질문게시판 > avr 다시 질문할게요..
TODAY926 TOTAL2,585,098
BASIC4MCU | 질문게시판 | avr 다시 질문할게요..
작성자 햄스팸 작성일2018-06-05 17:02 조회12,493회 댓글3건
#define outp(x,y) ((y)=(x))
#define inp(x) (x)
#define LCD_RS_SET   sbi(PORTD,0)
#define LCD_RS_CLEAR   cbi(PORTD,0)
#define LCD_RW_SET   sbi(PORTD,1)
#define LCD_RW_CLEAR   cbi(PORTD,1)
#define LCD_E_SET     sbi(PORTD,2)
#define LCD_E_CLEAR    cbi(PORTD,2)
#define LCD_LIGHT_SET  sbi(PORTD,3)
#define  LCD_LIGHT_CLEAR  cbi(PORTD,3)
#define sbi(PORTX,bitX)PORTX |= (1<<bitX)
#define cbi(PORTX,bitX)PORTX &= ~(1<<bitX)
unsigned char display_data1[]="  HANKYONG ";
unsigned char display_data2[]="  HAMHAMHAM ";
void delay(unsigned int i)
while(--i);
void lcd_busy(void)
unsigned char busy_data;
busy_data=0;
LCD_E_CLEAR;
outp(0x00, DDRB);
do{
LCD_RS_CLEAR;
LCD_RW_SET;
LCD_E_SET;
busy_data=inp(PINB);
LCD_E_CLEAR;
}while(busy_data & 0x80);
outp(0xFF,DDRB);
void lcd_enable(void)
LCD_E_SET;
LCD_E_CLEAR;
void lcd_func_set(void)
LCD_RW_CLEAR;
LCD_RS_CLEAR;
outp(0x38, PORTB);
lcd_enable();
void lcd_command(unsigned char lcd_data)
lcd_busy();
LCD_RW_CLEAR;
LCD_RS_CLEAR;
outp(lcd_data,PORTB);
lcd_enable();
void lcd_init(void)
LCD_E_CLEAR;
delay(50000);
lcd_func_set();
delay(10000);
lcd_func_set();
lcd_func_set();
lcd_command(0x38);
lcd_command(0x0C);
lcd_command(0x01);
lcd_command(0x06);
void lcd_write_char(unsigned char lcd_data)
 lcd_busy();
 LCD_RW_CLEAR;
 LCD_RS_SET;
 outp(lcd_data, PORTB);
lcd_enable();
void lcd_display(void)
unsigned char i;
LCD_LIGHT_SET;
lcd_command(0x02);
for(i=0;i<16;i++){
lcd_write_char(display_data1[i]);
lcd_command(0xC0);
for(i=0;i<16;i++){
lcd_write_char(display_data2[i]);
   outp(0xFF ,DDRB);
   outp(0x0F ,DDRD);
   outp(0x00 ,PORTD);
   lcd_init();
   lcd_display();
   while(1){};
 int i;
   DDRA = 0xff;
   PORTA=0xff;
   PORTA=0x00;
   PORTA=0x01;
 for(i=0;i<14;i++)
 if(i<7)
 PORTA = PORTA<<1;
 PORTA=PORTA<<1;
했는데요 LCD는 불이 들어오는데 LED는 불이 안들어오는데 뭐가 문젠가요?
댓글 3
조회수 12,493
아까하고 다른 코드인가요?
즉석으로 소스를 바로 바로 바꿀 정도면 대단한 실력이신데 질문을 하실 것 까지야...
햄스팸님의 댓글
햄스팸 댓글의 댓글 작성일
마스터님이 답변해주신 코드입니다..ㅠㅠ 왜 LED는 불이 안들어올까요?
    while(1){ };
이 명령은 무한루프이고
한번 들어가면 빠져나오지 못합니다.
이 아래에 코드를 적어도 실행되지 않습니다.
몇차례에 걸쳐서 수정해드리면서 계속해서 무한루프를 제거하고 있는데요
앞으로는 답변해드린 코드를 좀 공부하시고나서 질문하시면 감사하겠습니다.
공지 사이트 이용 안내댓글[28] master 17-10-29 33560
질문 아두이노 코딩 에러 질문댓글[1] 이미지새글첨부파일 박무농 23-03-25 27
질문 아두이노를 이용한 타이머, 태양전지 제어댓글[2] 새글 박무농 23-03-25 29
질문 초음파센서를 이용한 모터제어 질문있습니다.댓글[3] 이미지첨부파일 뉴비에오 23-03-24 39
질문 모터 작동 시, 일부 모듈이 꺼지는 현상에 대해 질문드립니다. 이미지 그렇찌 23-03-22 33
답변 답변글 답변 : 모터 작동 시, 일부 모듈이 꺼지는 현상에 대해 질문드립니다. 이미지 master 23-03-23 22
질문 HC06을 마스터로 설정하면 HC06끼리만 통신되나요?댓글[4] 비차 23-03-21 36
질문 아두이노 테트리스 게임댓글[1] 첨부파일 지욱애 23-03-02 160
질문 아두이노우노 블루투스 2개 연결댓글[1] dsfadfs 23-02-28 117
질문 아두이노 나노33 IOT 의 BLE 연결 문제 이미지 가루밀 23-02-24 81
질문 아두이노 블루투스 관련 질문입니다. 생물공학도 23-02-21 107
답변 답변글 답변 : 아두이노 블루투스 관련 질문입니다. master 23-02-21 108
질문 자율주행 로봇을 만드는데 질문있습니다.댓글[2] 뉴비에오 23-02-18 176
