질문게시판 > atmega 128 깔끔하게 정리 부탁드려요 ㅠㅠ
TODAY1,178 TOTAL2,163,019
BASIC4MCU | 질문게시판 | atmega 128 깔끔하게 정리 부탁드려요 ㅠㅠ
작성자 끵끵끵 작성일2019-12-10 17:17 조회5,424회 댓글1건
#include <io.h>
#include <delay.h>
unsigned char tccr0_set[24] = {31,30,30,30,30,30,30,30,29,29,29,29,29,29,29,28,28,28,28,28,28,28,28,27};
unsigned char ocr0_set[24] = {70,252,237,211,188,177,158,141,252,237,211,188,177,158,141,252,237,211,188,177,158,141,252,237};
unsigned char LED[24] = {0x04, 0x02, 0x80, 0x40, 0x20, 0x10, 0x08, 0x04, 0x02, 0x80, 0x40, 0x20, 0x10, 0x08, 0x04, 0x02, 0x80, 0x40, 0x20, 0x10, 0x08, 0x04, 0x02, 0x80};
typedef enum {la_0, si_0, do_1, re_1, mi_1, fa_1, sol_1, la_1, si_1, do_2, re_2, mi_2, fa_2, sol_2, la_2, si_2, do_3, re_3, mi_3, fa_3, sol_3, ra_3, si_3, do_4,F} melody_code;
typedef struct
     melody_code melody;
     float rhythm;
}   MUSIC_CODE;
#define LENGTH1 42
const MUSIC_CODE sheet1[] =
    {do_2, 1}, {do_2, 1}, {sol_2, 1}, {sol_2, 1}, {la_2,1}, {la_2, 1}, {sol_2, 2},    //반짝반짝 작은별
    {fa_2, 1}, {fa_2, 1}, {mi_2, 1}, {mi_2, 1}, {re_2,1}, {re_2, 1}, {do_2, 2},   //아름답게 비치네
    {sol_2, 1}, {sol_2, 1},{fa_2, 1}, {fa_2, 1}, {mi_2, 1}, {mi_2, 1}, {re_2,2},  //동쪽 하늘 에서도
    {sol_2, 1}, {sol_2, 1},{fa_2, 1}, {fa_2, 1}, {mi_2, 1}, {mi_2, 1}, {re_2,2},  //서쪽 하늘 에서도
#define LENGTH2 49
const MUSIC_CODE sheet2[] =
     {do_2,1}, {do_2, 0.5}, {do_2, 0.5}, {do_2, 1}, {do_2, 1},  //곰세마리가
    {mi_2, 1}, {sol_2, 0.5}, {sol_2, 0.5}, {mi_2, 1}, {do_2, 1},   //한 집에 있어
    {sol_2, 0.5}, {sol_2, 0.5}, {mi_2, 1},  {sol_2, 0.5}, {sol_2, 0.5}, {mi_2, 1},{do_2, 1},{do_2 ,1},{do_2,2},// 아빠곰 엄마곰 애기곰
    {sol_2, 1}, {sol_2, 1},{mi_2, 1}, {do_2, 1}, {sol_2, 1}, {sol_2, 1}, {sol_2, 2}, //아빠곰은 뚱뚱해
    {sol_2, 1}, {sol_2, 1},{mi_2, 1}, {do_2, 1}, {sol_2, 1}, {sol_2, 1}, {sol_2, 2}, //엄마곰은 날씬해
    {sol_2, 1}, {sol_2, 1},{mi_2, 1}, {do_2, 1},{sol_2, 0.5}, {sol_2, 0.5}, {sol_2, 0.5}, {la_2, 0.5}, {sol_2, 2},  //애기곰은 너무귀여워
    {do_3, 1}, {sol_2, 1}, {do_3, 1}, {sol_2, 1}, {mi_2,1}, {re_2, 1}, {do_2, 2}   //으쓱 으쓱 잘한다
unsigned char USART0_GetChar()
    while ((UCSR0A & (1 << RXC0) )== 0);
    if((UCSR0A & (1 << FE0)) || (UCSR0A & (1 << UPE0)))
    return (0);
    return (UDR0);
void USART0_PutChar(unsigned char ch)
    while ((UCSR0A & (1 << UDRE0)) == 0);
    UDR0 = ch;
void USART0_PutStr(char *str)
 int n = 0;
 while ( 1 )
        if ( str[n] == 0 )
        USART0_PutChar(str[n++]);
void SetTone (unsigned char n)
    TCCR0 = tccr0_set[n];
    OCR0 = ocr0_set[n];
    DDRB.4 = 1;
    PORTA = LED[n];
void InitTimer2()
    TCCR2 = (1 << WGM21);
    TCCR2 = (1 << CS21) | (1 << CS20);
    OCR2 = 249;
    TCNT2 = 0;
    TIFR = (1 << OCF2);
    TIMSK = (1 << OCIE2);
unsigned char Time2Flag;
unsigned short Cnt;
int seq;
interrupt [TIM2_COMP] void isr_timer2_comp()
    ++Time2Flag;
void FND1(){
    DDRG=0xff; DDRC=0xff;
    if(sheet1[seq].rhythm==0.25){ PORTG=0x01; PORTC=0x3f; }
    if(sheet1[seq].rhythm==0.50){ PORTG=0x02; PORTC=0x3f; }
    if(sheet1[seq].rhythm==1.00){ PORTG=0x04; PORTC=0x3f; }
    if(sheet1[seq].rhythm==2.00){ PORTG=0x08; PORTC=0x3f; }
void FND2(){
    if(sheet2[seq].rhythm==0.25){ PORTG=0x01; PORTC=0x3f; }
    if(sheet2[seq].rhythm==0.50){ PORTG=0x02; PORTC=0x3f; }
    if(sheet2[seq].rhythm==1.00){ PORTG=0x04; PORTC=0x3f; }
    if(sheet2[seq].rhythm==2.00){ PORTG=0x08; PORTC=0x3f; }
void Song1()
    InitTimer2();
    if(Time2Flag)
      Time2Flag =0;
       if(Cnt)
             if(Cnt == 10)
                    DDRB.4 = 0;
                else if(Cnt == 1)
                    if(sheet1[seq].rhythm != 0.0)
                      DDRA = 0xff;
                      FND1();
                      SetTone(sheet1[seq].melody);
                      Cnt = (unsigned short)(sheet1[seq].rhythm*350*60/LENGTH1);
                      ++seq;
     --Cnt;
void Song2()
    InitTimer2();
    if(Time2Flag)
       Time2Flag =0;
        if(Cnt)
                if(Cnt == 10)
                    DDRB.4 = 0;
                  else if(Cnt == 1)
                    if(sheet2[seq].rhythm != 0.0)     //노래 2 => sheet2
                        DDRA = 0xff;
                        FND2();
                        SetTone(sheet2[seq].melody);   //노래 2 => sheet2
                        Cnt = (unsigned short)(sheet2[seq].rhythm*350*60/LENGTH2); // 노래 2 => sheet2
                        ++seq;
     --Cnt;
void comInit()
    UCSR0B = (1 << RXEN0) | (1 << TXEN0);                      // TX, RX 활성화
    UCSR0C = (1 << UCSZ01) | (1 << UCSZ00);                    // 데이버 비트 8bit
    UBRR0H = 1;
    UBRR0L = 160;                                              // 2400 bps
    //disappeared
void main()
    char ch;
    comInit();
    EICRB = 0x0a;
    EIMSK = 0x30;
    SREG |= 0x80;
        ch =  USART0_GetChar() ;
        USART0_PutChar(ch);
        USART0_PutStr(" \r");
        if(ch == 49)          //숫자 1입력
            Cnt = 1;
            seq = 0;
            Song1();
            if(sheet2[seq].rhythm == 0)
                Cnt = 0;
        else if (ch == 50)  //숫자 2입력
            Cnt = 1;
            seq = 0;
            Song2();
            Cnt = 0;
조금 더 깔끔하게 다듬어 주실 수 있나요?>
조회수 5,424
이렇게 작성하면 윗 라인은 무효됩니다.
    TCCR2 |= (1 << CS21) | (1 << CS20);
아래 라인은 |= 를 사용하세요
공지 사이트 이용 안내댓글[24] master 17-10-29 29644
질문 아두이노 서보모터제어 하나도 모르겠습니다 ㅠ 이미지새글첨부파일 오소로롯 22:01 1
질문 아트메가 128 을 이용해서적외선 센서 코딩 중 물어볼게있습니다!! 새글 noster 19:32 15
질문 아두이노 에러질문댓글[1] 이미지새글첨부파일 리니어 16:09 21
질문 아두이노 블루투스 통신 관련 질문 있습니다!! 새글 블루툿 10:51 23
답변 답변글 답변 : 아두이노 블루투스(hc-06)사용중 질문있습니다. 새글 master 09:52 16
질문 아두이노 초음파센서 코딩 질문댓글[3] 이미지새글첨부파일 아두이노아린이 22-05-20 30
질문 atmega128 서보모터와 초음파센서댓글[5] 새글 tmiae 22-05-20 31
질문 컴퓨터 usb연결시 정상 작동하나 9V건전지 외부전원 연결 시 작동하지 않는 문제댓글[3] 이미지첨부파일 보겐을운용 22-05-19 188
질문 아두이노 millis ->atmega128에서 사용하고 싶습니다. akmong413 22-05-19 32
답변 답변글 답변 : 아두이노 millis ->atmega128에서 사용하고 싶습니다. master 22-05-19 34
질문 아두이노로 모터+드라이버 제어댓글[6] 모토 22-05-18 75
질문 라즈베리파이 웹캠 데이터 아두이노 전송 (초보)댓글[3] 전자과 22-05-17 62
질문 아두이노 우노 2개와 앱인벤터끼리의 블루투스 통신 방법댓글[3] 이미지첨부파일 pyoleo 22-05-17 116
