질문게시판 > 진동모터 작동
TODAY228 TOTAL2,698,033
BASIC4MCU | 질문게시판 | 진동모터 작동
작성자 아두에듀잉 작성일2019-11-28 17:38 조회7,152회 댓글0건
색상값이 R,G값이 95이상이면 진동모터를 작동시키고싶은데 진동모터가 작동하지않아서 코드의 문제가있나싶어서 질문드립니다.
#include <Wire.h>
#include "Adafruit_TCS34725.h"
// Pick analog outputs, for the UNO these three work well
// use ~560  ohm resistor between Red & Blue, ~1K for green (its brighter)
#define motor 7
#define redpin 3
#define greenpin 5
#define bluepin 6
// for a common anode LED, connect the common pin to +5V
// for common cathode, connect the common to ground
// set to false if using a common cathode LED
#define commonAnode true
// our RGB -> eye-recognized gamma color
byte gammatable[256];
Adafruit_TCS34725 tcs = Adafruit_TCS34725(TCS34725_INTEGRATIONTIME_50MS, TCS34725_GAIN_4X);
  //Serial.println("Color View Test!");
  if (tcs.begin()) {
    //Serial.println("Found sensor");
  } else {
    Serial.println("No TCS34725 found ... check your connections");
    while (1); // halt!
  // use these three pins to drive an LED
#if defined(ARDUINO_ARCH_ESP32)
  ledcAttachPin(redpin, 1);
  ledcSetup(1, 12000, 8);
  ledcAttachPin(greenpin, 2);
  ledcSetup(2, 12000, 8);
  ledcAttachPin(bluepin, 3);
  ledcSetup(3, 12000, 8);
#else
  pinMode(redpin, OUTPUT);
  pinMode(greenpin, OUTPUT);
  pinMode(bluepin, OUTPUT);
  pinMode(motor, OUTPUT);
#endif
  // thanks PhilB for this gamma table!
  // it helps convert RGB colors to what humans see
  for (int i=0; i<256; i++) {
    float x = i;
    x /= 255;
    x = pow(x, 2.5);
    x *= 255;
    if (commonAnode) {
      gammatable[i] = 255 - x;
    } else {
      gammatable[i] = x;
    //Serial.println(gammatable[i]);
// The commented out code in loop is example of getRawData with clear value.
// Processing example colorview.pde can work with this kind of data too, but It requires manual conversion to
// [0-255] RGB value. You can still uncomments parts of colorview.pde and play with clear value.
  if(redpin & greenpin > 95)
    digitalWrite(motor,HIGH);
  }else
    digitalWrite(motor,LOW);
  }delay(100);
  float red, green, blue;
  tcs.setInterrupt(false);  // turn on LED
  delay(60);  // takes 50ms to read
  tcs.getRGB(&red, &green, &blue);
  tcs.setInterrupt(true);  // turn off LED
  Serial.print("R:\t"); Serial.print(int(red));
  Serial.print("\tG:\t"); Serial.print(int(green));
  Serial.print("\tB:\t"); Serial.print(int(blue));
//  Serial.print("\t");
//  Serial.print((int)red, HEX); Serial.print((int)green, HEX); Serial.print((int)blue, HEX);
  Serial.print("\n");
//  uint16_t red, green, blue, clear;
//  tcs.setInterrupt(false);  // turn on LED
//  delay(60);  // takes 50ms to read
//  tcs.getRawData(&red, &green, &blue, &clear);
//  tcs.setInterrupt(true);  // turn off LED
//  Serial.print("C:\t"); Serial.print(int(clear));
//  Serial.print("R:\t"); Serial.print(int(red));
//  Serial.print("\tG:\t"); Serial.print(int(green));
//  Serial.print("\tB:\t"); Serial.print(int(blue));
//  Serial.println();
  ledcWrite(1, gammatable[(int)red]);
  ledcWrite(2, gammatable[(int)green]);
  ledcWrite(3, gammatable[(int)blue]);
#else
  analogWrite(redpin, gammatable[(int)red]);
  analogWrite(greenpin, gammatable[(int)green]);
  analogWrite(bluepin, gammatable[(int)blue]);
#endif
조회수 7,152
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 19826
공지 사이트 이용 안내댓글[28] master 17-10-29 34162
질문 압력센서에 따른 진동모터를 버튼으로 제어 회로도 질문 새글 도와주세용용 23-06-07 19
질문 아두이노 리니어 제어 모듈 설계중입니다. 도와주세요 새글 갓비타 23-06-06 17
답변 답변글 답변 : 아두이노 리니어 제어 모듈 설계중입니다. 도와주세요 새글 master 23-06-07 13
질문 dc모터 제어 관련 질문 드려요 ㅠㅠ!!댓글[2] 새글 dpwl 23-06-06 27
답변 답변글 답변 : dc모터 제어 관련 질문 드려요 ㅠㅠ!! 새글 master 23-06-07 15
질문 pixy2 cam 을 이용한 색상인식 모터 제어댓글[1] 가나다라 23-06-05 15
질문 안녕하세요 제품 품목 이름에 대해서 궁금합니다. 이미지첨부파일 알려주시면감사합니다 23-06-05 19
질문 Atmega128 온도센서로 led제어 질문드려요댓글[1] 이미지첨부파일 얍얍 23-06-05 27
질문 아구이노 코드를 atmega 128 코드로 변환 하고 싶습니다 ㅠㅠ댓글[1] 기로롱 23-06-05 26
질문 atmega128 uart 질문입니다.댓글[1] bme12 23-06-05 32
질문 라즈베리파이에 풀 프레임 이미지센서 활용에 대한 질문이 있습니다.댓글[1] 이미지첨부파일 KYLO 23-06-04 21
질문 아두이노 시리얼 번호를 이용해 led 제어 wnion 23-06-04 22
답변 답변글 답변 : 아두이노 시리얼 번호를 이용해 led 제어 새글 master 23-06-07 11
질문 ATMEGA128 혹시 여기서 왜 인터럽트 기능이 안되는지 알 수 있나요댓글[1] IEEE 23-06-04 35
질문 stm32f767을 이용해서 자이로가속도 센서의 값 받아오기댓글[1] rlchwjswk 23-06-03 24
질문 아두이노 모터제어 관련해서 질문드립니다!댓글[1] 이미지첨부파일 아두이노어렵잖아 23-06-03 47
질문 atmega128 디지털 조도 센서댓글[1] 까미 23-06-02 43
질문 적외선리모콘으로 부저를제어 하는방법 질문입니다.댓글[4] Tell 23-06-02 27
질문 lora 무선 모듈에 관한 질문입니다.댓글[1] 로이스10 23-06-01 24
질문 스텝모터 제어 코드 질문댓글[6] pmh11 23-05-31 49
질문 초음파 센서를 이용한 인원 카운팅댓글[1] 초음파야 23-05-31 41
질문 모터 Hall 스위치 연결 문의댓글[1] 오후 23-05-31 29
질문 아두이노 lcd 문자 스크롤디스플레이 wnion 23-05-31 38
답변 답변글 답변 : 아두이노 lcd 문자 스크롤디스플레이댓글[1] master 23-05-31 36
답변 답변글 답변 : 아두이노 타이머 인터럽트댓글[8] master 23-05-30 61
