질문게시판 > 코딩 질문이요
TODAY561 TOTAL2,162,402
BASIC4MCU | 질문게시판 | 코딩 질문이요
작성자 호롷홀 작성일2019-12-06 17:53 조회3,845회 댓글1건
const int Left_motor_back=8;   //(IN1)
const int Left_motor_go=9;     //(IN2)
const int Right_motor_go=10;   //(IN3)
const int Right_motor_back=11; //(IN4)
const int Echo=A1,trig=A0;
const int SensorRight=3,SensorLeft=4;
int servopin=2;//서보모터핀을 2번으로 설정
int myangle;//서보모터각도
int pulsewidth;//펄스폭 설정
int val;
int Front_Distance = 0;
int Left_Distance = 0;
int Right_Distance = 0;
int   SL,SR;
float duration,distance;
  pinMode(trig,OUTPUT);
  pinMode(Echo, INPUT);
  pinMode(servopin,OUTPUT);// 출력설정
void run(){
  analogWrite(Right_motor_go,100); analogWrite(Right_motor_back,0);
  analogWrite(Left_motor_go ,100); analogWrite(Left_motor_back ,0);
void brake(){
  analogWrite(Right_motor_go,0); analogWrite(Right_motor_back,0);
  analogWrite(Left_motor_go ,0); analogWrite(Left_motor_back ,0);
void left(){
  analogWrite(Left_motor_go ,  0); analogWrite(Left_motor_back ,0);
void spin_left(){
  analogWrite(Left_motor_go ,  0); analogWrite(Left_motor_back ,100);
void right(){
  analogWrite(Right_motor_go,  0); analogWrite(Right_motor_back,0);
void spin_right(){
  analogWrite(Right_motor_go,  0); analogWrite(Right_motor_back,100);
void back(int time){
  analogWrite(Right_motor_go,0); analogWrite(Right_motor_back,100);
  analogWrite(Left_motor_go ,0); analogWrite(Left_motor_back ,100);
  delay(time*100);
float Distance_test()   // 전방거리측정
  digitalWrite(trig, LOW);   // 트리거핀LOW 2μs
  delayMicroseconds(2);
  digitalWrite(trig, HIGH);  // 트리거핀HIGH 10μs
  delayMicroseconds(10);
  digitalWrite(trig, LOW);    // 트리거핀 LOW
  float Fdistance = pulseIn(Echo, HIGH);
  Fdistance= Fdistance/58;
  return Fdistance;
void servopulse(int servopin,int myangle) //서보모터를 각도만큼 회전
  pulsewidth=(myangle*11)+500;//각도를 500-2480 사이의 펄스값으로 변환
  digitalWrite(servopin,HIGH);//서보핀 HIGH
  delayMicroseconds(pulsewidth);//펄스폭만큼 딜레이
  digitalWrite(servopin,LOW);//서보핀 LOW
  delay(20-pulsewidth/1000);//남은 딜레이
void front_detection() //전방 장애물 감지
  for(int i=0;i<=5;i++)
    servopulse(servopin,90);//서보모터 PWM펄스 발생
  Front_Distance = Distance_test();
void left_detection()
  for(int i=0;i<=15;i++)
    servopulse(servopin,175);//서보모터 PWM펄스 발생
  Left_Distance = Distance_test();
void right_detection()
    servopulse(servopin,5);//서보모터 PWM펄스 발생(우측서보패닝)
  Right_Distance = Distance_test();
  digitalWrite(trig,HIGH); delayMicroseconds(10); digitalWrite(trig,LOW);
  duration=pulseIn(Echo,HIGH);
  distance=((float)(340*duration)/10000)/2;
  Serial.print("\nDIstance: "); Serial.println(distance);
  if(distance<20)brake(); // 장애물 20cm 이내발견되면 정지
  else{                   // 장애물 치웠을 때
    SR=digitalRead(SensorRight);
    SL=digitalRead(SensorLeft);
    if     (SL==HIGH &&SR==HIGH )run(); // 검정색 차선에 모두 반응했을때 전진
     if(SL==HIGH&&SR==LOW )left();  // 왼쪽만 검은색차선에 반응하면 좌회전
    else if(SL==LOW &&SR==HIGH)right(); // 오른쪽만 검은색차선에 반응하면 우회전
    else                       // 검은색 차선모두 인식하지 못했을때 초음파 거리 측정후 장애물 회피주행
    front_detection();//전방거리측정
    if(Front_Distance < 10)//전방 장애물 감지시
      back(2);//후진
      brake();//정지
      left_detection();//좌측거리측정
      right_detection();//우축거리측정
      if((Left_Distance < 15 ) &&( Right_Distance < 15 ))//좌우 양측에 장애물이 감지시
        spin_left();//방향전환시도
      else if(Left_Distance > Right_Distance)//좌측이 우측보다 공간여유가 있는 경우
        left();//좌회전
        brake();//정지
      else//우측이 좌측보다 공간여유가 있는 경우
        right();//우회전
        brake();//정지
      run(); //전방 장애물이 없는 경우 전진
//검정선을 따라가는 라인트레이서 기능과 라인트레이서중 장애물 발견시 정지 , 검은선이 끝낫을때 초음파 센서 활용하는 기능
//라인트레이서와 정지 기능은 가능하지만 검정선이 끝났을때 초음파기능이 불완전한 문제 서보모터가 계속 작동하며 전진및 좌회전 우회전이 불가능합니다
//코딩에 문제가 있는건가요??
조회수 3,845
검정색의 라인이 없으면
센서로 감지할 선이 없으니 좌회전 및 우회전을 할 수가 없는 것은 당연한겁니다.
알고리즘을 잘 만든 후에 작성하세요
공지 사이트 이용 안내댓글[24] master 17-10-29 29630
질문 아두이노 블루투스 통신 관련 질문 있습니다!! 새글 블루툿 10:51 12
질문 컴퓨터 usb연결시 정상 작동하나 9V건전지 외부전원 연결 시 작동하지 않는 문제댓글[3] 이미지새글첨부파일 보겐을운용 22-05-19 164
질문 아트메가 모터드라이브와 초음파 센서 연동 질문입니다댓글[1] 123424135123q 22-05-19 38
