질문게시판 > avr 다시 질문할게요..
인기검색어 > 아두이노 센서 ATMEGA128
최신글 질문게시판 동영상강좌 가입하기
▼ BASIC4MCU 후원업체 신제품 정보 ▼
▲ BASIC4MCU 후원업체 신제품 정보 ▲
BASIC4MCU > 질문게시판
avr 다시 질문할게요..
작성자 햄스팸 작성일18-06-05 17:02 조회8,429회 댓글3건
#define outp(x,y) ((y)=(x))
#define inp(x) (x)
#define LCD_RS_SET   sbi(PORTD,0)
#define LCD_RS_CLEAR   cbi(PORTD,0)
#define LCD_RW_SET   sbi(PORTD,1)
#define LCD_RW_CLEAR   cbi(PORTD,1)
#define LCD_E_SET     sbi(PORTD,2)
#define LCD_E_CLEAR    cbi(PORTD,2)
#define LCD_LIGHT_SET  sbi(PORTD,3)
#define  LCD_LIGHT_CLEAR  cbi(PORTD,3)
#define sbi(PORTX,bitX)PORTX |= (1<<bitX)
#define cbi(PORTX,bitX)PORTX &= ~(1<<bitX)
unsigned char display_data1[]="  HANKYONG ";
unsigned char display_data2[]="  HAMHAMHAM ";
void delay(unsigned int i)
while(--i);
void lcd_busy(void)
unsigned char busy_data;
busy_data=0;
LCD_E_CLEAR;
outp(0x00, DDRB);
do{
LCD_RS_CLEAR;
LCD_RW_SET;
LCD_E_SET;
busy_data=inp(PINB);
LCD_E_CLEAR;
}while(busy_data & 0x80);
outp(0xFF,DDRB);
void lcd_enable(void)
LCD_E_SET;
LCD_E_CLEAR;
void lcd_func_set(void)
LCD_RW_CLEAR;
LCD_RS_CLEAR;
outp(0x38, PORTB);
lcd_enable();
void lcd_command(unsigned char lcd_data)
lcd_busy();
LCD_RW_CLEAR;
LCD_RS_CLEAR;
outp(lcd_data,PORTB);
lcd_enable();
void lcd_init(void)
LCD_E_CLEAR;
delay(50000);
lcd_func_set();
delay(10000);
lcd_func_set();
lcd_func_set();
lcd_command(0x38);
lcd_command(0x0C);
lcd_command(0x01);
lcd_command(0x06);
void lcd_write_char(unsigned char lcd_data)
 lcd_busy();
 LCD_RW_CLEAR;
 LCD_RS_SET;
 outp(lcd_data, PORTB);
lcd_enable();
void lcd_display(void)
unsigned char i;
LCD_LIGHT_SET;
lcd_command(0x02);
for(i=0;i<16;i++){
lcd_write_char(display_data1[i]);
lcd_command(0xC0);
for(i=0;i<16;i++){
lcd_write_char(display_data2[i]);
   outp(0xFF ,DDRB);
   outp(0x0F ,DDRD);
   outp(0x00 ,PORTD);
   lcd_init();
   lcd_display();
   while(1){};
 int i;
   DDRA = 0xff;
   PORTA=0xff;
   PORTA=0x00;
   PORTA=0x01;
 for(i=0;i<14;i++)
 if(i<7)
 PORTA = PORTA<<1;
 PORTA=PORTA<<1;
했는데요 LCD는 불이 들어오는데 LED는 불이 안들어오는데 뭐가 문젠가요?
  • 카카오톡으로 보내기
댓글 : 3
조회수 : 8,429
아까하고 다른 코드인가요?
즉석으로 소스를 바로 바로 바꿀 정도면 대단한 실력이신데 질문을 하실 것 까지야...
햄스팸님의 댓글
햄스팸 댓글의 댓글작성일
마스터님이 답변해주신 코드입니다..ㅠㅠ 왜 LED는 불이 안들어올까요?
    while(1){ };
이 명령은 무한루프이고
한번 들어가면 빠져나오지 못합니다.
이 아래에 코드를 적어도 실행되지 않습니다.
몇차례에 걸쳐서 수정해드리면서 계속해서 무한루프를 제거하고 있는데요
앞으로는 답변해드린 코드를 좀 공부하시고나서 질문하시면 감사하겠습니다.
BASIC4MCU > 질문게시판 목록
제목 날짜
질문 아두이노 센서 쉴드 v5.0 과 음성인식 모듈(V2)통… 첨부파일AutoSun 새글 22-07-05
질문 초음파 센서를 사용한 dc모터 제어에 관해 질문 있습니… 첨부파일뉴비에오 새글 22-07-04
답변 답변 : 초음파 센서를 사용한 dc모터 제어에 관해 질… 댓글[2] master 새글 22-07-05
질문 아두이노 Sensor Shield 5.0 시리얼 통신 … 댓글[2] AutoSun 새글 22-07-04
질문 Atmega 코드 좀 봐주세요. 댓글[1] 첨부파일chelsea 새글 22-07-04
PC버전
