질문게시판 > 답변 : 답변 : 안녕하세요 썜avr128
TODAY456 TOTAL2,162,297
BASIC4MCU | 질문게시판 | 답변 : 답변 : 안녕하세요 썜avr128
작성자 master 작성일2019-11-27 17:12 조회3,038회 댓글0건
#include
#include
#include
unsigned char SEG[12]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x83};
unsigned char C[3]={0b00000001,0b00000010,0b00000100};
unsigned char R[5]={0b00000000,0b00000001,0b00000010,0b00000100,0b00001000};
unsigned char A[]={0xff,0xff,0xff,0xff,0b11111110,0b11111101,0b11111011,0b11110111};
unsigned int RESULT[4]={0,0,0,0};
unsigned int G[7]={ };
unsigned char n;
char num;
int Gap[7]={ };
int isr;
int a,p,y,t;
int u=0;
int start;
int sec1,sec10,min1,min10;
int s=0;
int loop;
ISR(INT4_vect){ //덧셈
  start=0;
  isr=0;
  for(int g=0; g;>
    isr+=G[g];
  Unit(0);
ISR(INT5_vect){ //곱셈
  start=0;
  int sum=0;
  int isr=1;
  for(int g=0; g;>
  isr*=G[g]; }
  sum=isr%10000;
  A[3]=SEG[sum/1000]; //1000의 자리
  A[2]=SEG[(sum%1000)/100]; //100의자리
  A[1]=SEG[((sum%1000)%100)/10]; //10의자리
  A[0]=SEG[((sum%1000)%100)%10]; //1의자리
ISR(INT6_vect){ //최소
  start=0;
  isr=G[0];
  for(int g=0; g;>
    if(G[g])isr=g[g];<>
  Unit(0);
ISR(INT7_vect){
  start=0;
  isr=0;
  for(int g=0; g;>
    if(G[g]>isr)isr=G[g];
Unit(0); }
ISR(INT_vect){
  start=1;
void TimerDisplay(){ //Timer/Counter Display
  A[0]=SEG[sec1];
  A[1]=SEG[sec10];
  A[2]=SEG[min1];
  A[3]=SEG[min10];
ISR(TIMER0_OVF_vect){
  if(loop<100)
  loop++;
    loop=0;
    sec1++;
    if(sec1>=10){ //second
      sec10++;
      sec1=sec1%10;
    if(sec10>=6){
      min1++;
      sec10=sec10%6;
      sec1=sec1%10;
    if(min1>=10){
      min10++;
      min1=min1%10;
      sec10=sec10%6;
      sec1=sec1%10;
  TCNT0=112;
char Keypad(){
  char n=0xff;
  PORTC=0b00000001;
  _delay_ms(1);
  if((PINC&0xf0)==0b000100000){
    n=SEG[1];
  else if((PINC&0xf0)==0b00100000){
    n=SEG[4];
  else if((PINC&0xf0)==0b01000000){
    n=SEG[7];
  else if((PINC&0xf0)==0b10000000){
    for(int i=0; i<4; i++)
    A[i]=0xff; //잘못 입력했을 때를 대비하여*누르면 세그먼트값 모두 지우기
  PORTC=0b00000010;
  _delay_ms(1);
  if((PINC&0xf0)==0b00010000){
    n=SEG[2];
    n=SEG[5];
    n=SEG[8];
  else if((PINC&0xf0)==0b1000000){
    n=SEG[0];
  PORTC=0b00000100;
  _delay_ms(1);
    n=SEG[3];
    n=SEG[6];
    n=SEG[9];
    G[u++]=StoreNumber();
    A[i]=0xff; //#이 눌러짐을 확인하기 위해 눌러지면 세그먼트 불 모두 소등
  return n;
int main(){
  DDRA=0xff;
  DDRB=0xff;
  DDRC=0x0f;
  DDRE=0x00; // PORTE의 4~7입력
  PORTE=0xf0; // PORTE의 4~7풀업
  DDRF=0x00; // PORTF0입력
  PORTF=0x01; // PORTF 0 풀업
  EIMSK=0b11110001; // INT4~7,0 인터럽트 인에이블
  EICRB=0b10101010; // INT4~7 하강에지
  EICRA=0b10101010; // INT0 하강에지
  SREG=0x80; // 전역 인터럽트 인에이블
  TCCR0=0b00000111;
  TCNT0=112;
  TIMSK=0b00000001;
    NumberInput();
    if(start==1)
    TimerDisplay(); // start값이 1일 때(INT0이 걸렸을 때)display호출
void NumberInput(){
  char temp;
  num=Keypad(); // Keypad함수의 반환값인 SEG배열을 num에 대입
  if(num!=0xff){
    A[3]=A[2];
    _delay_ms(10);
    A[2]=A[1];
    _delay_ms(10);
    A[1]=A[0];
    _delay_ms(10);
    A[0]=num;
    _delay_ms(10);
  } //세그먼트위에서 값을 왼쪽으로 시프트 시켜줌
  a=0;
  temp=0xfe;
  for(int i=0; i<100; i++){
    PORTB=temp;
    PORTA=A[a++]; // 세그먼트에 입력한 숫자 차례로 출력
    _delay_ms(1);
    temp=(temp<<1)|1; //세그먼트를 오른쪽에서 왼쪽으로 차례로 하나씩 점등
    if(a>3)a=0;
    if(temp==0xef)
    temp=0xfe; //세그먼트를 PORTB 0~3만 이용했으므로 4로 넘어가면 다시 오른쪽 제어
    _delay_ms(1);
int StoreNumber(void){
  int v[4];
  for(int h=0; h<4; h++){
    RESULT[h]=A[h]; //RESULT배열에 세그먼트에 나타난 숫자를 차례로 대입이 때 대입되는 값은 정수가 아닌 A배열의 값.
    for(int n=0; n<10; n++){
      if(RESULT[h]==SEG[n])v[h]=n; //A배열의 값이 대입되어 있기 떄문에 이를 정수로 바꿔주는 작업
      else if(RESULT[h]==0Xff)v[h]=0; //만약 아무 입력이 없다면 0 이라는 숫자로 취급
    y=(v[3]*1000)+(v[2]*100)+(v[1]*10)+(v[0]); //자릿수에 맞게 세그먼트 각자의 숫자를 하나의 숫자로 계산
  return y;
void ReadNum(){
  for(int g=0; g;>
    Gap[g]=G[g]; // 입력받은 4개의 값을 Gap 배열에 차례로 대입
void Unit(int sum){
  sum=isr%10000;
  A[3]=SEG[sum/1000];
147*2580 전혀 먹통이고 369#누르면 사진과같이 숫자 3333 만 세그먼트에 뜹니다..
스위치도 먹통입니다.
<답변>
우선,,,스위치 회로도가 엉터리입니다.
풀다운 저항이 무엇인지도 모르는 사람이 책을 썻나봅니다.
소스에서는 내부 풀업저항을 사용하고 있으므로 풀업 또는 풀다운 저항 둘 중의 하나로 회로를 구성해야합니다.
현재 동작하더라도 정상적인 회로구성이 아닙니다.
포트A에는 전류제한용 저항을 사용해야 합니다.
저대로 사용하면 포트A가 고장납니다.
역시..실력이 부족한 사람이 맞군요.
ISR(INT_vect){ start=1; }
ISR(INT0_vect){ start=1; }
인터럽트0 함수명은 오류가 있습니다.
  if     ((PINC&0xf0)==0b000100000){ n=SEG[1]; }
  if     ((PINC&0xf0)==0b00010000){ n=SEG[1]; }
여기도 오류가 있군요
// DateTime : 2019-11-27 오후 5:10:01
#include <avr/io.h>
#include <util/delay.h>
#include <avr/interrupt.h>
unsigned char C[3]={1,2,4};
unsigned char R[5]={0,1,2,4,8};
unsigned char A[]={0xff,0xff,0xff,0xff,~1,~2,~4,~8};
unsigned char n;
unsigned int  G[7];
char num;
int  Gap[7];
int  isr=0,a,p,y,t,u=0,start,sec1,sec10,min1,min10,s=0,loop;
  int v[4];
  for(int h=0h<4h++){
    RESULT[h]=A[h];
    for(int n=0n<10n++){
  return y;
char Keypad(){
  char n=0xff;
  PORTC=1_delay_us(1);
  if     (PINC&0x10){ n=SEG[1]; }
  else if(PINC&0x20){ n=SEG[4]; }
  else if(PINC&0x40){ n=SEG[7]; }
  PORTC=2_delay_us(1);
  if     (PINC&0x10){ n=SEG[2]; }
  else if(PINC&0x20){ n=SEG[5]; }
  else if(PINC&0x40){ n=SEG[8]; }
  else if(PINC&0x80){ n=SEG[0]; }
  PORTC=4_delay_us(1);
  if     (PINC&0x10){ n=SEG[3]; }
  else if(PINC&0x20){ n=SEG[6]; }
  else if(PINC&0x40){ n=SEG[9]; }
  else if(PINC&0x80){
    for(int i=0i<4i++)A[i]=0xff//#
  return n;
void NumberInput(){
  char temp=0xfe;
  a=0;
  num=Keypad();
  if(num!=0xff){
    A[3]=A[2]; A[2]=A[1]; A[1]=A[0]; A[0]=num;
    while(Keypad()!=0xFF); // key에서 손을 뗄 때까지 대기
  for(int i=0i<100i++){
    PORTB=tempPORTA=A[a++]; _delay_ms(1);
    temp=(temp<<1)|1if(a>3)a=0if(temp==0xef)temp=0xfe_delay_ms(1);
void ReadNum(){
  for(int g=0g<ug++)Gap[g]=G[g]; // 입력받은 4개의 값을 Gap 배열에 차례로 대입
void Unit(int sum){
  sum=isr%10000;
  A[3]=SEG[sum/1000%10];
  A[2]=SEG[sum/100%10];
  A[1]=SEG[sum/10%10];
  A[0]=SEG[sum%10];
  start=0isr=0;
  for(int g=0g<ug++){ isr+=G[g]; }
  Unit(0);
  int sum=0,isr=1;
  start=0;
  for(int g=0g<ug++){ isr*=G[g]; }
  sum=isr%10000;
  A[3]=SEG[sum/1000];
  start=0isr=G[0];
  for(int g=0g<ug++){ if(G[g]<isr)isr=G[g]; }
  Unit(0);
ISR(INT7_vect){
  start=0isr=0;
  for(int g=0g<ug++){ if(G[g]>isr)isr=G[g]; }
  Unit(0);
  A[0]=SEG[sec1]; A[1]=SEG[sec10]; A[2]=SEG[min1]; A[3]=SEG[min10];
  TCNT0=112;
  if(++loop>99){ loop=0;
    if(++sec1>9){ sec1=0//second
      if(++sec10>5){ sec10=0;
        if(++min1>=10){ min1=0if(++min10>5)min10=0; }
int main(){
  DDRA=0xff;  DDRB=0xff;  DDRC=0x0FPORTE=0xf0PORTF=0x01;
  TCNT0=112;  TCCR0=0x07TIMSK=0x01;
  EICRA=0xAAEICRB=0xAAEIMSK=0xF1// INT0, INT4~7 하강에지
  SREG=0x80;
    NumberInput();
    if(start==1)TimerDisplay(); // start값이 1일 때(INT0이 걸렸을 때)display호출
147*2580 전혀 먹통이고 369#누르면 사진과같이 숫자 3333  세그먼트에 뜹니다..
스위치도 먹통입니다.
  if(num!=0xff){
키를 눌렀을 경우, key에서 손을 뗄 때까지 대기하는 코드를 추가했습니다.
조금만 복잡해도 생각한대로 동작하지 않습니다.
차근 차근 하나씩 버그를 찾아서 수정하세요
복잡한 코드는 남이 도와주지 못합니다.
스스로 해결해야하죠
조회수 3,038
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 9627
공지 사이트 이용 안내댓글[24] master 17-10-29 29625
질문 아두이노 블루투스 통신 관련 질문 있습니다!! 새글 블루툿 10:51 4
질문 아두이노 DRV2605 헵틱 모터 드라이버댓글[1] 새글 gano 08:43 17
질문 아두이노 블루투스(hc-06)사용중 질문있습니다. 새글첨부파일 띵꽁 22-05-20 20
답변 답변글 답변 : 아두이노 블루투스(hc-06)사용중 질문있습니다. 새글 master 09:52 13
질문 ATmega128 진동센서 코딩 질문입니다.댓글[5] 새글 444222a 22-05-20 23
질문 atmega128 서보모터와 초음파센서댓글[5] 새글 tmiae 22-05-20 27
질문 컴퓨터 usb연결시 정상 작동하나 9V건전지 외부전원 연결 시 작동하지 않는 문제댓글[3] 이미지새글첨부파일 보겐을운용 22-05-19 158
질문 아트메가 모터드라이브와 초음파 센서 연동 질문입니다댓글[1] 123424135123q 22-05-19 35
질문 아두이노 우노 2개와 앱인벤터끼리의 블루투스 통신 방법댓글[3] 이미지첨부파일 pyoleo 22-05-17 106
질문 리니어 레일 거리 조절댓글[1] 면수 22-05-16 66
