질문게시판 > 모터를 작동시키기만 하면, 외부인터럽트에서 이상이 발생합니다.
TODAY1,412 TOTAL1,177,504
BASIC4MCU | 질문게시판 | 모터를 작동시키기만 하면, 외부인터럽트에서 이상이 발생합니다.
작성자 꾸람이 작성일2020-07-29 10:04 조회37회 댓글1건
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
261
262
263
264
265
266
267
268
269
270
271
272
273
274
275
276
277
278
279
280
281
282
283
284
285
286
287
288
289
290
291
292
293
294
*Author Teemu M꼗tykallio
*Plot TMC2130 or TMC2660 motor load using the stallGuard value.
*You can finetune the reading by changing the STALL_VALUE.
*This will let you control at which load the value will read 0
*and the stall flag will be triggered.This will also set pin DIAG1 high.
*A higher STALL_VALUE will make the reading less sensitive and
*a lower STALL_VALUE will make it more sensitive.
*You can control the rotation speed with
*0 Stop
*1 Resume
*+Speed up
*-Slow down
#include <Arduino.h>
#include <TMCStepper.h>
#include <IRremote.h>
#define INDEX_PIN 7
#define STALL_VALUE     20 //[0..255]
#define TOFF_VALUE        3 //[1...15]stealthchop=3
#define EN_PIN           10 // Enable
#define EN_PIN2           11 // Enable
#define photo1          20
#define photo2          19
#define photo3          13
#define photo4          51
#define SW_RX            5 // TMC2208/TMC2224 SoftwareSerial receive pin
#define SW_TX            6 // TMC2208/TMC2224 SoftwareSerial transmit pin
#define SERIAL_PORT Serial3 // TMC2208/TMC2224 HardwareSerial port
#define SERIAL_PORT2 Serial2 // TMC2208/TMC2224 HardwareSerial port
#define DRIVER_ADDRESS 0b00 // TMC2209 Driver address according to MS1 and MS2
#define R_SENSE 0.11f // Match to your driver
// SilentStepStick series use 0.11
// UltiMachine Einsy and Archim2 boards use 0.2
// Panucatt BSD2660 uses 0.1
// Watterott TMC5160 uses 0.075
#define stall 365
#define vs 20000
#define vmax 200000
#define jerk 4000
#define t_step 0.03
#define micro 64
#define start_current 2000
#define max_current 2000
int flag_up=0;
int flag_down=0;
int flag_stop=0;
double tm;
double v;
// Select your stepper driver type
TMC2209Stepper driver(&SERIAL_PORT,R_SENSE,DRIVER_ADDRESS);
TMC2209Stepper driver2(&SERIAL_PORT2,R_SENSE,DRIVER_ADDRESS);
//TMC2209Stepper driver(SW_RX,SW_TX,R_SENSE,DRIVER_ADDRESS);
using namespace TMC2209_n;
// Using direct register manipulation can reach faster stepping times
#define STEP_PORT     PORTF // Match with STEP_PIN
#define STEP_BIT_POS      0 // Match with STEP_PIN
int speed=vs;
IRrecv irrecv(21);
decode_results results;
//SoftwareSerial Serial(2,3); //?됰뗀竊?????뺚봺???醫롫섧
/*ISR(TIMER1_COMPA_vect){ //???????덉삂??????낃숲???껆몴???쎈뻬??
    //STEP_PORT^=1<<STEP_BIT_POS;
    Serial.print("0 ");
    Serial.print(driver.SG_RESULT(),DEC);
    Serial.print(" ");
    Serial.println(driver.cs2rms(driver.cs_actual()),DEC);
ISR(INT0_vect){
    while(irrecv.decode(&results)){
        if(results.value==0x20DF8877)
            Serial.println(results.value,HEX);
            irrecv.resume();
            flag_up=1;
        else if(results.value==0x20DFC837){
            irrecv.resume();
            flag_down=1;
        else if(results.value==0x20DF48B7){
            irrecv.resume();
            digitalWrite(EN_PIN,HIGH);
            digitalWrite(EN_PIN2,HIGH);
            flag_stop=1;
        irrecv.resume();
ISR(INT1_vect){
    flag_stop=1;
    Serial.println("stop1");
ISR(INT2_vect){
    flag_stop=1;
    Serial.println("stop2");
int counter;
    Serial.begin(115200);         // Init serial port and set baudrate
    irrecv.enableIRIn();
    SERIAL_PORT.begin(115200);
    while(!Serial);               // Wait for serial port to connect
    Serial.println("\nStart...");
    driver.beginSerial(115200);
    driver.begin();
    driver.pdn_disable(true);
    driver.I_scale_analog(false);
    driver.pwm_lim(12);
    driver.pwm_reg(8);
    driver.pwm_autograd(true);
    driver.pwm_grad(14);
    driver.pwm_freq(0b01);
    driver.pwm_ofs(36);
    driver.toff(4);
    driver.hend(5);
    driver.hstrt(0);
    driver.VACTUAL(speed);
    //driver.blank_time(24);
    driver.rms_current(2000); // mA
    driver.microsteps(micro);
    //driver.TCOOLTHRS(0xFFFFF); // 20bit max
    driver.semin(5);
    driver.semax(2);
    driver.sedn(0b01);
    driver.en_spreadCycle(false);   // Toggle spreadCycle on TMC2208/2209/2224
    driver.pwm_autoscale(1);
    driver.SGTHRS(STALL_VALUE);
    SERIAL_PORT2.begin(115200);
    driver2.beginSerial(115200);
    driver2.begin();
    driver2.pdn_disable(true);
    driver2.I_scale_analog(false);
    driver2.pwm_lim(12);
    driver2.pwm_reg(8);
    driver2.pwm_autograd(true);
    driver2.pwm_grad(14);
    driver2.pwm_freq(0b01);
    driver2.pwm_ofs(36);
    driver2.toff(4);
    driver2.hend(5);
    driver2.hstrt(0);
    driver2.VACTUAL(speed);
    //driver2.blank_time(24);
    driver2.rms_current(2000); // mA
    driver2.microsteps(micro);
    //driver2.TCOOLTHRS(0xFFFFF); // 20bit max
    driver2.semin(5);
    driver2.semax(2);
    driver2.sedn(0b01);
    driver2.en_spreadCycle(false);   // Toggle spreadCycle on TMC2208/2209/2224
    driver2.pwm_autoscale(1);
    driver2.SGTHRS(STALL_VALUE);
    /*uint8_t result=driver.test_connection();
    if(result){
        Serial.println("failed!");
        Serial.print("Likely cause: ");
        switch(result){
            case 1: Serial.println("loose connection"); break;
            case 2: Serial.println("no power"); break;
        Serial.println("Fix the problem and reset board.");
        // We need this delay or messages above don't get fully printed out
        abort();
    Serial.println("OK");
    pinMode(EN_PIN,OUTPUT);
    pinMode(photo1,INPUT);
    pinMode(photo2,INPUT);
    pinMode(photo3,INPUT);
    pinMode(photo4,INPUT);
    pinMode(EN_PIN2,OUTPUT);
    // Serial.begin(115200); //?됰뗀竊?????뺚봺?????뻿??뽰삂
    /*// Set stepper interrupt
        cli();//stop interrupts
        TCCR1A=0;// set entire TCCR1A register to 0
        TCCR1B=0;// same for TCCR1B
        TCNT1=0;//initialize counter value to 0
        OCR1A=6250;//=(16*10^6)/(1*1024)-1(must be<65536)
        // turn on CTC mode
        TCCR1B|=(1<<WGM12);
        // Set CS11 bits for 8 prescaler
        TCCR1B|=(1<<CS12);//|(1<<CS10);
        // enable timer compare interrupt
        TIMSK1|=(1<<OCIE1A);
        sei();//allow interrupts
    EIMSK=0x07//INT0/1/2???명꽣?쏀듃瑜??덉슜??
    EICRA=0x3D//INT0?곸듅?뱀??섍컯?먯?⑤몢?몃━嫄?/ INT1?곸듅?먯??몃━嫄?/ INT2?곸듅?먯??몃━嫄?
    sei(); //⑤뱺?명꽣?쏀듃瑜??덉슜??
    tm=sqrt((vmax-vs)/jerk);
    delay(10);
    int down_check_r=digitalRead(photo1);
    int up_check_r=digitalRead(photo2);
    int speed_check_r=digitalRead(photo3);
    int speed_check_l=digitalRead(photo4);
    if(flag_up==1&&up_check_r==LOW)
        digitalWrite(EN_PIN,LOW);
        digitalWrite(EN_PIN2,LOW);
        driver.shaft(0);
        driver2.shaft(1);
        driver.rms_current(start_current); // mA
        driver2.rms_current(start_current); // mA
        flag_up==0;
        motor();
    if(flag_down==1&&down_check_r==LOW)
        driver.shaft(1);
        driver2.shaft(0);
        flag_down=0;
        motor();
void motor()
    static uint32_t last_time=0;
    uint32_t ms=millis();
    for(double t=0;t<=2*tm;t+=t_step){
        if(t>=0&&t<=tm){
            v=vs+(jerk*t*t)/2;
        else if(t>tm&&t<=2*tm)
            v=vs-jerk*tm*tm+2*jerk*tm*t-(jerk*t*t)/2;
        driver.VACTUAL(v);
        driver2.VACTUAL(v);
    driver.rms_current(max_current); // mA
    driver2.rms_current(max_current); // mA
    for(;;){
        //delay(10);
        int sgsg=driver.SG_RESULT();
        ms=millis();
        if(flag_stop==1)
            flag_stop=0;
            flag_up=0;
            flag_down=0;
            /*for(double t=2*tm;t<=4*tm;t+=t_step){
                if(t>=2*tm&&t<=3*tm){
                    v=vs-(jerk*tm*tm)+2*jerk*tm*t-jerk*t*t/2;
                else if((t<=(4*tm))&&(t>(3*tm))){
                    v=vs+0.5*jerk*(t-4*tm)*(t-4*tm);
                driver.VACTUAL(v);
                driver2.VACTUAL(v);
            return;
        // last_time=0;
        if((ms-last_time)>100&&driver.toff()!=0&&speed!=0){ // run every 0.1s
            last_time=ms;
            Serial.print(1000-driver.SG_RESULT(),DEC);
            Serial.print(",");
            Serial.println(1000-driver2.SG_RESULT(),DEC);
리모컨으로 외부인터럽트 발생시켜 신호를 인식하여, 모터가 작동되면
이상하게 외부인터럽트 1/2번의 stop이라는 시리얼 문자가 엄청나게 빠르게 카운트가 올라갑니다.
인터럽트 1/2번은 상승에지에서 동작하게끔 해 두었는데, 모터가 회전하지 않으면 문제가 없는데
모터가 회전하기만하면... 상승/하강에지 관계없이 동작을 하네요..(아니면 인터럽트 주기가 매우 짧아져서 민감해진것 같기도 합니다)
현재 모터 회전은 모터 드라이버의 레지스터를 건드려서 동작시키는데
일반적으로 쓰는 타이머 인터럽트를 쓴느 방법으로 해도... 모터가 동작하면  외부인터럽트 1/2번이 오동작합니다.
원인이 뭘까요 ㅠㅠ
조회수 37
인터럽트 1/2번 회로에 대해서 아는 바가 없으니 오동작 원인도 알 수가 없습니다.
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 1961
공지 사이트 이용 안내댓글[12] master 17-10-29 12051
공지 [무료 공개] 소스코드 하이라이트 v2.0 beta [2013.02.07]댓글[1] 이미지첨부파일 master 18-01-23 4559
질문 메가로 진행중인데 질문드려요,,댓글[1] dongeun9 20-07-31 28
질문 아두이노 우노 -> 메가댓글[2] dongeun9 20-07-30 43
질문 아두이노 우노+DC모터 제어 질문드립니다.댓글[1] 빈군 20-07-30 35
질문 아두이노어플 통신 질문드립니다댓글[1] dongeun9 20-07-29 31
현재글 모터를 작동시키기만 하면, 외부인터럽트에서 이상이 발생합니다.댓글[1] 꾸람이 20-07-29 38
질문 질문 드립니다.댓글[1] 알려주세요제발ㅠㅠ 20-07-29 33
질문 질문드립니다 수파도프 20-07-28 33
답변 답변글 답변 : 질문드립니다 master 20-07-28 37
질문 아두이노 우노 -> 메가 질문드립니다댓글[2] dongeun9 20-07-28 36
질문 ATmega와 안드로이드 블루투스 연결 질문입니다. 구래몬 20-07-28 32
답변 답변글 답변 : ATmega와 안드로이드 블루투스 연결 질문입니다.댓글[1] master 20-07-28 32
질문 아두이노 RC카 양쪽 모터속도제어 질문입니다.댓글[3] 첨부파일 MaTD 20-07-27 47
질문 통신프로토콜 ? 세상통합 20-07-27 33
질문 타이머 인터럽트를 이용한 스텝모터 제어 질문입니다.댓글[6] 꾸람이 20-07-26 66
질문 매우 초보적인 아두이노 코딩질문입니다.댓글[1] 이미지첨부파일 화이팅dP 20-07-23 71
질문 아두이노 우노 푸쉬 버튼 서보모터 작동 관련 초보 질문입니다.댓글[1] 이미지 구름신 20-07-23 49
질문 적외선 거리센서 탐지범위 설정하는 방법 알려주시면 감사하겠습니다. 큐큐큐큨 20-07-22 44
답변 답변글 답변 : 적외선 거리센서 탐지범위 설정하는 방법 알려주시면 감사하겠습니다. master 20-07-22 55
질문 코딩 질문.. 전자학습자 20-07-22 59
답변 답변글 답변 : 코딩 질문..댓글[4] master 20-07-22 74
질문 소스 코드 질문좀 드리겠습니다..! 코딩공부하자 20-07-21 63
답변 답변글 답변 : 소스 코드 질문좀 드리겠습니다..! master 20-07-21 47
답변 답변글 답변 : 답변 : 소스 코드 질문좀 드리겠습니다..!댓글[4] 코딩공부하자 20-07-22 72
질문 아두이노 스텝모터 도와주세요~ 랩돌이 20-07-20 70
답변 답변글 답변 : 아두이노 스텝모터 도와주세요~댓글[1] master 20-07-20 86
질문 희미한 LED 문제댓글[6] 전자학습자 20-07-20 119
질문 소스 코딩 문제점을 찾고싶어요댓글[1] 첨부파일 bas213 20-07-17 107
