질문게시판 > 답변 : 아트메가128 진동 센서
TODAY1,169 TOTAL2,163,010
BASIC4MCU | 질문게시판 | 답변 : 아트메가128 진동 센서
작성자 master 작성일2019-11-05 22:57 조회5,338회 댓글1건
Introduction
This is an Arduino compatible piezo film vibration sensor. It is made up of flexible piezo film and converter board. The sensor is able to detect vibration, flexibility, impact and touch. The film is a flexible component comprising a 28 µm thick piezoelectric PVDF polymer film with screen-printed Ag-ink electrodes, laminated to a 0.125 mm polyester substrate, and fitted with two crimped contacts. As the piezo film is displaced from the mechanical neutral axis, the corresponding bending creates very high strain within the piezo polymer and therefore high voltages (about ±90V) are generated. When the assembly is deflected by direct contact, the device acts as a flexible "switch", and the generated output is sufficient to trigger MOSFET or CMOS stages directly. The module uses universal Gravity 3Pin interface for easy plug and play. It comes with Digital and Analog output signals, which are suitable for all kinds of different applications. The piezo vibration sensor is not only able to detect strong shocks, but also to detect slight vibrations. There is an on-board sensitivity adjustment potentiometer that you can adjust it to increase/decrease the output threshold value. Meanwhile, the piezo film sensor has a wide dynamic range (0.001Hz~1000MHz) also guarantees an excellent measuring performance.
Specification
  • Operating Voltage: 5V
  • Interface Type: Gravity PH2.0 3Pin interface
  • Operating Temperature: 0 ° C to 85 ° C
  • Storage Temperature: -40 ° C to 85 ° C
  • Dimension: 27mm * 22mm
  • Weight: 10 g
Board Overview
NumLabelDescription
1GNDGND
2VCCVCC
3SignalSignal
Tutorial
In this tutorial, we'll show you the sensor usage. Watch the serial monitor and LED "L" state.
 Note: The sensitivity potentiometer control the output threshold. When it rotates towards "MAX" direction, it need more swing to trigger sensor.
Requirements
Connection Diagram
Sample Code
* Piezo Vibration Sensor
* This example The sensors detect vibration
* @author linfeng(490289303@qq.com)
* @version  V1.0
* @date  2016-2-26
* GNU Lesser General Public License.
* See  for details.
* All above must be included in any redistribution
#define sensorPin A1
#define ledPin 13
  Serial.begin(115200);
  pinMode(ledPin,OUTPUT);
  int x=analogRead(sensorPin);
  Serial.println(x);
  if(x>500)digitalWrite(13,HIGH);
  else digitalWrite(13,LOW);
  delay(50);
Copy
Expected Results
FAQ
More
https://wiki.dfrobot.com/Gravity__Flexible_Piezo_Film_Vibration_Sensor_SKU__SEN0209#More
  Serial.println(x);
  delay(50);
50ms 주기로
아나로그 값을 읽어서 시리얼통신을 하면 아두이노와 동일한 출력을 얻을 수 있습니다.
시리얼모니터 결과를 보면
11 정도로 쭈욱 나오다가
1023 값이 2개 보입니다.
어느 정도의 세기로 센서를 건드렸는지 모르겠지만 50ms 주기로 읽으면 한 두 개의 출력 밖에 안나옵니다.
이 값을 어떻게 사용하려는지 모르지만 참고하세요
조회수 5,338
antjdnsxks님의 댓글
antjdnsxks 작성일
감사합니다
공지 사이트 이용 안내댓글[24] master 17-10-29 29644
질문 아트메가 128 을 이용해서적외선 센서 코딩 중 물어볼게있습니다!! 새글 noster 19:32 14
질문 아두이노 블루투스 통신 관련 질문 있습니다!! 새글 블루툿 10:51 23
질문 atmega128 서보모터와 초음파센서댓글[5] 새글 tmiae 22-05-20 31
질문 컴퓨터 usb연결시 정상 작동하나 9V건전지 외부전원 연결 시 작동하지 않는 문제댓글[3] 이미지첨부파일 보겐을운용 22-05-19 188
질문 아두이노 millis ->atmega128에서 사용하고 싶습니다. akmong413 22-05-19 32
답변 답변글 답변 : 아두이노 millis ->atmega128에서 사용하고 싶습니다. master 22-05-19 34
질문 아두이노로 모터+드라이버 제어댓글[6] 모토 22-05-18 75
질문 라즈베리파이 웹캠 데이터 아두이노 전송 (초보)댓글[3] 전자과 22-05-17 61
질문 아두이노 우노 2개와 앱인벤터끼리의 블루투스 통신 방법댓글[3] 이미지첨부파일 pyoleo 22-05-17 116
