질문게시판 > 아두이노 라이브러리 varspeedservo 관련 질문입니다
TODAY1,050 TOTAL2,176,358
BASIC4MCU | 질문게시판 | 아두이노 라이브러리 varspeedservo 관련 질문입니다
작성자 갓자친구 작성일2020-12-01 01:05 조회3,375회 댓글1건
VarSpeedServo의 slowmove 함수를 사용하는 코드를 찾았는데..
#include "VarSpeedServo.h"
VarSpeedServo RU;  //Right Upper 4
VarSpeedServo RL;  //Right Lower 5
VarSpeedServo LU;  //Left Upper  6
VarSpeedServo LL;  //Left Lower  7
const int array_cal[4] = {90,90,90,90}; //  Calibration을 통해 저 값을 수정하는 것 같습니다.
int RU_Degree = 0, LU_Degree = array_cal[2] + 5;
const int vel = 20;
const int delay_Forward = 750;
const int num1 = 6;
const int array_forward[num1][4] =
    {0,-40,0,-20},
    {30,-40,30,-20},
    {30,0,30,0},
    {0,20,0,40},
    {-30,20,-30,40},
    {-30,0,-30,0},
void Servo_Init()
    RU.attach(4);   // Connect the signal wire of the upper-right servo to pin 4
    RL.attach(5);   // Connect the signal wire of the lower-right servo to pin 5
    LU.attach(6);   // Connect the signal wire of the upper-left  servo to pin 6
    LL.attach(7);   // Connect the signal wire of the lower-left  servo to pin 7
void Adjust()                            // Avoid the servo's fast spinning in initialization
{                                        // RU,LU goes from array_cal[0] - 5 ,array_cal[2] + 5 degrees to array_cal[0],array_cal[2] degrees
    for(RU_Degree = array_cal[0] - 5; RU_Degree <= array_cal[0]; RU_Degree += 1) {
        RU.write(RU_Degree);             // in steps of 1 degree
        LU.write(LU_Degree--);           // tell servo to go to RU_Degreeition, LU_Degreeition in variable 'RU_Degree', 'LU_Degree'
        delay(15);                       // waits 15ms for the servo to reach the RU_Degreeition
void Forward()
    for(int x=0; x<num1; x++) {
        RU.slowmove (array_cal[0] + array_forward[x][0] , vel);
        RL.slowmove (array_cal[1] + array_forward[x][1] , vel);
        LU.slowmove (array_cal[2] + array_forward[x][2] , vel);
        LL.slowmove (array_cal[3] + array_forward[x][3] , vel);
        delay(delay_Forward);
#ifdef INSTALL
    Servo_Init();
    RU.slowmove (90 , vel);
    RL.slowmove (90 , vel);
    LU.slowmove (90 , vel);
    LL.slowmove (90 , vel);
    while(1);
#endif
#ifdef CALIBRATION
    Servo_Init();
    Adjust();
    RL.slowmove (array_cal[1] , vel);
    LL.slowmove (array_cal[3] , vel);
    delay(2000);
    while(1);
#endif
#ifdef RUN
    Servo_Init();
    Adjust();
    delay(2000);
#endif
    Forward();
여기에서
    {0,-40,0,-20},
    {30,-40,30,-20},
    {30,0,30,0},
    {0,20,0,40},
    {-30,20,-30,40},
    {-30,0,-30,0},
}; 요 부분이 각도로 추정되어서, 첫 줄 0,-40,0,-20을 array_cal[0] + array_forward[x][0]를 감안해서 90,50,90,70으로 보고 pos값으로 바꿨습니다.
for (pos = 123;pos<k*50+123;pos++){
        HCPCA9685.Servo(4,pos*1.8);
        HCPCA9685.Servo(5,pos);
        HCPCA9685.Servo(6,pos*1.8);
        HCPCA9685.Servo(7,pos*1.4);
        delay(5);
링크 2의 전 질문에서처럼 HCPCA9685 헤더를 포함하는 드라이버 쉴드를 사용해야하는 상황이었기 때문에
RU.slowmove (array_cal[0] + array_forward[x][0] , vel); 를 바로 위의 HCPCA9685.Servo(4,pos*1.8); 이거로 대체했습니다.
나머지 다섯 줄도 저런 방식으로 코드를 바꾸고 실행해봤지만... 두 다리가 제멋대로 움직이는 것 같았습니다.
slowmove 함수의 vel 변수가 동작에 영향을 미치는 거 같긴 한데 해결방법이 떠오르질 않습니다 ㅠㅠ....
또, 링크 3에서 본 HCPCA9685 헤더 라이브러리에는 비슷한 기능이 보이질 않는것 같습니다.
위의 코드에서 Adjust 함수 또한 코드를 바꿀 방법이 떠오르지 않습니다 ㅠㅠ
아래는 제가 현재 드라이버 쉴드를 사용하는 것으로 수정중인 코드입니다.
#include <Servo.h> // 서보모터 라이브러리 사용
#include "HCPCA9685.h"  // 설치한 헤더 파일
#define I2CAdd 0x40
HCPCA9685 HCPCA9685(I2CAdd);
 HCPCA9685.Init(SERVO_MODE);
 HCPCA9685.Sleep(false);
void Forward()
    unsigned int pos;
    unsigned int k = 2.03888888888888889;
    for(int x=0; x< 6; x++){
        delay(5);
      HCPCA9685.Servo(4,pos*2.4);
      HCPCA9685.Servo(6,pos*2.4);
      delay(5);
      for (pos = 123;pos<k*120+123;pos++){
      HCPCA9685.Servo(4,pos);
      HCPCA9685.Servo(5,pos*0.75);
      HCPCA9685.Servo(6,pos);
      HCPCA9685.Servo(7,pos*0.75);
      delay(5);
      for (pos = 123;pos<k*90+123;pos++){
      HCPCA9685.Servo(5,pos*1.23);
      HCPCA9685.Servo(7,pos*1.45);
      delay(5);
      for (pos = 123;pos<k*60+123;pos++){
      HCPCA9685.Servo(5,pos*1.84);
      HCPCA9685.Servo(7,pos*2.17);
      delay(5);
      HCPCA9685.Servo(5,pos*1.5);
      HCPCA9685.Servo(7,pos*1.5);
      delay(5);
  Forward();
조회수 3,375
무엇 때문에 라이브러리를 찾은 것인가요?
서보모터의 속도는 딜레이를 변경하면 됩니다.
공지 사이트 이용 안내댓글[24] master 17-10-29 29870
질문 아두이노 모터 질문 새글첨부파일 todd33671 17:51 8
질문 압력센서 질문있습니다.댓글[3] 새글 브레이크 14:17 18
질문 아두이노 코딩 질문댓글[1] 이미지새글 에도이누 14:05 20
질문 esp32를 이용한 피에조부저댓글[1] 이미지새글 ejdog 22-05-27 17
질문 아두이노 서보모터 무한회전 문제 해결을 어떻게 해야할까요 새글 GinGer 22-05-27 22
답변 답변글 답변 : 아두이노 서보모터 무한회전 문제 해결을 어떻게 해야할까요댓글[5] 새글 master 22-05-27 35
질문 모터 엔코더 제어 질문드립니다. 새글 oreoreo 22-05-27 21
답변 답변글 답변 : 모터 엔코더 제어 질문드립니다. 새글 master 22-05-27 16
답변 답변글 답변 : 블루투스 관련 코드 도와주세요 새글 master 22-05-27 19
질문 마이크로칩 스튜디오 코드 해석 새글 최선을다하자 22-05-27 25
답변 답변글 답변 : 마이크로칩 스튜디오 코드 해석 새글 master 22-05-27 28
질문 적외선 거리 센서로 블루투스 알람 설정 코딩...댓글[1] 새글 ededed 22-05-26 27
질문 아두이노 api 질문댓글[1] 새글첨부파일 리니어 22-05-26 23
질문 atmega128 키패드 입력 오류에 대하여 질문 있습니다.댓글[2] 마프하나 22-05-26 59
질문 초음파센싱을 통한 리니어벨트 (스텝모터사용) 조건문댓글[1] 아두이노대학 22-05-26 38
질문 아트메가128/ srf05 초음파센서를 이용한 타이머 인터럽트 질문입니다 아트메가넘어려워 22-05-26 36
답변 답변글 답변 : 아트메가128/ srf05 초음파센서를 이용한 타이머 인터럽트 질문입니다 master 22-05-26 40
질문 atmega128에서 스위치1개는LED, 스위치 1개는 세그먼트의 동작하게 하려는데.. aasdw 22-05-26 69
답변 답변글 답변 : atmega128에서 스위치1개는LED, 스위치 1개는 세그먼트의 동작하게 하려는데..댓글[1] master 22-05-26 59
질문 Atmega128 블루투스 오류 질문 yhj2644 22-05-26 65
답변 답변글 답변 : Atmega128 블루투스 오류 질문 master 22-05-26 43
질문 아두이노 간단한 프로그램 행복지수업 22-05-25 54
