질문게시판 > 아두이노
TODAY1,874 TOTAL3,356,824
BASIC4MCU | 질문게시판 | 아두이노
작성자 비공개 작성일2018-06-05 16:16 조회10,255회 댓글0건
#include <Wire.h>
#include <Adafruit_MLX90614.h>
Adafruit_MLX90614 mlx=Adafruit_MLX90614();
double Amb,Obj,AmbSum,ObjSum;
  Serial.println("Adafruit MLX90614 test");
  mlx.begin();
  AmbSum=0; ObjSum=0;
  for(int i=0; i<10; i++){
    AmbSum+=mlx.readAmbientTempC();
    ObjSum+=mlx.readObjectTempC();
    Serial.print(i+1); Serial.print("\tAmbient="); Serial.print(Amb);
    Serial.print("*C\tObject="); Serial.print(Obj); Serial.println("*C");
  Amb=AmbSum/10;
  Obj=ObjSum/10;
  Serial.print("Ambient Avr.="); Serial.print(Amb);
  Serial.print("*C\tObject Avr.="); Serial.print(Obj); Serial.println("*C");
  Serial.println();
  delay(2000);
  if(Obj<28)analogWrite(4,HIGH);
  else      analogWrite(4,LOW);
} ------비접촉 적외선 센서
#include <TinyGPS.h>
/* This sample code demonstrates the normal use of a TinyGPS object.
   It requires the use of SoftwareSerial, and assumes that you have a
   4800-baud serial GPS device hooked up on pins 3(rx) and 4(tx).
TinyGPS gps;
SoftwareSerial nss(3, 4);
static void gpsdump(TinyGPS &gps);
static bool feedgps();
static void print_float(float val, float invalid, int len, int prec);
static void print_int(unsigned long val, unsigned long invalid, int len);
static void print_date(TinyGPS &gps);
static void print_str(const char *str, int len);
  Serial.begin(115200);
  nss.begin(9600);
  Serial.print("Testing TinyGPS library v. "); Serial.println(TinyGPS::library_version());
  Serial.println("by Mikal Hart");
  Serial.println();
  Serial.print("Sizeof(gpsobject) = "); Serial.println(sizeof(TinyGPS));
  Serial.println();
  Serial.println("Sats HDOP Latitude Longitude Fix  Date       Time       Date Alt     Course Speed Card  Distance Course Card  Chars Sentences Checksum");
  Serial.println("          (deg)    (deg)     Age                        Age  (m)     --- from GPS ----  ---- to London  ----  RX    RX        Fail");
  Serial.println("--------------------------------------------------------------------------------------------------------------------------------------");
  bool newdata = false;
  unsigned long start = millis();
  // Every second we print an update
  while (millis() - start < 1000)
    if (feedgps())
      newdata = true;
  gpsdump(gps);
  float flat, flon;
  unsigned long age, date, time, chars = 0;
  unsigned short sentences = 0, failed = 0;
  static const float LONDON_LAT = 51.508131, LONDON_LON = -0.128002;
  print_int(gps.satellites(), TinyGPS::GPS_INVALID_SATELLITES, 5);
  print_int(gps.hdop(), TinyGPS::GPS_INVALID_HDOP, 5);
  gps.f_get_position(&flat, &flon, &age);
  print_float(flat, TinyGPS::GPS_INVALID_F_ANGLE, 9, 5);
  print_float(flon, TinyGPS::GPS_INVALID_F_ANGLE, 10, 5);
  print_int(age, TinyGPS::GPS_INVALID_AGE, 5);
  print_date(gps);
  print_float(gps.f_altitude(), TinyGPS::GPS_INVALID_F_ALTITUDE, 8, 2);
  print_float(gps.f_course(), TinyGPS::GPS_INVALID_F_ANGLE, 7, 2);
  print_float(gps.f_speed_kmph(), TinyGPS::GPS_INVALID_F_SPEED, 6, 2);
  print_str(gps.f_course() == TinyGPS::GPS_INVALID_F_ANGLE ? "*** " : TinyGPS::cardinal(gps.f_course()), 6);
  print_int(flat == TinyGPS::GPS_INVALID_F_ANGLE ? 0UL : (unsigned long)TinyGPS::distance_between(flat, flon, LONDON_LAT, LONDON_LON) / 1000, 0xFFFFFFFF, 9);
  print_float(flat == TinyGPS::GPS_INVALID_F_ANGLE ? 0.0 : TinyGPS::course_to(flat, flon, 51.508131, -0.128002), TinyGPS::GPS_INVALID_F_ANGLE, 7, 2);
  print_str(flat == TinyGPS::GPS_INVALID_F_ANGLE ? "*** " : TinyGPS::cardinal(TinyGPS::course_to(flat, flon, LONDON_LAT, LONDON_LON)), 6);
  gps.stats(&chars, &sentences, &failed);
  print_int(chars, 0xFFFFFFFF, 6);
  print_int(sentences, 0xFFFFFFFF, 10);
  print_int(failed, 0xFFFFFFFF, 9);
  Serial.println();
  char sz[32];
  if (val == invalid)
    strcpy(sz, "*******");
    sprintf(sz, "%ld", val);
  sz[len] = 0;
  for (int i=strlen(sz); i<len; ++i)
    sz[i] = ' ';
  if (len > 0)
    sz[len-1] = ' ';
  Serial.print(sz);
  feedgps();
  char sz[32];
  if (val == invalid)
    sz[len] = 0;
        if (len > 0)
          sz[len-1] = ' ';
    for (int i=7; i<len; ++i)
        sz[i] = ' ';
    Serial.print(sz);
    Serial.print(val, prec);
    int vi = abs((int)val);
    int flen = prec + (val < 0.0 ? 2 : 1);
    flen += vi >= 1000 ? 4 : vi >= 100 ? 3 : vi >= 10 ? 2 : 1;
    for (int i=flen; i<len; ++i)
      Serial.print(" ");
  feedgps();
  int year;
  byte month, day, hour, minute, second, hundredths;
  unsigned long age;
  gps.crack_datetime(&year, &month, &day, &hour, &minute, &second, &hundredths, &age);
  if (age == TinyGPS::GPS_INVALID_AGE)
    Serial.print("*******    *******    ");
    char sz[32];
    sprintf(sz, "%02d/%02d/%02d %02d:%02d:%02d   ",
        month, day, year, hour, minute, second);
    Serial.print(sz);
  feedgps();
  int slen = strlen(str);
  for (int i=0; i<len; ++i)
    Serial.print(i<slen ? str[i] : ' ');
  feedgps();
  while (nss.available())
    if (gps.encode(nss.read()))
      return true;
  return false;
} ------GPS쉴드 소스
SoftwareSerial BTSerial(4, 5); // 소프트웨어 시리얼 (TX,RX)
Serial.println("Hello!");
BTSerial.begin(9600);
  while (BTSerial.available()){
    byte data = BTSerial.read();
    Serial.write(data);
  while (Serial.available()){
    byte data = Serial.read();
    BTSerial.write(data);
}  ------블루투스 소스
비접촉 적외선 센서 코딩이랑 GPS코딩이랑 블루투스 코딩을 합치고 싶은데...알려주세요ㅠㅠ  블루투스는 앱인벤터로 만들겁니다!!!
조회수 10,255
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 23755
공지 사이트 이용 안내댓글[31] master 17-10-29 37703
질문 ATmega4809 nRF24L01 모듈을 이용한 무선 통신댓글[3] 새글 Ahri 24-06-12 14
질문 atmega128에 dht11 왜 측정을 못하죠?댓글[1] 탈북한시민 24-06-11 31
질문 atmega128이 실행이 되지 않습니다댓글[1] 이미지첨부파일 니굴 24-06-10 35
질문 아트메가 128 쓰는디 while 문이 안먹혀요댓글[1] 수히 24-06-09 27
질문 atmega128 UART통신으로 FND출력 Rion 24-06-09 42
답변 답변글 답변 : atmega128 UART통신으로 FND출력댓글[1] master 24-06-10 26
질문 atmega128 라인트레이서 코드와 회로도 질문...몇일 째 머리아파 죽겠네요ㅠ댓글[2] 이미지첨부파일 왕두일 24-06-06 125
답변 답변글 답변 : atmega128 라인트레이서 코드와 회로도 질문...몇일 째 머리아파 죽겠네요ㅠ master 24-06-07 62
질문 atmega128을 이용한 LCD 사용에 문제가 발생했습니다.댓글[3] 이미지 네넴 24-06-05 299
질문 Co 센서 값에 따른 ppm을 계산하려는데댓글[1] 라칸 24-06-05 68
질문 17HS4401, A4988 스텝모터 제어댓글[1] 이미지 jhbaik 24-06-03 92
질문 코드비전avr을 이용한 아두이노 우노 제어댓글[1] gkstntjd 24-05-29 120
질문 Energia 시리얼 모니터에 아무것도 출력되지않습니다.댓글[1] 김의공 24-05-22 130
질문 아두이노 스위치, 에어펌프 연결댓글[1] 이미지첨부파일 존존 24-05-20 277
질문 MSP430런치패드를 이용한 LCD 코딩 관련 질문댓글[1] 뀨쥰이 24-05-16 173
질문 생활 속 가스 센서 이미지첨부파일 Fosen 24-05-13 97
질문 atmega128A로 초음파센서 바밤 24-05-13 228
답변 답변글 답변 : atmega128A로 초음파센서 master 24-05-13 198
질문 eeprom 값 출력이 다르게 나옵니다댓글[5] 이미지첨부파일 idghte 24-05-05 356
답변 답변글 답변 : eeprom 값 출력이 다르게 나옵니다 master 24-05-05 112
질문 센서나 블루투스에서 조건문이 실행이 느립니다. 현아 24-05-03 172
답변 답변글 답변 : 센서나 블루투스에서 조건문이 실행이 느립니다. master 24-05-03 153
질문 님들 MG811 이산화탄소 센서를 쓰는데 라칸 24-05-03 141
답변 답변글 답변 : 님들 MG811 이산화탄소 센서를 쓰는데 이미지 master 24-05-03 132
질문 아두이노와 디지털 홀센서 사용 중 sampling rate 문제입니다. 첨부파일 fjur564 24-05-03 163
답변 답변글 답변 : 아두이노와 디지털 홀센서 사용 중 sampling rate 문제입니다. 이미지 master 24-05-03 191
질문 OP AMP댓글[1] 이미지첨부파일 창원거북이 24-05-02 144
질문 라즈베리파이 라우팅 테이블을 영구 추가하려는데 라칸 24-04-30 123
