BASIC4MCU | 질문게시판 | 답변 : 소스 합쳐주세요
작성자 master 작성일2020-06-30 19:50 조회3,136회 댓글1건
https://www.basic4mcu.com/bbs/board.php?bo_table=gac&wr_id=13015
// MCU BASIC: https://www.basic4mcu.com// DateTime : 2020-06-30 오후 7:56:14// by Ok-Hyun Park//#include <Arduino.h>#include <Wire.h>#include <SoftwareSerial.h>SoftwareSerial btSerial(A4,A5);//int mq3Pin=A3; // MQ-3 센서핀을 아두이노 보드의 A3 핀으로 설정int redPin=7; // LED 센서의 R 핀을 아두이노 보드의 7번 핀으로 설정int greenPin=6; // LED 센서의 G 핀을 아두이노 보드의 6번 핀으로 설정int bluePin=5; // LED 센서의 B 핀을 아두이노 보드의 5번 핀으로 설정//String keyPressed;//String btGet(){String CMD;if(btSerial.available()>0){char command=btSerial.read();switch(command){case 'R': CMD="Forward"; break;case 'Q': CMD="Backward"; break;case 'P': CMD="Right"; break;case 'O': CMD="Left"; break;case 'S': CMD="Stop"; break;default: CMD="Stop"; break;}}return CMD;}//void move(int direction,int speed){if (direction==1){ analogWrite(6,speed); analogWrite(9,0); analogWrite(10,speed); analogWrite(11,0); }else if(direction==2){ analogWrite(6,0); analogWrite(9,speed); analogWrite(10,0); analogWrite(11,speed); }else if(direction==3){ analogWrite(6,speed); analogWrite(9,0); analogWrite(10,0); analogWrite(11,0); }else if(direction==4){ analogWrite(6,0); analogWrite(9,0); analogWrite(10,speed); analogWrite(11,0); }else if(direction==5){ analogWrite(6,speed); analogWrite(9,0); analogWrite(10,0); analogWrite(11,speed); }else if(direction==6){ analogWrite(6,0); analogWrite(9,speed); analogWrite(10,speed); analogWrite(11,0); }}//long Ranging(int Trig_pin,int Echo_pin){long duration,distacne_cm;long Time_out;Time_out=30000;pinMode(Trig_pin,OUTPUT); pinMode(Echo_pin,INPUT);digitalWrite(Trig_pin,LOW); delayMicroseconds(2);digitalWrite(Trig_pin,HIGH); delayMicroseconds(10); digitalWrite(Trig_pin,LOW);duration=pulseIn(Echo_pin,HIGH,Time_out);if(duration==0){ duration=Time_out; }distacne_cm=duration /29/2;return distacne_cm;}//void _delay(float seconds){long endTime=millis()+seconds*1000;while(millis()<endTime)_loop();}//void setup(){btSerial.begin(9600);pinMode(6,OUTPUT); pinMode(9,OUTPUT); pinMode(10,OUTPUT); pinMode(11,OUTPUT);analogWrite(6,LOW); analogWrite(9,LOW); analogWrite(10,LOW); analogWrite(11,LOW);pinMode(A0,OUTPUT); pinMode(A1,OUTPUT); pinMode(A2,OUTPUT);keyPressed=btGet();btSerial.println("AT"); _delay(2);String btcmd="AT+NAME";btcmd.concat("SPAC01");btSerial.println(btcmd); _delay(2);}//void loop(){int v=analogRead(mq3Pin);if(v>400){analogWrite(6,0); analogWrite(9,0); analogWrite(10,0); analogWrite(11,0); // STOP}else{keyPressed=btGet();if(keyPressed=="Forward"){ move(1,100/100.0*255); }if(keyPressed=="Left"){ move(3,100/100.0*255); }if(keyPressed=="Right"){ move(4,100/100.0*255); }if(Ranging(3,4)<10){ move(1,0/100.0*255); }if(Ranging(3,4)<60){ analogWrite(A0,0); analogWrite(A1,0); analogWrite(A2,255); }if(Ranging(3,4)<40){ analogWrite(A0,0); analogWrite(A1,255); analogWrite(A2,0); }if(Ranging(3,4)<20){ analogWrite(A0,255); analogWrite(A1,0); analogWrite(A2,0); }if(keyPressed=="Backward"){ move(2,100/100.0*255); }}}
조회수 3,136우경민님의 댓글
우경민 작성일알코올 센서 부분은 어딘가여?
