BASIC4MCU | 질문게시판 | while 상태에서 피에조부저
작성자 ALSLALSL2 작성일2021-06-02 05:03 조회8,899회 댓글5건본문
while 상태에서 피에조부저가 켰졌다가 꺼지게 할수있나요??
또한 PIR뿐만아니라 압력센서도 사용할 때
압력과 PIR이 둘다 없을 때 불빛이 깜박거리게 하고 둘중하나 라도 인지가 되면 작동을 안하게 바꿀수있을까요??
int counter;
int R = 12;
int G = 11;
int B = 10;
int piezoPin = 7;
pinMode(R, OUTPUT);
pinMode(G, OUTPUT);
pinMode(B, OUTPUT);
pinMode(9,INPUT);
pinMode(7,INPUT);
int readValue = digitalRead(9);
if(digitalRead(9) == HIGH){
digitalWrite(R, LOW);
digitalWrite(B, LOW);
digitalWrite(G, HIGH);
delay(5000);
for (counter = 0; counter<10; ++counter){
noTone(piezoPin);
digitalWrite(R, HIGH);
delay(150);
delay(150);
digitalWrite(G, LOW);
digitalWrite(B, HIGH);
delay(150);
delay(150);
delay(150);
delay(150);
delay(150);
delay(150);
delay(150);
delay(150);
delay(150);
delay(150);
delay(150);
delay(150);
delay(150);
delay(150);
delay(150);
delay(150);
delay(150);
delay(150);
delay(150);
delay(150);
delay(150);
delay(150);
delay(150);
delay(150);
delay(150);
delay(150);
delay(150);
delay(150);
delay(150);
delay(150);
delay(150);
delay(150);
delay(150);
delay(150);
delay(150);
delay(150);
delay(150);
delay(150);
while(digitalRead(9) == LOW){
tone(piezoPin, 271, 500);
댓글 5
조회수 8,899master님의 댓글
int counter;
int R=12,G=11,B=10;
int piezoPin=7;
pinMode(R,OUTPUT); pinMode(G,OUTPUT); pinMode(B,OUTPUT);
pinMode(9,INPUT); pinMode(7,INPUT);
int PIR_Val=digitalRead(9);
int PRESS_Val=digitalRead(7);
if(PIR_Val){
digitalWrite(R,0); digitalWrite(B,0); digitalWrite(G,1); delay(5000);
for(counter=0;counter<10;++counter){}
else if(PRESS_Val){
digitalWrite(R,0); digitalWrite(B,1); digitalWrite(G,0); delay(5000);
else{ // digitalRead(9)==0 && digitalRead(7)==0
noTone(piezoPin);
digitalWrite(R,1); delay(150);
digitalWrite(R,0); digitalWrite(G,1); delay(150);
digitalWrite(G,0); digitalWrite(B,1); delay(150);
digitalWrite(B,0); digitalWrite(R,1); digitalWrite(G,1); delay(150);
digitalWrite(B,1); digitalWrite(R,1); digitalWrite(G,0); delay(150);
digitalWrite(B,1); digitalWrite(R,0); digitalWrite(G,1); delay(150);
digitalWrite(B,1); digitalWrite(R,1); digitalWrite(G,1); delay(150);
digitalWrite(B,0); digitalWrite(R,0); digitalWrite(G,0); delay(150);
while(digitalRead(9)==0){
tone(piezoPin,271,500); noTone(piezoPin); delay(500);
ALSLALSL2님의 댓글
ALSLALSL2 작성일깜박거리는 도중에 인체감지센서사 감지되면 멈췄다가 다시 시작하는 코딩을 추가하고싶은데 방법이 있을까요?
멈추는 것은 딜레이를 사용하면 됩니다.
ALSLALSL2님의 댓글
ALSLALSL2 작성일
압력센서 값이 계속 1이 떠았는 것은
혹시 뭐가 잘못 된것일까요??
압력센서 예제로 체크하세요
