질문게시판 > 답변 : 제발 도와주세요 ㅜㅜ (완전초보)
TODAY495 TOTAL2,269,774
BASIC4MCU | 질문게시판 | 답변 : 제발 도와주세요 ㅜㅜ (완전초보)
작성자 master 작성일2018-06-05 16:31 조회4,820회 댓글0건
// DateTime : 2018-06-05 오후 4:34:29
#include <avr/io.h>
#define outp(x,y)       ((y)=(x))
#define inp(x)          (x)
#define LCD_RS_SET      sbi(PORTD,0)
#define LCD_RS_CLEAR    cbi(PORTD,0)
#define LCD_RW_SET      sbi(PORTD,1)
#define LCD_RW_CLEAR    cbi(PORTD,1)
#define LCD_E_SET       sbi(PORTD,2)
#define LCD_E_CLEAR     cbi(PORTD,2)
#define LCD_LIGHT_SET   sbi(PORTD,3)
#define LCD_LIGHT_CLEAR cbi(PORTD,3)
#define sbi(PORTX,bitXPORTX|=(1<<bitX)
#define cbi(PORTX,bitXPORTX&=~(1<<bitX)
unsigned char display_data1[]="  HANKYONG ";
unsigned char display_data2[]="  HAMHAMHAM ";
void delay(unsigned int i){ while(--i); }
void lcd_busy(void){
  unsigned char busy_data;
  busy_data=0LCD_E_CLEARoutp(0x00,DDRB);
  doLCD_RS_CLEARLCD_RW_SETLCD_E_SETbusy_data=inp(PINB); LCD_E_CLEAR; } while(busy_data&0x80);
  outp(0xFF,DDRB);
void lcd_enable(void){ LCD_E_SETdelay(100); LCD_E_CLEAR; }
void lcd_func_set(void){ LCD_RW_CLEARLCD_RS_CLEARoutp(0x38,PORTB); lcd_enable(); }
void lcd_command(unsigned char lcd_data){
  lcd_busy(); delay(1000); LCD_RW_CLEARLCD_RS_CLEARoutp(lcd_data,PORTB); lcd_enable();
void lcd_init(void){
  LCD_E_CLEARdelay(50000); lcd_func_set(); delay(10000); lcd_func_set(); delay(1000); lcd_func_set();
  delay(1000); lcd_command(0x38); lcd_command(0x0C); lcd_command(0x01); lcd_command(0x06);
void lcd_write_char(unsigned char lcd_data){
  lcd_busy(); delay(1000); LCD_RW_CLEARLCD_RS_SEToutp(lcd_data,PORTB); lcd_enable();
void lcd_display(void){
  unsigned char i;
  LCD_LIGHT_SET;
  lcd_command(0x02); for(i=0;i<16;i++)lcd_write_char(display_data1[i]);
  lcd_command(0xC0); for(i=0;i<16;i++)lcd_write_char(display_data2[i]);
int main(void){
  unsigned char LED=0;
  outp(0xFF,DDRB); outp(0x0F,DDRD); outp(0x00,PORTD);
  outp(0x00,DDRF); outp(0xFF,DDRE); outp(0xFF,PORTE);
  lcd_init();
    lcd_display();
    LED=inp(PINF); outp(LED,PORTE);
조회수 4,820
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 11799
공지 사이트 이용 안내댓글[25] master 17-10-29 31123
질문 포토다이오드와의 연결 질문합니다.댓글[4] 이미지새글첨부파일 박윤모 22-08-10 15
질문 회로 구성댓글[4] 새글 픽공부 22-08-10 18
질문 아두이노 센서, 와이파이, 블루투스 연결댓글[1] 새글 pattern 22-08-10 23
질문 PIC 블루투스 연결댓글[19] 픽공부 22-08-09 30
질문 PIC18F452 블루투스 연결댓글[4] 마이컴 22-08-08 25
질문 아두이노 코드 해석을 못하겠습니다...댓글[2] 김가헌 22-08-08 34
질문 아두이노 코드를 avr로 변환해 주세요 ...ㅠ댓글[3] 옹냥냥 22-08-08 27
질문 아두이노 녹음-스피커모듈 관련 질문있습니다 ㅠㅠ댓글[2] 방귀뿡뿡 22-08-08 22
질문 Serial EEPROM 실수값 저장..댓글[2] 이미지첨부파일 광이 22-08-07 21
질문 STM32 Live Expression 값들이 깜빡이는 현상댓글[3] 둠둠 22-08-05 82
질문 아두이노 ESP32 wifi module댓글[1] Yoon 22-08-03 147
질문 atmega128과 dht11, lcd를 연결했는데 0도라고 뜹니다.댓글[1] 고양이33 22-08-02 335
질문 ATMEGA 128 코드를 합치려고 하는데 어렵네요댓글[2] 고양이33 22-08-02 198
질문 서보모터 제어에 대해 질문있습니다.댓글[2] 첨부파일 뉴비에오 22-07-30 137
질문 적외선 통신 알려주실분있나요 ㅠㅠ댓글[1] hkjsj10 22-07-30 136
질문 아두이노 관련 궁금합니다.댓글[1] 뱝뱝 22-07-28 134
질문 아두이노 우노 MCP4725댓글[3] 이미지 opqr 22-07-27 276
질문 레오나르도 인체감지센서 알림 안옴 면지지 22-07-24 194
답변 답변글 답변 : 레오나르도 인체감지센서 알림 안옴 master 22-07-25 134
질문 Uno에서 엔코더값 놓치는 이유가 뭘까요...댓글[3] MAKTUB 22-07-24 143
질문 아두이노 압력센서 연동 질문댓글[4] dbice 22-07-23 226
질문 아두이노 버튼 누르기 문의댓글[1] 김형근 22-07-23 167
질문 HM10 다중페어링댓글[1] ㅎㅋㅎㅋㅎ 22-07-22 192
질문 모터드라이브 선정댓글[6] 이미지 조숩인 22-07-22 267
질문 ad9850 sin파 2댓글[6] 이미지첨부파일 opqr 22-07-21 210
질문 ad9850 sin파 합성댓글[7] 첨부파일 opqr 22-07-20 271
질문 특정값이 n초이상,n번 이상 연속될경우를 감지하는 함수가 있나요댓글[4] 우수 22-07-17 291
질문 delay를 millis함수로 바꾸는데 질문있습니다.댓글[12] 첨부파일 뉴비에오 22-07-16 651
