질문게시판 > avr 질문입니다.
인기검색어 > 아두이노 센서 ATMEGA128
최신글 질문게시판 동영상강좌 가입하기
▼ BASIC4MCU 후원업체 신제품 정보 ▼
▲ BASIC4MCU 후원업체 신제품 정보 ▲
BASIC4MCU > 질문게시판
avr 질문입니다.
작성자 비공개 작성일18-06-07 10:08 조회4,889회 댓글0건
#define F_CPU           8000000UL
#define outp(x,y)       ((y)=(x))
#define inp(x)          (x)
#define LCD_RS_SET      sbi(PORTD,0)
#define LCD_RS_CLEAR    cbi(PORTD,0)
#define LCD_RW_SET      sbi(PORTD,1)
#define LCD_RW_CLEAR    cbi(PORTD,1)
#define LCD_E_SET       sbi(PORTD,2)
#define LCD_E_CLEAR     cbi(PORTD,2)
#define LCD_LIGHT_SET   sbi(PORTD,3)
#define LCD_LIGHT_CLEAR cbi(PORTD,3)
#define sbi(PORTX,bitX)PORTX|=(1<<bitX)
#define cbi(PORTX,bitX)PORTX&=~(1<<bitX)
unsigned char display_data1[]="  HANKYONG ";
unsigned char display_data2[]="  HAMHAMHAM ";
void delay(unsigned int i){ while(--i); }
void lcd_busy(void){
  unsigned char busy_data;
  busy_data=0; LCD_E_CLEAR; outp(0x00,DDRB);
  do{ LCD_RS_CLEAR; LCD_RW_SET; LCD_E_SET; busy_data=inp(PINB); LCD_E_CLEAR; } while(busy_data&0x80);
  outp(0xFF,DDRB);
void lcd_enable(void){ LCD_E_SET; delay(100); LCD_E_CLEAR; }
void lcd_func_set(void){ LCD_RW_CLEAR; LCD_RS_CLEAR; outp(0x38,PORTB); lcd_enable(); }
void lcd_command(unsigned char lcd_data){
  lcd_busy(); delay(1000); LCD_RW_CLEAR; LCD_RS_CLEAR; outp(lcd_data,PORTB); lcd_enable();
void lcd_init(void){
  LCD_E_CLEAR; delay(50000);
  lcd_func_set(); delay(10000); lcd_func_set(); delay(1000); lcd_func_set(); delay(1000);
  lcd_command(0x38); lcd_command(0x0C); lcd_command(0x01); lcd_command(0x06);
void lcd_write_char(unsigned char lcd_data){
  lcd_busy(); delay(1000); LCD_RW_CLEAR; LCD_RS_SET; outp(lcd_data,PORTB); lcd_enable();
void lcd_display(void){
  unsigned char i;
  LCD_LIGHT_SET;
  lcd_command(0x02); for(i=0; i<16; i++){ lcd_write_char(display_data1[i]); }
  lcd_command(0xC0); for(i=0; i<16; i++){ lcd_write_char(display_data2[i]); }
int main(void){
  unsigned char b=0x01,d=0;
  DDRC=0xff;
  lcd_init();
    PORTC=b; delay(100);
    if(d==0){
      b<<=1;
      if(b==0x00){ b=0x80; d=1; }
      b>>=1;
      if(b==0x00){ b=0x01; d=0; } //방향전환
    outp(0xFF,DDRB); outp(0x0F,DDRD); outp(0x00,PORTD);
    lcd_display();
이렇게 실행 시켰더니 lcd랑 led모두 동작하지 않네요..
뭐가 문제일까요?
  • 카카오톡으로 보내기
댓글 : 0
조회수 : 4,889
BASIC4MCU > 질문게시판 목록
제목 날짜
질문 앱인벤터 list index too large 오류 질… 첨부파일PT규 새글 22-07-07
질문 Atmega IO핀 출력 상태 질문이요.. 댓글[3] chelsea 새글 22-07-06
답변 답변 : Atmega IO핀 출력 상태 질문이요.. 댓글[6] master 새글 22-07-06
질문 아두이노 센서 쉴드 v5.0 과 음성인식 모듈(V2)통… 댓글[6] 첨부파일AutoSun  22-07-05
질문 초음파 센서를 사용한 dc모터 제어에 관해 질문 있습니… 첨부파일뉴비에오  22-07-04
답변 답변 : 초음파 센서를 사용한 dc모터 제어에 관해 질… 댓글[2] master  22-07-05
질문 아두이노 Sensor Shield 5.0 시리얼 통신 … 댓글[2] AutoSun  22-07-04
질문 Atmega 코드 좀 봐주세요. 댓글[1] 첨부파일chelsea  22-07-04
PC버전
