BASIC4MCU | 질문게시판 | 아두이노 소스코드 컴파일 에러 질문
작성자 블람 작성일2020-06-24 13:38 조회4,789회 댓글1건본문
심박센서와 걸음수 측정 두코드를 합쳐서 컴파일을 시도 했는데 다음과 같은 에러가 뜹니다 .
왜그런걸까요 ? 알려주신다면 감사하겠습니다 ...
*에러내용
C:\Users\user\AppData\Local\Temp\cc3PSdDK.ltrans0.ltrans.o: In function `main':
<artificial>:(.text.startup+0x45e): undefined reference to `PulseSensorPlayground::UsingInterrupts'
<artificial>:(.text.startup+0x466): undefined reference to `PulseSensorPlaygroundSetupInterrupt()'
collect2.exe: error: ld returned 1 exit status
exit status 1
보드 Arduino Mega or Mega 2560 컴파일 에러.
*소스코드
#include <math.h>
#include <Wire.h>
#include <PulseSensorPlayground.h>
/* Bluetooth */
SoftwareSerial BTSerial(2, 3); //Connect HC-06. Use your (TX, RX) settings
/* 심박 센서 */
PulseSensorPlayground pulseSensor;
/* 심박 센서 */
#define USE_ARDUINO_INTERRUPTS true
const int PulseWire = 0;
int Threshold = 550;
/* time */
#define SENDING_INTERVAL 1000
#define SENSOR_READ_INTERVAL 50
unsigned long prevSensoredTime = 0;
unsigned long curSensoredTime = 0;
/* Data buffer */
#define ACCEL_BUFFER_COUNT 125
byte aAccelBuffer[ACCEL_BUFFER_COUNT];
int iAccelIndex = 2;
/* MPU-6050 sensor */
#define MPU6050_ACCEL_XOUT_H 0x3B // R
#define MPU6050_PWR_MGMT_1 0x6B // R/W
#define MPU6050_PWR_MGMT_2 0x6C // R/W
#define MPU6050_WHO_AM_I 0x75 // R
#define MPU6050_I2C_ADDRESS 0x68
typedef union accel_t_gyro_union {
struct {
uint8_t x_accel_h;
uint8_t x_accel_l;
uint8_t y_accel_h;
uint8_t y_accel_l;
uint8_t z_accel_h;
uint8_t z_accel_l;
uint8_t t_h;
uint8_t t_l;
uint8_t x_gyro_h;
uint8_t x_gyro_l;
uint8_t y_gyro_h;
uint8_t y_gyro_l;
uint8_t z_gyro_h;
uint8_t z_gyro_l;
} reg;
struct {
int x_accel;
int y_accel;
int z_accel;
int temperature;
int x_gyro;
int y_gyro;
int z_gyro;
} value;
int error;
uint8_t c;
pulseSensor.analogInput(PulseWire);
pulseSensor.setThreshold(Threshold);
if (pulseSensor.begin()) {
Serial.println("We created a pulseSensor Object !"); //This prints one time at Arduino power-up, or on Arduino reset.
Wire.begin();
BTSerial.begin(9600); // set the data rate for the BT port
// default at power-up:
// Gyro at 250 degrees second
// Acceleration at 2g
// Clock source at internal 8MHz
// The device is in sleep mode.
error = MPU6050_read (MPU6050_WHO_AM_I, &c, 1);
Serial.print(F("WHO_AM_I : "));
Serial.print(c,HEX);
Serial.print(F(", error = "));
Serial.println(error,DEC);
// According to the datasheet, the 'sleep' bit
// should read a '1'. But I read a '0'.
// That bit has to be cleared, since the sensor
// is in sleep mode at power-up. Even if the
// bit reads '0'.
error = MPU6050_read (MPU6050_PWR_MGMT_2, &c, 1);
Serial.print(F("PWR_MGMT_2 : "));
// Clear the 'sleep' bit to start the sensor.
MPU6050_write_reg (MPU6050_PWR_MGMT_1, 0);
initBuffer();
int myBPM = pulseSensor.getBeatsPerMinute();
if (pulseSensor.sawStartOfBeat()) { // Constantly test to see if "a beat happened".
Serial.println("♥ A HeartBeat Happened ! "); // If test is "true", print a message "a heartbeat happened".
Serial.print("BPM: "); // Print phrase "BPM: "
Serial.println(myBPM); // Print the value inside of myBPM.
delay(20);
curSensoredTime = millis();
// Read from sensor
if(curSensoredTime - prevSensoredTime > SENSOR_READ_INTERVAL) {
readFromSensor(); // Read from sensor
prevSensoredTime = curSensoredTime;
// Send buffer data to remote
if(iAccelIndex >= ACCEL_BUFFER_COUNT - 3) {
sendToRemote();
initBuffer();
Serial.println("------------- Send 20 accel data to remote");
* BT Transaction
void sendToRemote() {
// Write gabage bytes
BTSerial.write( "accel" );
// Write accel data
BTSerial.write( (char*)aAccelBuffer );
// Flush buffer
//BTSerial.flush();
* Read data from sensor and save it
void readFromSensor() {
int error;
double dT;
accel_t_gyro_union accel_t_gyro;
error = MPU6050_read (MPU6050_ACCEL_XOUT_H, (uint8_t *) &accel_t_gyro, sizeof(accel_t_gyro));
if(error != 0) {
Serial.print(F("Read accel, temp and gyro, error = "));
// Swap all high and low bytes.
// After this, the registers values are swapped,
// so the structure name like x_accel_l does no
// longer contain the lower byte.
uint8_t swap;
#define SWAP(x,y) swap = x; x = y; y = swap
SWAP (accel_t_gyro.reg.x_accel_h, accel_t_gyro.reg.x_accel_l);
SWAP (accel_t_gyro.reg.y_accel_h, accel_t_gyro.reg.y_accel_l);
SWAP (accel_t_gyro.reg.z_accel_h, accel_t_gyro.reg.z_accel_l);
SWAP (accel_t_gyro.reg.t_h, accel_t_gyro.reg.t_l);
SWAP (accel_t_gyro.reg.x_gyro_h, accel_t_gyro.reg.x_gyro_l);
SWAP (accel_t_gyro.reg.y_gyro_h, accel_t_gyro.reg.y_gyro_l);
SWAP (accel_t_gyro.reg.z_gyro_h, accel_t_gyro.reg.z_gyro_l);
// Print the raw acceleration values
Serial.print(F("accel x,y,z: "));
Serial.print(accel_t_gyro.value.x_accel, DEC);
Serial.print(F(", "));
Serial.print(accel_t_gyro.value.y_accel, DEC);
Serial.print(accel_t_gyro.value.z_accel, DEC);
Serial.print(F(", at "));
Serial.print(iAccelIndex);
Serial.println(F(""));
if(iAccelIndex < ACCEL_BUFFER_COUNT && iAccelIndex > 1) {
int tempX = accel_t_gyro.value.x_accel;
int tempY = accel_t_gyro.value.y_accel;
int tempZ = accel_t_gyro.value.z_accel;
// Check min, max value
if(tempX > 16380) tempX = 16380;
if(tempY > 16380) tempY = 16380;
if(tempZ > 16380) tempZ = 16380;
if(tempX < -16380) tempX = -16380;
if(tempY < -16380) tempY = -16380;
if(tempZ < -16380) tempZ = -16380;
// We dont use negative value
tempX += 16380;
tempY += 16380;
tempZ += 16380;
char temp = (char)(tempX >> 8);
if(temp == 0x00)
temp = 0x7f;
aAccelBuffer[iAccelIndex] = temp;
iAccelIndex++;
temp = (char)(tempX);
if(temp == 0x00)
temp = 0x01;
iAccelIndex++;
temp = (char)(tempY >> 8);
if(temp == 0x00)
temp = 0x7f;
iAccelIndex++;
temp = (char)(tempY);
if(temp == 0x00)
temp = 0x01;
iAccelIndex++;
temp = (char)(tempZ >> 8);
if(temp == 0x00)
temp = 0x7f;
iAccelIndex++;
temp = (char)(tempZ);
if(temp == 0x00)
temp = 0x01;
iAccelIndex++;
// The temperature sensor is -40 to +85 degrees Celsius.
// It is a signed integer.
// According to the datasheet:
// 340 per degrees Celsius, -512 at 35 degrees.
// At 0 degrees: -512 - (340 * 35) = -12412
// Serial.print(F("temperature: "));
// dT = ( (double) accel_t_gyro.value.temperature + 12412.0) / 340.0;
// Serial.print(dT, 3);
// Serial.print(F(" degrees Celsius"));
// Serial.println(F(""));
// Print the raw gyro values.
// Serial.print(F("gyro x,y,z : "));
// Serial.print(accel_t_gyro.value.x_gyro, DEC);
// Serial.print(F(", "));
// Serial.print(accel_t_gyro.value.y_gyro, DEC);
// Serial.print(accel_t_gyro.value.z_gyro, DEC);
* MPU-6050 Sensor read/write
int MPU6050_read(int start, uint8_t *buffer, int size)
int i, n, error;
Wire.beginTransmission(MPU6050_I2C_ADDRESS);
n = Wire.write(start);
if (n != 1)
return (-10);
n = Wire.endTransmission(false); // hold the I2C-bus
if (n != 0)
return (n);
// Third parameter is true: relase I2C-bus after data is read.
Wire.requestFrom(MPU6050_I2C_ADDRESS, size, true);
i = 0;
while(Wire.available() && i<size)
buffer[i++]=Wire.read();
if ( i != size)
return (-11);
return (0); // return : no error
int MPU6050_write(int start, const uint8_t *pData, int size)
int n, error;
n = Wire.write(start); // write the start address
if (n != 1)
return (-20);
n = Wire.write(pData, size); // write data bytes
if (n != size)
return (-21);
error = Wire.endTransmission(true); // release the I2C-bus
if (error != 0)
return (error);
int MPU6050_write_reg(int reg, uint8_t data)
int error;
error = MPU6050_write(reg, &data, 1);
return (error);
* Utilities
void initBuffer() {
iAccelIndex = 2;
for(int i=iAccelIndex; i<ACCEL_BUFFER_COUNT; i++) {
aAccelBuffer[i] = 0x00;
aAccelBuffer[0] = 0xfe;
aAccelBuffer[1] = 0xfd;
aAccelBuffer[122] = 0xfd;
aAccelBuffer[123] = 0xfe;
aAccelBuffer[124] = 0x00;
조회수 4,789master님의 댓글
https://www.google.com/search?q=PulseSensorPlayground+mega2560&oq=PulseSensorPlayground+mega2560&aqs=chrome..69i57.6865j0j7&sourceid=chrome&ie=UTF-8
같은 증상이 있는지 찾아보세요
