질문게시판 > avr 다시 질문할게요..
TODAY206 TOTAL2,278,742
BASIC4MCU | 질문게시판 | avr 다시 질문할게요..
작성자 햄스팸 작성일2018-06-05 17:02 조회9,449회 댓글3건
#define outp(x,y) ((y)=(x))
#define inp(x) (x)
#define LCD_RS_SET   sbi(PORTD,0)
#define LCD_RS_CLEAR   cbi(PORTD,0)
#define LCD_RW_SET   sbi(PORTD,1)
#define LCD_RW_CLEAR   cbi(PORTD,1)
#define LCD_E_SET     sbi(PORTD,2)
#define LCD_E_CLEAR    cbi(PORTD,2)
#define LCD_LIGHT_SET  sbi(PORTD,3)
#define  LCD_LIGHT_CLEAR  cbi(PORTD,3)
#define sbi(PORTX,bitX)PORTX |= (1<<bitX)
#define cbi(PORTX,bitX)PORTX &= ~(1<<bitX)
unsigned char display_data1[]="  HANKYONG ";
unsigned char display_data2[]="  HAMHAMHAM ";
void delay(unsigned int i)
while(--i);
void lcd_busy(void)
unsigned char busy_data;
busy_data=0;
LCD_E_CLEAR;
outp(0x00, DDRB);
do{
LCD_RS_CLEAR;
LCD_RW_SET;
LCD_E_SET;
busy_data=inp(PINB);
LCD_E_CLEAR;
}while(busy_data & 0x80);
outp(0xFF,DDRB);
void lcd_enable(void)
LCD_E_SET;
LCD_E_CLEAR;
void lcd_func_set(void)
LCD_RW_CLEAR;
LCD_RS_CLEAR;
outp(0x38, PORTB);
lcd_enable();
void lcd_command(unsigned char lcd_data)
lcd_busy();
LCD_RW_CLEAR;
LCD_RS_CLEAR;
outp(lcd_data,PORTB);
lcd_enable();
void lcd_init(void)
LCD_E_CLEAR;
delay(50000);
lcd_func_set();
delay(10000);
lcd_func_set();
lcd_func_set();
lcd_command(0x38);
lcd_command(0x0C);
lcd_command(0x01);
lcd_command(0x06);
void lcd_write_char(unsigned char lcd_data)
 lcd_busy();
 LCD_RW_CLEAR;
 LCD_RS_SET;
 outp(lcd_data, PORTB);
lcd_enable();
void lcd_display(void)
unsigned char i;
LCD_LIGHT_SET;
lcd_command(0x02);
for(i=0;i<16;i++){
lcd_write_char(display_data1[i]);
lcd_command(0xC0);
for(i=0;i<16;i++){
lcd_write_char(display_data2[i]);
   outp(0xFF ,DDRB);
   outp(0x0F ,DDRD);
   outp(0x00 ,PORTD);
   lcd_init();
   lcd_display();
   while(1){};
 int i;
   DDRA = 0xff;
   PORTA=0xff;
   PORTA=0x00;
   PORTA=0x01;
 for(i=0;i<14;i++)
 if(i<7)
 PORTA = PORTA<<1;
 PORTA=PORTA<<1;
했는데요 LCD는 불이 들어오는데 LED는 불이 안들어오는데 뭐가 문젠가요?
댓글 3
조회수 9,449
아까하고 다른 코드인가요?
즉석으로 소스를 바로 바로 바꿀 정도면 대단한 실력이신데 질문을 하실 것 까지야...
햄스팸님의 댓글
햄스팸 댓글의 댓글 작성일
마스터님이 답변해주신 코드입니다..ㅠㅠ 왜 LED는 불이 안들어올까요?
    while(1){ };
이 명령은 무한루프이고
한번 들어가면 빠져나오지 못합니다.
이 아래에 코드를 적어도 실행되지 않습니다.
몇차례에 걸쳐서 수정해드리면서 계속해서 무한루프를 제거하고 있는데요
앞으로는 답변해드린 코드를 좀 공부하시고나서 질문하시면 감사하겠습니다.
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 12060
공지 사이트 이용 안내댓글[25] master 17-10-29 31230
질문 아두이노 코딩 결합댓글[1] 새글 hohoje 22-08-18 23
질문 UART통신 스위치 사용댓글[4] 새글 픽공부 22-08-18 26
질문 아두이노코딩 질문사항댓글[1] kai5439 22-08-16 47
질문 해석좀 해주세요댓글[2] bubu 22-08-14 86
질문 lcd 1602에 특수문자를 출력하는 방법을 알고싶습니다.댓글[3] dndktn 22-08-12 98
질문 stm32 wifi 파일전송댓글[3] 하리 22-08-11 78
질문 회로 구성 수정댓글[2] 첨부파일 픽공부 22-08-11 96
질문 아두이노 와이파이통신 질문 있습니다댓글[1] 학생 22-08-11 80
질문 포토다이오드와의 연결 질문합니다.댓글[7] 이미지첨부파일 박윤모 22-08-10 99
질문 회로 구성댓글[4] 픽공부 22-08-10 74
질문 아두이노 센서, 와이파이, 블루투스 연결댓글[1] pattern 22-08-10 99
질문 PIC 블루투스 연결댓글[19] 픽공부 22-08-09 117
질문 PIC18F452 블루투스 연결댓글[4] 마이컴 22-08-08 130
질문 아두이노 코드 해석을 못하겠습니다...댓글[2] 김가헌 22-08-08 119
질문 아두이노 코드를 avr로 변환해 주세요 ...ㅠ댓글[3] 옹냥냥 22-08-08 89
질문 아두이노 녹음-스피커모듈 관련 질문있습니다 ㅠㅠ댓글[2] 방귀뿡뿡 22-08-08 69
질문 Serial EEPROM 실수값 저장..댓글[2] 이미지첨부파일 광이 22-08-07 56
질문 STM32 Live Expression 값들이 깜빡이는 현상댓글[3] 둠둠 22-08-05 124
질문 아두이노 ESP32 wifi module댓글[1] Yoon 22-08-03 198
질문 atmega128과 dht11, lcd를 연결했는데 0도라고 뜹니다.댓글[1] 고양이33 22-08-02 542
질문 ATMEGA 128 코드를 합치려고 하는데 어렵네요댓글[2] 고양이33 22-08-02 255
질문 서보모터 제어에 대해 질문있습니다.댓글[2] 첨부파일 뉴비에오 22-07-30 186
질문 적외선 통신 알려주실분있나요 ㅠㅠ댓글[1] hkjsj10 22-07-30 169
질문 아두이노 관련 궁금합니다.댓글[1] 뱝뱝 22-07-28 170
질문 아두이노 우노 MCP4725댓글[3] 이미지 opqr 22-07-27 331
질문 레오나르도 인체감지센서 알림 안옴 면지지 22-07-24 248
답변 답변글 답변 : 레오나르도 인체감지센서 알림 안옴 master 22-07-25 182
질문 Uno에서 엔코더값 놓치는 이유가 뭘까요...댓글[3] MAKTUB 22-07-24 199
