질문게시판 > 스마트 윈도우 빗물감지,블라인드 코딩소스 해석좀해주세요
TODAY298 TOTAL2,173,690
BASIC4MCU | 질문게시판 | 스마트 윈도우 빗물감지,블라인드 코딩소스 해석좀해주세요
작성자 아두이노개어렵 작성일2020-10-20 15:31 조회2,942회 댓글1건
//   PIN Define       ///////////////////////////////////////////////////
//#define PWM 180
#define SW1 2   // 4.7k = 10k 대체, capacitor x
#define SW2 3
#define SW3 4
#define SW4 5
// SW
#define MOTER_B  6  // ic2 // 블라인드용
#define MOTER_A  7  // 7
#define MOTER_EN  8  // 1
#define MOTER_D  9  // 10  // 창문용
#define MOTER_C  10  //14
#define MOTER_EN1 11  // 9
//MOTER
#define CDS A0  /// 아래쪽이 블라인드
//cds
#define Rain A1   ///윗쪽이 창문
//Rain
//   input variable   ////////////////////////////////////////////////
int buttonState1 = 0;
int buttonState2 = 0;
int buttonState3 = 0;
int buttonState4 = 0;
int cds_val;
int Rain_val;
int state;  //for BT
static int Timer = 0;
static int Timer1 = 0;
static int Timer_for_Sensor = 0;
static int MOTER_DIR = 0;
static int MOTER_DIR1 = 0;
static int DIR_flag = 0;
static int DIR_flag1 = 0;
static bool flag = 1;  //Timer clear flag
static bool flag1 = 1;  //Timer clear flag
static bool BT_flag = 0; //for BT --------------------------------------------- add
static bool MOTER_flag = 0;  //Timer clear flag
static bool MOTER_flag1 = 0;  //Timer clear flag
static bool cds_flag = 1;  //Timer clear flag
static bool before_cds = 0;  //Timer clear flag
static bool Rain_flag = 1;  //Timer clear flag
static bool before_Rain = 0;  //Timer clear flag
static bool cds_chattering_flag = 1;  //Timer clear flag
static bool Rain_chattering_flag = 1;  //Timer clear flag
//   Function List    ///////////////////////////////////////////////
void pinMode_init();    //pin setting
void key_scan();        //key sensing
void key_scan1();        //key sensing
void BTS();
void MOTER_run();       //MOTER running
void MOTER_run1();       //MOTER running
void MOTER_LEFT();      //MOTER motion left
void MOTER_RIGHT();     //MOTER motion right
void MOTER_STOP();      //MOTER motion stop
void MOTER_LEFT1();      //MOTER motion left
void MOTER_RIGHT1();     //MOTER motion right
void MOTER_STOP1();      //MOTER motion stop
void ISR_Timer();       //Timer interrupt
void cds_run();         //cds running
void Rain_run();         //Rain running
//   Setup            //////////////////////////////////////////////////
  pinMode_init();
  Serial.begin(9600);                //Serial init
  MsTimer2::set(100, ISR_Timer);     //100ms, ISR_Timer
  MsTimer2::start();                 // Timer start
//   Loop             ///////////////////////////////////////////////////
    key_scan();
    key_scan1();
    BTS();
    MOTER_run();
    MOTER_run1();
    cds_run();
    Rain_run();
//   Pinmode setup    //////////////////////////////////////////////////
void pinMode_init()
    pinMode(SW1, INPUT);
    pinMode(SW2, INPUT);
    pinMode(SW3, INPUT);
    pinMode(SW4, INPUT);
    pinMode(MOTER_A, OUTPUT);
    pinMode(MOTER_B, OUTPUT);
    pinMode(MOTER_EN, OUTPUT);
    pinMode(MOTER_C, OUTPUT);
    pinMode(MOTER_D, OUTPUT);
    pinMode(MOTER_EN1, OUTPUT);
    pinMode(CDS, INPUT);
    pinMode(Rain, INPUT);
//   Key scan         //////////////////////////////////////////////
void key_scan()
  buttonState1 = digitalRead(SW1);
  buttonState2 = digitalRead(SW2);
  if (!buttonState1)   MOTER_DIR = 1;
  if (!buttonState2)   MOTER_DIR = 2;
void key_scan1()
    buttonState3 = digitalRead(SW3);
    buttonState4 = digitalRead(SW4);
    if (!buttonState3)   MOTER_DIR1 = 1;
    if (!buttonState4)   MOTER_DIR1 = 2;
//   MOTER Run        ////////////////////////////////////////////////
void MOTER_run()
{ // blind
    switch (MOTER_DIR)
      case 0:
          MOTER_STOP();
          DIR_flag = 0;
      case 1:
          if (DIR_flag != 1)
              flag = 1;
          if (flag)
              Timer = 0;
              Timer1 = 0;
              flag = 0;
          MOTER_LEFT();
          DIR_flag = 1;
      case 2:
          if (DIR_flag != 2)
              flag = 1;
          if (flag)
              Timer = 0;
              Timer1 = 0;
              flag = 0;
          MOTER_RIGHT();
          DIR_flag = 2;
      default:
void MOTER_run1()
{ // window!!!
    switch (MOTER_DIR1)
      case 0:
          MOTER_STOP1();
          DIR_flag1 = 0;
      case 1:
          if (DIR_flag1 != 1)
              flag1 = 1;
          if (flag1)
              Timer = 0;
              Timer1 = 0;
              flag1 = 0;
          MOTER_LEFT1();
          DIR_flag1 = 1;
      case 2:
          if (DIR_flag1 != 2)
              flag1 = 1;
          if (flag1)
              Timer = 0;
              Timer1 = 0;
              flag1 = 0;
          MOTER_RIGHT1();
          DIR_flag1 = 2;
      default:
//   MOTER LEFT       //////////////////////////////////////////////////
void MOTER_LEFT()
{     // blind
    digitalWrite(MOTER_EN, HIGH);
    digitalWrite(MOTER_A, HIGH);
    digitalWrite(MOTER_B, LOW);
    cds_chattering_flag = 0;
    //debug message
    //Serial.print("left");
    //Serial.print("\n");
void MOTER_LEFT1()
{  //window
    digitalWrite(MOTER_EN1, HIGH);
    digitalWrite(MOTER_C, HIGH);
    digitalWrite(MOTER_D, LOW);
    Rain_chattering_flag = 0;
    //debug message
//   MOTER RIGHT      /////////////////////////////////////////////////
void MOTER_RIGHT()
{  //blind
    digitalWrite(MOTER_A, LOW);
    digitalWrite(MOTER_B, HIGH);
    //debug message
    //Serial.print("right");
void MOTER_RIGHT1()
{  //window
    digitalWrite(MOTER_C, LOW);
    digitalWrite(MOTER_D, HIGH);
    //Serial.print(MOTER_D);
    //debug message
//   MOTER STOP       ////////////////////////////////////////////////
void MOTER_STOP()
{  // blind
    digitalWrite(MOTER_EN, LOW);
void MOTER_STOP1()
{ //window
    digitalWrite(MOTER_EN1, LOW);
//  BLUETOOTH             ///////////////////////////////////////////
// flag -> BT_flag change
void BTS()
    //if some date is sent, reads it and saves in state
    if (Serial.available() > 0)
        state = Serial.read();
        BT_flag = 0;
    // if the state is '0' the DC motor will turn off
    if (state == '0')
        MOTER_DIR = 0;
        MOTER_DIR1 = 0;
        if (BT_flag == 0)
            Serial.println("BlindMotor or Window: off");
            BT_flag = 1;
        state = 0;
    // if the state is '1' the motor will turn right
    else if (state == '1')
        MOTER_DIR = 1;
        if (BT_flag == 0)
            BT_flag = 1;
            state = 0;
    // if the state is '2' the motor will turn left
    else if (state == '2')
        MOTER_DIR = 2;
        if (BT_flag == 0)
            BT_flag = 1;
        state = 0; ///jinsoo
    else if (state == '3')
        MOTER_DIR1 = 1;
        if (BT_flag == 0)
            BT_flag = 1;
        state = 0;
    else if (state == '4')
        MOTER_DIR1 = 2;
        if (BT_flag == 0)
            BT_flag = 1;
        state = 0;
//   cds              //////////////////////////////////////////////
void cds_run() {
    if (cds_chattering_flag)
        cds_val = analogRead(CDS);
        Serial.println(cds_val);
        cds_val = cds_val / 750;  // 750 is 0 or 1 value
        if (before_cds != cds_val)
            before_cds = cds_val;
            MOTER_flag = 1;
        else if (before_cds == cds_val)
            MOTER_flag = 0;
        if (MOTER_flag)
            if (cds_val)
                MOTER_DIR = 1;
                MOTER_DIR = 2;
//   Rain window             //////////////////////////////////////////////
void Rain_run() {
    if (Rain_chattering_flag)
        Rain_val = analogRead(Rain);
        Rain_val = Rain_val / 600;  // 600 is 0 or 1 value OPEN
        if (before_Rain != Rain_val)
            before_Rain = Rain_val;
            MOTER_flag1 = 1;
        else if (before_Rain == Rain_val)
            MOTER_flag1 = 0;
        if (MOTER_flag1)
            if (Rain_val)
                MOTER_DIR1 = 1;
               MOTER_DIR1 = 2;
//   TIMER            ////////////////////////////////////////
void ISR_Timer()
    Timer++;
    Timer1++;
    //window
    if (Timer > 25)
        Timer = 0;
        MOTER_DIR = 0;
        flag = 1;
    //blind
    if (Timer1 > 10)
        Timer1 = 0;
        MOTER_DIR1 = 0;
        flag1 = 1;
스마트 윈도우 코딩에 관해서 해석좀 부탁드립니다...
정말 글이 길고 어려운거를 알고있습니다.
유튜브나 글을 찾아봐도 정말 단기간에는 이해하고 해석하기 어려워서
전문가 분들에게 부탁드리려고 합니다
간단하게라도 한문단이라도 해석 부탁드립니다
조회수 2,942
소스가 조금 길지만 어려운 문장은 없습니다.
열공하세요
공지 사이트 이용 안내댓글[24] master 17-10-29 29814
질문 아두이노와 휴대폰을 HC-06으로 연결시켜서 블루투스연결이 끊기면 부저에서 소리가 나게 할려하는데 어떻게 해…댓글[1] 졸작부수다 22-05-23 253
질문 보드레이트 질문댓글[1] 죠르디 22-05-23 37
