프로세싱 질문도 답변해주시나요..?? 부탁드립니다ㅠㅠ
작성자 kher 작성일19-12-01 15:30 조회11,680회 댓글3건본문
예제를 찾아서 참고하면서 프로세싱 하려고 하는데 이해가 안되는 부분이 있어서요. 해석 부탁드릴 수 있을까요???
int start_range_flag=0;
float firebullet_x[]=new float[30];
float firebullet_y[]=new float[30];
float enemy_rect[][]=new float[5][200];
int bullet_num=1;
int enemy_num=50;
int timeCount=0;
float die_mousex=-20;
float die_mousey=-20;
int die_enemy_num=0;
int die_timeCount=0;
int a=0;
int b=0;
int c=0;
int bomb_flag=0;
int bomb_count=0;
int B_circle_max_flag=0;
int bomb_ea=1;
float B_distance=0;
int frame_animator_count=0;
int final_location=0;
float speed=0;
float x_speed=0;
float y_speed=0;
float tracking_value_x=0;
float tracking_value_y=0;
int frameconstant=300;
int change_positon_flag=0;
int game_end_flag=1;
String time="d";
//color
color light_red=color(244,57,36);
color light_blue=color(36,214,244);
size(1000,600);
frameRate(frameconstant);
enemy_rect[0][0]=-20;
enemy_rect[0][1]=-20;
void draw()
background(0,0,0);
if(game_end_flag==1)
cursor();
textAlign(CENTER);
if(mouseX>330 && mouseX<470)
if(mouseY>460 && mouseY<510)
start_range_flag=1;
start_range_flag=0;
start_range_flag=0;
if(start_range_flag==1)
textSize(60);
textSize(40);
text("START",400,500);
noCursor();
//enemy_circle
//enemy_generator_code
//enemy incresed
if(frameCount%frameconstant==0 && game_end_flag==0)//when every second, will create new enemy
enemy_num++;
if(game_end_flag==0)
for(int i=0; i<enemy_num;i++)
if(enemy_rect[0][i]<=0 || enemy_rect[0][i]>1000)
change_positon_flag=1;
if(enemy_rect[1][i]<=0 || enemy_rect[1][i]>600)
if(change_positon_flag==1)
//upper
if(i%4==0)
enemy_rect[0][i]=(int)random(0,800);
enemy_rect[1][i]=0;
enemy_rect[4][i]=enemy_rect[0][i];
//below
if(i%4==1)
enemy_rect[1][i]=590;
enemy_rect[4][i]=1400+enemy_rect[0][i];
//left
if(i%4==2)
enemy_rect[0][i]=0;
enemy_rect[1][i]=(int)random(0,600);
enemy_rect[4][i]=2200+enemy_rect[1][i];
//right
if(i%4==3)
enemy_rect[0][i]=790;
enemy_rect[4][i]=800+enemy_rect[1][i];
//enemy_speed
speed=(float)random(0.2,1); //speed
x_speed=sqrt((float)random(pow(speed,2)/5,pow(speed,2)/1.5));
y_speed=sqrt(pow(speed,2)-pow(x_speed,2));
//enemy_direction
if(enemy_rect[4][i]>=0 && enemy_rect[4][i]<400)
{//upper_L
enemy_rect[2][i]=x_speed;
enemy_rect[3][i]=y_speed;
if(enemy_rect[4][i]>=400 && enemy_rect[4][i]<800)
{//upper_R
enemy_rect[2][i]=-x_speed;
if(enemy_rect[4][i]>=800 && enemy_rect[4][i]<1100)
{//right_up
if(enemy_rect[4][i]>=1100 && enemy_rect[4][i]<1400)
{//right_down
enemy_rect[3][i]=-y_speed;
if(enemy_rect[4][i]>=1400 && enemy_rect[4][i]<1800)
{//below_right
if(enemy_rect[4][i]>=1800 && enemy_rect[4][i]<2200)
{//below_left
if(enemy_rect[4][i]>=2200 && enemy_rect[4][i]<2500)
if(enemy_rect[4][i]>=2500 && enemy_rect[4][i]<2800)
//when your triangle were crashed, game end.
for(int i=0;i<enemy_num;i++)
//enemy_rect crash
if(mouseX-5<enemy_rect[0][i]+5 && enemy_rect[0][i]+5<mouseX+5)
if(mouseY-5<enemy_rect[1][i]+5 && enemy_rect[1][i]+5<mouseY+5)
game_end_flag=1;
die_mousex=mouseX;
die_mousey=mouseY;
die_enemy_num=i;
die_timeCount=timeCount;
//final_rect crash
if(mouseX>final_location && mouseX< final_location+200)
if(mouseY<600 && mouseY>600+c)
game_end_flag=1;
die_mousex=mouseX;
die_mousey=mouseY;
c=0;
final_location=0;
//Air_plane?
fill(light_blue);
triangle(mouseX-10,mouseY+10,mouseX+0,mouseY-10,mouseX+10,mouseY+10);
fill(light_red);
rect(mouseX-5,mouseY-2.5,10,10);
triangle(die_mousex-10,die_mousey+10,die_mousex+0,die_mousey-10,die_mousex+10,die_mousey+10);
fill(light_red);
rect(die_mousex-5,die_mousey-2.5,10,10);
//enemy_tracking and drawing
if(mouseX>enemy_rect[0][i])
tracking_value_x=mouseX-enemy_rect[0][i]+50;
tracking_value_x=-((-mouseX)+enemy_rect[0][i]+50);
if(mouseY>enemy_rect[1][i])
tracking_value_y=mouseY-enemy_rect[1][i]+50;
tracking_value_y=-((-mouseY)+enemy_rect[1][i]+50);
if((i%10)==0)//enemy_tracker
fill(100,100,255);
if(tracking_value_x<100 && tracking_value_x>-100)
enemy_rect[2][i]=+tracking_value_x/400;
if(tracking_value_y<100 && tracking_value_y>-100)
enemy_rect[3][i]=+tracking_value_y/400;
//code will regenerate tracker,when more two trackers were crashed
for(int j=1;i+10*j<100;j++)
if(abs(enemy_rect[0][i]-enemy_rect[0][i+10*j])<7 && abs(enemy_rect[1][i]-enemy_rect[1][i+10*j])<7 )
enemy_rect[0][i+10*j]=-10000;
enemy_rect[1][i+10*j]=-10000;
enemy_rect[0][i]=enemy_rect[0][i]+enemy_rect[2][i];
enemy_rect[1][i]=enemy_rect[1][i]+enemy_rect[3][i];
fill(120,120,120);
enemy_rect[0][i]=enemy_rect[0][i]+enemy_rect[2][i]+tracking_value_x/5000;
enemy_rect[1][i]=enemy_rect[1][i]+enemy_rect[3][i]+tracking_value_y/5000;
rect(enemy_rect[0][i],enemy_rect[1][i],10,10);
fill(120,120,120);
rect(enemy_rect[0][die_enemy_num],enemy_rect[1][die_enemy_num],10,10);
//TEST CODE
//velocity_view
fill(255,255,255);
textSize(10);
text(enemy_rect[2][enemy_num-1],100,300);
text(enemy_rect[3][enemy_num-1],100,315);
text(enemy_num,110,330);
//rect_[?][0]_information_view
text(enemy_rect[0][0],100,340);
text(enemy_rect[1][0],100,350);
text(tracking_value_x,100,370);
text(frameCount,100,390);
void mousePressed()
if(mouseButton==LEFT) //When mousebutton was pressed, fire bullet such as ellipse)
firebullet_x[bullet_num]=mouseX;
firebullet_y[bullet_num]=mouseY-7;
bullet_num++;
if(bullet_num==20)
bullet_num=0;
frame_animator_count=(int) frameconstant/5;
if(mouseButton==RIGHT)//bomb
bomb_flag=1;
if(start_range_flag==1 && game_end_flag==1 && mouseButton==LEFT)//game start
game_end_flag=0;
timeCount=0;
enemy_num=50;
bomb_ea=1;
for(int i=0; i<200; i++)
for(int j=0; j<5; j++)
enemy_rect[j][i]=0;
댓글 : 3
조회수 : 11,680
프로세싱을 돌려본 적이 없으니 프로세싱에 대해서는 답변을 해드리지 못하며
c문법이 막히는 부분이 있으면 설명을 해드릴 수는 있지만
시간 상 전체 해석은 못 해드립니다.
kher님의 댓글
kher
혹시 enemy_rect[][] 이부분이 뭘 의미하는지는 알수없을까요...??
c문법만 보면 이중 배열입니다.
코드상에서의 역할은 전체 내용을 검토해야 하므로 설명해드리기 어렵습니다.
예제를 올린 사이트의 설명글도 읽어야하고, 동작을 시켜서 동작 상태도 봐야합니다.
프로젝트를 진행하는 분의 몫이죠
