질문게시판 > 답변 : 소스 코드 질문좀 드리겠습니다..!
TODAY1,388 TOTAL1,177,480
BASIC4MCU | 질문게시판 | 답변 : 소스 코드 질문좀 드리겠습니다..!
작성자 master 작성일2020-07-21 21:13 조회46회 댓글0건
// DateTime : 2020-07-21 오후 9:18:46
#define F_CPU 8000000UL
#include <avr/io.h>
#include <util/delay.h>
#include <avr/interrupt.h>
volatile unsigned char FND[10]={0x84,0xF5,0x4C,0x64,0x35,0x26,0x06,0xB4,0x04,0x34};
volatile unsigned char fnd_sel[2]={0x7F,0xBF};
volatile unsigned char Cnt1=0,Cnt2=0,Cnt3=0,Stop_cnt=0,cnt=0,ON_flag=0;
volatile unsigned int  ten_us_cnt1=0,ten_us_cnt2=0;
volatile unsigned char key_flag=0,cnt_mode=0,mode_flag=0,flag=0,Stop_flag=0;
volatile unsigned char mode=1,old_ON_mode=0,ON_mode=0,old_OFF_mode=0,OFF_mode=0;
volatile unsigned char count=0,ON_cnt=0,OFF_cnt=0;
void display_fnd(int count){ // FND 표시
  int i,fnd[2];
  fnd[1]=(count/10)%10;
  fnd[0]=count%10;
  for(i=0i<2i++){ PORTD=FND[fnd[i]]; PORTB=fnd_sel[i]; _delay_ms(2); }
ISR(TIMER0_OVF_vect){
  TCNT0=256-125;
  if(PIND&4){
    if(flag==0){ flag=1;
      old_OFF_mode=OFF_mode;
      if(OFF_cnt>=500)OFF_mode=2else OFF_mode=1;
      ON_cnt=0OFF_cnt=0;
      if(ON_cnt<3000){ ON_cnt++; }
    if(flag==1){ flag=0
      old_ON_mode=ON_mode;
      if(ON_cnt>=500)ON_mode=2else ON_mode=1;
      ON_cnt=0OFF_cnt=0;
      if(OFF_cnt<3000)OFF_cnt++;
  if(cnt_mode==1){
    count=0;
    while(PIND&4){
      if(++Cnt2==75){ Cnt2=0;
        //Out_Value();
        if(count<64)count++;
          if(++Cnt3==20){ Cnt3=0;
            mode=1cnt_mode=0count=0;
      display_fnd(count);
    while(PIND&4)==0){
      if(++Stop_cnt==500){
        Stop_cnt=0mode=1cnt_mode=0count=0//Out_Value();
      display_fnd(count);
ISR(TIMER1_COMPA_vect){
  if(cnt_mode==1){
    ten_us_cnt1++;
    if     (ten_us_cnt1<105){ PORTB|= 0x02;  }
    else if(ten_us_cnt1<210){ PORTB&=~0x02;  } // 8us freq: 600Hz
    else                    { ten_us_cnt1=0; }
    ten_us_cnt2++;
    if     (ten_us_cnt21750){ PORTB|= 0x04;  }
    else if(ten_us_cnt23500){ PORTB&=~0x04;  } // 8us freq: 36Hz
    else                      { ten_us_cnt2=0; }
int main(void){
  DDRB=0xC7DDRC=0x3FDDRD=0xFB;
  TCNT0=256-125TCCR0B=0x03TIMSK0=0x01// 64분주 // Overflow // 1ms
                 TCCR1B=0x0BTIMSK1=0x02// CTC mode 64분주 8us // Compare A Match
  SREG|=0x80;
    if((old_ON_mode==1)&&(OFF_mode==1)&&(ON_mode==1)){ // 더블클릭 모드 변경
      if(key_flag==0){ key_flag=1;
        old_OFF_mode=old_ON_mode=OFF_mode=ON_mode=0;
        if(++mode>3){ mode=1; }
    elsekey_flag=0; }
    if(mode==1){
      PORTD=0xEBPORTB=0x30;
      if(PIN4&4){
        cnt=0;
        while(PIND&4){ _delay_ms(10); if(++cnt>100)break; } // 누르고 있는 시간
        if(cnt>100){ cnt_mode=1; }
      elsecnt=0; }
타이머0 인터럽트 안에서 루프를 돌면서 디스플레이도 하고 키체크를 하고 있는데요
어떤 인터럽트 안에서 놀고 있으면 메인함수 및 다른 인터럽트는 실행되지 않습니다.
조회수 46
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 1960
공지 사이트 이용 안내댓글[12] master 17-10-29 12051
공지 [무료 공개] 소스코드 하이라이트 v2.0 beta [2013.02.07]댓글[1] 이미지첨부파일 master 18-01-23 4559
질문 메가로 진행중인데 질문드려요,,댓글[1] dongeun9 20-07-31 28
질문 아두이노 우노 -> 메가댓글[2] dongeun9 20-07-30 43
질문 아두이노 우노+DC모터 제어 질문드립니다.댓글[1] 빈군 20-07-30 35
질문 아두이노어플 통신 질문드립니다댓글[1] dongeun9 20-07-29 31
질문 모터를 작동시키기만 하면, 외부인터럽트에서 이상이 발생합니다.댓글[1] 꾸람이 20-07-29 35
질문 질문 드립니다.댓글[1] 알려주세요제발ㅠㅠ 20-07-29 33
질문 질문드립니다 수파도프 20-07-28 33
답변 답변글 답변 : 질문드립니다 master 20-07-28 37
질문 아두이노 우노 -> 메가 질문드립니다댓글[2] dongeun9 20-07-28 36
질문 ATmega와 안드로이드 블루투스 연결 질문입니다. 구래몬 20-07-28 32
답변 답변글 답변 : ATmega와 안드로이드 블루투스 연결 질문입니다.댓글[1] master 20-07-28 32
질문 아두이노 RC카 양쪽 모터속도제어 질문입니다.댓글[3] 첨부파일 MaTD 20-07-27 47
질문 통신프로토콜 ? 세상통합 20-07-27 32
질문 타이머 인터럽트를 이용한 스텝모터 제어 질문입니다.댓글[6] 꾸람이 20-07-26 66
질문 매우 초보적인 아두이노 코딩질문입니다.댓글[1] 이미지첨부파일 화이팅dP 20-07-23 71
질문 아두이노 우노 푸쉬 버튼 서보모터 작동 관련 초보 질문입니다.댓글[1] 이미지 구름신 20-07-23 48
질문 적외선 거리센서 탐지범위 설정하는 방법 알려주시면 감사하겠습니다. 큐큐큐큨 20-07-22 44
답변 답변글 답변 : 적외선 거리센서 탐지범위 설정하는 방법 알려주시면 감사하겠습니다. master 20-07-22 55
질문 코딩 질문.. 전자학습자 20-07-22 59
답변 답변글 답변 : 코딩 질문..댓글[4] master 20-07-22 74
질문 소스 코드 질문좀 드리겠습니다..! 코딩공부하자 20-07-21 62
현재글 답변글 답변 : 소스 코드 질문좀 드리겠습니다..! master 20-07-21 47
답변 답변글 답변 : 답변 : 소스 코드 질문좀 드리겠습니다..!댓글[4] 코딩공부하자 20-07-22 72
질문 아두이노 스텝모터 도와주세요~ 랩돌이 20-07-20 70
답변 답변글 답변 : 아두이노 스텝모터 도와주세요~댓글[1] master 20-07-20 85
질문 희미한 LED 문제댓글[6] 전자학습자 20-07-20 119
질문 소스 코딩 문제점을 찾고싶어요댓글[1] 첨부파일 bas213 20-07-17 107
