질문게시판 > 답변 : 안녕하세요 썜avr128
TODAY1,086 TOTAL2,162,927
BASIC4MCU | 질문게시판 | 답변 : 안녕하세요 썜avr128
작성자 핑구맹구 작성일2019-11-27 16:23 조회3,354회 댓글0건
답변감사합니다
수정해보았는데요
일단 코딩값입니다.
unsigned char SEG[12] = {0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x83};
unsigned char C[3] = {0b00000001, 0b00000010,0b00000100};
unsigned char R[5] = {0b00000000,0b00000001,0b00000010,0b00000100,0b00001000};
unsigned char A[] = {0xff,0xff,0xff,0xff,0b11111110,0b11111101,0b11111011,0b11110111};
unsigned int RESULT[4]={0,0,0,0};
unsigned int G[7] = {};
unsigned char n;
char num;
int Gap[7]={};
int isr;
int a,p,y,t;
int u=0;
int start;
int sec1,sec10,min1,min10;
int s=0;
int loop;
ISR(INT4_vect) { //덧셈
start=0;
isr=0;
for(int g=0; g<u; g++){
isr+=G[g];
Unit(0);
ISR(INT5_vect) { //곱셈
start=0;
int sum=0;
int isr=1;
isr*=G[g];}
sum = isr%10000;
A[3] = SEG[sum/1000]; //1000의 자리
A[2] = SEG[(sum%1000)/100]; //100의자리
A[1] = SEG[((sum%1000)%100)/10]; //10의자리
A[0] = SEG[((sum%1000)%100)%10]; //1의자리
ISR(INT6_vect) { //최소
start=0;
isr=G[0];
for(int g=0; g<u; g++) {
if(G[g]<isr) isr=G[g];
Unit(0);
ISR(INT7_vect) {
start=0;
isr=0;
if(G[g]>isr) isr=G[g];
Unit(0);}
ISR(INT_vect){
start=1;
void TimerDisplay() { //Timer/Counter Display
A[0]=SEG[sec1];
A[1]=SEG[sec10];
A[2]=SEG[min1];
A[3]=SEG[min10];
ISR(TIMER0_OVF_vect){
if(loop < 100)
loop++;
else {
loop=0;
sec1++;
if(sec1>=10) { //second
sec10++;
sec1=sec1%10;
if(sec10>=6) {
min1++;
sec10=sec10%6;
sec1=sec1%10;
if(min1>=10) {
min10++;
min1=min1%10;
sec10=sec10%6;
sec1=sec1%10;
TCNT0=112;
char Keypad() {
char n=0xff;
PORTC=0b00000001;
_delay_ms(1);
if((PINC&0xf0) == 0b000100000){
n=SEG[1];
else if((PINC&0xf0) == 0b00100000){
n=SEG[4];
else if((PINC&0xf0) == 0b01000000){
n=SEG[7];
else if((PINC&0xf0) == 0b10000000){
for(int i=0; i<4; i++)
A[i]=0xff; //잘못 입력했을 때를 대비하여 *누르면 세그먼트값 모두 지우기
PORTC=0b00000010;
_delay_ms(1);
if((PINC&0xf0)==0b00010000){
n=SEG[2];
else if((PINC&0xf0)==0b00100000){
n=SEG[5];
else if((PINC&0xf0)==0b01000000){
n=SEG[8];
else if((PINC&0xf0)==0b1000000){
n=SEG[0];
PORTC=0b00000100;
  _delay_ms(1);
  n=SEG[3];
  n=SEG[6];
  n=SEG[9];
  else if((PINC&0xf0)==0b10000000){
  G[u++]=StoreNumber();
    A[i]=0xff; // #이 눌러짐을 확인하기 위해 눌러지면 세그먼트 불 모두 소등
return n;
 int main() {
  DDRA=0xff;
  DDRB=0xff;
  DDRC=0x0f;
  DDRE=0x00; // PORTE의 4~7입력
  PORTE=0xf0; // PORTE의 4~7풀업
  DDRF=0x00; // PORTF0입력
  PORTF=0x01; // PORTF 0 풀업
  EIMSK=0b11110001; // INT4~7, 0 인터럽트 인에이블
  EICRB=0b10101010; // INT4~7 하강에지
  EICRA=0b10101010; // INT0 하강에지
  SREG=0x80; // 전역 인터럽트 인에이블
  TCCR0=0b00000111;
  TCNT0=112;
  TIMSK=0b00000001;
  while(1) {
  NumberInput();
if(start==1)
  TimerDisplay(); // start값이 1일 때 (INT0이 걸렸을 때) display호출
 void NumberInput() {
  char temp;
  num=Keypad(); // Keypad함수의 반환값인 SEG배열을 num에 대입
  if(num!=0xff){
  A[3]=A[2];
  _delay_ms(10);
  A[2]=A[1];
  _delay_ms(10);
  A[1]=A[0];
  _delay_ms(10);
  A[0]=num;
  _delay_ms(10);
  } //세그먼트위에서 값을 왼쪽으로 시프트 시켜줌
  a=0;
  temp=0xfe;
  for(int i=0; i<100; i++){
  PORTB=temp;
  PORTA=A[a++]; // 세그먼트에 입력한 숫자 차례로 출력
  _delay_ms(1);
  temp=(temp<<1)|1; //세그먼트를 오른쪽에서 왼쪽으로 차례로 하나씩 점등
  if(a>3) a=0;
  if(temp==0xef)
  temp=0xfe; //세그먼트를 PORTB 0~3만 이용했으므로 4로 넘어가면 다시 오른쪽 제어
  _delay_ms(1);
int StoreNumber(void) {
int v[4];
for(int h=0; h<4; h++) {
RESULT[h]=A[h]; //RESULT배열에 세그먼트에 나타난 숫자를 차례로 대입이 때 대입되는 값은 정수가 아닌 A배열의 값.
for(int n=0; n<10; n++){
if(RESULT[h]==SEG[n]) v[h]=n; //A배열의 값이 대입되어 있기 떄문에 이를 정수로 바꿔주는 작업
else if(RESULT[h]==0Xff) v[h]=0;//만약 아무 입력이 없다면 0 이라는 숫자로 취급
y=(v[3]*1000)+(v[2]*100)+(v[1]*10)+(v[0]); //자릿수에 맞게 세그먼트 각자의 숫자를 하나의 숫자로 계산
return y;
void ReadNum() {
Gap[g]=G[g]; // 입력받은 4개의 값을 Gap 배열에 차례로 대입
void Unit(int sum){
sum=isr%10000;
147* 2580 전혀 먹통이고 369# 누르면 사진과같이 숫자 3333 만 세그먼트에 뜹니다..
스위치도 먹통입니다.
조회수 3,354
공지 사이트 이용 안내댓글[24] master 17-10-29 29641
질문 아트메가 128 을 이용해서 블루투스 + 적외선 센서 코딩 중 물어볼게있습니다!! 새글 noster 19:32 12
질문 아두이노 블루투스 통신 관련 질문 있습니다!! 새글 블루툿 10:51 20
답변 답변글 답변 : 아두이노 블루투스 통신 관련 질문 있습니다!! 새글 master 11:05 15
질문 아두이노 블루투스 통신댓글[1] 새글 블루툿 22-05-20 22
질문 컴퓨터 usb연결시 정상 작동하나 9V건전지 외부전원 연결 시 작동하지 않는 문제댓글[3] 이미지첨부파일 보겐을운용 22-05-19 185
질문 온도센서로 서보모터 제어 코딩댓글[1] 진수네1조 22-05-18 67
질문 아두이노 우노 2개와 앱인벤터끼리의 블루투스 통신 방법댓글[3] 이미지첨부파일 pyoleo 22-05-17 114
