질문게시판 > 답변 : 소스코드 질문드립니다.
TODAY408 TOTAL2,169,358
BASIC4MCU | 질문게시판 | 답변 : 소스코드 질문드립니다.
작성자 master 작성일2020-06-29 22:09 조회2,715회 댓글0건
LiquidCrystal_I2C lcd(0x27,16,2);
#include <Stepper.h>
const int stepsPerRevolution=64// 모터별 스탭 수 설정(28YBJ-48의 경우 64)
Stepper stepper(stepsPerRevolution,8,10,9,11);
SR04 sr04=SR04(ECHO_PIN,TRIG_PIN);
Servo myservo;
const int     min_distance=2,max_distance=17,step_distance=3;
const String  accessequence="234";
String        sequence_entered="";
int           length_accessequence,pos_sequence_entered=0,previous_group=-1;
unsigned long last_time=0;
const long    time_interval=1000;
  stepper.setSpeed(220);
  pinMode(GREEN_LED,OUTPUT); pinMode(WHITE_LED,OUTPUT); pinMode(RED_LED,OUTPUT);
  digitalWrite(RED_LED,1);
  lcd.init(); lcd.backlight(); lcd.clear();
  lcd.setCursor(0,0); lcd.print("Waiting...");
  for(int i=0i<length_accessequencei++){ lcd.setCursor(i,1); lcd.print("*"); }
  length_accessequence=accessequence.length();
  myservo.attach(SERVO_PIN);
  myservo.write(0);
char int_to_char(int number){
  return char(48+number);
int group_distance(int distance){
  int group=1;
  for(int i=min_distancei<=max_distancei=i+step_distance){
    if(distance>i)group++; else return group;
  return group;
int calculateDistance(){
  digitalWrite(TRIG_PIN,1); delayMicroseconds(10); digitalWrite(TRIG_PIN,0);
  long duration=pulseIn(ECHO_PIN,1);
  return duration*0.034/2;
  int sensorReading=analogRead(A0); // 조이스틱 X축 A0에 연결
  if(sensorReading<300){
    stepper.step(1); // 좌 회전
  if(sensorReading>800){
    stepper.step(-1); // 우 회전
    int distance=calculateDistance();
    if((distance<min_distance)or(distance>max_distance))return;
    int group=group_distance(distance);
    if(distance<=max_distance){
      if(not(previous_group==group)){
        previous_group=group;
        last_time=millis();
        lcd.setCursor(0,0); lcd.print("Distance="); lcd.print(group);
        if((millis()-last_time)>=time_interval){
          last_time=millis();
          digitalWrite(WHITE_LED,1); delay(100); digitalWrite(WHITE_LED,0);
          lcd.setCursor(pos_sequence_entered,1); lcd.print(group);
          sequence_entered=sequence_entered+int_to_char(group);
          if(sequence_entered==accessequence){
            lcd.setCursor(0,0); lcd.print("            ");
            lcd.setCursor(0,1); lcd.print("ACCESS GRANTED");
            digitalWrite(RED_LED,0); digitalWrite(GREEN_LED,1);
            myservo.write(90); delay(2000);
            digitalWrite(RED_LED,1); digitalWrite(GREEN_LED,0);
            myservo.write(0);
          if(++pos_sequence_entered>=length_accessequence){
            delay(500);
            sequence_entered=""pos_sequence_entered=0;
            lcd.clear();
    delay(200);
핀 연결을 알 수 있는 것은 LCD와 스텝모터 뿐입니다.
선언부가 빠진체로 첨부했나보군요
조회수 2,715
공지 사이트 이용 안내댓글[24] master 17-10-29 29743
질문 아두이노와 휴대폰을 HC-06으로 연결시켜서 블루투스연결이 끊기면 부저에서 소리가 나게 할려하는데 어떻게 해…댓글[1] 새글 졸작부수다 22-05-23 111
질문 초음파+스텝모터 도꺼비 22-05-22 23
답변 답변글 답변 : 초음파+스텝모터 master 22-05-23 25
질문 atmega128 스톱워치 작성 중 외부 인터럽트 관련 질문 드립니다.댓글[4] 이미지 마프하나 22-05-22 50
답변 답변글 답변 : atmega128 스톱워치 작성 중 외부 인터럽트 관련 질문 드립니다.댓글[1] 이미지 master 22-05-23 31
질문 서보모터제어 해당코드에서 어떤걸 추가해야할까요댓글[3] 이미지첨부파일 오소로롯 22-05-22 37
질문 Atmega128 UART통신에서 ECHO 관련 질문드립니다. dsfdfsa 22-05-22 35
질문 아두이노 서보모터제어 하나도 모르겠습니다 ㅠ댓글[2] 이미지첨부파일 오소로롯 22-05-21 51
질문 아두이노 에러질문댓글[1] 이미지첨부파일 리니어 22-05-21 45
질문 아두이노 DRV2605 헵틱 모터 드라이버댓글[4] gano 22-05-21 52
