질문게시판 > LCD 로 테트리스를 만들려고 하는데요..
TODAY1,243 TOTAL2,922,679
BASIC4MCU | 질문게시판 | LCD 로 테트리스를 만들려고 하는데요..
작성자 잘하자 작성일2019-11-02 14:43 조회9,013회 댓글2건
AVR 로 할려고 하는데... 벽과 블럭까지는 만들었습니다. 근데 블럭이 나타나면 벽이 사라지네요 어떻게 해야할까요..
#include <mega128a.h>
#include <delay.h>
#define ENABLE PORTA.2
#define FUNCSET 0x28
#define DISPON 0x0C
#define ALLCLR 0x01
#define ENTMODE 0x06
#define LINE2 0xC0
#define uchar unsigned char
#define Busy delay_ms(2)
void Reset();
void Command(uchar ch);
void Data(uchar ch);
void LCD_String(char flash *str);
void Map_Made();
void Block_made();
flash uchar map1[3][8] = {0x1F,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x1F,0x0,0x0,0x0,0x0,0x0,0x0,0x0, 0x1F, 0x01,0x01,0x01,0x01,0x01,0x01,0x01};
flash uchar map2[3][8] = {0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x1F,0x0,0x0, 0x0,0x0,0x0,0x0,0x0,0x1F,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x1F};
int map_wall_i= 0;
int map_wall_j= 0;
int map_wall_count= 0;
void main(void)
Reset();
Map_Made();
Block_made();
while (1)
    // Please write your application code here
void Map_Made(){ //테트리스 맵
map_wall_count=0;
for(map_wall_i = 0; map_wall_i < 3; map_wall_i++){
for(map_wall_j = 0; map_wall_j < 8; map_wall_j++){
Command(0x40 + map_wall_count);
Data(map1[map_wall_i][map_wall_j]);
Command(0x58 + map_wall_count);
Data(map2[map_wall_i][map_wall_j]);
map_wall_count++;
Command(0x86);
Data(0);
for(map_wall_i = 0; map_wall_i < 6; map_wall_i++){
Command(0x87 + map_wall_i);
Data(1);
Command(0x8D);
Data(2);
Command(0xC6);
Data(3);
Command(0xC7 + map_wall_i);
Data(4);
Command(0xCD);
Data(5);
void Block_made(){
Command(0x7C);//해당 블럭그리기
Data(4);
void Command(uchar ch){//LCD 문자 명령어
Busy;
PORTA = 0x0;
PORTA |= (ch & 0xF0);
delay_us(1);
ENABLE = 1;
delay_us(1);
ENABLE = 0;
PORTA = 0x0;
PORTA |= (ch <<4);
delay_us(1);
ENABLE = 1;
delay_us(1);
ENABLE = 0;
}//LCD 문자 명령어
void Data(uchar ch){//LCD 글자 쓰기
Busy;
PORTA = 0x01;
delay_us(1);
ENABLE = 1;
delay_us(1);
ENABLE = 0;
PORTA = 0x01;
PORTA |= (ch <<4);
delay_us(1);
ENABLE = 1;
delay_us(1);
ENABLE = 0;
} //LCD 글자 쓰기
void LCD_String(char flash *str){//문자열 보내기
char flash *Pstr = 0;
Pstr = str;
while(*Pstr)Data(*Pstr++);
}//문자열 보내기
void Reset(){
DDRA = 0xFF;
PORTA = 0x0;
delay_ms(15);
Command(0x20);
delay_ms(5);
Command(0x20);
delay_us(100);
Command(0x20);
Command(FUNCSET);
Command(DISPON);
Command(ALLCLR);
Command(ENTMODE);
제가 테티리스 맵까지 만들었는데 문제는 블럭이 내려갈때 맵으로 만들어둔 점선들이 사라지고 블럭만 보이게 되네요 ㅜㅜ
맵을 안사라지게 할려면 어떻게 해야할까요 ㅠㅠ 해당 파일은 벽이 사라지고 블럭만 나온 상태고...
벽과 블락 다같이 나타나게 할려면 우찌 줘야할까요..
조회수 9,013
모양을 만들 수 있는 개수는 총 8가지입니다.
벽만은 4가지를 사용해야 하고
벽과 블럭을 동시에 표시 하려면 블럭종류x벽4=?
벽을 사용하지말고 만들어보세요
초짜님의 댓글
초짜 댓글의 댓글 작성일
아아 즉 내려가는 거까지 다같이 만들어야하네요...그럼 여러개의 블럭 쌓을때도 사실상 또 다 만들어줘야하는거네요? 아..
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 21040
공지 사이트 이용 안내댓글[29] master 17-10-29 34893
질문 안녕하세요 스위치로 led 제어 관련 질문이 있습니다 새글 노형빈 19:12 5
질문 16X16 도트 매트릭스 구동방법 질문입니다. 새글첨부파일 맹균 17:21 10
질문 stm32에서 RTC 시간 함수 쓰는데 의문점댓글[1] 새글 라칸 10:13 14
질문 GPS 모듈 관련 질문입니다.댓글[3] 지구과학 23-09-22 22
질문 아두이노 블루투스와 초음파센서를 이용한 장애물 정지댓글[2] 둘둘이 23-09-22 42
답변 답변글 답변 : 아두이노 블루투스와 초음파센서를 이용한 장애물 정지댓글[1] 새글 master 16:59 14
질문 stm32 보드에서 시간설정과 불러오기를 하는데댓글[5] 라칸 23-09-22 36
질문 아두이노 인터럽트 질문입니다.댓글[2] Tell 23-09-21 36
답변 답변글 답변 : 아두이노 인터럽트 질문입니다.댓글[1] master 23-09-22 52
질문 아두이노와 거리 감지 센서의 전류 관련댓글[1] hmkim 23-09-21 59
질문 아두이노 코딩 질문있습니다. 도와주세요....댓글[1] 이미지첨부파일 vnpaz 23-09-20 66
질문 아두이노를 사용한 dc모터 위치제어댓글[2] 모터위치 23-09-20 57
질문 stm32 디버깅이나 rst버튼 없이 하는 방법좀댓글[1] 라칸 23-09-20 51
질문 LCD에 숫자 표기법을 바꾸고 싶습니댓글[2] Bs드리프터 23-09-19 121
질문 알코올 측정기(MQ-3) 관련 질문 이미지 소오금 23-09-18 60
답변 답변글 답변 : 알코올 측정기(MQ-3) 관련 질문 master 23-09-19 110
질문 스텝모터 제어하는 소스파일 수정방법 질문드립니다. Bs드리프터 23-09-15 72
답변 답변글 답변 : 스텝모터 제어하는 소스파일 수정방법 질문드립니다.댓글[1] master 23-09-15 106
질문 atmega 128을 이용한 악기 튜너기댓글[1] 아두이노짱 23-09-15 312
질문 stm32 보드 ip주소 찾는법댓글[1] 라칸 23-09-13 64
질문 마이컴 종류 질문댓글[2] stevie8 23-09-12 116
질문 주파수 실수배 체배 관련문의댓글[6] 스쳐두임신 23-09-11 150
질문 스마트 창문 제작 중에 질문 있습니다!댓글[1] 이미지첨부파일 N8008 23-09-09 111
질문 아두이노와 파이어베이스 연결이 안되는데 도와주실수 있을까요댓글[1] 아카링고 23-09-08 361
질문 노르딕 타이머댓글[1] stevie8 23-09-08 260
질문 아두이노우노 엔코더모터 서보모터 코드댓글[1] 팔쟁이 23-09-07 200
질문 rs485 모드버스 통신 질문댓글[2] 킹초보 23-08-28 395
질문 데이터 타입 질문댓글[1] stevie8 23-08-22 212
