iv_INT7
void int7_isr(void){ mode^=1; }
#pragma interrupt_handler timer1_compa_isriv_TIMER1_COMPA
void timer1_compa_isr(void){ half_sec_flag=1; } //500ms
#pragma interrupt_handler timer3_compa_isriv_TIMER3_COMPA
void timer3_compa_isr(void){ //1sec
  if(set_flag==0){
    if(++sec==60){ sec=0;
      if(++min==60){ min=0if(++hr==24)hr=0; }
void main(void){
  char amFlag,semiCol=0,hr1;
  DDRC=0xff;
  DDRG=0x03;
  clcd_init();
  TCCR1B=0x0COCR1A=31249TIMSK=0x10//500ms
  TCCR3B=0x0DOCR3A=15624ETIMSK=0x10//1sec
  EICRB=0xAA;  EIMSK=0xF0;  SEI();
    if(half_sec_flag){ half_sec_flag=0// 매 500ms 마다 실행
      semiCol^=1;                       // 토글
      if(hr<12)amFlag=1;  else amFlag=0;
      if(hr>12)hr1=hr-12else hr1=hr;
      write_cmd(0x88); if(amFlag)write_str("AM "); else write_str("PM ");
      if(set_flag==0){
        if(semiCol){ sprintf(str,"%02d:%02d",hr1,min); }
        else       { sprintf(str,"%02d %02d",hr1,min); }
        write_cmd(0x8b); write_str(str);
        if(mode){ // min
          else       { sprintf(str,"%02d   ",hr1); }
          else       { sprintf(str,"   %02d",min); }
댓글 7
조회수 17,714
반헬쭉님의 댓글
반헬쭉 작성일
LCD에 표시하는 함수를 배열을 쓰지않고 하나씩 주르륵 나열했을때는 딜레이가 어마어마하게 중첩되서 어쩔 수 없이 오류가 생기는 건가요?
컴파일러가 없으므로 무슨 말을 하는지 알 수가 없습니다.
상세하게 설명해보세요
반헬쭉님의 댓글
반헬쭉 댓글의 댓글 작성일
#include <avrdef.h>
void delay_ms(unsigned int m);
void clcd_init(void);
void write_instruction(char addr);
void write_data(char data);
void clock_operating(void);
char sec_1,sec_10,min_1,min_10,hr_1,hr_10;
char sec=0,min=0,hr=0;
unsigned int number;
char short_key=1, long_key=0,mode=0;
void main(void)
    DDRC = 0xff; // clcd data bus
    DDRG = 0x03;
    EICRB = 0xA8;
    EIMSK = 0xF0;
    SEI(); //re-enable interrupts
    clcd_init(); // clcd function reset
        while(short_key)
            clock_operating();
            if(hr<=11)
                write_instruction(0x88);
                write_data('A');
                write_data('M');
                write_data(' ');
                write_data('P');
                write_data('M');
                write_data(' ');
            if(hr<=12)
                write_instruction(0x8b);
                write_data(hr_10+0X30);
                write_data(hr_1+0X30);
            else if((hr>=13)&&(hr<22))
                write_data(' ');
                write_data((hr-12)+0X30);
                write_data(1+0X30);
                write_data((hr-22)+0X30);
            write_instruction(0x8d);
            write_data(':');
            write_data(min_10+0X30);
            write_data(min_1+0X30);
            delay_ms(500);
            write_data(' ');
        while(long_key)
            number=0;
            clock_operating();
            if(mode==0)
                if(hr<=11)
                    write_data('A');
                    write_data('M');
                    write_data(' ');
                    write_data('P');
                    write_data('M');
                    write_data(' ');
                if(hr<=12)
                    delay_ms(500);
                    write_data(' ');
                    write_data(' ');
                    delay_ms(500);
                    write_data(' ');
                    delay_ms(500);
                    write_data(' ');
                    write_data(' ');
                    delay_ms(500);
                    write_data(1+0X30);
                    delay_ms(500);
                    write_data(' ');
                    write_data(' ');
                    delay_ms(500);
                write_data(':');
            if(mode==1)
                if(hr<=11)
                    write_data('A');
                    write_data('M');
                    write_data(' ');
                    write_data('P');
                    write_data('M');
                    write_data(' ');
                if(hr<=12)
                    write_data(' ');
                    write_data(1+0X30);
                write_data(':');
                write_instruction(0x8e);
                delay_ms(500);
                write_data(' ');
                write_data(' ');
                delay_ms(500);
void int4_isr(void)
    number++;
    delay_ms(1);
    if(number<100)
        short_key = 1;
        long_key = 0;
    else if ((number>=100)&&(number<250))
        short_key = 0;
        long_key = 1;
void int5_isr(void)
    if(long_key)
        if(mode==0)
            hr++;
            if(hr>23)
                hr=0;
        else if(mode==1)
            min++;
            if(min>59)
                min=0;
                hr++;
void int6_isr(void)
    if(long_key)
        if(mode==0)
            hr--;
            if(!hr>=0)
                hr=23;
        else if(mode==1)
            min--;
            if(!min>=0)
                min=59;
                hr--;
void int7_isr(void)
    mode^=1;
    int i,j;
    for(i=0; i<m; i++)
        for(j=0; j<2180; j++)
    delay_ms(15);
    write_instruction(0x38);
    delay_ms(5);
    delay_ms(100);
    write_instruction(0x08);
    write_instruction(0x01);
    write_instruction(0x06);
    write_instruction(0x0C);
    PORTG = 0x02;
    PORTC = addr;
    PORTG = 0x00;
    delay_ms(1);
    PORTG = 0x02;
    PORTG = 0x03;
    PORTC = data;
    PORTG = 0x01;
    delay_ms(1);
    PORTG = 0x03;
    hr_10 = hr / 10;
    hr_1 = hr - hr_10*10;
    min_10 = min / 10;
    min_1 = min - min_10*10;
    sec_10 = sec / 10;
    sec_1 = sec - sec_10*10;
    if(short_key==1)
    sec++;
    delay_ms(1000);
    if(sec==60)
        sec=0;
        min++;
    if(min==60)
        min=0;
        hr++;
    if(hr==24)
        hr=0;
반헬쭉님의 댓글
반헬쭉 댓글의 댓글 작성일
작성해주신  소스에 사용 안 해본 용어들이 많길래 시간출력이랑 스위치 동작만 수정해서 돌려봤는데요, 이 때 문제점이 PM 11 59 에서 AM 00 00 으로 바로 바뀌지 않고 PM 23 59로 바뀌었다가 AM 00 00으로 바뀌더군요. 또 6번 스위치는 조건을 걸었음에도, 0보다 작은값이 되었을때의 조건을 인식하지 못하는지 원하는 값이 아닌 숫자가 뜨네요..
답변 소스가 이해가 안가더라도 동작시켜볼 수는 있는 것 아닌가요?
반헬쭉님의 댓글
반헬쭉 댓글의 댓글 작성일
동작도 안합니다 ㅠ
컴파일 오류가 있는지 잘 체크하고
어디까지 동작하고 어디부터 동작하지 않는지 디버깅하세요
공지 사이트 이용 안내댓글[24] master 17-10-29 29693
질문 초음파+스텝모터 새글 도꺼비 22-05-22 15
답변 답변글 답변 : 초음파+스텝모터 새글 master 04:42 15
질문 아두이노 인터럽트 질문있습니다.댓글[1] 새글 띵꽁 22-05-22 25
답변 답변글 답변 : 아두이노 인터럽트 질문있습니다.댓글[3] 새글 master 22-05-22 19
질문 atmega128 스톱워치 작성 중 외부 인터럽트 관련 질문 드립니다.댓글[4] 이미지새글 마프하나 22-05-22 31
질문 서보모터제어 해당코드에서 어떤걸 추가해야할까요댓글[3] 이미지새글첨부파일 오소로롯 22-05-22 25
질문 아두이노 서보모터제어 하나도 모르겠습니다 ㅠ댓글[2] 이미지새글첨부파일 오소로롯 22-05-21 35
질문 아트메가 128 을 이용해서적외선 센서 코딩 중 물어볼게있습니다!!댓글[5] 새글 noster 22-05-21 27
질문 아두이노 블루투스 통신 관련 질문 있습니다!! 블루툿 22-05-21 28
답변 답변글 답변 : 아두이노 블루투스 통신 관련 질문 있습니다!! master 22-05-21 28
질문 아두이노 d1r2 W238 방수 초음파 센서댓글[1] 밤새아두이노 22-05-21 40
질문 아두이노 블루투스(hc-06)사용중 질문있습니다. 첨부파일 띵꽁 22-05-20 43
질문 아두이노 블루투스 통신댓글[1] 블루툿 22-05-20 42
질문 ATmega128 진동센서 코딩 질문입니다.댓글[5] 444222a 22-05-20 55
질문 아두이노 초음파센서 코딩 질문댓글[3] 이미지첨부파일 아두이노아린이 22-05-20 46
질문 atmega128 서보모터와 초음파센서댓글[5] tmiae 22-05-20 63
질문 avr compiler 종류 질문입니다!댓글[3] 민준싸 22-05-20 47
질문 컴퓨터 usb연결시 정상 작동하나 9V건전지 외부전원 연결 시 작동하지 않는 문제댓글[3] 이미지첨부파일 보겐을운용 22-05-19 332
질문 아두이노 dac 연결댓글[5] 이미지첨부파일 kodory 22-05-19 47
질문 아두이노 millis ->atmega128에서 사용하고 싶습니다. akmong413 22-05-19 48
답변 답변글 답변 : 아두이노 millis ->atmega128에서 사용하고 싶습니다.댓글[2] master 22-05-19 59
