BASIC4MCU | 질문게시판 | 혼자 stm32F103RB 보드로 초음파 거리측정기를 만들라는데..FND로 출력값을 나타내고싶은데 코딩좀 도와주세요...ㅠㅠ
작성자 이삼공대생 작성일2021-06-03 17:56 조회2,199회 댓글0건본문
/* USER CODE BEGIN Header */
* @file : main.c
* @brief : Main program body
* @attention
* <h2><center>© Copyright (c) 2021 STMicroelectronics.
* All rights reserved.</center></h2>
* This software component is licensed by ST under BSD 3-Clause license,
* the "License"; You may not use this file except in compliance with the
* License. You may obtain a copy of the License at:
* opensource.org/licenses/BSD-3-Clause
/* USER CODE END Header *//* Includes ------------------------------------------------------------------*/
#include "main.h"
#include "tim.h"
#include "usart.h"
#include "gpio.h"/* Private includes ----------------------------------------------------------*/
/* USER CODE BEGIN Includes *//* USER CODE END Includes */
/* Private typedef -----------------------------------------------------------*/
/* USER CODE BEGIN PTD *//* USER CODE END PTD */
/* Private define ------------------------------------------------------------*/
/* USER CODE BEGIN PD */
#define INIT 0
#define SEND_TRIG 1
#define WAIT_TRIG_END 2
#define WAIT_ECHO_END 3
#define CALC_DIST 4/* USER CODE END PD */
/* Private macro -------------------------------------------------------------*/
/* USER CODE BEGIN PM *//* USER CODE END PM */
/* Private variables ---------------------------------------------------------*/
/* USER CODE BEGIN PV */
uint8_t curr_state, next_state;
uint8_t trig_pulse_end, echo_pulse_end;
/* USER CODE END PV *//* Private function prototypes -----------------------------------------------*/
void SystemClock_Config(void);
/* USER CODE BEGIN PFP *//* USER CODE END PFP */
/* Private user code ---------------------------------------------------------*/
/* USER CODE BEGIN 0 *//* USER CODE END 0 */
* @brief The application entry point.
* @retval int
/* USER CODE BEGIN 1 */
int echo_time;
float echo_dist;/* USER CODE END 1 */
/* MCU Configuration--------------------------------------------------------*/
/* Reset of all peripherals, Initializes the Flash interface and the Systick. */
HAL_Init();/* USER CODE BEGIN Init */
/* USER CODE END Init */
/* Configure the system clock */
SystemClock_Config();/* USER CODE BEGIN SysInit */
/* USER CODE END SysInit */
/* Initialize all configured peripherals */
MX_GPIO_Init();
MX_USART2_UART_Init();
MX_TIM2_Init();
MX_TIM3_Init();
/* USER CODE BEGIN 2 */
curr_state = INIT;
next_state = INIT;trig_pulse_end = 0;
echo_pulse_end = 0;
/* USER CODE END 2 */
/* Infinite loop */
/* USER CODE BEGIN WHILE */
while (1)
switch(curr_state) {
case INIT:
next_state = SEND_TRIG;
case SEND_TRIG:
next_state = WAIT_TRIG_END;
case WAIT_TRIG_END:
next_state = (trig_pulse_end) ? WAIT_ECHO_END : WAIT_TRIG_END;
case WAIT_ECHO_END:
next_state = (echo_pulse_end) ? CALC_DIST : WAIT_ECHO_END;
default: // CALC_DIST
next_state = INIT;
}/* USER CODE END WHILE */
/* USER CODE BEGIN 3 */
if (curr_state == INIT) {
trig_pulse_end = 0;
echo_pulse_end = 0;htim2.Instance->CNT = 0;
htim3.Instance->CNT = 0;
else if (curr_state == SEND_TRIG) {
HAL_GPIO_WritePin(GPIOA, GPIO_PIN_11, GPIO_PIN_SET);
HAL_TIM_Base_Start_IT(&htim2); // Textbook P.313
else if (curr_state == CALC_DIST) {
echo_time = htim3.Instance->CNT;
echo_dist = (0.00034 * ((float) echo_time)) / 2.0;if (echo_dist <= 0.1)
HAL_GPIO_WritePin(GPIOA, GPIO_PIN_5, GPIO_PIN_SET);
HAL_GPIO_WritePin(GPIOA, GPIO_PIN_5, GPIO_PIN_RESET);
}curr_state = next_state;
/* USER CODE END 3 */
* @brief System Clock Configuration
* @retval None
RCC_OscInitTypeDef RCC_OscInitStruct = {0};
RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};/** Initializes the CPU, AHB and APB busses clocks
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
RCC_OscInitStruct.HSIState = RCC_HSI_ON;
RCC_OscInitStruct.HSICalibrationValue = RCC_HSICALIBRATION_DEFAULT;
RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSI_DIV2;
RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL16;
if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
Error_Handler();
RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
|RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK)
Error_Handler();
}/* USER CODE BEGIN 4 */
void HAL_TIM_PeriodElapsedCallback(TIM_HandleTypeDef *htim)
if (htim->Instance == TIM2) {
HAL_TIM_Base_Stop_IT(htim);
HAL_GPIO_WritePin(GPIOA, GPIO_PIN_11, GPIO_PIN_RESET);
trig_pulse_end = 1;
}void HAL_GPIO_EXTI_Callback(uint16_t GPIO_Pin)
if (GPIO_Pin == GPIO_PIN_12) { // Interrupt from Echo signal
if (HAL_GPIO_ReadPin(GPIOA, GPIO_PIN_12) == GPIO_PIN_SET)
HAL_TIM_Base_Start(&htim3);
else {
HAL_TIM_Base_Stop(&htim3);
echo_pulse_end = 1;
/* USER CODE END 4 */
* @brief This function is executed in case of error occurrence.
* @retval None
void Error_Handler(void)
/* USER CODE BEGIN Error_Handler_Debug */
/* User can add his own implementation to report the HAL error return state *//* USER CODE END Error_Handler_Debug */
}#ifdef USE_FULL_ASSERT
* @brief Reports the name of the source file and the source line number
* where the assert_param error has occurred.
* @param file: pointer to the source file name
* @param line: assert_param error line source number
* @retval None
void assert_failed(uint8_t *file, uint32_t line)
/* USER CODE BEGIN 6 */
/* User can add his own implementation to report the file name and line number,
tex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
/* USER CODE END 6 */
#endif /* USE_FULL_ASSERT *//************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
위와같이 최대한 코딩을 하였으나.. FND로 출력값을 나타내주는 코딩을 잘못하겠어요... 어디에 어떤 코딩을 해야할지랑 빠진 것이 있나..모르겠습니다... 도와주세요....
조회수 2,199등록된 댓글이 없습니다.
