질문게시판 > 아두이노 RGB모듈 LCD표현
TODAY1,103 TOTAL2,174,495
BASIC4MCU | 질문게시판 | 아두이노 RGB모듈 LCD표현
작성자 15ef 작성일2020-11-19 03:42 조회9,530회 댓글3건
#include <Servo.h>
#include <Wire.h>
Servo myservo;
#define ECHO 2
#define TRIG 3
int Tx = 12; //전송 보내는핀
int Rx = 11; //수신 받는핀
SoftwareSerial bluetooth(Tx,Rx);
int angle = 0;
int lot=3;
char btval = 0; // 앱인벤터 버튼 값 입력 변수
int mode = 0; // 모드 설정
  pinMode(TRIG,OUTPUT);
  pinMode(ECHO,INPUT);
  bluetooth.begin(9600);
  lcd.init();
  lcd.backlight();
  lcd.begin(16,2);
  myservo.attach(9);
  pinMode(4,OUTPUT);
  pinMode(5,OUTPUT);
  pinMode(6,OUTPUT);
  pinMode(7,OUTPUT);
  pinMode(8,OUTPUT);
  pinMode(10,OUTPUT);
  digitalWrite(5,1);
  digitalWrite(7,1);
  digitalWrite(10,1);
  digitalWrite(4,0);
  digitalWrite(6,0);
  digitalWrite(8,0);
  digitalWrite(TRIG,LOW);
  digitalWrite(ECHO,LOW);
  delayMicroseconds(2);
  digitalWrite(TRIG,HIGH);
  delayMicroseconds(10);
  int a = analogRead(A0);
  int b = analogRead(A1);
  int c = analogRead(A2);
  long duration = pulseIn(ECHO,HIGH);
  long distance = duration / 58.2;
  btval = bluetooth.read(); //블루투스 버튼 값 입력
  lcd.setCursor(0,0);
  lcd.print("parking lot : ");
  lcd.print(lot);
  if(distance < 10){
    myservo.write(90);
    myservo.write(0);
  if(a < 500){                    // 차량 있을 때
    mode = 1;
    bluetooth.write('a');
    digitalWrite(4,1); // red led on
    digitalWrite(5,0); // green led off
    lot = lot-1;
    if(lot<0){
      lot=0;
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.print(lot);
  else{                           // 차량 없을 때
    bluetooth.write('b');
    digitalWrite(4,0);
    digitalWrite(5,1);
    lot = lot+1;
    if(lot>3){
      lot = 3;
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.print(lot);
  if(b < 500){                    // 차량 있을 때
    mode = 2;
    bluetooth.write('c');
    digitalWrite(6,1);
    digitalWrite(7,0);
    lot = lot-1;
    if(lot<0){
      lot=0;
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.print(lot);
  else{                           // 차량 없을 때
    bluetooth.write('d');
    digitalWrite(6,0);
    digitalWrite(7,1);
    lot = lot+1;
    if(lot>3){
      lot = 3;
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.print(lot);
  if(c < 500){                    // 차량 있을 때
    mode = 3;
    bluetooth.write('e');
    digitalWrite(8,1);
    digitalWrite(10,0);
    lot = lot-1;
    if(lot<0){
      lot=0;
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.print(lot);
  else{                          // 차량 없을 때
    bluetooth.write('f');
    digitalWrite(8,0);
    digitalWrite(10,1);
    lot = lot+1;
    if(lot>3){
      lot = 3;
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.print(lot);
  mode = bluetooth.read();
  if(mode == 'a'){
   digitalWrite(8,1);
   digitalWrite(10,0);
제가 쓴 코드는 위와 같습니다.
제가 구현하고자 하는 것은 조도센서로 어두울때 R, 밝을때 G로 하고, 그에 값으로 G의 갯수를 lot으로 표현하려고 합니다.
그런데 위처럼 코드로 구현해 보았는데, 조도센서에 의해 RGB제어는 잘 되고 있는데 lot숫자 표기에서 문제가 발생했습니다.
어떨때는 조도센서 1개를 어둡게 했을 때 lot이 0이거나 3그대로 일 때가 있고, 2개를 어둡게 했는데, lot이 3에서 0으로 순차적으로 변할때도 있습니다. ㅠㅠ
코드가 문제일까요...?
댓글 3
조회수 9,530
읽은 값을 사용하지 않으므로 상관없긴 하지만
소프트웨어 시리얼은 available()을 반드시 체크해서 읽어야 합니다.
  if(bluetooth.available()){
    mode=bluetooth.read();
    if(mode=='a'){ digitalWrite(8,1); digitalWrite(10,0); }
  digitalWrite(TRIG,HIGH); delayMicroseconds(10); digitalWrite(TRIG,LOW);
  long duration=pulseIn(ECHO,HIGH); long distance=duration / 58.2;
  if(distance < 10){ myservo.write(90); } else{ myservo.write(0); }
  int a=analogRead(A0);
  int b=analogRead(A1);
  int c=analogRead(A2);
  lot=0;
  if(a<500){ mode=1; bluetooth.write('a'); digitalWrite(4,1); digitalWrite(5,0); } // 차량 있을 때
  else{ bluetooth.write('b'); digitalWrite(4,0); digitalWrite(5,1); lot++; } // 차량 없을 때
  if(b < 500){ mode=2; bluetooth.write('c'); digitalWrite(6,1); digitalWrite(7,0); } // 차량 있을 때
  else{ bluetooth.write('d'); digitalWrite(6,0); digitalWrite(7,1); lot++; } // 차량 없을 때
  if(c < 500){ mode=3; bluetooth.write('e'); digitalWrite(8,1); digitalWrite(10,0); } // 차량 있을 때
  else{ bluetooth.write('f'); digitalWrite(8,0); digitalWrite(10,1); lot++; } // 차량 없을 때
  lcd.setCursor(0,0); lcd.print("parking lot : "); lcd.print(lot);
15ef님의 댓글
15ef 작성일
감사합니다 해결했습니다!!
질문 ATmega128 1602A LCD 출력 질문입니다.댓글[2] 새글 444222a 12:23 19
답변 답변글 답변 : 아트메가128/ srf05 초음파센서를 이용한 타이머 인터럽트 질문입니다 새글 master 22-05-26 25
질문 Atmega128 블루투스 오류 질문 새글 yhj2644 22-05-26 32
답변 답변글 답변 : Atmega128 블루투스 오류 질문 새글 master 22-05-26 24
답변 답변글 답변 : 아두이노 간단한 프로그램 새글 master 22-05-26 22
질문 atmega128 타이머 작성시 키패트 입력으로 인터럽트 사용에 대하여 질문이 있습니다.댓글[1] 이미지새글 마프하나 22-05-25 44
질문 atmega 128 타이머 작성 중 질문 드립니다.댓글[8] 이미지 마프하나 22-05-23 87
질문 아두이노와 휴대폰을 HC-06으로 연결시켜서 블루투스연결이 끊기면 부저에서 소리가 나게 할려하는데 어떻게 해…댓글[1] 졸작부수다 22-05-23 282
질문 보드레이트 질문댓글[1] 죠르디 22-05-23 45
