질문게시판 > 답변 : 마이크로프로세서 질문드립니다
인기검색어 > 아두이노 센서 ATMEGA128
최신글 질문게시판 동영상강좌 가입하기
▼ BASIC4MCU 후원업체 신제품 정보 ▼
▲ BASIC4MCU 후원업체 신제품 정보 ▲
BASIC4MCU > 질문게시판
작성자 master 작성일18-06-02 20:29 조회6,404회 댓글0건
첨부 이미지
첨부 이미지
1
2
3
4
5
6
7
8
9
10
11
12
13
// 타이머1 10비트 Fast PWM Mode // COM1x=2 Bottom(0x00)~OCR2구간 Set(5V), OCR2~TOP구간 Clear(0V)
    TCCR1A=0x83; TCCR1B=0x09//주기=16000000/   1/1024=15625Hz=64us
    TCCR1A=0x83; TCCR1B=0x0A//주기=16000000/   8/1024=1953.125Hz=512us
    TCCR1A=0x83; TCCR1B=0x0B//주기=16000000/  64/1024=244.140625Hz=4.096ms
    TCCR1A=0x83; TCCR1B=0x0C//주기=16000000/ 256/1024=61.03515625Hz=16.384ms
    TCCR1A=0x83; TCCR1B=0x0D//주기=16000000/1024/1024=15.2587890625Hz=65.536ms
// 타이머1 10비트 Fast PWM Mode // COM1x=3 Bottom(0x00)~OCR2구간 Clear(0V), OCR2~TOP구간 Set(5V)
    TCCR1A=0xC3; TCCR1B=0x09//주기=16000000/   1/1024=15625Hz=64us
    TCCR1A=0xC3; TCCR1B=0x0A//주기=16000000/   8/1024=1953.125Hz=512us
    TCCR1A=0xC3; TCCR1B=0x0B//주기=16000000/  64/1024=244.140625Hz=4.096ms
    TCCR1A=0xC3; TCCR1B=0x0C//주기=16000000/ 256/1024=61.03515625Hz=16.384ms
    TCCR1A=0xC3; TCCR1B=0x0D//주기=16000000/1024/1024=15.2587890625Hz=65.536ms
cs
1
2
3
4
5
6
7
8
9
10
11
12
13
// 타이머3 10비트 Fast PWM Mode // COM3x=2 Bottom(0x00)~OCR2구간 Set(5V), OCR2~TOP구간 Clear(0V)
    TCCR3A=0x83; TCCR3B=0x09//주기=16000000/   1/1024=15625Hz=64us
    TCCR3A=0x83; TCCR3B=0x0A//주기=16000000/   8/1024=1953.125Hz=512us
    TCCR3A=0x83; TCCR3B=0x0B//주기=16000000/  64/1024=244.140625Hz=4.096ms
    TCCR3A=0x83; TCCR3B=0x0C//주기=16000000/ 256/1024=61.03515625Hz=16.384ms
    TCCR3A=0x83; TCCR3B=0x0D//주기=16000000/1024/1024=15.2587890625Hz=65.536ms
// 타이머3 10비트 Fast PWM Mode // COM3x=3 Bottom(0x00)~OCR2구간 Clear(0V), OCR2~TOP구간 Set(5V)
    TCCR3A=0xC3; TCCR3B=0x09//주기=16000000/   1/1024=15625Hz=64us
    TCCR3A=0xC3; TCCR3B=0x0A//주기=16000000/   8/1024=1953.125Hz=512us
    TCCR3A=0xC3; TCCR3B=0x0B//주기=16000000/  64/1024=244.140625Hz=4.096ms
    TCCR3A=0xC3; TCCR3B=0x0C//주기=16000000/ 256/1024=61.03515625Hz=16.384ms
    TCCR3A=0xC3; TCCR3B=0x0D//주기=16000000/1024/1024=15.2587890625Hz=65.536ms
cs
https://www.basic4mcu.com/bbs/board.php?bo_table=gesiyo6&wr_id=130
256분주면 이 설정이 되겠군요
TCCR3A=0x83
이 설정은 OC3A 만 출력하는 것인데
OC3B만 출력하도록 변경하면 TCCR3A=0x23; 으로 변경하면 되겠습니다.
첨부 이미지
OC3B는 PE4이므로
DDRE=0x10; // 출력 설정을 해야하고
10비트는 0~1023인데 40%면 409 입니다.
DDRE=0x10;
OCR3B=409TCCR3A=0x23TCCR3B=0x0C//주기=16000000/256/1024=61.03515625Hz=16.384ms
  • 카카오톡으로 보내기
댓글 : 0
조회수 : 6,404
BASIC4MCU > 질문게시판 목록
제목 날짜
질문 아두이노 센서값 출력 질문입니다! 댓글[1] 아궁2 새글 22-06-24
질문 ATmega128, ATmega28 RS232통신 첨부파일Moon4201 새글 22-06-24
답변 답변 : ATmega128, ATmega28 RS232… master 새글 08:07
질문 아두이노 delay를 millis로 바꾸고 싶습니다. 슨슨슨모  22-06-16
답변 답변 : 아두이노 delay를 millis로 바꾸고 싶… master  22-06-17
PC버전
