BASIC4MCU | 질문게시판 | 코드비전 소스입니다.
작성자 atmega1 작성일2019-11-06 22:33 조회7,090회 댓글2건본문
#include <mega128.h>
#include <stdio.h>
#include <lcd.h>
#include <delay.h>
#define L_IN1 PORTB.0 // L_motor Dir Control
#define L_IN2 PORTB.1
#define R_IN1 PORTB.2 //R_Motor Dir Control
#define R_IN2 PORTB.3
#define L_EN PORTB.5 //L_motor control, OCR1A output pin
#define R_EN PORTB.6 // R_motor Control, OCR1B output pin
#asm
equ__lcd_port = 0x15; //PORTC -LCD
#endasm
volatile unsigned char mod[3][16] = {"Ready ","Memorizing"};
volatile unsigned char temp_L[16];
volatile unsigned char temp_R[16];
volatile unsigned int L_cnt, R_cnt;
volatile unsigned int L_cnt_s[100], L_Dir_s[100];
volatile unsigned int R_cnt_s[100], R_Dir_s[100];
volatile unsigned int L_run_cnt, R_run_cnt, L_top, R_top;
volatile bit L_Run,R_Run,L_comp, R_comp, test1, tes2, test3;
volatile int L_step, R_step,top, err_L, err_R;
volatile bit L_D, R_D, Memo_flag, md_sel,;
volatile bit L_chk_flag, R_chk_flag, L_t_chk,R_t_chk;
interrupt [EXT_INT0] void Memo(void)
if(L_Run !=1 || R_Run !=1)
md_sel = ~md_sel; //Memorizing mode on/off
L_chk_flag =1;
R_chk_flag =1;
if(L_t_chk ==1)
//L Motor
L_Dir_s[L_step] = L_D; //방향저장
L_cnt_s[L_step] = L_cnt;
//R Motor
if(R_t_chk==1)
R_Dir_s[R_step] = ~R_D; // 방향저장
R_cnt_s[R_step] = R_cnt; // 펄스 수 저장
//초기화
if(L_t_chk==1 || R_t_chk==1)
L_t_chk =0;
R_t_chk= 0;
md_sel = 0;
L_cnt =0;
R_cnt =0;
L_run_cnt =0;
R_run_cnt =0;
L_chk_flag =0;
R_chk_flag =0;
//저장완료
Memo_flag =1;
interrupt [EXT_INT1] void Run_mode(void)
if(Memo_flag ==1)
L_Run =1;
R_Run = 1;
L_run_cnt =0;
R_run_cnt = 0;
//Left Motor
interrupt [EXT_INT4] void Left_motor_capture(void)
if(md_sel == 1) // save mode
L_cnt++;
if(L_chk_flag == 1) //DIR check
L_t_chk = 1;
if(PINE.5 ==0)
L_D =0; //im_Dir Reverse
L_D = 1; // im_dir Drive
L_chk_flag =0;
if(L_D ^PINE.5 ==1)
if(L_cnt >2)
L_step++;
L_chk_flag =1;
L_cnt = 0;
if(Memo_flag == 1)
L_run_cnt++;
// Right Motor
interrupt[EXT_INT6] void Right_Motor_capture(void)
if(md_sel == 1)
R_cnt++; //회전 펄스 수++
if(R_chk_flag == 1) { // Direction check
R_t_chk = 1;
if(PINE.7 == 0) {
R_D= 0; // Im_Dir Reverse
else {
R_D = 1; // Im_dir Drive
R_chk_flag = 0; // chk Flag off, 더이상 방향 체크 없이 카운트만 체크
if(R_D^PINE.7 ==1 ) // 방향 전화 xor 연산을 통해 감지
if(R_cnt >2) // 카운트가 2이상이어야지만 step 증가
R_Dir_s[R_step] = ~R_D; //방향 저장
R_cnt_s[R_step] = R_cnt; //펄스 수 저장
R_step++; // Step ++
R_chk_flag = 1; //방향 chk flag On
R_cnt = 0; //R_cnt 초기화
if(Memo_flag == 1) // 저장된값 출력시 if 문을 발생
R_run_cnt++;
void main(void)
DDRB = 0xff;
EICRA = (1<<ISC31) | (0<<ISC30) | (1<<ISC21) | (0<<ISC20) | (1<<ISC11) | (0<<ISC10) | (1<<ISC01) | (0<<ISC00);
EICRB = (0<<ISC71) | (0<<ISC70) | (1<<ISC61) | (0<<ISC60) | (0<<ISC51) | (0<<ISC50) | (1<<ISC41) | (0<<ISC40);
EIMSK = (0<<INT7) | (1<<INT6) | (0<<INT5) | (1<<INT4) | (0<<INT3) | (0<<INT2) | (1<<INT1) | (1<<INT0);
TCCR1A = (0<<COM1A1) | (0<<COM1A0) | (0<<COM1B1) | (0<<COM1B0) | (0<<COM1C1) | (0<<COM1C0) | (0<<WGM11) | (1<<WGM10);
TCCR1B = (0<<ICNC1) | (0<<ICES1) | (0<<WGM13) | (1<<WGM12) | (0<<CS12) | (1<<CS11) | (1<<CS10);
OCR1A = 170;
OCR1B = 170;
lcd_init(16);
#asm("sei")
while (1)
/// LCD 상태 표시
lcd_gotoxy(0,0);
sprintf(temp_L,"mode:%s",mode[md_sel]);
lcd_puts(temp_L);
lcd_gotoxy(0,1);
sprintf(temp_R,"L :%3d R :%3d", L_step, R_step);
lcd_puts(temp_R);
// 저장 정보가 있을 때
if(Memo_flag == 1&& (L_Run == 1||R_Run ==1))
// L Motor
if(L_Run == 1)
if(L_cnt_s[L_top] !=0)
if(L_Dir_s[L_top] == 0)
TCCR1A |= (1<<COM1A1) | (1<<COM1A0);
L_IN1 = 1;
L_IN2 = 0; // reverse
TCCR1A |= (1<<COM1A1) | (0<<COM1A0);
L_IN1 = 0;
L_IN2 = 1; //drive
err_L = L_cnt_s[L_top] - L_run_cnt;
if(err_L == 0)
TCCR1A |= (0<<COM1A1) | (0<<COM1A0) | (0<<COM1C0) | (0<<WGM11) | (1<<WGM10);
L_EN = 0;
L_IN1 = 1;
L_IN2 = 1;
delay_us(30);
L_run_cnt = 0;
L_top++;
if(L_step < L_top)
TCCR1A |=(0<<COM1A1) | (0<<COM1A0) | (0<<COM1C1) | (0<<COM1C0) | (0<<WGM11) | (1<<WGM10);
L_IN1=1;
L_IN2=1;
L_EN =0;
L_run_cnt = 0;
L_top = 0;
L_Run = 0;
L_comp = 1;
if(L_comp == 1)
L_EN = 0;
/************************ R MOTOR ************************/
if(R_Run == 1)
if(R_cnt_s[R_top] !=0)
/******************** R 방향 파악 ********************/
if(R_Dir_s[R_top] ==0) /*******Reverse*******/
TCCR1A |= (1<<COM1B1) | (0<<COM1B0);
R_IN1 = 0;
R_IN2 = 1;
else /*******Drive*******/
TCCR1A |= (1<<COM1B1) | (1<<COM1B0);
R_IN1 = 1;
R_IN2 = 0;
err_R = R_cnt_s[R_top] - R_run_cnt;
if(err_R == 0)
TCCR1A |= (0<<COM1B1) | (0<<COM1B0) | (0<<COM1C1) | (0<<COM1C0) | (0<<WGM11) | (1<<WGM10);
R_EN = 0;
R_IN1 = 1;
R_IN2 = 1;
delay_us(30);
R_run_cnt = 0;
R_top++;
test1 = 1;
if(R_step < R_top)
test1 = 1;
R_IN1 = 1;
R_IN2 = 1;
R_EN = 0;
R_run_cnt = 0;
R_step = 0;
err_R = 0;
R_Run = 0;
R_comp = 1;
if(R_comp == 1)
R_EN = 0;
if(L_comp == 1 && R_comp == 1)
Memo_flag = 0;
OCR1A = 0;
OCR1B = 0;
TCCR1A = (0<<COM1A1) | (0<<COM1A0) | (0<<COM1B1) | (0<<COM1B0) | (0<<COM1C1) | (0<<COM1C0) | (0<<WGM11) | (0<<WGM10);
TCCR1B = (0<<ICNC1) | (0<<ICES1) | (0<<WGM13) | (0<<WGM12) | (0<<CS12) | (0<<CS11) | (0<<CS10);
L_EN = 0;
R_EN = 0;
소스 자체는 괜찮은거 같은데 틀린곳이 있는지 확인해주시길바랍니다.
프로젝트 컴파일에는 에러가 안뜨는데 build the project를 누르면 에러가 3개가 뜹니다. 사진 처럼 어떻게 되는건지 알려주세요
댓글 2
조회수 7,090master님의 댓글
unsigned char mod[3][16]={ "Ready ","Memorizing"};
배열명을 mode[3][16]로 변경하든지
sprintf(temp_L,"mode:%s",mod[md_sel]); //<-- mod[]로 변경하세요
#include <lcd.h>
#asm
equ__lcd_port=0x15; //PORTC-LCD
#endasm
위 LCD 라이브러리 선언은 구버전의 코드비젼용입니다.
신버전에서는
#include <alcd.h>
헤더파일 하나만 선언하면 되고
LCD 포트 설정은 .. 사진을 답변글에 첨부해드리죠
