질문게시판 > 답변 : 답변 : 데이터 섹션이 보드에서 사용 가능한 공간을 초과합니다
TODAY1,142 TOTAL2,176,450
BASIC4MCU | 질문게시판 | 답변 : 답변 : 데이터 섹션이 보드에서 사용 가능한 공간을 초과합니다
작성자 master 작성일2021-06-24 17:02 조회1,763회 댓글0건
const char image2_circle[] PROGMEM = "ST<{\"cmd_code\":\"set_image\",\"type\":\"image\",\"widget\":\"image2\",\"image\":\"circle\"}>ET";
const char image3_circle[] PROGMEM = "ST<{\"cmd_code\":\"set_image\",\"type\":\"image\",\"widget\":\"image3\",\"image\":\"circle\"}>ET";
const char button1_false[] PROGMEM = "ST<{\"cmd_code\":\"set_enable\",\"type\":\"widget\",\"widget\":\"button1\",\"enable\":false}>ET";
const char button2_false[] PROGMEM = "ST<{\"cmd_code\":\"set_enable\",\"type\":\"widget\",\"widget\":\"button2\",\"enable\":false}>ET";
const char image2_x[] PROGMEM = "ST<{\"cmd_code\":\"set_image\",\"type\":\"image\",\"widget\":\"image2\",\"image\":\"x\"}>ET";
const char image3_x[] PROGMEM = "ST<{\"cmd_code\":\"set_image\",\"type\":\"image\",\"widget\":\"image3\",\"image\":\"x\"}>ET";
unsigned int r_flag1 = 0;
uint8_t   RecievedTemp1[30]       = {0};
uint8_t   cout_i = 0;
unsigned int quan_hang1 = 0;
unsigned int quan_hang2 = 0;
unsigned int quan_hang3 = 0;
unsigned int quan_lie1 = 0;
unsigned int quan_lie2 = 0;
unsigned int quan_lie3 = 0;
unsigned int quan_zuoxia = 0;
unsigned int quan_youxia = 0;
unsigned int cha_hang1 = 0;
unsigned int cha_hang2 = 0;
unsigned int cha_hang3 = 0;
unsigned int cha_lie1 = 0;
unsigned int cha_lie2 = 0;
unsigned int cha_lie3 = 0;
unsigned int cha_zuoxia = 0;
unsigned int cha_youxia = 0;
unsigned int cha[8]={0};
   Serial.begin(115200);
   for(int i=3; i<=8; i++)pinMode(i,OUTPUT);
  if(Serial.available() != 0){
//    for(cout_i = 0; cout_i < 30; cout_i ++){
//        //RecievedTemp1[cout_i] = Serial.readBytes(RecievedTemp1, 15);
//        Serial.readBytes(RecievedTemp1, 20);
//        //Serial.println(RecievedTemp1[cout_i]);
//    for(cout_i = 0; cout_i < 19; cout_i ++){ Serial.println(RecievedTemp1[cout_i]); }
    switch(RecievedTemp1[13]){
      case 49:
        if((r_flag1 == 0)&&(RecievedTemp1[14]==2)){
          Serial.println(image2_circle);
          r_flag1 = 1; quan_hang1++; quan_lie1++; quan_youxia++; // quan[0]++; quan[3]++; quan[7]++;
          Serial.println(button1_false);
        else if((r_flag1 == 1)&&(RecievedTemp1[14]==2)){
          Serial.println(image2_x);
          r_flag1 = 0; cha_hang1++; cha_lie1++; cha_youxia++; // cha[0]++; cha[3]++; cha[7]++;
      case 50:
          Serial.println(image3_circle);
          r_flag1 = 1; quan_hang1++; quan_lie2++; // quan[0]++; quan[4]++;
          Serial.println(button2_false);
          Serial.println(image3_x);
          r_flag1 = 0; cha_hang1++; cha_lie2++; // cha[0]++;  cha[4]++;
  case 51:
        Serial.println("ST<{\"cmd_code\":\"set_image\",\"type\":\"image\",\"widget\":\"image4\",\"image\":\"circle\"}>ET");
        r_flag1 = 1;
        quan_hang1++;
            quan_lie3++;
            quan_zuoxia++;
//        quan[0]++;
//        quan[5]++;
//        quan[6]++;
            Serial.println("ST<{\"cmd_code\":\"set_enable\",\"type\":\"widget\",\"widget\":\"button3\",\"enable\":false}>ET");
          Serial.println("ST<{\"cmd_code\":\"set_image\",\"type\":\"image\",\"widget\":\"image4\",\"image\":\"x\"}>ET");
         r_flag1 = 0;
         cha_hang1++;
           cha_lie3++;
            cha_zuoxia++;
//        cha[0]++;
//        cha[5]++;
//        cha[6]++;
  case 52:
        Serial.println("ST<{\"cmd_code\":\"set_image\",\"type\":\"image\",\"widget\":\"image5\",\"image\":\"circle\"}>ET");
        r_flag1 = 1;
        quan_hang2++;
            quan_lie1++;
            Serial.println("ST<{\"cmd_code\":\"set_enable\",\"type\":\"widget\",\"widget\":\"button4\",\"enable\":false}>ET");
          Serial.println("ST<{\"cmd_code\":\"set_image\",\"type\":\"image\",\"widget\":\"image5\",\"image\":\"x\"}>ET");
         r_flag1 = 0;
         cha_hang2++;
           cha_lie1++;
  case 53:
        Serial.println("ST<{\"cmd_code\":\"set_image\",\"type\":\"image\",\"widget\":\"image6\",\"image\":\"circle\"}>ET");
        r_flag1 = 1;
        quan_hang2++;
            quan_lie2++;
            quan_zuoxia++;
            quan_youxia++;
            Serial.println("ST<{\"cmd_code\":\"set_enable\",\"type\":\"widget\",\"widget\":\"button5\",\"enable\":false}>ET");
          Serial.println("ST<{\"cmd_code\":\"set_image\",\"type\":\"image\",\"widget\":\"image6\",\"image\":\"x\"}>ET");
          r_flag1 = 0;
          cha_hang2++;
            cha_lie2++;
            cha_zuoxia++;
            cha_youxia++;
  case 54:
        Serial.println("ST<{\"cmd_code\":\"set_image\",\"type\":\"image\",\"widget\":\"image7\",\"image\":\"circle\"}>ET");
        r_flag1 = 1;
        quan_hang2++;
            quan_lie3++;
//        quan[1]++;
            Serial.println("ST<{\"cmd_code\":\"set_enable\",\"type\":\"widget\",\"widget\":\"button6\",\"enable\":false}>ET");
          Serial.println("ST<{\"cmd_code\":\"set_image\",\"type\":\"image\",\"widget\":\"image7\",\"image\":\"x\"}>ET");
         r_flag1 = 0;
         cha_hang2++;
           cha_lie3++;
  case 55:
        Serial.println("ST<{\"cmd_code\":\"set_image\",\"type\":\"image\",\"widget\":\"image8\",\"image\":\"circle\"}>ET");
        r_flag1 = 1;
        quan_hang3++;
            quan_lie1++;
            quan_zuoxia++;
            Serial.println("ST<{\"cmd_code\":\"set_enable\",\"type\":\"widget\",\"widget\":\"button7\",\"enable\":false}>ET");
          Serial.println("ST<{\"cmd_code\":\"set_image\",\"type\":\"image\",\"widget\":\"image8\",\"image\":\"x\"}>ET");
         r_flag1 = 0;
         cha_hang3++;
           cha_lie1++;
            cha_zuoxia++;
  case 56:
        Serial.println("ST<{\"cmd_code\":\"set_image\",\"type\":\"image\",\"widget\":\"image9\",\"image\":\"circle\"}>ET");
        r_flag1 = 1;
        quan_hang3++;
            quan_lie2++;
            Serial.println("ST<{\"cmd_code\":\"set_enable\",\"type\":\"widget\",\"widget\":\"button8\",\"enable\":false}>ET");
          Serial.println("ST<{\"cmd_code\":\"set_image\",\"type\":\"image\",\"widget\":\"image9\",\"image\":\"x\"}>ET");
         r_flag1 = 0;
         cha_hang3++;
           cha_lie2++;
  case 57:
        Serial.println("ST<{\"cmd_code\":\"set_image\",\"type\":\"image\",\"widget\":\"image10\",\"image\":\"circle\"}>ET");
        r_flag1 = 1;
        quan_hang3++;
            quan_lie3++;
            quan_youxia++;
            Serial.println("ST<{\"cmd_code\":\"set_enable\",\"type\":\"widget\",\"widget\":\"button9\",\"enable\":false}>ET");
          Serial.println("ST<{\"cmd_code\":\"set_image\",\"type\":\"image\",\"widget\":\"image10\",\"image\":\"x\"}>ET");
         r_flag1 = 0;
         quan_hang3++;
           quan_lie3++;
            quan_youxia++;
  if((quan_hang1==3)||(cha_hang1==3))
            Serial.println("ST<{\"cmd_code\":\"set_visible\",\"type\":\"widget\",\"widget\":\"gif4\",\"visible\":true}>ET");
      else if((quan_hang2==3)||(cha_hang2==3))
            Serial.println("ST<{\"cmd_code\":\"set_visible\",\"type\":\"widget\",\"widget\":\"gif5\",\"visible\":true}>ET");
      else if((quan_hang3==3)||(cha_hang3==3))
            Serial.println("ST<{\"cmd_code\":\"set_visible\",\"type\":\"widget\",\"widget\":\"gif6\",\"visible\":true}>ET");
      else if((quan_lie1==3)||(cha_lie1==3))
            Serial.println("ST<{\"cmd_code\":\"set_visible\",\"type\":\"widget\",\"widget\":\"gif7\",\"visible\":true}>ET");
      else if((quan_lie2==3)||(cha_lie2==3))
            Serial.println("ST<{\"cmd_code\":\"set_visible\",\"type\":\"widget\",\"widget\":\"gif8\",\"visible\":true}>ET");
      else if((quan_lie3==3)||(cha_lie3==3))
            Serial.println("ST<{\"cmd_code\":\"set_visible\",\"type\":\"widget\",\"widget\":\"gif9\",\"visible\":true}>ET");
      else if((quan_zuoxia==3)||(cha_zuoxia==3))
            Serial.println("ST<{\"cmd_code\":\"set_visible\",\"type\":\"widget\",\"widget\":\"gif10\",\"visible\":true}>ET");
      else if((quan_youxia==3)||(cha_youxia==3))
            Serial.println("ST<{\"cmd_code\":\"set_visible\",\"type\":\"widget\",\"widget\":\"gif11\",\"visible\":true}>ET");
총 44라인 중 8개만 코드메모리로 선언을 변경했습니다.
전역 변수는 동적 메모리 2568바이트(125%)를 사용, -520바이트의 지역변수가 남음.  최대는 2048 바이트.
코드메모리로 변경한 만큼 데이터메모리 오버플로우 크기가 줄어들었습니다.
나머지도 모두 변경하시면 되겠습니다.
조회수 1,763
공지 사이트 이용 안내댓글[24] master 17-10-29 29871
질문 압력센서 질문있습니다.댓글[3] 새글 브레이크 14:17 18
질문 아두이노 서보모터 무한회전 문제 해결을 어떻게 해야할까요 새글 GinGer 22-05-27 23
답변 답변글 답변 : 아두이노 서보모터 무한회전 문제 해결을 어떻게 해야할까요댓글[5] 새글 master 22-05-27 37
질문 모터 엔코더 제어 질문드립니다. 새글 oreoreo 22-05-27 21
답변 답변글 답변 : 모터 엔코더 제어 질문드립니다. 새글 master 22-05-27 16
답변 답변글 답변 : 블루투스 관련 코드 도와주세요 새글 master 22-05-27 19
질문 마이크로칩 스튜디오 코드 해석 새글 최선을다하자 22-05-27 26
답변 답변글 답변 : 마이크로칩 스튜디오 코드 해석 새글 master 22-05-27 28
질문 적외선 거리 센서로 블루투스 알람 설정 코딩...댓글[1] 새글 ededed 22-05-26 28
질문 atmega128 키패드 입력 오류에 대하여 질문 있습니다.댓글[2] 마프하나 22-05-26 62
질문 초음파센싱을 통한 리니어벨트 (스텝모터사용) 조건문댓글[1] 아두이노대학 22-05-26 39
질문 아트메가128/ srf05 초음파센서를 이용한 타이머 인터럽트 질문입니다 아트메가넘어려워 22-05-26 37
답변 답변글 답변 : 아트메가128/ srf05 초음파센서를 이용한 타이머 인터럽트 질문입니다 master 22-05-26 44
질문 atmega128에서 스위치1개는LED, 스위치 1개는 세그먼트의 동작하게 하려는데.. aasdw 22-05-26 69
답변 답변글 답변 : atmega128에서 스위치1개는LED, 스위치 1개는 세그먼트의 동작하게 하려는데..댓글[1] master 22-05-26 62
질문 Atmega128 블루투스 오류 질문 yhj2644 22-05-26 66
답변 답변글 답변 : Atmega128 블루투스 오류 질문 master 22-05-26 45
질문 아두이노 간단한 프로그램 행복지수업 22-05-25 54
