질문게시판 > avr질문이요
TODAY1,835 TOTAL2,168,509
BASIC4MCU | 질문게시판 | avr질문이요
작성자 다빈 작성일2018-06-05 17:20 조회10,106회 댓글4건
#include<avr/io.h>
#include<util/delay.h>
#include"LCD.h"
#define SIG 0x01
unsigned char password[4] = "1234"; //패스워드
unsigned char pass_buf[4] = "0000"; //현재의 패스워드를 저장 할 버퍼
unsigned char msg1[ ] = "Password : ";
unsigned char msg2[ ] = "Correct pass!!";
unsigned char msg3[ ] = "Incorrect pass!!";
unsigned char cnt=0,loop=1;
void Port_init(void)
  DDRB = 0xff; PORTB=0x00;
 DDRE = 0xff; PORTE=0x00;
 DDRF = 0x1f; PORTF=0xff;
unsigned char scan_key(void)
  unsigned char Scan_signal=0, scan_value=0;
  unsigned int i;
  for(i=0;i<4;i++)
  Scan_signal = ~(SIG << i);
  PORTF = Scan_signal;
  if((PINF & 0xe0) != 0xe0)
   scan_value= (PINF & 0xe0)|(Scan_signal & 0x0f);
  while((PINF & 0xe0) != 0xe0); //키가 눌려 있을 경우
  return scan_value;
void save_buf(unsigned char number)
 pass_buf[cnt++] = number;
 LCD_data(number);
void display_key(unsigned char input)
 switch(input)
  case 0xce : save_buf(0x30+1); break;// 1
  case 0xae : save_buf(0x30+2); break;// 2
  case 0x6e : save_buf(0x30+3); break;// 3
  case 0xcd : save_buf(0x30+4); break;// 4
  case 0xad : save_buf(0x30+5); break;// 5
  case 0x6d : save_buf(0x30+6); break;// 6
  case 0xcb : save_buf(0x30+7); break;// 7
  case 0xab : save_buf(0x30+8); break;// 8
  case 0x6b : save_buf(0x30+9); break;// 9
  case 0xc7 : save_buf(0x23);   break;// #
  case 0xa7 : save_buf(0x30);   break;// 0
  case 0x67 : save_buf(0x2A);   break;// *
void compare_pw(void)
 if(cnt==4)
  unsigned int i, pw_error=0;
  for(i=0;i<4;i++) // 패스워드 비교
   if(password[i]!=pass_buf[i])pw_error++;
  if(pw_error==0) //패스워드가 맞을 때
   LCD_cmd(0x00); _delay_ms(2); //display clear;
   LCD_cmd(0x01); _delay_ms(2); //cursor return home;
   LCD_str_out(msg2); _delay_ms(100);
   cnt=0;
   loop=0;
  else   //패스워드가 틀릴 때
   LCD_str_out(msg3); _delay_ms(100);
   cnt=0;
   loop=1;
   LCD_str_out(msg1);
void main()
 Port_init();
 LCD_init();
  LCD_str_out(msg1);
  while(loop)
   display_key(scan_key());
   compare_pw();
  loop=1;
오류가 떠요
댓글 4
조회수 10,106
오류(에러)에 보면
../main.c:3:16: error: LCD.h: No such file or directory
적색으로 표시되어 있고
더블 클릭하면
#include"LCD.h" 커서가 이리로 갑니다.
헤더파일이 없다는 에러입니다.
다빈님의 댓글
다빈 작성일
그건 알겠는데 걔를 없애면 수많은 오류들이 탄생해요
당연히 LCD 관련 코드들이 전부 반란을 일으키겠죠?
헤더파일 구해서 작업폴더에 넣으세요
LCD 사용하지 않으면
LCD 관련 코드를 모두 삭제하세요
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 9664
공지 사이트 이용 안내댓글[24] master 17-10-29 29733
질문 atmega128 GPS,블루투스 질문드립니다.댓글[1] 새글 코딩초보1 14:53 20
질문 서보모터 제어에 관하여 궁금합니다댓글[2] 이미지새글첨부파일 오소로롯 00:24 23
질문 atmega 128 타이머 작성 중 질문 드립니다.댓글[2] 이미지새글 마프하나 22-05-23 25
질문 아두이노와 휴대폰을 HC-06으로 연결시켜서 블루투스연결이 끊기면 부저에서 소리가 나게 할려하는데 어떻게 해…댓글[1] 새글 졸작부수다 22-05-23 86
답변 답변글 답변 : 아두이노와 휴대폰을 HC-06으로 연결시켜서 블루투스연결이 끊기면 부저에서 소리가 나게 할려하는데 … 새글 master 16:43 15
질문 atmega 128 블루투스 질문 입니다댓글[1] 새글 yhj2644 22-05-23 28
질문 아트메가 공부중에 질문있습니다..댓글[1] 새글 suid82 22-05-23 18
질문 Atmega128 UART통신 echo 반복 질문댓글[1] 새글 ming2ming 22-05-23 25
질문 아두이노의 지속 시간에 대해 질문합니다. 새글 merry 22-05-23 29
질문 초음파+스텝모터 새글 도꺼비 22-05-22 21
답변 답변글 답변 : 초음파+스텝모터 새글 master 22-05-23 23
질문 아두이노 인터럽트 질문있습니다.댓글[1] 띵꽁 22-05-22 28
답변 답변글 답변 : 아두이노 인터럽트 질문있습니다.댓글[3] 새글 master 22-05-22 25
질문 atmega128 스톱워치 작성 중 외부 인터럽트 관련 질문 드립니다.댓글[4] 이미지 마프하나 22-05-22 44
답변 답변글 답변 : atmega128 스톱워치 작성 중 외부 인터럽트 관련 질문 드립니다.댓글[1] 이미지새글 master 22-05-23 24
질문 서보모터제어 해당코드에서 어떤걸 추가해야할까요댓글[3] 이미지첨부파일 오소로롯 22-05-22 34
질문 Atmega128 UART통신에서 ECHO 관련 질문드립니다. dsfdfsa 22-05-22 32
답변 답변글 답변 : Atmega128 UART통신에서 ECHO 관련 질문드립니다.댓글[1] master 22-05-22 27
질문 아두이노 서보모터제어 하나도 모르겠습니다 ㅠ댓글[2] 이미지첨부파일 오소로롯 22-05-21 50
질문 아트메가 128 을 이용해서적외선 센서 코딩 중 물어볼게있습니다!!댓글[5] noster 22-05-21 48
질문 아두이노 에러질문댓글[1] 이미지첨부파일 리니어 22-05-21 39
질문 아두이노 블루투스 통신 관련 질문 있습니다!! 블루툿 22-05-21 40
답변 답변글 답변 : 아두이노 블루투스 통신 관련 질문 있습니다!! master 22-05-21 45
질문 아두이노 DRV2605 헵틱 모터 드라이버댓글[4] gano 22-05-21 44
질문 아두이노 d1r2 W238 방수 초음파 센서댓글[1] 밤새아두이노 22-05-21 59
질문 아두이노 블루투스(hc-06)사용중 질문있습니다. 첨부파일 띵꽁 22-05-20 63
