질문게시판 > xd-58c(심박센서) bpm 질문
TODAY486 TOTAL1,083,135
BASIC4MCU | 질문게시판 | xd-58c(심박센서) bpm 질문
작성자 심심심심 작성일2020-05-20 15:10 조회70회 댓글1건
/*  Getting_BPM_to_Monitor prints the BPM to the Serial Monitor, using the least lines of code and PulseSensor Library.
 *  Tutorial Webpage: https://pulsesensor.com/pages/getting-advanced
--------Use This Sketch To------------------------------------------
1) Displays user's live and changing BPM, Beats Per Minute, in Arduino's native Serial Monitor.
2) Print: "♥  A HeartBeat Happened !" when a beat is detected, live.
2) Learn about using a PulseSensor Library "Object".
4) Blinks LED on PIN 13 with user's Heartbeat.
#define USE_ARDUINO_INTERRUPTS true    // Set-up low-level interrupts for most acurate BPM math.
#include <PulseSensorPlayground.h>     // Includes the PulseSensorPlayground Library.
//  Variables
const int PulseWire = 0;       // PulseSensor PURPLE WIRE connected to ANALOG PIN 0
const int LED13 = 13;          // The on-board Arduino LED, close to PIN 13.
int Threshold = 550;           // Determine which Signal to "count as a beat" and which to ignore.
                               // Use the "Gettting Started Project" to fine-tune Threshold Value beyond default setting.
                               // Otherwise leave the default "550" value.
PulseSensorPlayground pulseSensor;  // Creates an instance of the PulseSensorPlayground object called "pulseSensor"
  Serial.begin(9600);          // For Serial Monitor
  // Configure the PulseSensor object, by assigning our variables to it.
  pulseSensor.analogInput(PulseWire);
  pulseSensor.blinkOnPulse(LED13);       //auto-magically blink Arduino's LED with heartbeat.
  pulseSensor.setThreshold(Threshold);
  // Double-check the "pulseSensor" object was created and "began" seeing a signal.
   if (pulseSensor.begin()) {
    Serial.println("We created a pulseSensor Object !");  //This prints one time at Arduino power-up,  or on Arduino reset.
 int myBPM = pulseSensor.getBeatsPerMinute();  // Calls function on our pulseSensor object that returns BPM as an "int".
                                               // "myBPM" hold this BPM value now.
if (pulseSensor.sawStartOfBeat()) {            // Constantly test to see if "a beat happened".
 Serial.println("♥  A HeartBeat Happened ! "); // If test is "true", print a message "a heartbeat happened".
 Serial.print("BPM: ");                        // Print phrase "BPM: "
 Serial.println(myBPM);                        // Print the value inside of myBPM.
  delay(20);                    // considered best practice in a simple sketch.
위 오픈소스를 이용해서 진행해봤는데요
다른분들 하신것들을 보면 위 코드 사용해서도 bpm값이 일정하게 뜨는데 그렇지 못하네요
혹시 몰라 다른 심박센서인 ad8232도 이용해 보았으나 일정한 값은 나오지 않습니다..
원래 판매되는 심박센서가 정밀한 제품이 아니다 보니 오차가 클수있는건가요??
아니면 코딩과정이나 무엇이 문제가 있는걸까요
조회수 70
제공된 모듈의 예제를 돌려서 정확하게 동작해야 정상입니다.
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 1698
공지 사이트 이용 안내댓글[11] master 17-10-29 11198
공지 [무료 공개] 소스코드 하이라이트 v2.0 beta [2013.02.07]댓글[1] 이미지첨부파일 master 18-01-23 4215
질문 아두이노 7세그먼트댓글[1] 새글 Cordingplz 20-06-02 8
질문 atmega128 uart0사용법댓글[6] 새글 jiseok 20-06-02 14
질문 아두이노 우노 외부전원 9v댓글[2] 새글 helpme 20-06-02 9
질문 솔레노이드 벨브를 이용한 가스벨브제어댓글[2] 새글 밀키스 20-06-02 11
질문 아두이노 모터 센서 오류댓글[1] 새글 박지성룡 20-06-02 14
질문 아두이노 인터럽트 led 새글 옹아 20-06-02 19
답변 답변글 답변 : 아두이노 인터럽트 led 새글 master 20-06-02 9
질문 avr 블루투스, 초음파, LED 설계댓글[1] 새글 전과자14학번 20-06-02 19
답변 답변글 답변 : avr 블루투스, 초음파, LED 설계 새글 master 20-06-02 12
질문 진동센서값 오류잡아주세요,,,댓글[1] 새글 팬다 20-06-02 12
질문 공부방향 문의댓글[1] 새글 갈비야 20-06-02 12
질문 질문 하나 드리겠습니다... 제발 도와주십시오 제발... ㅠㅠ댓글[1] 이미지새글 아두이노어려워 20-06-01 27
질문 타이머/카운터 1을 10비트 분해능의 Fast PWM 모드로 설정, 문제좀 알려주세요댓글[1] 새글 Tani 20-06-01 18
질문 AVR 코드로 7세그먼트 4자리 불 들어오는법이요!!댓글[1] 이미지새글첨부파일 dslaks 20-06-01 21
질문 아두이노 시리얼 통신 새글 눈의궁전 20-06-01 17
답변 답변글 답변 : 아두이노 시리얼 통신 새글 master 20-06-01 18
질문 아두이노 소스코드 합치기 질문 드립니다.댓글[2] 새글 하기싫다 20-06-01 25
질문 키패드설정값 문자표기 릴레이작동댓글[2] 왕왕초a 20-06-01 19
질문 아트메가와 아두이노 통신 하는방법! jiseok 20-06-01 20
답변 답변글 답변 : 아트메가와 아두이노 통신 하는방법!댓글[3] master 20-06-01 17
질문 atmega128을 이용하여 PORTA에 2진수 패턴이 출력되도록 하는 C프로그램 작성 혀스석 20-05-31 30
답변 답변글 답변 : atmega128을 이용하여 PORTA에 2진수 패턴이 출력되도록 하는 C프로그램 작성댓글[2] master 20-06-01 24
질문 센서 평균값 구하기댓글[2] 팬다 20-05-31 26
답변 답변글 답변 : 센서 평균값 구하기 master 20-06-01 9
질문 Atmega128P BLDC 모터관련 질문좀할게요(3)댓글[1] 차니 20-05-30 38
답변 답변글 답변 : Atmega128P BLDC 모터관련 질문좀할게요(3) master 20-05-30 36
질문 (질문)atmega128을 이용한 LED제어댓글[2] 발양말 20-05-29 68
