질문게시판 > Atmega128P BLDC 모터관련 질문좀할게요(3)
TODAY1,353 TOTAL1,146,143
BASIC4MCU | 질문게시판 | Atmega128P BLDC 모터관련 질문좀할게요(3)
작성자 차니 작성일2020-05-30 19:21 조회145회 댓글1건
선생님 안녕하세요?
BLDC 모터 한방향(CW)으로는 홀센서 입력받고 정상적으로 동작이 가능하게 구현하였는데..
반대 방향(CCW)으로 구동이 되질 않네요 ㅜㅜ
혹시 코드좀 봐주실 수 있을까요?
void HALL_SENSOR_CW(void)
 PIN_TEST();
 input = flag_u|flag_v|flag_w;
 switch(input)
  case 0x00:
  lcd_home();
  lcd_clear();
  lcd_control_write(0x80);
  lcd_print_data(str_not, 3);
  lcd_control_write(0xC0);
  lcd_print_data(str_connect, 6);
  _delay_ms(3000);
  _delay_ms(3000);
  beep();
  beep();
  beep();
  case 0x30: //input v_data, w_data;
  OCR1AL = count; //U+
  PORTD = 0x04;   //W-
  _delay_ms(110);
  case 0x20: //input w_data;
  OCR1BL = count; //V+
  PORTD = 0x04;   //W-
  _delay_ms(110);
  case 0xA0:   //input u_data, w_data;
  PORTD = 0x01;   //U-
  _delay_ms(110);
  case 0x80:   //input u_data;
  OCR1CL = count; //W+
  PORTD = 0x01;   //U-
  _delay_ms(110);
  case 0x90:   //input u_data, v_data;
  PORTD = 0x02; //V-;
  _delay_ms(110);
  case 0x10: //input v_data;
  PORTD = 0x02;   //V-
  _delay_ms(110);
 switch(count)
  case 220:
  PORTD = 0x00;
  OCR1AL = 0x00;
  OCR1BL = 0x00;
  OCR1CL = 0x00;
  _delay_ms(110);
  case 180:
  PORTD = 0x00;
  OCR1AL = 0x00;
  OCR1BL = 0x00;
  OCR1CL = 0x00;
  _delay_ms(150);
  case 140:
  PORTD = 0x00;
  OCR1AL = 0x00;
  OCR1BL = 0x00;
  OCR1CL = 0x00;
  _delay_ms(190);
  case 100:
  PORTD = 0x00;
  OCR1AL = 0x00;
  OCR1BL = 0x00;
  OCR1CL = 0x00;
  _delay_ms(230);
  case 60:
  PORTD = 0x00;
  OCR1AL = 0x00;
  OCR1BL = 0x00;
  OCR1CL = 0x00;
  _delay_ms(270);
  case 20:
  PORTD = 0x00;
  OCR1AL = 0x00;
  OCR1BL = 0x00;
  OCR1CL = 0x00;
  _delay_ms(310);
void HALL_SENSOR_CCW(void)
 PIN_TEST();
 switch(input)
  PORTD = 0x01;   //U-
  _delay_ms(110);
  OCR1CL = count;//W+
  PORTD = 0x02;   //V-
  _delay_ms(110);
  PORTD = 0x02;   //V-
  _delay_ms(110);
  PORTD = 0x04;   //W-
  _delay_ms(110);
  PORTD = 0x04; //W-;
  _delay_ms(110);
  PORTD = 0x01;   //U-
  _delay_ms(110);
 switch(count)
  case 220:
  _delay_ms(200);
  PORTD = 0x00;
  OCR1AL = 0x00;
  OCR1BL = 0x00;
  OCR1CL = 0x00;
  _delay_ms(110);
  case 180:
  _delay_ms(200);
  PORTD = 0x00;
  OCR1AL = 0x00;
  OCR1BL = 0x00;
  OCR1CL = 0x00;
  _delay_ms(150);
  case 140:
  _delay_ms(200);
  PORTD = 0x00;
  OCR1AL = 0x00;
  OCR1BL = 0x00;
  OCR1CL = 0x00;
  _delay_ms(190);
  case 100:
  _delay_ms(200);
  PORTD = 0x00;
  OCR1AL = 0x00;
  OCR1BL = 0x00;
  OCR1CL = 0x00;
  _delay_ms(230);
  case 60:
  _delay_ms(200);
  PORTD = 0x00;
  OCR1AL = 0x00;
  OCR1BL = 0x00;
  OCR1CL = 0x00;
  _delay_ms(270);
  case 20:
  _delay_ms(200);
  PORTD = 0x00;
  OCR1AL = 0x00;
  OCR1BL = 0x00;
  OCR1CL = 0x00;
  _delay_ms(310);
조회수 145
간단한 코드는 눈으로 봐도 디버깅이 가능하지만
BLDC는 실제 동작시켜가면서 디버깅을 해야 하므로 남이 봐줄 수가 없습니다.
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 1857
공지 사이트 이용 안내댓글[12] master 17-10-29 11753
공지 [무료 공개] 소스코드 하이라이트 v2.0 beta [2013.02.07]댓글[1] 이미지첨부파일 master 18-01-23 4436
질문 아두이노 LCD, 블루투스 코드 병합 ㅜㅜ간절합니다 새글 야야두이노 20:50 2
질문 Atmega48 주파수 관련해서 질문드립니다..!댓글[3] 새글 코딩공부하자 16:19 11
질문 타이머 인터럽트 채터링 문제? 이미지새글첨부파일 궁금 15:48 10
답변 답변글 답변 : 타이머 인터럽트 채터링 문제?댓글[2] 새글 master 16:53 9
질문 아두이노 질문있습니다댓글[1] 이미지새글 djfuqspdy 20-07-12 23
질문 PD제어 소스 질문있습니다.댓글[3] 궁금 20-07-10 34
질문 unique id 생성댓글[1] cheaminee 20-07-10 28
질문 아두이노 포트 변경댓글[2] cheaminee 20-07-09 38
질문 소스 코딩 도와주세요 bas213 20-07-09 43
답변 답변글 답변 : 소스 코딩 도와주세요 master 20-07-09 34
질문 안녕하세요. 질문있습니다. dkendlsh 20-07-08 24
답변 답변글 답변 : 안녕하세요. 질문있습니다.댓글[1] master 20-07-08 30
질문 아두이노 nfc 센서와 pH센서 같이 연결댓글[1] 알려주세요제발ㅠㅠ 20-07-08 32
질문 아두이노 초음파 센서, 부저, 스위치 합치기 도와주세요ㅜㅜ 이밍밍 20-07-05 57
질문 이 도어락 코드좀 이미지첨부파일 문준혁 20-07-05 60
질문 아두이노 입력전원댓글[2] 왕왕초a 20-07-02 67
질문 외부인터럽트가 발생했을때 ADC변환, 데이터 송신프로그램 질문입니다. 이소부 20-07-02 40
답변 답변글 답변 : 외부인터럽트가 발생했을때 ADC변환, 데이터 송신프로그램 질문입니다. master 20-07-02 48
질문 아두이노 마사지 키트 문의드립니다.댓글[3] 야아이양 20-07-02 52
질문 아두이노 공기청정기댓글[3] 행노비 20-07-02 64
질문 (아두이노)압력센서를 이용한 led on/off와 팬 작동댓글[1] 호조조 20-07-02 45
질문 아두이노 기체유량센서댓글[1] 최하림 20-07-01 42
질문 아두이노 pwm 제어 관련 질문드리고 싶습니다.댓글[4] 궁금스 20-07-01 80
질문 아두이노 합침 첨부파일 우경민 20-06-30 52
질문 소스 합쳐주세요 첨부파일 우경민 20-06-30 66
답변 답변글 답변 : 소스 합쳐주세요댓글[1] master 20-06-30 94
질문 소스코드 질문드립니다댓글[1] rqjiqwrji 20-06-30 79
