질문게시판 > 답변 : 아두이노 ide 코드 질문입니다.!(소스합치기)
TODAY477 TOTAL1,083,126
BASIC4MCU | 질문게시판 | 답변 : 아두이노 ide 코드 질문입니다.!(소스합치기)
작성자 master 작성일2020-05-21 12:14 조회63회 댓글0건
// DateTime : 2020-05-21 오후 12:17:09
#include <SoftwareSerial.h>
#include <DFPlayer_Mini_Mp3.h>
#include <Adafruit_NeoPixel.h>
LiquidCrystal_I2C lcd(0x27,16,2);
#include <DHT11.h>
#ifdef __AVR__
#include <avr/power.h>
#endif
#define CO       'c'  // red
#define FO       'f'  // green
#define RED      'r'  // red
#define GREEN    'g'  // green
#define BLUE     'b'  // blue
#define PINK     'p'  // pink
#define YELLOW   'y'  // yellow
#define AQUA     'a'  // aqua
#define OFF      'o'  // aqua
#define PIN      6
int t_h_pin=5;                // 온습도 센서핀
int humidifier=7;             // 가습기 센서핀
SoftwareSerial btSerial(2,3); // 블루투스 RX,TX
int button=9;
int trigPin=10;
int echoPin=11;
SoftwareSerial mySerial(12,13); // 스피커 RX,TX
int busy=4;                     // Pin estado del modulo
char command;
String string;
boolean start=false;
boolean next_song=true;
boolean play_state=false;
DHT11 dht11(t_h_pin);
// Parameter 1=number of pixels in strip
// Parameter 2=Arduino pin number(most are valid)
// Parameter 3=pixel type flags,add together as nee00000ded:
//   NEO_KHZ800  800 KHz bitstream(most NeoPixel products w/WS2812 LEDs)
//   NEO_KHZ400  400 KHz(classic 'v1'(not v2)FLORA pixels,WS2811 drivers)
//   NEO_GRB     Pixels are wired for GRB bitstream(most NeoPixel products)
//   NEO_RGB     Pixels are wired for RGB bitstream(v1 FLORA pixels,not v2)
//   NEO_RGBW    Pixels are wired for RGBW bitstream(NeoPixel RGBW products)
Adafruit_NeoPixel strip=Adafruit_NeoPixel(60,PIN,NEO_GRB+NEO_KHZ800);
// IMPORTANT: To reduce NeoPixel burnout risk,add 1000 uF capacitor across
// pixel power leads,add 300-500 Ohm resistor on first pixel's data input
// and minimize distance between Arduino and first pixel.Avoid connecting
// on a live circuit...if you must,connect GND first.
  btSerial.begin(9600);
  mySerial.begin(9600);     // Start SoftwareSerial DFPlayer Mini
  mySerial.listen();        // Pone a la escucha el modulo DFPlayer Mini
  mp3_set_serial(mySerial); // Enlaza el SoftwareSerial con DFPlayer Mini
  delay(10);
  mp3_reset();
  pinMode(trigPin,OUTPUT);
  pinMode(echoPin,INPUT);
  pinMode(button,INPUT);
  pinMode(t_h_pin,OUTPUT);    // 온습도 핀모드 설정
  pinMode(humidifier,OUTPUT); // 가습기 핀모드 설정
  lcd.init();
  lcd.backlight(); // I2C LCD 모듈 backlight_ON
  // This is for Trinket 5V 16MHz,you can remove these three lines if you are not using a Trinket
  #if defined(__AVR_ATtiny85__)
  if(F_CPU==16000000)clock_prescale_set(clock_div_1);
  #endif
  // End of trinket special code
  strip.begin();
  strip.show(); // Initialize all pixels to 'off'
  boolean busy_state=digitalRead(busy);
  if((busy_state)==HIGH&&(next_song==true)&&(play_state==true)){
    if(start==true){ mp3_next(); }
  btSerial.listen();
  delay(50);
  if(btSerial.available()>0){ string=""; }
  Serial.println(string);
  while(btSerial.available()>0){
    command=((byte)btSerial.read());
    Serial.println(command);
    if(command==': '){ break; } elsestring+=command; }
    delay(10);
  mySerial.listen();
  switch(command){
    case 'E'reproducir();      break// play
    case 'S'parar();           break// stop
    case 'D'pause();           break// Pause
    case 'N'pista_siguiente(); break// next song
    case 'J'pista_anterior();  break// prev song
    case 'H'next_track();      break// Siguiente cancion automatica
  float duration,distance;
  char LED,HUM;
  float temp,humi;
  digitalWrite(trigPin,HIGH); delayMicroseconds(1000); digitalWrite(trigPin,LOW);
  duration=pulseIn(echoPin,HIGH);
  distance=((float)(340*duration)/10000)/2;
  float height=24.5-distanceSerial.print(height); Serial.println("cm"); delay(200);
  if(digitalRead(button)==LOW){
    lcd.init();
    lcd.setCursor(0,1); lcd.print("HEIGHT="); lcd.print(height); lcd.print("cm");
    lcd.begin(16,2);
    delay(200);
  elselcd.print(""); }
  dht11.read(humi,temp);
  btSerial.print(temp);          btSerial.print("℃     ");
  btSerial.print(humi);          btSerial.print("%");
  Serial.print("humidity: ");    Serial.println(humi);
  Serial.print("temperature: "); Serial.print(temp);
  lcd.setCursor(0,0); lcd.print("t: "); lcd.print(temp);
  lcd.setCursor(9,0); lcd.print("h: "); lcd.print(humi);
  delay(3000);
    LED=HUM=btSerial.read();
    if     (LED==RED   )colorWipe(strip.Color(255,  0,  0),50);
    else if(LED==GREEN )colorWipe(strip.Color(  0,255,  0),50);
    else if(LED==BLUE  )colorWipe(strip.Color(  0,  0,255),50);
    else if(LED==PINK  )colorWipe(strip.Color(255,  0,255),50);
    else if(LED==YELLOW)colorWipe(strip.Color(255,255,  0),50);
    else if(LED==AQUA  )colorWipe(strip.Color(  0,255,255),50);
    else if(LED==OFF   )colorWipe(strip.Color(  0,  0,  0),50);
    else if(HUM==CO){ // 습도 값이 30 미만(기준 값)
      digitalWrite(humidifier,HIGH); // 가습기 센서 작동_ON
      lcd.setCursor(0,1); lcd.print(" humidifier_ON ");
    else if(HUM==FO){
      digitalWrite(humidifier,LOW); // 가습기 센서 작동_ON
      lcd.setCursor(0,1); lcd.print(" humidifier_OFF");
void colorWipe(uint32_t c,uint8_t wait){
  for(uint16_t i=0i<strip.numPixels(); i++){ strip.setPixelColor(i,c); strip.show(); }
void reproducir(){ play_state=truestart=truemp3_play(); }
void parar(){ play_state=falsemp3_stop(); }
void pause(){ play_state=falsemp3_pause(); }
void pista_siguiente(){ mp3_next(); }
void  pista_anterior(){ mp3_prev(); }
void next_track(){
  if(next_song==true){ next_song=false; } elsenext_song=true; }
소프트웨어 시리얼을 2개 사용하고 있는데요
송신은 2개 모두 가능하지만
수신은 한개만 가능합니다.
특수한 기능은 타이머를 사용하는 경우가 많은데요
타이머 중복으로 인해서 문제가 생기는 경우가 많습니다.
각각 동작할 때는 문제가 없지만 합치면 같은 타이머를 사용하면서 문제가 되는 것이죠
조회수 63
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 1698
공지 사이트 이용 안내댓글[11] master 17-10-29 11198
공지 [무료 공개] 소스코드 하이라이트 v2.0 beta [2013.02.07]댓글[1] 이미지첨부파일 master 18-01-23 4215
질문 아두이노 7세그먼트댓글[1] 새글 Cordingplz 20-06-02 8
질문 atmega128 uart0사용법댓글[6] 새글 jiseok 20-06-02 13
질문 아두이노 우노 외부전원 9v댓글[2] 새글 helpme 20-06-02 9
질문 솔레노이드 벨브를 이용한 가스벨브제어댓글[2] 새글 밀키스 20-06-02 11
질문 아두이노 모터 센서 오류댓글[1] 새글 박지성룡 20-06-02 14
질문 아두이노 인터럽트 led 새글 옹아 20-06-02 17
답변 답변글 답변 : 아두이노 인터럽트 led 새글 master 20-06-02 9
질문 avr 블루투스, 초음파, LED 설계댓글[1] 새글 전과자14학번 20-06-02 19
답변 답변글 답변 : avr 블루투스, 초음파, LED 설계 새글 master 20-06-02 11
질문 진동센서값 오류잡아주세요,,,댓글[1] 새글 팬다 20-06-02 12
질문 공부방향 문의댓글[1] 새글 갈비야 20-06-02 12
질문 질문 하나 드리겠습니다... 제발 도와주십시오 제발... ㅠㅠ댓글[1] 이미지새글 아두이노어려워 20-06-01 27
질문 타이머/카운터 1을 10비트 분해능의 Fast PWM 모드로 설정, 문제좀 알려주세요댓글[1] 새글 Tani 20-06-01 18
질문 AVR 코드로 7세그먼트 4자리 불 들어오는법이요!!댓글[1] 이미지새글첨부파일 dslaks 20-06-01 21
질문 아두이노 시리얼 통신 새글 눈의궁전 20-06-01 17
답변 답변글 답변 : 아두이노 시리얼 통신 새글 master 20-06-01 18
질문 아두이노 소스코드 합치기 질문 드립니다.댓글[2] 새글 하기싫다 20-06-01 25
질문 키패드설정값 문자표기 릴레이작동댓글[2] 왕왕초a 20-06-01 19
질문 아트메가와 아두이노 통신 하는방법! jiseok 20-06-01 20
답변 답변글 답변 : 아트메가와 아두이노 통신 하는방법!댓글[3] master 20-06-01 17
질문 atmega128을 이용하여 PORTA에 2진수 패턴이 출력되도록 하는 C프로그램 작성 혀스석 20-05-31 30
답변 답변글 답변 : atmega128을 이용하여 PORTA에 2진수 패턴이 출력되도록 하는 C프로그램 작성댓글[2] master 20-06-01 24
질문 센서 평균값 구하기댓글[2] 팬다 20-05-31 26
답변 답변글 답변 : 센서 평균값 구하기 master 20-06-01 9
질문 Atmega128P BLDC 모터관련 질문좀할게요(3)댓글[1] 차니 20-05-30 38
답변 답변글 답변 : Atmega128P BLDC 모터관련 질문좀할게요(3) master 20-05-30 36
질문 (질문)atmega128을 이용한 LED제어댓글[2] 발양말 20-05-29 68
