BASIC4MCU | 질문게시판 | 스텝모터가 시계반대 방향으로 가는 방법좀요
작성자 dhdh 작성일2020-06-09 16:03 조회4,124회 댓글1건본문
#include <Adafruit_Fingerprint.h>
#include <Stepper.h>
// FINGERPRINT
int getFingerprintIDez();
SoftwareSerial mySerial(2, 3); // pin #2 is IN from sensor (GREEN wire) pin #3 is OUT from arduino (WHITE wire)
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
// MOTOR 28BYJ-48
#define STEPS_PER_MOTOR_REVOLUTION 32
#define STEPS_PER_OUTPUT_REVOLUTION 32 * 64 // 2048
Stepper small_stepper(STEPS_PER_MOTOR_REVOLUTION, 8, 10, 9, 11);
int Steps2Take;
// BUZZER
int buzzer = 7;
int i;
finger.begin(57600);
pinMode(buzzer,OUTPUT);
if (finger.verifyPassword()) {
Serial.println("Found fingerprint sensor!");
} else {
Serial.println("Did not find fingerprint sensor :(");
while (1);
Serial.println("Waiting for valid finger...");
int idFinger = getFingerprintIDez();
if (idFinger >= 0) {
openDrawer();
tone(buzzer, 1000, 150);
delay(200);
delay(5000);
closeDrawer();
void openDrawer() {
Steps2Take = STEPS_PER_OUTPUT_REVOLUTION / 0.1; // Rotate clockwise 1/4 turn
small_stepper.setSpeed(500); // 700 a good max speed??
small_stepper.step(Steps2Take);
void closeDrawer() {
Steps2Take = -STEPS_PER_OUTPUT_REVOLUTION / -1; // Rotate against clockwise 1/4 turn
uint8_t getFingerprintID() {
uint8_t p = finger.getImage();
switch (p) {
case FINGERPRINT_OK:
Serial.println("Image taken");
case FINGERPRINT_NOFINGER:
Serial.println("No finger detected");
return p;
case FINGERPRINT_PACKETRECIEVEERR:
Serial.println("Communication error");
return p;
case FINGERPRINT_IMAGEFAIL:
Serial.println("Imaging error");
return p;
default:
Serial.println("Unknown error");
return p;
// OK success!
p = finger.image2Tz();
switch (p) {
Serial.println("Image converted");
case FINGERPRINT_IMAGEMESS:
Serial.println("Image too messy");
return p;
return p;
case FINGERPRINT_FEATUREFAIL:
Serial.println("Could not find fingerprint features");
return p;
case FINGERPRINT_INVALIDIMAGE:
return p;
default:
return p;
// OK converted!
p = finger.fingerFastSearch();
if (p == FINGERPRINT_OK) {
Serial.println("Found a print match!");
} else if (p == FINGERPRINT_PACKETRECIEVEERR) {
return p;
} else if (p == FINGERPRINT_NOTFOUND) {
Serial.println("Did not find a match");
return p;
} else {
return p;
// found a match!
Serial.print("Found ID #"); Serial.print(finger.fingerID);
Serial.print(" with confidence of "); Serial.println(finger.confidence);
// returns -1 if failed, otherwise returns ID #
int getFingerprintIDez() {
if (p != FINGERPRINT_OK) return -1;
// found a match!
return finger.fingerID;
조회수 4,124master님의 댓글
small_stepper.step( Steps2Take); // 정회전
small_stepper.step(-Steps2Take); // 역회전
음수값을 주면 반대로 회전합니다.
