BASIC4MCU | 질문게시판 | 답변 : 앱인벤터 질문있습니다
작성자 master 작성일2019-11-14 17:45 조회2,778회 댓글0건
https://www.basic4mcu.com/bbs/board.php?bo_table=gac&wr_id=10730
// MCU BASIC: https://www.basic4mcu.com// DateTime : 2019-11-14 오후 5:44:31// by Ok-Hyun Park//#include#include#include#include#define DHTPIN A1#define relay 10#define relayA 11#define DHTTYPE DHT22//DHT dht(DHTPIN,DHTTYPE);int TxPin=2;int RxPin=3;SoftwareSerial BTSerial(TxPin,RxPin);//bool flag=0;int h,t,gas,gas2;char crt1,crt2;int i;//void setup(){Serial.begin(9600);pinMode(A0,INPUT); pinMode(A2,INPUT);pinMode(relay,OUTPUT); pinMode(relayA,OUTPUT);BTSerial.begin(9600);}//void loop(){h=dht.readHumidity();t=dht.readTemperature();gas=analogRead(A0);gas2=analogRead(A2);//---------------------------if(BTSerial.available()){ //블루투스에서 신호가 있으면,crt1=BTSerial.read();Serial.write(crt1); //블루투스를 읽어 시리얼 모니터에 출력if(crt1=='A'){ digitalWrite(relay,HIGH); }if(crt1=='B'){ digitalWrite(relay,LOW); }}if(Serial.available()){ //시리얼 모니터(PC)에서 신호가 있으면,crt2=Serial.read();if(crt2=='A'){ digitalWrite(relay,HIGH); }if(crt2=='B'){ digitalWrite(relay,LOW); }}//if((gas<400)&&(h<60)){Serial.println(h); Serial.print("% gas="); Serial.println(gas);BTSerial.write(Serial.read()); //시리얼 모니터 입력 내용을 블루투스에 출력BTSerial.print("습도: "); BTSerial.print(h); BTSerial.println("%");BTSerial.print("가스: "); BTSerial.print(gas);digitalWrite(relay,LOW);}else{digitalWrite(relay,HIGH);if(h>60){Serial.println(h); Serial.print("%"); Serial.println(" humidity.WARNING");BTSerial.print(h); BTSerial.print("%"); BTSerial.print(" 습도 warning ");delay(10000);}if(gas>400){Serial.print(gas); Serial.println(" gas.WARNING");BTSerial.print(gas); BTSerial.print(" gas warning ");delay(15000);}}//if(gas<400){if(flag){ flag=0;Serial.print("perfume");delay(10000);digitalWrite(relayA,HIGH);for(i=0; i<100; i++){ delay(100); }digitalWrite(relayA,LOW);}}else{ flag=1; }//delay(1000);}
조회수 2,778등록된 댓글이 없습니다.
