BASIC4MCU | 질문게시판 | 제발 도와주세요 ㅜㅜ (완전초보)
작성자 햄스팸 작성일2018-06-05 15:58 조회4,414회 댓글0건본문
#define outp(x,y) ((y)=(x))
#define inp(x) (x)
#define LCD_RS_SET sbi(PORTD,0)
#define LCD_RS_CLEAR cbi(PORTD,0)
#define LCD_RW_SET sbi(PORTD,1)#define LCD_RW_CLEAR cbi(PORTD,1)
#define LCD_E_SET sbi(PORTD,2)
#define LCD_E_CLEAR cbi(PORTD,2)
#define LCD_LIGHT_SET sbi(PORTD,3)
#define LCD_LIGHT_CLEAR cbi(PORTD,3)
#define sbi(PORTX,bitX)PORTX |= (1<<bitX)
#define cbi(PORTX,bitX)PORTX &= ~(1<<bitX)
unsigned char display_data1[]=" HANKYONG ";unsigned char display_data2[]=" HAMHAMHAM ";
void delay(unsigned int i){
while(--i);
void lcd_busy(void)
unsigned char busy_data;
busy_data=0;
LCD_E_CLEAR;
outp(0x00, DDRB);
do{
LCD_RS_CLEAR;
LCD_RW_SET;
LCD_E_SET;
busy_data=inp(PINB);
LCD_E_CLEAR;
}while(busy_data & 0x80);outp(0xFF,DDRB);
void lcd_enable(void){
LCD_E_SET;
LCD_E_CLEAR;}
void lcd_func_set(void){
LCD_RW_CLEAR;
LCD_RS_CLEAR;
outp(0x38, PORTB);
lcd_enable();
void lcd_command(unsigned char lcd_data){
lcd_busy();
LCD_RW_CLEAR;
LCD_RS_CLEAR;
outp(lcd_data,PORTB);
lcd_enable();}
void lcd_init(void)
LCD_E_CLEAR;
delay(50000);
lcd_func_set();
delay(10000);
lcd_func_set();
lcd_func_set();
lcd_command(0x38);
lcd_command(0x0C);
lcd_command(0x01);
lcd_command(0x06);}
void lcd_write_char(unsigned char lcd_data){
lcd_busy();
LCD_RW_CLEAR;
LCD_RS_SET;
outp(lcd_data, PORTB);
lcd_enable();}
void lcd_display(void){
unsigned char i;
LCD_LIGHT_SET;
lcd_command(0x02);
for(i=0;i<16;i++){lcd_write_char(display_data1[i]);
lcd_command(0xC0);
for(i=0;i<16;i++){lcd_write_char(display_data2[i]);
int main(void){
outp(0xFF ,DDRB);
outp(0x0F ,DDRD);
outp(0x00 ,PORTD);
lcd_init();
lcd_display();
while(1){};
unsigned char LED;
outp(0x00, DDRF);
outp(0xFF,DDRE);
outp(0xFF,PORTE);
LED=0x00;
LED=inp(PINF);
outp(LED,PORTE);
파란부분을 추가하기전에는 LCD에 출력됬는데 추가한뒤로는 출력이 아예 안되요왜그럴까요??ㅜㅡ
조회수 4,414등록된 댓글이 없습니다.
