질문게시판 > 아두이노 RC카 양쪽 모터속도제어 질문입니다.
TODAY1,386 TOTAL1,177,478
BASIC4MCU | 질문게시판 | 아두이노 RC카 양쪽 모터속도제어 질문입니다.
작성자 MaTD 작성일2020-07-27 17:59 조회46회 댓글3건
첨부파일
양쪽 모터가 계속 속도도 안맞고 전체적으로 잘못된거 같습니다...
에러도 안나서 디버깅하기도 매우 힘드네요...ㅜㅜ
#include <Servo.h>
Servo sensorMotor;
#define leftMotorSpd 6  // motor enable control : speed control,PWM output
#define rightMotorSpd 3   // motor enable control : speed control,PWM output
#define leftMotorForward 8// motor IN1 : '1’
#define leftMotorBackward 7 // motor IN2 : '0’
#define rightMotorForward 4 // motor IN3 : '1’
#define rightMotorBackward 2  // motor IN4 : '0’
#define sonicSensorTrig  12
#define sonicSensorEcho 13
#define sonicSensor 11
#define minPosition 1000
#define maxPosition 2000
#define centerPosition 1500
#define toPosition 165
int motorSpeed;   // motor speed range : 0-255
int speedLevel;
bool forwardFlag = false;
long distArray[7];
typedef enum{
  initState,  // 0
  sensingState, // 1
  detectState,  // 2
  goforward12State, // 3
  goforward11State, // 4
  goforward10State, // 5
  goforward13State, // 6
  goforward14State, // 7
  turnrightState, // 8
  turnleftState,  // 9
  gobackwardState,  //10
  safetyspeedState, //11
  stopState //12
}states;
typedef enum{
  direct9,
  direct10,
  direct11,
  direct12,
  direct13,
  direct14,
  direct15
}directs;
states state;
directs crntDirect, prevDirect;
  // put your stup code here, to run once:
  sensorMotor.attach (sonicSensor, minPosition, maxPosition);
  sensorMotor.writeMicroseconds (centerPosition);
  delay(500);
  pinMode(sonicSensorTrig, OUTPUT);
  pinMode(sonicSensorEcho, INPUT);
  pinMode(leftMotorForward, OUTPUT);
  pinMode(leftMotorBackward, OUTPUT);
  pinMode(leftMotorSpd, OUTPUT);
  pinMode(rightMotorForward, OUTPUT);
  pinMode(rightMotorBackward, OUTPUT);
  pinMode(rightMotorSpd, OUTPUT);
  crntDirect = direct12;
  state = initState;
// state = stopState;
// testMotors();
  switch (state) {
    case initState:
     Serial.println("    initMotors()");
      initMotors();
      speedLevel = 1;
      //initdistanceArray();
      state = sensingState;
    case sensingState:
      Serial.println("    sensingDistance()");
      sensingDistance();
      delay(2);
      state = detectState;
    case detectState:
      Serial.println ("   wheretoGo()");
      prevDirect = crntDirect;
      wheretoGO();
    case goforward12State:
      Serial.println ("   goforward12() ");
      distArray [3] = senseD ();
      if (distArray [3] >= 1000) {
        speedLevel++;
        forward();
      Serial.print("  speed level= ");
      Serial.println(speedLevel);
        if(speedLevel >= 6) speedLevel=6;
        state = goforward12State;
      else {
        speedLevel--;
        forward();
        if(speedLevel <= 1) speedLevel=1;
      if (distArray[3] <= 300) {
        state = safetyspeedState;
      Serial.print("  speed level = ");
    case goforward11State:
      forward ();
      delay (50);
      state = stopState;
    case goforward10State:
      forward ();
      delay (50);
      state = stopState;
    case goforward13State:
      forward ();
      delay (50);
      state = stopState;
    case goforward14State:
      forward ();
      state = stopState;
    case turnrightState:
      forward ();
      delay (50);
      state = stopState;
    case turnleftState:
      forward ();
      delay (50);
      state = stopState;
    case gobackwardState:
      backward ();
      delay (50);
      state = stopState;
    case safetyspeedState:
      forward ();
      delay (50);
      state = stopState;
    case stopState:
      stopMotors ();
      state = stopState;
  Serial.print("  state = ");
  Serial.println (state);
void sensingDistance(void) {
  int j=6;
  for(int i = maxPosition; i >= minPosition; i -= toPosition) {
    sensorMotor.writeMicroseconds (i);
//    sensorMotor.write(i);
    delay(150);
    distArray[j] = senseD();
    j--;
 sensorMotor.writeMicroseconds(centerPosition);
long senseD(void) {
  long duration, dist;
  // digitalWrite(sonicSensorTrig, LOW);
  // delay(2);
  digitalWrite(sonicSensorTrig, HIGH);
  delay(20);
  duration = pulseIn(sonicSensorEcho, HIGH);
  dist = ((duration * 340) / 1000) / 2;
  Serial.println(" ");
  Serial.print("  distance = ");
  Serial.println(dist);
  Serial.println(duration);
  return dist;
void wheretoGO(void) {
  if(distArray[3] >= 500) { state = goforward12State; crntDirect = direct12;}
  else if(distArray[4] >= 500) state = goforward13State;
  else if(distArray[2] >= 500) state = goforward11State;
  else if(distArray[1] >= 500) state = goforward10State;
  else if(distArray[5] >= 500) state = goforward14State;
  else if(distArray[6] >= 500) state = turnrightState;
  else if(distArray[0] >= 500) state = turnleftState;
  else state = safetyspeedState;
  if(distArray[4] >= 30) state = goforward13State;
  else if(distArray[4] >= 29) state = safetyspeedState;
  if(distArray[5] >= 30) state = goforward14State;
  if(distArray[6] >= 30) state = turnrightState;
  if(distArray[2] >= 30) state = goforward11State;
  if(distArray[1] >= 30) state = goforward10State;
  if(distArray[0] >= 30) state = turnleftState;
void initMotors(void) {
  digitalWrite(leftMotorForward, HIGH);
  digitalWrite(leftMotorBackward, LOW);
  digitalWrite(rightMotorForward, HIGH);
  digitalWrite(rightMotorBackward, LOW);
  analogWrite(leftMotorSpd, 0);
  analogWrite(rightMotorSpd, 0);
void forward(void) {
  if(speedLevel==1) {
    analogWrite(leftMotorSpd, 40);
    analogWrite(rightMotorSpd, 40);
  if(speedLevel==2) {
    analogWrite(leftMotorSpd, 80);
    analogWrite(rightMotorSpd, 80);
  if(speedLevel==3) {
    analogWrite(leftMotorSpd, 120);
    analogWrite(rightMotorSpd, 120);
  if(speedLevel==4) {
    analogWrite(leftMotorSpd, 160);
    analogWrite(rightMotorSpd, 160);
  if(speedLevel==5) {
    analogWrite(leftMotorSpd, 200);
    analogWrite(rightMotorSpd, 200);
  if(speedLevel==6) {
    analogWrite(leftMotorSpd, 240);
    analogWrite(rightMotorSpd, 240);
  delay(20);
void backward(void) {
  if(speedLevel==1) {
  delay(20);
void stopMotors(void) {
  delay(10);
void initdistanceArry(void) {
  for(int i=0; i<=6; i++)
      distArray[i]=0;
void testMotors(void) {
  Serial.print("  testMotors ");
  for (int i=40; i<=150; i+=10)
    analogWrite(leftMotorSpd, i);
    analogWrite(rightMotorSpd, i);
    delay(500);
  for (int i=150; i>=40; i-=5)
    delay(500);
댓글 3
조회수 46
양쪽 모터(및 바퀴) 속도가 다른 경우가 많이 있습니다.
모터 문제가 있을 수도 있고 바퀴 문제가 있을 수도 있으며 두 가지 모두 문제가 있을 수도 있습니다.
MaTD님의 댓글
MaTD 작성일
양쪽 속도를 코드로 제어하려고 하는데 어떻게 해야할까요???
현재 오른쪽 모터가 더 강하게 돌아서 계속 오른쪽으로 회전합니다.
if(speedLevel==1) {
    analogWrite(rightMotorSpd, 35); // analogWrite(rightMotorSpd, 40);
오른쪽을 약하게 주면 되겠죠
  for (int i=150; i>=40; i-=5)  {
    analogWrite(rightMotorSpd, i-5); // analogWrite(rightMotorSpd, i);
    delay(500);
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 1960
공지 사이트 이용 안내댓글[12] master 17-10-29 12051
공지 [무료 공개] 소스코드 하이라이트 v2.0 beta [2013.02.07]댓글[1] 이미지첨부파일 master 18-01-23 4559
질문 메가로 진행중인데 질문드려요,,댓글[1] dongeun9 20-07-31 28
질문 아두이노 우노 -> 메가댓글[2] dongeun9 20-07-30 43
질문 아두이노 우노+DC모터 제어 질문드립니다.댓글[1] 빈군 20-07-30 35
질문 아두이노어플 통신 질문드립니다댓글[1] dongeun9 20-07-29 31
질문 모터를 작동시키기만 하면, 외부인터럽트에서 이상이 발생합니다.댓글[1] 꾸람이 20-07-29 35
질문 질문 드립니다.댓글[1] 알려주세요제발ㅠㅠ 20-07-29 33
질문 질문드립니다 수파도프 20-07-28 33
답변 답변글 답변 : 질문드립니다 master 20-07-28 37
질문 아두이노 우노 -> 메가 질문드립니다댓글[2] dongeun9 20-07-28 36
질문 ATmega와 안드로이드 블루투스 연결 질문입니다. 구래몬 20-07-28 32
답변 답변글 답변 : ATmega와 안드로이드 블루투스 연결 질문입니다.댓글[1] master 20-07-28 32
현재글 아두이노 RC카 양쪽 모터속도제어 질문입니다.댓글[3] 첨부파일 MaTD 20-07-27 47
질문 통신프로토콜 ? 세상통합 20-07-27 32
질문 타이머 인터럽트를 이용한 스텝모터 제어 질문입니다.댓글[6] 꾸람이 20-07-26 66
질문 매우 초보적인 아두이노 코딩질문입니다.댓글[1] 이미지첨부파일 화이팅dP 20-07-23 70
질문 아두이노 우노 푸쉬 버튼 서보모터 작동 관련 초보 질문입니다.댓글[1] 이미지 구름신 20-07-23 46
질문 적외선 거리센서 탐지범위 설정하는 방법 알려주시면 감사하겠습니다. 큐큐큐큨 20-07-22 43
답변 답변글 답변 : 적외선 거리센서 탐지범위 설정하는 방법 알려주시면 감사하겠습니다. master 20-07-22 55
질문 코딩 질문.. 전자학습자 20-07-22 58
답변 답변글 답변 : 코딩 질문..댓글[4] master 20-07-22 74
질문 소스 코드 질문좀 드리겠습니다..! 코딩공부하자 20-07-21 62
답변 답변글 답변 : 소스 코드 질문좀 드리겠습니다..! master 20-07-21 46
답변 답변글 답변 : 답변 : 소스 코드 질문좀 드리겠습니다..!댓글[4] 코딩공부하자 20-07-22 72
질문 아두이노 스텝모터 도와주세요~ 랩돌이 20-07-20 70
답변 답변글 답변 : 아두이노 스텝모터 도와주세요~댓글[1] master 20-07-20 85
질문 희미한 LED 문제댓글[6] 전자학습자 20-07-20 119
질문 소스 코딩 문제점을 찾고싶어요댓글[1] 첨부파일 bas213 20-07-17 107
