질문게시판 > ATmega128을 이용한 DC모터 속도 제어에 대해 질문합니다.
TODAY1,790 TOTAL2,168,464
BASIC4MCU | 질문게시판 | ATmega128을 이용한 DC모터 속도 제어에 대해 질문합니다.
작성자 비공개 작성일2018-06-06 00:26 조회7,191회 댓글0건
#include <mega128.h>
#include <delay.h>
//-------------------ICR
#define DSTop 8000
unsigned char segment_num[10] = {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7c,0x07,0x7f,0x67};
unsigned char segment_control[4] = {0xf7,0xfb,0xfd,0xfe};
unsigned int temp1=0, temp2 = 0, cnt, encoder_cnt=0;
int PPR = 208, rpm=0, motor_stop = 1;
int ENcnt, TimeTicker;
float temp, TimeVal, Krp;
int data=0; //adc 전역변수
void Port_set_func(void);
void Interrupt_set_func(void);
void init_input_capture_func();
void ADC_Init_func(void);
void main(void)
    Interrupt_set_func();
    Port_set_func();
    ADC_Init_func();
         if(motor_stop==1 && (data>0)){
            delay_ms(300);
            ETIMSK = 0x24;
            OCR1A = data * 7.8125; //8000/1024 = 7.8125. ADC 1의 변화는 OCR 7.8125만큼의 변화
            motor_stop = 0;
         else if(motor_stop==0){
            delay_ms(300);
         if(data<1){
            motor_stop = 1;
            ETIMSK = 0x00;
            rpm = 0;
        data=(int)ADCL+((int)ADCH<<8); //ADC Code
    DDRA = 0xff;
    DDRB = 0x21;
    DDRC = 0xff;
    DDRG = 0x03;
    DDRE = 0x00;
    PORTA = 0x00;
    PORTB = 0x00;
    //PORTC = 0x0f; //ICRcode
    //PORTC=0x00; //ADCcode
    DDRF=0x00;
    TIMSK = 0x01;
    TCCR0 = 0x07;
    TCNT0 = 0xb2;
    TCCR1A = 0x80;
    TCCR1B = 0x11;
    TCNT1 = 0x0000;
    ICR1 = DSTop;
    OCR1A = 0;
    ETIMSK = 0x00;
    #asm("sei");
    TCCR3A = 0x00;
    switch (PINE >> 7)
        case 0x01:
            TCCR3B = 0x84;
        case 0x00:
            TCCR3B = 0xC4;
        default:
            #asm("sei");
    TCNT3H = 0;
    TCNT3L = 0;
void ADC_Init_func()
    ADMUX=0x47;
    ADCSRA=0xE7;
interrupt [TIM0_OVF] void TIM0_OVF_isr(void)
    PORTC = segment_control[cnt];
    if(cnt == 0) PORTA = segment_num[rpm % 10];
    if(cnt == 1) PORTA = segment_num[(rpm / 10) % 10];
    if(cnt == 2) PORTA = segment_num[(rpm / 100) % 10];
    if(cnt == 3) PORTA = segment_num[(rpm / 1000) % 10];
    cnt ++;
    if(cnt ==4) cnt =0;
    TCNT0 = 0xb2;
interrupt [TIM3_OVF] void TIM3_OVF_isr(void)
    TimeTicker++;
    if(TimeTicker >3)
        rpm = 0;
         temp1 = temp2 = ENcnt = 0;
interrupt [TIM3_CAPT] void TIM3_CAPT_isr(void)
    Krp = (60*16000000/256)/PPR;
    encoder_cnt++;
    if(ENcnt == 0)
        temp1 = ICR3L;
        temp1 = temp1+ICR3H*256;
        TimeTicker = 0;
        temp2 = ICR3L;
        temp2 = temp2+ICR3H*256;
        TimeVal = (float)((TimeTicker*65536+temp2)-temp1);
        temp = (Krp/TimeVal);
        temp1 = temp2;
        TimeTicker = 0;
        if(encoder_cnt/(208*1))
            rpm = (int) temp;
            encoder_cnt = 0;
    ENcnt = 1;
이 코드는 가변저항을 PORT F에 연결하고, 가변저항을 조절함으로써 DC모터 속도 제어를 할 수 있는 코드입니다.
그런데, 이는 단방향 코드이기에 양방향으로 DC모터의 속도를 조절할 수 있는 방법을 알고 싶습니다.
조회수 7,191
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 9664
공지 사이트 이용 안내댓글[24] master 17-10-29 29733
질문 atmega128 GPS,블루투스 질문드립니다.댓글[1] 새글 코딩초보1 14:53 20
질문 서보모터 제어에 관하여 궁금합니다댓글[2] 이미지새글첨부파일 오소로롯 00:24 23
질문 atmega 128 타이머 작성 중 질문 드립니다.댓글[2] 이미지새글 마프하나 22-05-23 25
질문 아두이노와 휴대폰을 HC-06으로 연결시켜서 블루투스연결이 끊기면 부저에서 소리가 나게 할려하는데 어떻게 해…댓글[1] 새글 졸작부수다 22-05-23 86
답변 답변글 답변 : 아두이노와 휴대폰을 HC-06으로 연결시켜서 블루투스연결이 끊기면 부저에서 소리가 나게 할려하는데 … 새글 master 16:43 15
질문 보드레이트 질문댓글[1] 새글 죠르디 22-05-23 17
질문 atmega 128 블루투스 질문 입니다댓글[1] 새글 yhj2644 22-05-23 28
질문 아트메가 공부중에 질문있습니다..댓글[1] 새글 suid82 22-05-23 18
질문 Atmega128 UART통신 echo 반복 질문댓글[1] 새글 ming2ming 22-05-23 25
질문 아두이노의 지속 시간에 대해 질문합니다. 새글 merry 22-05-23 29
질문 초음파+스텝모터 새글 도꺼비 22-05-22 20
답변 답변글 답변 : 초음파+스텝모터 새글 master 22-05-23 22
질문 아두이노 인터럽트 질문있습니다.댓글[1] 새글 띵꽁 22-05-22 28
답변 답변글 답변 : 아두이노 인터럽트 질문있습니다.댓글[3] 새글 master 22-05-22 25
질문 atmega128 스톱워치 작성 중 외부 인터럽트 관련 질문 드립니다.댓글[4] 이미지 마프하나 22-05-22 44
답변 답변글 답변 : atmega128 스톱워치 작성 중 외부 인터럽트 관련 질문 드립니다.댓글[1] 이미지새글 master 22-05-23 24
질문 서보모터제어 해당코드에서 어떤걸 추가해야할까요댓글[3] 이미지첨부파일 오소로롯 22-05-22 34
질문 Atmega128 UART통신에서 ECHO 관련 질문드립니다. dsfdfsa 22-05-22 32
답변 답변글 답변 : Atmega128 UART통신에서 ECHO 관련 질문드립니다.댓글[1] master 22-05-22 27
질문 아두이노 서보모터제어 하나도 모르겠습니다 ㅠ댓글[2] 이미지첨부파일 오소로롯 22-05-21 50
질문 아트메가 128 을 이용해서적외선 센서 코딩 중 물어볼게있습니다!!댓글[5] noster 22-05-21 48
질문 아두이노 에러질문댓글[1] 이미지첨부파일 리니어 22-05-21 39
질문 아두이노 블루투스 통신 관련 질문 있습니다!! 블루툿 22-05-21 40
답변 답변글 답변 : 아두이노 블루투스 통신 관련 질문 있습니다!! master 22-05-21 45
질문 아두이노 DRV2605 헵틱 모터 드라이버댓글[4] gano 22-05-21 44
질문 아두이노 d1r2 W238 방수 초음파 센서댓글[1] 밤새아두이노 22-05-21 59
질문 아두이노 블루투스(hc-06)사용중 질문있습니다. 첨부파일 띵꽁 22-05-20 63
