질문게시판 > 소스코드 합치는 방법좀 알려주세요 ...
TODAY675 TOTAL2,165,174
BASIC4MCU | 질문게시판 | 소스코드 합치는 방법좀 알려주세요 ...
작성자 구슬박은놈 작성일2019-12-06 12:57 조회4,246회 댓글1건
첨부파일
#include <U8glib.h>
#include <Adafruit_Sensor.h>
#include <DHT.h>
#include <DHT_U.h>
#include <Wire.h>
#include "RTClib.h"
#include "MQ131.h"
#include "MQ7.h"
// 0.96인치 128x64 OLED
U8GLIB_SSD1306_128X64 u8g(U8G_I2C_OPT_NONE);  // I2C / TWI
 MQ7 mq7(A12,5.0);
// Setup RTC
  RTC_DS3231 RTC;
  int  monthIndex[122] ={0,3,6,9,12,15,18,21,24,27,30,33};
  String thisMonth = "";
  String thisTime = "";
  String thisDay="";
// DHT22 온도/습도 센서
#define DHTPIN            22         // Pin which is connected to the DHT sensor.
#define DHTTYPE           DHT11     // DHT 22 (AM2302)
DHT_Unified dht(DHTPIN, DHTTYPE);
uint32_t dht22DelayMS = 0;
//온도 이미지삽입
const uint8_t temp[] PROGMEM = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xFF,
0x07, 0xFF, 0xC0, 0x07, 0xFF, 0x87, 0xFF, 0xC0, 0x07, 0x01, 0xC7, 0x00, 0x00, 0x07, 0x01, 0xC7,
0x00, 0x00, 0x07, 0xFF, 0xC7, 0x00, 0x00, 0x07, 0xFF, 0x87, 0x00, 0x00, 0x01, 0xFF, 0x07, 0xFF,
0xC0, 0x00, 0x38, 0x07, 0xFF, 0xC0, 0x0F, 0xFF, 0xC0, 0x38, 0x00, 0x0F, 0xFF, 0xC0, 0x38, 0x00,
0x07, 0x00, 0x00, 0x38, 0x00, 0x07, 0x00, 0x00, 0x38, 0x00, 0x07, 0x00, 0x00, 0x38, 0x00, 0x07,
0xFF, 0xCF, 0xFF, 0xC0, 0x07, 0xFF, 0xCF, 0xFF, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
//습도 이미지삽입
const uint8_t hum[] PROGMEM = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFC, 0x07, 0xFF, 0xC0, 0x01, 0xFE,
0x07, 0xFF, 0xC0, 0x01, 0xCF, 0x07, 0x00, 0x00, 0x03, 0xC7, 0x87, 0x00, 0x00, 0x07, 0x83, 0xC7,
0x00, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x0F, 0xFF, 0xC7, 0xFF, 0xC0, 0x0F, 0xFF, 0xC7, 0xFF,
0xC0, 0x00, 0x00, 0x00, 0x38, 0x00, 0x07, 0x03, 0xC0, 0x38, 0x00, 0x07, 0xFF, 0xC0, 0x38, 0x00,
0x07, 0xFF, 0xC0, 0x38, 0x00, 0x07, 0x03, 0xC0, 0x38, 0x00, 0x07, 0xFF, 0xCF, 0xFF, 0xC0, 0x07,
0xFF, 0xCF, 0xFF, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  Wire.begin();
  RTC.begin();
  dht.begin();
 Serial.begin(115200);
  MQ131.begin(2,A8, LOW_CONCENTRATION, 10000);
  Serial.println("Calibration in progress...");
  MQ131.calibrate();
  Serial.println("Calibration done!");
  Serial.print("R0 = ");
  Serial.print(MQ131.getR0());
  Serial.println(" Ohms");
  Serial.print("Time to heat = ");
  Serial.print(MQ131.getTimeToRead());
  Serial.println(" s");
  sensor_t sensor;
  dht.temperature().getSensor(&sensor);
  dht22DelayMS = sensor.min_delay / 1000;
  float temperature;
  float humidity;
 Serial.println("Sampling...");
  MQ131.sample();
  Serial.print("Concentration O3 : ");
  Serial.print(MQ131.getO3(PPM));
  Serial.println(" ppm");
  Serial.print(MQ131.getO3(PPB));
  Serial.println(" ppb");
  Serial.print(MQ131.getO3(MG_M3));
  Serial.println(" mg/m3");
  Serial.print(MQ131.getO3(UG_M3));
  Serial.println(" ug/m3");
  Serial.print("Concentration MQ7B : ");
  Serial.println(mq7.getPPM());
  getDHT11Data(&temperature, &humidity);
  u8g.firstPage();
  do {
    draw(); //온도 습도 이미지 출력위해 삽입
    u8g.setFont(u8g_font_fub14);   //폰트지정
    u8g.setPrintPos(35, 35);
    u8g.print(": ");
    u8g.print(temperature);
    u8g.print("\xb0""C"); //온도기호삽입
    u8g.setPrintPos(35, 58);
    u8g.print(": ");
    u8g.print(humidity);
    u8g.print("%");
    delay(dht22DelayMS);
  } while(u8g.nextPage());
void draw(void) {
  // graphic commands to redraw the complete screen should be placed here
  u8g.setFont(u8g_font_7x13r);
  //***** RTC **********
  DateTime now = RTC.now();
  // display date at bottom of screen
  thisDay = String(now.day(), DEC) + "/";
  thisMonth= String(now.month(), DEC) + "/";
  thisDay=thisDay + thisMonth + String(now.year() , DEC);
  const char* newDay = (const char*) thisDay.c_str();
  u8g.drawStr(50,10, newDay);
  // display time in digital format
  thisTime="";
  if (now.hour() < 10){ thisTime="0"+ thisTime;} // add leading zero if required
  thisTime=thisTime + String(now.hour()) + ":";
  if (now.minute() < 10){ thisTime=thisTime + "0";} // add leading zero if required
  thisTime=thisTime + String(now.minute()); // + ":";
 // if (now.second() < 10){ thisTime=thisTime + "0";} // add leading zero if required
 // thisTime=thisTime + String(now.second());
  const char* newTime = (const char*) thisTime.c_str();
  u8g.drawStr(5,10, newTime);
  u8g.drawBitmapP(0, 14, 5, 24, temp); //온도글자위해삽입.0과 14는 좌표.5는 비트맵이미지 가로(40)/8. 24는 비트맵 세로픽셀
  u8g.drawBitmapP(0, 38, 5, 24, hum);  //습도글자위해삽입.0과 38는 좌표.5는 비트맵이미지 가로(40)/8. 24는 비트맵 세로픽셀
void getDHT11Data(float *temperature, float *humidity) {
  sensors_event_t event;
  dht.temperature().getEvent(&event);
  if(!isnan(event.temperature)) {
    *temperature = event.temperature;
  } else {
    *temperature = -1;
  // Get Humidity
  dht.humidity().getEvent(&event);
  if (!isnan(event.relative_humidity)) {
    *humidity = event.relative_humidity;
  } else {
    *humidity = -1;
위에 소스코드가 제가 나름대로 찾아보고 합친 소스코드입니다
컴파일 실행중에는 아무 오류없이 실행됩니다만... 실행결과가OLED 에표시되는 정보는 (온습도 , 현재시간 표시)  표시되지않고
  가스 센서 만 정상적으로 동작됩니다  어디서 뭐가 잘못된건지 알려주세요 ..! ㅜㅜ
(sketch _ nov27a.ino : oled에 현재 온습도와 시간 표시되는 코드
 GAS-Link _EX.ino : 가스센서 실행 코드 (MQ131, MQ7)
조회수 4,246
OLED 예제로 공부한 후에 합치세요
공지 사이트 이용 안내댓글[24] master 17-10-29 29689
질문 초음파+스텝모터 새글 도꺼비 22-05-22 14
답변 답변글 답변 : 초음파+스텝모터 새글 master 04:42 13
질문 아두이노 인터럽트 질문있습니다.댓글[1] 새글 띵꽁 22-05-22 24
답변 답변글 답변 : 아두이노 인터럽트 질문있습니다.댓글[3] 새글 master 22-05-22 18
질문 atmega128 스톱워치 작성 중 외부 인터럽트 관련 질문 드립니다.댓글[4] 이미지새글 마프하나 22-05-22 30
질문 서보모터제어 해당코드에서 어떤걸 추가해야할까요댓글[3] 이미지새글첨부파일 오소로롯 22-05-22 21
질문 아두이노 서보모터제어 하나도 모르겠습니다 ㅠ댓글[2] 이미지새글첨부파일 오소로롯 22-05-21 32
질문 아트메가 128 을 이용해서적외선 센서 코딩 중 물어볼게있습니다!!댓글[4] 새글 noster 22-05-21 27
질문 아두이노 블루투스 통신 관련 질문 있습니다!! 블루툿 22-05-21 27
답변 답변글 답변 : 아두이노 블루투스 통신 관련 질문 있습니다!! master 22-05-21 28
질문 아두이노 d1r2 W238 방수 초음파 센서댓글[1] 밤새아두이노 22-05-21 39
질문 아두이노 블루투스(hc-06)사용중 질문있습니다. 첨부파일 띵꽁 22-05-20 41
질문 아두이노 블루투스 통신댓글[1] 블루툿 22-05-20 41
질문 ATmega128 진동센서 코딩 질문입니다.댓글[5] 444222a 22-05-20 54
질문 아두이노 초음파센서 코딩 질문댓글[3] 이미지첨부파일 아두이노아린이 22-05-20 45
질문 atmega128 서보모터와 초음파센서댓글[5] tmiae 22-05-20 62
질문 avr compiler 종류 질문입니다!댓글[3] 민준싸 22-05-20 46
질문 컴퓨터 usb연결시 정상 작동하나 9V건전지 외부전원 연결 시 작동하지 않는 문제댓글[3] 이미지첨부파일 보겐을운용 22-05-19 329
질문 아두이노 dac 연결댓글[5] 이미지첨부파일 kodory 22-05-19 46
질문 아두이노 millis ->atmega128에서 사용하고 싶습니다. akmong413 22-05-19 47
답변 답변글 답변 : 아두이노 millis ->atmega128에서 사용하고 싶습니다.댓글[2] master 22-05-19 59
