질문게시판 > 답변 : 답변 : 소스코드 질문드립니다.
TODAY1,095 TOTAL2,162,936
BASIC4MCU | 질문게시판 | 답변 : 답변 : 소스코드 질문드립니다.
작성자 master 작성일2020-06-30 19:27 조회3,015회 댓글0건
// DateTime : 2020-06-30 오후 7:33:08
#include <Stepper.h>
const int stepsPerRevolution=64// 모터별 스탭 수 설정(28YBJ-48의 경우 64)
Stepper stepper(stepsPerRevolution,8,9,10,11);
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27,16,2); //LCD 0x27,16,2
#include <Servo.h>
#define SERVO_PIN 2
Servo myservo;
#include "SR04.h"
#define TRIG_PIN  3
#define ECHO_PIN  4
SR04 sr04=SR04(ECHO_PIN,TRIG_PIN);
#define GREEN_LED 5
#define WHITE_LED 6
#define RED_LED   7
const int min_distance=2,max_distance=17,step_distance=3;
const String accessequence="234";
String sequence_entered="";
int length_accessequence,pos_sequence_entered=0,previous_group=-1;
unsigned long last_time=0;
const long time_interval=1000;
  pinMode(GREEN_LED,OUTPUT); pinMode(WHITE_LED,OUTPUT); pinMode(RED_LED,OUTPUT);
  lcd.init(); lcd.backlight();
  lcd.clear(); lcd.setCursor(0,0); lcd.print("Waiting...");
  for(int i=0i<length_accessequencei++){ lcd.setCursor(i,1); lcd.print("*"); }
  digitalWrite(RED_LED,HIGH);
  length_accessequence=accessequence.length();
  myservo.attach(SERVO_PIN); myservo.write(0);
  stepper.setSpeed(220); // 속도 설정
char int_to_char(int number){
  return char(48+number);
int group_distance(int distance){
  int group=1;
  for(int i=min_distancei<=max_distancei=i+step_distance){
    if(distance<=i)return group;
    else           group++;
  return group;
int calculateDistance(){
  long duration;
  digitalWrite(TRIG_PIN,HIGH); delayMicroseconds(10); digitalWrite(TRIG_PIN,LOW);
  duration=pulseIn(ECHO_PIN,HIGH);
  return duration*0.034/2;
  int sensorReading=analogRead(A0);      // 조이스틱 X축 A0에 연결
  if(sensorReading<300)stepper.step(1);  // 좌 회전
  if(sensorReading>800)stepper.step(-1); // 우 회전
  int distance=calculateDistance();
  if((distance<min_distance)or(distance>max_distance))return;
  int group=group_distance(distance);
  if(distance<=max_distance){
    if(not(previous_group==group)){ previous_group=grouplast_time=millis();
      lcd.setCursor(0,0); lcd.print("Distance="); lcd.print(group);
      if((millis()-last_time)>=time_interval){ last_time=millis();
        digitalWrite(WHITE_LED,HIGH); delay(100); digitalWrite(WHITE_LED,LOW);
        lcd.setCursor(pos_sequence_entered,1); lcd.print(group);
        sequence_entered=sequence_entered+int_to_char(group);
        pos_sequence_entered++;
        if(sequence_entered==accessequence){
          lcd.setCursor(0,0); lcd.print("            ");
          lcd.setCursor(0,1); lcd.print("ACCESS GRANTED");
          digitalWrite(RED_LED,LOW); digitalWrite(GREEN_LED,HIGH); myservo.write(90); delay(2000);
          digitalWrite(RED_LED,HIGH); digitalWrite(GREEN_LED,LOW); myservo.write(0);
        if(pos_sequence_entered>=length_accessequence){
          delay(500);
          sequence_entered=""pos_sequence_entered=0;
          lcd.clear(); lcd.setCursor(0,0); lcd.print("Distance="); lcd.print(group);
  delay(200);
조회수 3,015
공지 사이트 이용 안내댓글[24] master 17-10-29 29641
질문 아트메가 128 을 이용해서 블루투스 + 적외선 센서 코딩 중 물어볼게있습니다!! 새글 noster 19:32 12
질문 아두이노 블루투스 통신 관련 질문 있습니다!! 새글 블루툿 10:51 21
질문 컴퓨터 usb연결시 정상 작동하나 9V건전지 외부전원 연결 시 작동하지 않는 문제댓글[3] 이미지첨부파일 보겐을운용 22-05-19 186
질문 온도센서로 서보모터 제어 코딩댓글[1] 진수네1조 22-05-18 67
질문 아두이노 우노 2개와 앱인벤터끼리의 블루투스 통신 방법댓글[3] 이미지첨부파일 pyoleo 22-05-17 114
