질문게시판 > 소스 코드 질문좀 드리겠습니다..!
TODAY51 TOTAL1,177,568
BASIC4MCU | 질문게시판 | 소스 코드 질문좀 드리겠습니다..!
작성자 코딩공부하자 작성일2020-07-21 11:05 조회63회 댓글0건
#define F_CPU 8000000UL
unsigned char FND[10]={0x84,0xF5,0x4C,0x64,0x35,0x26,0x06,0xB4,0x04,0x34};
unsigned char fnd_sel[2] = {0x7F, 0xBF};
unsigned char Cnt1=0, Cnt2=0, Cnt3=0, Stop_cnt=0, cnt=0, ON_flag=0;
unsigned short ten_us_cnt1 = 0, ten_us_cnt2 = 0;
volatile unsigned char key_flag=0, cnt_mode=0, mode_flag=0, flag=0, Stop_flag=0;
volatile unsigned char mode=1, old_ON_mode=0,ON_mode=0,old_OFF_mode=0,OFF_mode=0;
volatile unsigned char count=0, ON_cnt=0,OFF_cnt=0;
void display_fnd(int count)  // FND 표시
int i, fnd[2];
fnd[1] = (count/10)%10;
fnd[0] = count%10;
for (i=0; i<2; i++)
{ PORTD= FND[fnd[i]];
PORTB= fnd_sel[i];
_delay_ms(2);
ISR(TIMER0_OVF_vect)
TCNT0 = 256-125;
if((PIND&0x04)==4)
if(flag == 0)
old_OFF_mode=OFF_mode;
if(OFF_cnt>=500)OFF_mode=2;
else { OFF_mode=1; }
flag=1; ON_cnt=0; OFF_cnt=0;
if(ON_cnt<3000) { ON_cnt++; }
if(flag == 1)
old_ON_mode=ON_mode;
if(ON_cnt>=500)ON_mode=2;
else { ON_mode=1; }
flag=0; ON_cnt=0; OFF_cnt=0;
if(OFF_cnt<3000) { OFF_cnt++; }
if(cnt_mode == 1)
count = 0;
while((PIND&0x04)==4)
Cnt2++;
if(Cnt2 == 75)
Cnt2 = 0;
count++;
//Out_Value();
if(count > 64) { count = 64; }
if(count == 64)
Cnt3++;
if(Cnt3 == 20)
Cnt3 = 0;
mode = 1;
cnt_mode = 0;
count = 0;
display_fnd(count);
while((PIND&0x04)!=4)
Stop_cnt++;
if(Stop_cnt == 500)
Stop_cnt = 0;
mode = 1;
cnt_mode = 0;
count = 0;
//Out_Value();
display_fnd(count);
ISR(TIMER1_COMPA_vect)
if(cnt_mode == 1)
ten_us_cnt1++;
ten_us_cnt2++;
if (ten_us_cnt1 < 105) PORTB |= 0x02;
else if (ten_us_cnt1 < 210) PORTB &= ~0x02;   // 8us freq : 600Hz
PORTB &= ~0x02;
ten_us_cnt1 = 0;
if (ten_us_cnt2 < 1750) PORTB |= 0x04;
else if (ten_us_cnt2 < 3500) PORTB &= ~0x04;  // 8us freq : 36Hz
else if (ten_us_cnt2 == 3500)
PORTB &= ~0x04;
ten_us_cnt2 = 0;
DDRD = 0xFB;
DDRB = 0xC7;
DDRC = 0x3F;
TIMSK0 = 0x01;    // Overflow
TCCR0B = 0x03;    // 64분주
TCNT0 = 256-125;  // 1ms
TIMSK1 = 0x02;    // Compare A Match
TCCR1B = 0x0B;   // CTC mode 64분주 8us
SREG |= 0x80;
if((old_ON_mode==1)&&(OFF_mode==1)&&(ON_mode==1))  // 더블클릭 모드 변경
if(key_flag == 0)
key_flag = 1;
old_OFF_mode=old_ON_mode=OFF_mode=ON_mode=0;
mode++;
if(mode > 3) { mode = 1; }
else { key_flag=0; }
if(mode == 1)
PORTD = 0xEB;
PORTB = 0x30;
if((PIN4&0x04)==4)
cnt=0;
while((PIND&0x04)==4) { _delay_ms(10); if(++cnt>100) break; }    // 누르고 있는 시간
if(cnt>100) { cnt_mode = 1; }
else { cnt = 0; }
지금 제가 만들어보고있는 소스인데요. 현재 mode = 1에서 스위치를 누르고있으면 TIMER0에 있는 cnt_mode에 들어가 스위치를 누르고 있는동안 count가 64까지 증가하는 하고, 스위치를 일정시간 동안 떼고있으면 다시 mode = 1로 돌아가는 코드 입니다. 현재 잘 안되는게 제가 포트에서 주파수를 내보내려고하는데 TIMER1 CTC 64분주로 8us를 만들어놓고, TIMER1 인터럽트에서 포트에서 주파주를 나오도록 코드를 만들어보았는데요. TIMER0의 cnt_mode = 1 일때 스위치를 누르는 동안 같이 주파수를 내보내도록 하고싶습니다.
unsigned short ten_us_cnt1, ten_us_cnt2;
int i, fnd[2];
fnd[0] = count%10;
for (i=0; i<2; i++)
PORTB= fnd_sel[i];
_delay_ms(2);
if(cnt_mode == 1)
ten_us_cnt1++;
ten_us_cnt2++;
PORTB &= ~0x02;
ten_us_cnt1 = 0;
PORTB &= ~0x04;
ten_us_cnt2 = 0;
DDRB = 0xC7;
TCCR1B = 0x0B;
TIMSK1 = 0x02;
SREG |= 0x80;
ten_us_cnt1 = 0;
ten_us_cnt2 = 0;
이 코드로만 했을 때는 주파수가 PORT에서 나오는 것을 확인했습니다. PORTB에서 충돌이 나서 FND에 숫자 count 되는게 안나오는 거같은데 다른 포트에 영향 주지 않도록 PORTB |= ( 1 << PORTB1); 이런식으로도 변경을 해서 해봤는데 안되네요..ㅠㅠ 혹시 저 문제가 포트 충돌로 인한 문제가 맞을까요..? 맞다면 다른 포트에 영향을 주지않고, 사용할 수 있는 방법이 있는지 궁금합니다..!
조회수 63
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 1961
공지 사이트 이용 안내댓글[12] master 17-10-29 12051
공지 [무료 공개] 소스코드 하이라이트 v2.0 beta [2013.02.07]댓글[1] 이미지첨부파일 master 18-01-23 4560
질문 메가로 진행중인데 질문드려요,,댓글[1] dongeun9 20-07-31 28
질문 아두이노 우노 -> 메가댓글[2] dongeun9 20-07-30 43
질문 아두이노 우노+DC모터 제어 질문드립니다.댓글[1] 빈군 20-07-30 35
질문 아두이노어플 통신 질문드립니다댓글[1] dongeun9 20-07-29 31
질문 모터를 작동시키기만 하면, 외부인터럽트에서 이상이 발생합니다.댓글[1] 꾸람이 20-07-29 38
질문 질문 드립니다.댓글[1] 알려주세요제발ㅠㅠ 20-07-29 33
질문 질문드립니다 수파도프 20-07-28 33
답변 답변글 답변 : 질문드립니다 master 20-07-28 37
질문 아두이노 우노 -> 메가 질문드립니다댓글[2] dongeun9 20-07-28 36
질문 ATmega와 안드로이드 블루투스 연결 질문입니다. 구래몬 20-07-28 32
답변 답변글 답변 : ATmega와 안드로이드 블루투스 연결 질문입니다.댓글[1] master 20-07-28 33
질문 아두이노 RC카 양쪽 모터속도제어 질문입니다.댓글[3] 첨부파일 MaTD 20-07-27 47
질문 통신프로토콜 ? 세상통합 20-07-27 33
질문 타이머 인터럽트를 이용한 스텝모터 제어 질문입니다.댓글[6] 꾸람이 20-07-26 67
질문 매우 초보적인 아두이노 코딩질문입니다.댓글[1] 이미지첨부파일 화이팅dP 20-07-23 71
질문 아두이노 우노 푸쉬 버튼 서보모터 작동 관련 초보 질문입니다.댓글[1] 이미지 구름신 20-07-23 50
질문 적외선 거리센서 탐지범위 설정하는 방법 알려주시면 감사하겠습니다. 큐큐큐큨 20-07-22 44
답변 답변글 답변 : 적외선 거리센서 탐지범위 설정하는 방법 알려주시면 감사하겠습니다. master 20-07-22 56
질문 코딩 질문.. 전자학습자 20-07-22 59
답변 답변글 답변 : 코딩 질문..댓글[4] master 20-07-22 75
현재글 소스 코드 질문좀 드리겠습니다..! 코딩공부하자 20-07-21 64
답변 답변글 답변 : 소스 코드 질문좀 드리겠습니다..! master 20-07-21 47
답변 답변글 답변 : 답변 : 소스 코드 질문좀 드리겠습니다..!댓글[4] 코딩공부하자 20-07-22 73
질문 아두이노 스텝모터 도와주세요~ 랩돌이 20-07-20 70
답변 답변글 답변 : 아두이노 스텝모터 도와주세요~댓글[1] master 20-07-20 86
질문 희미한 LED 문제댓글[6] 전자학습자 20-07-20 119
질문 소스 코딩 문제점을 찾고싶어요댓글[1] 첨부파일 bas213 20-07-17 107
