질문게시판 > 답변 : 아두이노와 아트메가 동시에 사용할떄요
TODAY289 TOTAL2,691,666
BASIC4MCU | 질문게시판 | 답변 : 아두이노와 아트메가 동시에 사용할떄요
작성자 master 작성일2018-06-04 00:03 조회9,816회 댓글1건
// DateTime : 2018-06-03 오후 11:56:15
#include <Servo.h>
#include <SoftwareSerial.h>
SoftwareSerial btSerial(4,5); //t,r
#include <Wire.h>
LiquidCrystal_I2C lcd(0x3F,16,2);
#include "VoiceRecognitionV3.h"
VR myVR(2,3);
byte buffer[1024];
uint8_t records[7]; // save record
uint8_t buf[64];
int tt=0;
int Relay=6//6번 릴레이
#define zero         (0// 멈춰줘
#define one          (1// 전진해
#define two          (2// 후진해
#define three        (3// 좌회전
#define onRecord    (14// 불켜줘
#define offRecord   (15// 불꺼줘
#define goldRecord  (16// 우회전
void printSignature(uint8_t *buf,int len){
  int i;
  for(i=0i<leni++){
    if(buf[i]>0x19&&buf[i]<0x7F){ Serial.write(buf[i]); }
    else                        { Serial.print("["); Serial.print(buf[i],HEX); Serial.print("]"); }
void printVR(uint8_t *buf){
  Serial.println("VR Index\tGroup\tRecordNum\tSignature");
  Serial.print(buf[2],DEC); Serial.print("\t\t");
  if     (buf[0]==0xFF){ Serial.print("NONE"); }
  else if(buf[0]& 0x80){ Serial.print("UG "); Serial.print(buf[0]&(~0x80),DEC); }
  else                 { Serial.print("SG "); Serial.print(buf[0],DEC); }
  Serial.print("\t"); Serial.print(buf[1],DEC); Serial.print("\t\t");
  if(buf[3]>0){ printSignature(buf+4,buf[3]); }
  else        { Serial.print("NONE"); }
  Serial.println("\r\n");
  pinMode(Relay,OUTPUT); //릴레이모듈
  lcd.init(); lcd.backlight(); lcd.setCursor(3,0); lcd.print("0123456");
  Serial.begin(115200);
  btSerial.begin(9600);
  myVR.begin(9600);
  if(myVR.clear()==0){ Serial.println("Recognizer cleared."); }
    Serial.println("Not find VoiceRecognitionModule.");
    Serial.println("Please check connection and restart Arduino.");
    while(1);
  if(myVR.load((uint8_t)zero      )>=0){ Serial.println("멈춰  "); }
  if(myVR.load((uint8_t)one       )>=0){ Serial.println("전진  "); }
  if(myVR.load((uint8_t)two       )>=0){ Serial.println("후진  "); }
  if(myVR.load((uint8_t)three     )>=0){ Serial.println("좌회전"); }
  if(myVR.load((uint8_t)onRecord  )>=0){ Serial.println("불켜  "); }
  if(myVR.load((uint8_t)offRecord )>=0){ Serial.println("불꺼  "); }
  if(myVR.load((uint8_t)goldRecord)>=0){ Serial.println("우회전"); }
  if(Serial.available()){
    delay(5);
    while(Serial.available()){ btSerial.write(Serial.read()); }
  int ret;
  ret=myVR.recognize(buf,50);
  if(ret>0){
    switch(buf[1]){
      case onRecord  : lcd.clear(); lcd.setCursor(3,0); lcd.print("on led "); digitalWrite(Relay,HIGH); break;
      case offRecord : lcd.clear(); lcd.setCursor(3,0); lcd.print("off led"); digitalWrite(Relay,LOW ); break;
      case zero      : lcd.clear(); lcd.setCursor(3,0); lcd.print("stop   "); btSerial.write('0'); delay(10); break;
      case one       : lcd.clear(); lcd.setCursor(3,0); lcd.print("go!    "); btSerial.write('1'); delay(10); break;
      case two       : lcd.clear(); lcd.setCursor(3,0); lcd.print("back   "); btSerial.write('2'); delay(10); break;
      case three     : lcd.clear(); lcd.setCursor(3,0); lcd.print("left   "); btSerial.write('3'); delay(10); break;
      case goldRecordlcd.clear(); lcd.setCursor(3,0); lcd.print("Right  "); btSerial.write('4'); delay(10); break;
      default        : Serial.println("Record function undefined"); break;
    /**voice recognized*/
    printVR(buf);
  Serial.println("000000000000");
http://www.makewith.co/page/manual/109
위 사이트 소스를 정리했습니다.
위 코드에서 LCD와 릴레이는 필요 없을테니 제거하고요
블루투스 TX로 출력을 내도록 수정해보죠
// DateTime : 2018-06-04 오전 12:04:37
#include <Servo.h>
VR              myVR(2,3);
byte buffer[1024];
uint8_t buf[64];
int tt=0;
  int i;
  for(i=0i<leni++){
  myVR.begin(9600);
    while(1);
  int ret;
  if(ret>0){
    switch(buf[1]){
      case onRecord  : btSerial.write('0'); break;
      case offRecord : btSerial.write('1'); break;
      case zero      : btSerial.write('2'); break;
      case one       : btSerial.write('3'); break;
      case two       : btSerial.write('4'); break;
      case three     : btSerial.write('5'); break;
      case goldRecordbtSerial.write('6'); break;
      default        : btSerial.write(0x0); break;
    printVR(buf);
아두이노 입장에서는 4번이 RX이고, 5번이 TX이므로
아두이노의 5번(TX)------(RX0)PE0 128
이렇게 연결하면 되겠습니다.
물론 GND도 연결해줘야합니다.
조회수 9,816
허니님의 댓글
허니 작성일
와 진짜 이렇게 늦게까지 답변해주셔서 정말 감사합니다.
이제 시간도 얼마 없어서 포기할까 진지하게 생각했는데 정말 감사합니다.
덕분에 팀플 끝까지 포기하지 않겠습니다!
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 19418
공지 사이트 이용 안내댓글[28] master 17-10-29 34131
질문 stm32f767을 이용해서 자이로가속도 센서의 값 받아오기 새글 rlchwjswk 23-06-03 9
질문 아두이노 모터제어 관련해서 질문드립니다!댓글[1] 이미지새글첨부파일 아두이노어렵잖아 23-06-03 21
질문 atmega128 디지털조도센서 코드오류댓글[1] 이미지새글 까미 23-06-02 25
질문 atmega128 디지털 조도 센서댓글[1] 새글 까미 23-06-02 27
질문 적외선리모콘으로 부저를제어 하는방법 질문입니다.댓글[4] 새글 Tell 23-06-02 18
질문 lora 무선 모듈에 관한 질문입니다.댓글[1] 로이스10 23-06-01 18
질문 적외선 송수신기 DC모터2개 제어 질문입니다.댓글[5] Tell 23-06-01 31
질문 스텝모터 제어 코드 질문댓글[4] pmh11 23-05-31 32
질문 초음파 센서를 이용한 인원 카운팅댓글[1] 초음파야 23-05-31 26
질문 모터 Hall 스위치 연결 문의댓글[1] 오후 23-05-31 21
질문 아두이노 lcd 문자 스크롤디스플레이 wnion 23-05-31 22
답변 답변글 답변 : 아두이노 lcd 문자 스크롤디스플레이댓글[1] master 23-05-31 28
질문 아두이노 타이머 인터럽트 미ㅏㄴㅇ 23-05-30 37
답변 답변글 답변 : 아두이노 타이머 인터럽트댓글[6] master 23-05-30 44
질문 THC-Soil Sensor with TTL 모듈 아두이노 센서값 받아오기댓글[1] ppiickle 23-05-30 30
질문 stm32 psd센서구동 질문댓글[2] 수포자 23-05-29 28
질문 앱인벤터 아두이노 보드 LCD 글씨 나타내기 질문댓글[7] 이미지 당찬병아리 23-05-29 41
질문 atmega128 led와 fan댓글[3] 이라 23-05-28 44
질문 stm32f767 스텝모터 속도 질문있습니다 123132 23-05-27 34
답변 답변글 답변 : stm32f767 스텝모터 속도 질문있습니다 master 23-05-28 30
질문 아트메가 128 코딩 오류 질문입니다.댓글[1] 태태킴 23-05-27 31
질문 스텝모터 제어하는 소스파일인데 질문있습니다. Bs드리프터 23-05-27 38
답변 답변글 답변 : 스텝모터 제어하는 소스파일인데 질문있습니다. master 23-05-27 35
질문 모터 컨트롤러와 웜기어 모터 연결 문의 드립니다댓글[1] 오후에 23-05-27 28
답변 답변글 답변 : 모터 컨트롤러와 웜기어 모터 연결 문의 드립니다댓글[1] 첨부파일 오후에 23-05-27 33
질문 아두이노 스텝모터 초음파 결합댓글[2] 결합기원 23-05-26 55
답변 답변글 답변 : 아두이노 스텝모터 초음파 결합 master 23-05-27 28
질문 piezo부저 연결 방법댓글[2] 이미지첨부파일 djwb 23-05-26 34
