BASIC4MCU | 질문게시판 | 답변 : 아두이노 집게손 코딩 질문있습니다.
작성자 master 작성일2019-11-01 19:29 조회3,502회 댓글0건
https://www.basic4mcu.com/bbs/board.php?bo_table=gac&wr_id=10504
// MCU BASIC: https://www.basic4mcu.com// DateTime : 2019-11-01 오후 7:28:19// by Ok-Hyun Park//#include <SoftwareSerial.h>SoftwareSerial mySerial(12,13); // RX,TX#include <Servo.h>//const int SERVOS=4;Servo myservo[SERVOS];//int DELAYTIME=200;int PIN[SERVOS],value[SERVOS],currentAngle[SERVOS],MIN[SERVOS],MAX[SERVOS],INITANGLE[SERVOS];int afrom[]={90,55,165},ato[]={20,140,110},amiddle[]={20,55,165},afinal[]={179,125,95},aafterfinal[]={179,55,165};int servo_moving[SERVOS]={0,0,0,0};int bt_servo=0,bt_move=0,idle=0;bool stringComplete=false;//void setup(){pinMode(3,OUTPUT); digitalWrite(3,HIGH);mySerial.begin(9600);init_Pins();//auto_mode();Serial.begin(9600);}//void loop(){move_bt();move_joy();}//void init_Pins(){PIN[0]=11; MIN[0]= 0; MAX[0]=179; INITANGLE[0]= 90;PIN[1]=10; MIN[1]=35; MAX[1]=179; INITANGLE[1]= 90;PIN[2]= 9; MIN[2]=90; MAX[2]=179; INITANGLE[2]=155;PIN[3]= 5; MIN[3]= 0; MAX[3]=179; INITANGLE[3]= 25;//for(int i=0; i<SERVOS; i++){myservo[i].attach(PIN[i]); myservo[i].write(INITANGLE[i]); value[i]=0;idle=0;}}//void move_bt(){checkSoftSerial();for(int i=0; i<SERVOS; i++){currentAngle[i]=myservo[i].read();if(servo_moving[i]!=0){currentAngle[i]+=servo_moving[i];currentAngle[i]=currentAngle[i]>MAX[i]?--currentAngle[i]: currentAngle[i];currentAngle[i]=currentAngle[i]<MIN[i]?++currentAngle[i]: currentAngle[i];myservo[i].write(currentAngle[i]);delay(20);}}}//void checkSoftSerial(){String str="";if(mySerial.available()){for(int i=0; i<2; i++)str+=(char)mySerial.read();//int value=str.toInt(); // the servo to movebt_servo=value/10;//int angle=value%10; // the direction to moveif (angle==2)bt_move= 1;else if(angle==1)bt_move=-1;else bt_move= 0;//servo_moving[bt_servo]=bt_move;}}//void move_joy(){for(int i=0; i<SERVOS; i++){value[i]=analogRead(i);currentAngle[i]=myservo[i].read();if(value[i]>612){idle=0;if(currentAngle[i]>MIN[i])--currentAngle[i];}else if(value[i]<412){idle=0;if(currentAngle[i]<MAX[i])++currentAngle[i];}else{ idle++; }//if(idle==100){ myservo[i].detach(); }}for(int i=0; i<SERVOS; i++){if(!myservo[i].attached())myservo[i].attach(PIN[i]);myservo[i].write(currentAngle[i]);}delay(20);}//void auto_mode(){for(int i=0; i<2; i++){closeclaw(false); armfromto(afrom,ato); closeclaw(true); delay(DELAYTIME);armfromto(ato,amiddle); delay(DELAYTIME);armfromto(amiddle,afinal); closeclaw(false); delay(DELAYTIME);armfromto(afinal,aafterfinal); delay(DELAYTIME);armfromto(aafterfinal,afrom); delay(DELAYTIME);}}//void armfromto(int*arrf,int*arrt){int lp[3],seg=3,sign;for(int i=0; i<3; i++)lp[i]=abs((arrt[i]-arrf[i])/seg);//delay(DALAYTIME);for(int i=0; i<3; i++){sign=arrt[i]-arrf[i]>0?1:-1;for(int j=0; j<lp[i]; j++){ myservo[i].write(arrf[i]+j*seg*sign); delay(20); }delay(DELAYTIME);}}//void closeclaw(boolean op){if(op){ myservo[3].write( 5); }else { myservo[3].write(30); }}
조회수 3,502등록된 댓글이 없습니다.
