질문게시판 > 소프트웨어 질문있습니다
TODAY904 TOTAL2,585,076
BASIC4MCU | 질문게시판 | 소프트웨어 질문있습니다
작성자 우왕우오옹 작성일2020-12-09 00:06 조회7,258회 댓글2건
각도제어를 20ms 속도제어를 4ms마다 측정을 하는데요 (pi제어) 20ms시 각도제어 측정 후 속도제어를 측정하고싶으면 어떤식으로 코드를 짜야할까요? (인터럽트 처리 루틴질문입니다)
#include "OK-2561BR.h"
#define  Tss    0.004
#define  Kps    0.012
#define  Kis    0.27
#define Tsa     0.2
#define  Kpa    5
#define  Kia    112.5
volatile unsigned char L_m1, L_count, L_count0 = 0;
volatile unsigned char R_m1, R_count, R_count0 = 0;
volatile float L_Wr, L_Wref, Aref = 0;
volatile float R_Wr, R_Wref;
volatile float Wref = 500.;
volatile unsigned char wheel = 'A'; // wheel selection('A'=all, 'L'=left, 'R'=right)
volatile float L_Werr, L_Werr0 = 0., L_PI = 0.; // left motor speed error for PI control
volatile float R_Werr, R_Werr0 = 0., R_PI = 0.; // right motor speed error for PI control
volatile float Aerr, Aerr0 = 0., A_PI = 0.;
volatile float PIconstants,APIconstants; // speed PI control constant
volatile unsigned char RXD, RXD_status=0; // USART1 receive temporary buffer and receive status
volatile unsigned char RXD_index, RXD_flag = 0; // USART1 buffer index and receive data flag
volatile unsigned char RXD_buffer[8]; // RXD buffer(0xAA,YH,YL,PH,PL,RH,RL,0x55)
volatile unsigned char RXD_data[8]; // RXD data
float pitch;
ISR(USART1_RX_vect) /* USART1 interrupt function */
unsigned char i;
RXD = UDR1; // receive a character
if((RXD_status == 1) && (RXD_index <= 7)) // receive data
RXD_buffer[RXD_index++] = RXD;
if((RXD_status == 0) && (RXD == 0xAA)) // 전송 시작 표시 ?
{ RXD_status = 1;
RXD_index = 0;
else if((RXD_index == 8) && (RXD == 0x55)) // 전송 종료 표시 ?
{ RXD_status = 0;
RXD_index = 0;
RXD_flag = 1; // if OK, store receive data
for(i = 0; i <= 7; i++)
RXD_data[i] = RXD_buffer[i];
ISR(TIMER4_COMPA_vect) /* Timer4 interrupt function(2.5ms period) */
unsigned int PWM; // PWM output data
L_count = TCNT0; // read TCNT0 for left motor
R_count = TCNT1; // read TCNT1 for right motor
sei();                                        // global interrupt enable
L_m1 = L_count - L_count0; // calculate left motor speed
L_count0 = L_count;
L_Wr = (float)L_m1*60./52./Tss;
if((PINC & 0x10) == 0x00) L_Wr *= -1.;
R_m1 = R_count - R_count0; // calculate right motor speed
R_count0 = R_count;
R_Wr = (float)R_m1*60./52./Tss;
if((PINC & 0x20) == 0x00) R_Wr *= -1.;
L_Werr = L_Wref - L_Wr; // ***** speed PI controller of left motor
L_PI = L_PI + PIconstants*L_Werr - Kps*L_Werr0;
L_Werr0 = L_Werr;
if(L_PI > 999.)       L_PI = 999.; // PI control limiter
else if(L_PI < -999.) L_PI = -999.;
if(L_PI >= 0.) // output PWM value for forward
{ PWM = L_PI + 0.5;
OCR3A = PWM;
PORTC = (PORTC & 0xFC) | 0x02;
else // output PWM value for backward
{ PWM = -L_PI + 0.5;
OCR3A = PWM;
PORTC = (PORTC & 0xFC) | 0x01;
R_Werr = R_Wref - R_Wr; // ***** speed PI controller of right motor
R_PI = R_PI + PIconstants*R_Werr - Kps*R_Werr0;
R_Werr0 = R_Werr;
if(R_PI > 999.)       R_PI = 999.; // PI control limiter
else if(R_PI < -999.) R_PI = -999.;
if(R_PI >= 0.) // output PWM value for forward
{ PWM = R_PI + 0.5;
OCR3B = PWM;
PORTC = (PORTC & 0xF3) | 0x08;
{ PWM = -R_PI + 0.5;
OCR3B = PWM;
PORTC = (PORTC & 0xF3) | 0x04;
Aerr = Aref - pitch; // 기울기 pi
A_PI = A_PI + APIconstants*Aerr - Kpa*Aerr0;
Aerr0 = Aerr;
if(A_PI > 999.)       A_PI = 999.;
else if(A_PI < -999.) A_PI = -999.;
if(A_PI >= 0.) // output PWM value for forward
{ PWM = A_PI + 0.5;
OCR3A = PWM;
OCR3B = PWM;
{ PWM = -A_PI + 0.5;
OCR3A = PWM;
OCR3B = PWM;
asm volatile("PUSH R0");
asm volatile("POP  R0");
조회수 7,258
2.5ms로 만들지말고 4ms 주기로 만드세요
ISR(TIMER4_COMPA_vect){ /* Timer4 interrupt function(4ms period) */
  ststic char c=0;
  if(++c>=4){ c=0; // 20ms
    각도제어
  속도제어 // 4ms
공지 사이트 이용 안내댓글[28] master 17-10-29 33560
질문 아두이노 코딩 에러 질문댓글[1] 이미지새글첨부파일 박무농 23-03-25 27
질문 아두이노를 이용한 타이머, 태양전지 제어댓글[2] 새글 박무농 23-03-25 29
질문 초음파센서를 이용한 모터제어 질문있습니다.댓글[3] 이미지첨부파일 뉴비에오 23-03-24 39
질문 모터 작동 시, 일부 모듈이 꺼지는 현상에 대해 질문드립니다. 이미지 그렇찌 23-03-22 33
답변 답변글 답변 : 모터 작동 시, 일부 모듈이 꺼지는 현상에 대해 질문드립니다. 이미지 master 23-03-23 22
질문 HC06을 마스터로 설정하면 HC06끼리만 통신되나요?댓글[4] 비차 23-03-21 36
질문 아두이노 테트리스 게임댓글[1] 첨부파일 지욱애 23-03-02 160
질문 아두이노우노 블루투스 2개 연결댓글[1] dsfadfs 23-02-28 117
질문 아두이노 나노33 IOT 의 BLE 연결 문제 이미지 가루밀 23-02-24 81
질문 아두이노 블루투스 관련 질문입니다. 생물공학도 23-02-21 107
답변 답변글 답변 : 아두이노 블루투스 관련 질문입니다. master 23-02-21 108
질문 자율주행 로봇을 만드는데 질문있습니다.댓글[2] 뉴비에오 23-02-18 176
