질문게시판 > 아두이노 지문인식 도어락 질문드립니다.
TODAY220 TOTAL2,173,612
BASIC4MCU | 질문게시판 | 아두이노 지문인식 도어락 질문드립니다.
작성자 미르음 작성일2020-10-20 14:25 조회2,866회 댓글1건
#include <Adafruit_Fingerprint.h>
#if (defined(__AVR__) || defined(ESP8266)) && !defined(__AVR_ATmega2560__)
// For UNO and others without hardware serial, we must use software serial...
// pin #2 is IN from sensor (GREEN wire)
// pin #3 is OUT from arduino  (WHITE wire)
// Set up the serial port to use softwareserial..
SoftwareSerial mySerial(2, 3);
#else
// On Leonardo/M0/etc, others with hardware serial, use hardware serial!
// #0 is green wire, #1 is white
#define mySerial Serial1
#endif
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
#include <Servo.h>  //Servo 라이브러리를 추가
#define LS 7
Servo myservo;    //Servo 클래스로 myservo객체 생성
int buzzer = 6;
int PIRinput = 8;
int LED1 = 9;
int PIRState = LOW;
int blueTx = 4;   // Tx (블투 보내는핀 설정)
int blueRx = 5;   // Rx (블투 받는핀 설정)
SoftwareSerial BTSerial(blueTx, blueRx);  // 시리얼 통신을 위한 객체선언
String myString=""; //받는 문자열
  pinMode(PIRinput, INPUT);
  pinMode(LS, INPUT);
  pinMode(LED1, OUTPUT);
  pinMode(buzzer,OUTPUT);
  while (!Serial);  // For Yun/Leo/Micro/Zero/...
  Serial.println("\n\nAdafruit finger detect test");
  // set the data rate for the sensor serial port
  finger.begin(57600);
  delay(5);
  mySerial.listen();
  if (finger.verifyPassword()) {
    Serial.println("Found fingerprint sensor!");
  } else {
    Serial.println("Did not find fingerprint sensor :(");
    while (1) { delay(1); }
  Serial.println(F("Reading sensor parameters"));
  finger.getParameters();
  Serial.print(F("Status: 0x")); Serial.println(finger.status_reg, HEX);
  Serial.print(F("Sys ID: 0x")); Serial.println(finger.system_id, HEX);
  Serial.print(F("Capacity: ")); Serial.println(finger.capacity);
  Serial.print(F("Security level: ")); Serial.println(finger.security_level);
  Serial.print(F("Device address: ")); Serial.println(finger.device_addr, HEX);
  Serial.print(F("Packet len: ")); Serial.println(finger.packet_len);
  Serial.print(F("Baud rate: ")); Serial.println(finger.baud_rate);
  finger.getTemplateCount();
  if (finger.templateCount == 0) {
    Serial.print("Sensor doesn't contain any fingerprint data. Please run the 'enroll' example.");
  else {
    Serial.println("Waiting for valid finger...");
      Serial.print("Sensor contains "); Serial.print(finger.templateCount); Serial.println(" templates");
  myservo.attach(12); // 12번핀 서보모터 연결
  myservo.write(0);  // 서보 초기각도 0
  BTSerial.listen();
  BTSerial.begin(9600); //블루투스 시리얼 개방
    int sw = 1;
  switch(sw){
  case 1:
    if(digitalRead(PIRinput) == HIGH)
   mySerial.listen();
   digitalWrite(LED1, HIGH);
   delay(500);
   getFingerprintID();
   delay(50);            //don't ned to run this at full speed.
      digitalWrite(LED1, LOW);
     // break;
   case 2:
    if(digitalRead(LS) == HIGH & digitalRead(PIRinput) == LOW)
  //  delay(1000);
    myservo.write(0);
    return finger.fingerID;
   // delay(500);
    else if(finger.fingerID == 1 )
   // delay(1000);
    myservo.write(180);  // 서보 각도 180
 /*   else if(finger.fingerID != 1)
    tone(buzzer, 261, 1000);  // 부저 소리 출력
    delay(500);
   case 3:
  //     delay(500);
       BTSerial.listen();
       while(BTSerial.available())  // BTSerial 값이 있으면
    char myChar = (char)BTSerial.read();  //mySerial int형식의 값을 char형식으로 변환
    myString+=myChar;   //수신되는 문자열을 myString에 모두 붙임 (1바이트씩 전송되는 것을 모두 붙임)
    delay(5);           //수신 문자열 끊김 방지
  if(!myString.equals(""))  //myString 값이 있다면
    Serial.println("input value: "+myString); //시리얼모니터에 myString값 출력
      if(myString=="ON")  //myString 값이 'on' 이라면
        myservo.write(180);     //각도 180도로 움직임
        delay(2000);
    else if(myString=="OFF")  //myString 값이 'on' 이라면
        myservo.write(0);     //각도 180도로 움직임
        delay(2000);
    myString="";  //myString 변수값 초기화
  uint8_t getFingerprintID() {
  uint8_t p = finger.getImage();
  switch (p) {
    case FINGERPRINT_OK:
      Serial.println("Image taken");
    case FINGERPRINT_NOFINGER:
      Serial.println("No finger detected");
      return p;
    case FINGERPRINT_PACKETRECIEVEERR:
      Serial.println("Communication error");
      return p;
    case FINGERPRINT_IMAGEFAIL:
      Serial.println("Imaging error");
      return p;
    default:
      Serial.println("Unknown error");
      return p;
  // OK success!
  p = finger.image2Tz();
  switch (p) {
      Serial.println("Image converted");
    case FINGERPRINT_IMAGEMESS:
      Serial.println("Image too messy");
      return p;
      return p;
    case FINGERPRINT_FEATUREFAIL:
      Serial.println("Could not find fingerprint features");
      return p;
    case FINGERPRINT_INVALIDIMAGE:
      return p;
    default:
      return p;
  // OK converted!
  p = finger.fingerSearch();
  if (p == FINGERPRINT_OK) {
    Serial.println("Found a print match!");
  } else if (p == FINGERPRINT_PACKETRECIEVEERR) {
    return p;
  } else if (p == FINGERPRINT_NOTFOUND) {
    Serial.println("Did not find a match");
    delay(500);
    return p;
  } else {
    return p;
  // found a match!
  Serial.print("Found ID #"); Serial.print(finger.fingerID);
  Serial.print(" with confidence of "); Serial.println(finger.confidence);
// returns -1 if failed, otherwise returns ID #
int getFingerprintIDez() {
  if (p != FINGERPRINT_OK)  return -1;
  p = finger.fingerFastSearch();
  // found a match!
우선 작동 순서입니다.
  // 스위치 1부터 자동으로 시작
  // 케이스1 : PIR 감지되면 LED 켜진 후 지문인식 작동하며 케이스2로 이동
  // 안되면 LED와 지문인식 작동X(스위치문 탈출)
  // 케이스2 :
  // 리미트스위치LS는 눌러져있고 & PIR 감지가 안될경우(문닫히고 사람이 없는경우) 모터각도 0도(잠김)
  //  올바른 지문이 인식된 경우 모터각도 180도(잠금풀림)
 //  잘못된 지문이 인식된 경우 부저울림
  // 케이스3 :
  // 블루투스의 송신 값이 ON 일 경우 모터각도 180도(잠금풀림)
  // 블루투스의 송신 값이 OFF일 경우 모터각도 0도(잠김)
문제점
 1. 블루투스 시리얼 송신과 지문인식 송신이 충돌나는 상황입니다.
     그래서 잘못된 지문인식을 하여도 문이 열리는 현상이 발생해서 블루투스있는 케이스3을 지워서 해봤더니 안열리는걸 보니
     충돌나는 상황때문에 발생하는거 같습니다.
2. 블루투스 송신은 아무리 스마트폰 어플로 보내도 시리얼모니터엔 표시가 될때도 있긴하지만 거의  지문인식 송신만 받게되어 먹통인 경우입니다.
    어떻게 해야할까요?
    우노말고 메가를 사용하면 해결이 될까요?
조회수 2,866
메가를 사용하시고
소프트웨어 시리얼이 아닌 하드웨어 시리얼을 사용해서 연결하세요
공지 사이트 이용 안내댓글[24] master 17-10-29 29813
질문 atmega128 키패드 입력 오류에 대하여 질문 있습니다.댓글[2] 새글 마프하나 22-05-26 41
질문 atmega128 GPS,블루투스 질문드립니다.댓글[1] 코딩초보1 22-05-24 38
질문 아두이노와 휴대폰을 HC-06으로 연결시켜서 블루투스연결이 끊기면 부저에서 소리가 나게 할려하는데 어떻게 해…댓글[1] 졸작부수다 22-05-23 247
질문 보드레이트 질문댓글[1] 죠르디 22-05-23 35
질문 atmega 128 블루투스 질문 입니다댓글[1] yhj2644 22-05-23 57
