질문게시판 > 아두이노 라인following질문있어요
TODAY378 TOTAL2,175,686
BASIC4MCU | 질문게시판 | 아두이노 라인following질문있어요
작성자 id0101 작성일2020-11-25 18:34 조회6,336회 댓글3건
//        MOTOR RIGHT     ==>  MOTOR DRIVER A
//        MOTOR LEFT      ==>  MOTOR DRIVER B
//        IR SENSOR RIGHT ==>  A0 (SENSOR0)
//        IR SENSOR LEFT  ==>  A1 (SENSOR1)
//        ECHO            ==>  8
//        TRIG            ==>  9
//        TXD             ==>  4
//        RXD             ==>  5
//     Appinventor file : Robot_Controller_II_robotics_2020.aia
#include <Ultrasonic.h>
char trig= 9;
char echo= 8;
int distance;
Ultrasonic ultrasonic(trig, echo);
// bluetooth communication
int blueRx = 4;
int blueTx = 5;
unsigned char commandReadyFlag = 0;
unsigned char command, power;
SoftwareSerial mySerial(blueRx,blueTx); // 소프트웨어 시리얼통신 포트 생성
int flag=0;
// sensor
#define BLACK 0
#define WHITE 1
// 회전 방향
#define CW  1   // clockwise
#define CCW 0   // counter-clockwise
// 왼쪽, 오른쪽 바퀴
#define MOTOR_LEFT 0
#define MOTOR_RIGHT 1
// motor settings
// 아두이노 PIN 설정
const byte PWMA = 3;      // PWM control (speed) for motor A
const byte PWMB = 11;     // PWM control (speed) for motor B
const byte DIRA = 12;     // Direction control for motor A
const byte DIRB = 13;     // Direction control for motor B
int sensor0, sensor1; // sensor reading 0 ~ 1023
int sensorLeft, sensorRight;  // BLACK(0), WHITE(1)
  mySerial.begin(9600);
  setupArdumoto();      // Set all pins as outputs
  int cutDistance= 10;
  ultra();
  // Bluetooth communication
  communication();
  if (command == 1)
    if(distance > cutDistance){
      // read sensor
  readSensors();
  // color finder
  sensorRight = colorFinder(sensor0);
  sensorLeft  = colorFinder(sensor1);
  // 로봇제어
  robotControl(sensorLeft,sensorRight);
    robotAvoidance();
  robotStop();
void ultra(){
  distance= ultrasonic.read();
 // setupArdumoto initialize all pins
void setupArdumoto()
  // All pins should be setup as outputs:
  pinMode(PWMA, OUTPUT);
  pinMode(PWMB, OUTPUT);
  pinMode(DIRA, OUTPUT);
  pinMode(DIRB, OUTPUT);
  // Initialize all pins as low:
  digitalWrite(PWMA, LOW);
  digitalWrite(PWMB, LOW);
  digitalWrite(DIRA, LOW);
  digitalWrite(DIRB, LOW);
void driveArdumoto(byte motor, byte dir, byte spd)
  if(motor == MOTOR_RIGHT)
    digitalWrite(DIRA, dir);
    analogWrite(PWMA, spd);
  else if(motor == MOTOR_LEFT)
    digitalWrite(DIRB, dir);
    analogWrite(PWMB, spd);
void robotForward(int powerLeft, int powerRight)
  driveArdumoto(MOTOR_RIGHT,CW,powerRight);
  driveArdumoto(MOTOR_LEFT,CCW,powerRight);
void robotBackward(int powerLeft, int powerRight)
  driveArdumoto(MOTOR_RIGHT,CCW,powerRight);
  driveArdumoto(MOTOR_LEFT,CW,powerRight);
void robotRight(int powerLeft, int powerRight)
void robotLeft(int powerLeft, int powerRight)
void robotStop()
  stopArdumoto(MOTOR_LEFT);
  stopArdumoto(MOTOR_RIGHT);
 // stopArdumoto makes a motor stop
void stopArdumoto(byte motor)
  driveArdumoto(motor, 0, 0);
// Read sensor measurements
void readSensors(){
  sensor0 = 1023 - analogRead(A0);  // sensor Right
  sensor1 = 1023 - analogRead(A1);  // sensor Left
  /*sensorRight = sensor0;
    sensorLeft = sensor1;
    Serial.print("sensor R:");
    Serial.println(sensorRight);
    Serial.print("sensor L:");
   Serial.println(sensorLeft); */
// color finder
char colorFinder(int sensorValue) {
   char color;
   const int THRESHOLD = 800;
  if(sensorValue > THRESHOLD)
    color = WHITE;
     color = BLACK;
   return color;
// 로봇제어 함수
void robotControl(int sensorLeft, int sensorRight){
  if (sensorLeft == BLACK && sensorRight == BLACK){
      robotForward(200,200);
   else if (sensorLeft == BLACK && sensorRight == WHITE) {
              robotLeft(200,200);
              delay(30);
   else if (sensorLeft == WHITE && sensorRight == BLACK) {
              robotRight(200,200);
              delay(30);
    if(flag==0)
    robotStop();
void robotAvoidance()
  robotRight(200,200); // 45도
  delay(300);
  robotForward(200,200);  // 20 cm
  delay(1100);
  robotLeft(200,200);  // 75 deg
  delay(400);
  delay(1400);
void communication(){
  if (mySerial.available() >= 4){
    //Serial.println("data arrived ");
    unsigned char buffer[4];
    // read data from buffer and save to array
    for (char i=0; i<4; i++){
      buffer[i] = mySerial.read();
    // verify data
    if ( buffer[0]== 255 && buffer[3] == 100) {
         command = buffer[1];
         power = buffer[2];
         Serial.print("command:");
         Serial.println(command);
          Serial.print("power:");
         Serial.println(power);
위에 코드는 로봇이 검은선을 따라가는 코드인데요 처음에 검은선을 이탈하면 그냥가고 그다음에 또 이탈하면 로봇이 정지하게 해야하는데 아무리해봐도 안돼서요ㅠㅠ 알려주실분 있나요...?
일단 저는 int flag=0;을 선언하고 void robotControl(int sensorLeft, int sensorRight) 이 함수에 else{
    if(flag==0)
    robotStop();
이렇게 넣어봤는데 처음 라인을 이탈했을때 가고 2번째로 이탈했을때 멈춰야하는데 그냥 가더라구요ㅠㅠ
댓글 3
조회수 6,336
    if(flag==0){ robotForward(200,200); flag=1; } // flag=1; 추가하세요
    else robotStop();
예상되는 문제점은
루프 함수의 루프시간이 200ms라고 하고
이탈해서 검은라인으로 복귀하는데 600ms가 걸린다고 가정하면
이탈 후 검은라인으로 복귀하기 전 robotControl() 이 함수를 3번 실행하게 되는데
처음 200ms는 그대로 가고
두 번째에서 else가 실행 되면서 정지하게 됩니다.
시간적인 요소도 고려해서 살펴보세요
id0101님의 댓글
id0101 작성일
와!! 감사합니다 잘돼요
진짜 감사합니다!!!
질문 ATmega128 1602A LCD 출력 질문입니다.댓글[2] 새글 444222a 22-05-27 34
질문 atmega128에서 스위치1개는LED, 스위치 1개는 세그먼트의 동작하게 하려는데.. aasdw 22-05-26 59
답변 답변글 답변 : atmega128에서 스위치1개는LED, 스위치 1개는 세그먼트의 동작하게 하려는데..댓글[1] 새글 master 22-05-26 34
답변 답변글 답변 : Atmega128 블루투스 오류 질문 새글 master 22-05-26 33
질문 atmega128 타이머 작성시 키패트 입력으로 인터럽트 사용에 대하여 질문이 있습니다.댓글[1] 이미지 마프하나 22-05-25 92
